Constantly going into 'overdrive'
  • bernie_lamb
    • Dec 2016
    • 83
    #76
    I’ve got a screenshot, but I can’t get it to copy into here!
    • Malnutrition
      PCHF Moderator
      • 7041
      #77
      Upload it here. Imgur.com
      Also, if you have issues with that Antivirus, then use one of the others…
      • bernie_lamb
        • Dec 2016
        • 83
        #78
        It says 'Downloading SecureAPlusSetup_v4.5.1.exe it’s now on 83%
        • Malnutrition
          PCHF Moderator
          • 7041
          #79
          They are having server issues, that is why it may be taking a long time.
          The internet for you is running fine other than that?
          • bernie_lamb
            • Dec 2016
            • 83
            #80
            I don’t really have issues if it’s going to do the job (eventually!)
            • bernie_lamb
              • Dec 2016
              • 83
              #81
              Yes, quite a lot faster than it was before
              • bernie_lamb
                • Dec 2016
                • 83
                #82
                I think I’m going to stick with it and then do a scan after it’s uploaded. It’s now on 92%
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  #83
                  It is a really good antivirus!!
                  I install it on all of my families machines.
                  If you are willing to wait then that is fine.
                  We will take care of everything else when you have completed the SecureAplus setup.
                  • bernie_lamb
                    • Dec 2016
                    • 83
                    #84
                    OK. Scan is running
                    • bernie_lamb
                      • Dec 2016
                      • 83
                      #85
                      Originally posted by bernie lamb
                      OK. Scan is running
                      Do you need to see the scan report?
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #86
                        Actually no, just remove anything found.
                        Can you call this matter solved?
                        • bernie_lamb
                          • Dec 2016
                          • 83
                          #87
                          Of course. I really can’t thank you enough for your help!:love:
                          • Malnutrition
                            PCHF Moderator
                            • 7041
                            #88
                            Glad to have helped!! Please tell a friend … or two about us. https://forum.windowsinstructed.com/...cons/smile.png
                            Optimize your internet connection.
                            Click here for instructions.
                            suggest the following in place of adblock.
                            Alternate DNS Server. Ad Blocking DNS.
                            Ublock Origin.
                            Anti Ad Block Killer.
                            Also, keep your browsing private with these tools:
                            Self Destructing Cookies.
                            Self Destructing Cookies Chrome.
                            Some items to keep you safe on the internet.
                            Qualys BrowserCheck To update plugins.
                            Web Of Trust To Avoid Shady Websites.
                            Unchecky To Avoid Bundled Software.
                            Privazer To Clean up your mahcine.
                            Now Lets Clean up the tools we used and remove old restore points.
                            Download DelFix by “Xplode” to your Desktop.
                            Right Click the tool and Run as Admin ( Xp Users Double Click)
                            Put a check mark next the items below:
                            Remove disinfection tools
                            Create registry backup
                            Purge System Restore
                            Now click on “Run” button.
                            allow the program to complete its work.
                            all the tools we used will be removed.
                            Tool will create and open a log report (DelFix.txt)
                            Note: The report can be located at the following location C:\DelFix.txt
                            • bernie_lamb
                              • Dec 2016
                              • 83
                              #89
                              Ublock Origin.
                              Wow! Thank you so much for this. I certainly will be passing word along!
