Step 1: ClearLNK
Download ClearLNK save it to your desktop.
Drag the file Check_Browsers_LNK from your Collection log made earlier.
As per picture.
A report on the work as a file ClearLNK- .log
Will be produced, post that log.
https://pchelpforum.net/proxy.php?image=https%3A%2F%2Fup2sha.re%2Fuploads% 2F2015%2F3%2FBPD7B3BAgEQl.gif&hash=f65630ba2178027 f4643224f28999e44
Step 2: AVZ Fix
Disable your antivirus prior to this fix.
Copy the content of the code box below.
Open the folder you unzipped Autologger in. Double click the AVZ4 folder Right click AVZ run as admin. (Xp users Double Click)
Go to file – Custom Scripts.
Paste the content of your clipboard into the Custom Script Area.
Click the Run Button. https://pchelpforum.net/attachments/...7-23-png.1484/
The program will reboot your machine.
Step 3: FRST Scan logs.
Once downloaded right click the FRST desktop icon and select “Run as administrator” from the menu"
FRST will open with two dialogue boxes, accept the disclaimer.
[ol]
[li]Accept the default whitelist options,[/li][li]If the additions.txt options box is not checked please select it. [/li]
[li]Then select Scan[/li][/ol]
Please Copy and Paste the contents of these logs in your next post
As per picture.
Step 2: AVZ Fix
Code:
begin
RegKeyIntParamWrite('HKEY_LOCAL_MACHINE', 'SYSTEM\CurrentControlSet\Control\Terminal Server','fAllowToGetHelp', 0);
RegKeyIntParamWrite('HKEY_LOCAL_MACHINE', 'SYSTEM\CurrentControlSet\Control\LSA','RestrictAnonymous', 2);
SetServiceStart('RDSessMgr', 4);
SetServiceStart('mnmsrvc', 4);
SetServiceStart('TermService', 4);
SetServiceStart('RemoteRegistry', 4);
SetAVZGuardStatus(True);
DeleteService('ZAM');
StopService('ZAM');
DeleteFile('C:\WINDOWS\System32\drivers\zam32.sys','32');
DeleteFile('C:\Program Files\Bonjour\mDNSResponder.exe','32');
DeleteFile('C:\Program Files\TuneUp','32');
DeleteFile('2014\TuneUpUtilitiesService32.exe','32');
DeleteFile('C:\WINDOWS\system32\MsSip1.dll','32');
DeleteFile('C:\WINDOWS\system32\MsSip2.dll','32');
DeleteFile('C:\WINDOWS\system32\MsSip3.dll','32');
RegKeyParamDel('HKEY_LOCAL_MACHINE','SYSTEM\CurrentControlSet\Services\WinTrust\SubjectPackages\MS Subjects 1','$DLL');
RegKeyParamDel('HKEY_LOCAL_MACHINE','SYSTEM\CurrentControlSet\Services\WinTrust\SubjectPackages\MS Subjects 2','$DLL');
RegKeyParamDel('HKEY_LOCAL_MACHINE','SYSTEM\CurrentControlSet\Services\WinTrust\SubjectPackages\MS Subjects 3','$DLL');
DeleteFile('C:\WINDOWS\TEMP\0.del','32');
RegKeyParamDel('HKEY_USERS','.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce','Del2110015');
RegKeyParamDel('HKEY_USERS','S-1-5-18\Software\Microsoft\Windows\CurrentVersion\RunOnce','Del2110015');
ClearHostsFile;
ExecuteSysClean;
RebootWindows(true);
end.
[ol]
