Alright, go ahead with the instructions in post #28.
Constantly going into 'overdrive'
This is the fastest defrag program out there.Originally posted by bernie lambDoes defrag take long?
You can finish when you like. No need to continue tonight.Originally posted by bernie lambOnly it’s moseying on towards 3am here and I’m wilting!Comment
I’m really grateful for your help with this. Just for info, over 9000 files to be 'unfragmented. At the present rate about another hour, I reckon. I really need to sleep! I’m OLD!:love:Comment
I will be here tomorrow…Have a good night.Originally posted by bernie lambI really need to sleep! I’m OLD!Comment
I’m just going to leave it running. Should I switch Avira and MalwareBytes back on ON?
I’ll be back tomorrow (or later today as it is now!)Comment
Once the defrag program is finished Analyzing, then click the defrag now button.
[ATTACH]1576[/ATTACH]
Sure, or wait until morning when you are done with the defrag. Either way is fine, just reboot after the defrag is complete.Originally posted by bernie lambShould I switch Avira and MalwareBytes back on ON?Comment
SupRestric report (it’s in French!):
Rapport de Contrôle restrictions Pierre13 (CTR version 2.4.0.0 ) du 16\02\2017 à 10:35:27
PC de User
Microsoft Windows XP Service Pack 3 (32 bits)
Contrôle présence restrictions
[TROJ_POWELIKS.B] clé feature_browser_emulation impossible à supprimer.
[TROJ_POWELIKS.B] clé smartdithering supprimée.
[BKDR_BLACKEN.A] clé Check_Associations supprimée.
Autorisation installation sponsor Java supprimée.
Restriction Affichage Documents supprimée.
Restriction synchronisation en arrière-plan des flux d’informations et des Web Slices supprimée.
Restriction découverte des flux RSS et des Web Slices supprimée.
Pavé numérique activé.
Restriction utilisateur pour Windows Installer supprimée.
Restriction détection installation supprimée.
Recherche Windows Update rétablie.
Service Pare feu Windows activé.
Paramètres Pare feu Windows rétablis par défaut et activés.
233 restrictions contrôlées.
11 restriction(s) réparée(s).
Re démarrer le PC pour prendre en compte la ou les réparations.
Le rapport est sur le bureau (C:\Documents and Settings\User\Desktop\CTR.txt)Comment
Translated for you…Originally posted by bernie lambSupRestric report (it’s in French!):
Report of Restrictions Control Pierre13 (CTR version 2.4.0.0) of 16 \ 02 \ 2017 at 10:35:27
User’s PC
Microsoft Windows XP Service Pack 3 (32-bit)
Control presence restrictions
[TROJ_POWELIKS.B] feature_browser_emulation key can not be deleted.
[TROJ_POWELIKS.B] smartdithering key deleted.
[BKDR_BLACKEN.A] key Check_Associations deleted.
Java sponsor installation permission removed.
Restriction Display Documents deleted.
Restriction Synchronization Background Information Streams and Web Slices Removed.
Restriction discovery of RSS feeds and Web Slices deleted.
Numeric keypad active.
User Restriction for Windows Installer Removed.
Restriction detection detection deleted.
Windows Update Search Reverted.
Windows Firewall service enabled.
Windows Firewall settings restored by default and enabled.
233 controlled restrictions.
11 restriction (s) repaired.
Reboot the PC to take the repair (s) into account.
The report is on the desktop (C: \ Documents and Settings \ User \ Desktop \ CTR.txt)Comment
Before I forget (in case it’s significant), when I rebooted after defrag, there was a little delay as a ‘Hidden Window’ was closed.
You speak French, too!!!:love:
Good morning!Comment
Thanks for letting me know, just move onto the Autologger scan. Then set Ccleaner to run at each system boot, this way you do not need to worry about cleaning your temp files. From the TFC.exe log it seems that there was 17 gigs of temp files removed from your machine, this is a large amount – more than normal.
Note: This tool will clean your browsing history as well.
[li]Download CCleaner from here.[/li][li]After install Click Options.[/li][li]Go to monitoring.[/li][li]Uncheck All Monitoring items.[/li][li]Go to advanced – Click close program after cleaning.[/li][li]Go to settings – click run ccleaner when the computer starts.[/li][li]Now that you have ccleaner installed and set-up:[/li][li]Open the program.[/li][li]Go to Tools[/li][li]Go to Startup[/li][li]Now double click each item. To Disable.[/li][li]Leave only your antivirus enabled.[/li][li]Then disable All items in your scheduled task as well.[/li][li]Unless they are related to windows defender.Or your antivirus.[/li][li]Reboot the machine.[/li][/ul]Comment
No, but google does. It is needed when dealing with these logs, people from all over the world post here.Originally posted by bernie lambYou speak French, too!!!:love:Comment
Just had a flash from Avira!
C:\Documents and Settings\User\SupRestric.exe containing pattern of ‘TR/Downloader.yagwm’ was blockedComment
This is a false positive, it is the file I had you use. The one with the french output. You can delete that file now, no problem.Originally posted by bernie lambC:\Documents and Settings\User\SupRestric.exe containing pattern of ‘TR/Downloader.yagwm’ was blockedComment
