DNS timeouts, game lag, ethernet issues...
  • Jakeeer
    • Jan 2023
    • 56
    #61
    Originally posted by PeterOz
    If overclocking ram in bios turn off.
    Reduce display Hz Down from 240Hz - for testing purposes.
    What version of Direct X do you have
    [ol]
    [li]To check which version of DirectX is on your PC using the DirectX Diagnostic Tool, select the Start button and type dxdiag in the search box, then press Enter.[/li][li]In the DirectX Diagnostic Tool, select the System tab, then check the DirectX version number under System Information.[/li][/ol]
    Direct X 12.
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #62
      @Malnutrition
      What about an older driver
      [HEADING=2]GeForce Game Ready Driver - WHQL[/HEADING]
      Driver Version: 526.86 - Release Date: 2022 November 10
      Download the latest official GeForce drivers to enhance your PC gaming experience and run apps faster.
      Make a restore point first
      • PeterOz
        • Mar 2021
        • 4181
        #63
        And this
        • Jakeeer
          • Jan 2023
          • 56
          #64
          PeterOz:
          Is DOCP considered an overclock? Regardless ive tried with both it on and off as well as turning off every power saving feature and vice versa as well as resetting bios to default settings.
          I’ve tried a previous driver in the past (Ive had this problem on and off for some months now) but Ill try everything listed here.
          • Jakeeer
            • Jan 2023
            • 56
            #65
            I’m starting to think there’s some type of interference causing thing due to how much different hardware I’ve tried (3 motherboards, a Ryzen 5600x, Intel i5 12600k, 2 gpus, 2psus, 2 sets of ram, 2 ssds, win 10, win 11)… I live right next to what’s essentially a juvenile detention center. Maybe there’s RF interference going on?
            I tried without DOCP and bios set to all defaults and it wasnt any better. After one game it got so bad that whenever someone jumped in front of me it felt like their player model was stuck at 30fps and skipping frames. Everything just feels broken. And there are so many times where the game feels perfect and it’s blatantly obvious how different it feels. On a β€œgood” day I wreck everyone and hit flick shots constantly with no aim assist on controller with 0 deadzones. But when this crap happens it all feels futile. People who I normally outshoot roughly 85% of the time suddenly outshoot me 85% of the time. It’s like the timing of the game feels off. Everything from the audio to the projectiles to the β€˜timing’ and pacing of interactions with other players. And I know it’s not just β€˜lag’ because on a good day I’ll see someone lagging but it’s manageable because it’s isolated to just that one player as opposed to the entirety of the game.
            Sorry for the rant, just getting irritated…
            I think the only thing I didnt try tonight was lowering my refresh rate. I’ll give that a try tomorrow, until then I’ll briefly list some other things I’ve tried, incase anyone happens to recommend something I’ve done:
            Playing in a clean boot
            Playing on wifi (same experience plus additional lag)
            Trying another monitor (165hz 1440p Asus as opposed to my Benq Zowie)
            Turning off AMA/Dyac+ on my monitor
            Disabling/enabling PBO
            I’ve tried Win 10 and 11
            Different USB cable for controller (it was the same brand though)
            Nvidia control panel: prefer maximum performance+ ultra low latency
            Windows high performance power plan
            Disabling USB device/LAN power saving features in device manager
            Using a different ethernet port on the G3100 router
            Disconnecting every other devices’ cables from the router
            And probably more Im forgetting.
            I do appreciate all the help and contribution to solving this problem everyone ???
            • Malnutrition
              PCHF Moderator
              • 7041
              #66
              Download and run Quick CPU to see if this helps.
              Quick CPU Tutorial…
              [MEDIA=youtube]s49r4Eq2WkQ[/MEDIA]
              • Jakeeer
                • Jan 2023
                • 56
                #67
                Quick CPU Tutorial…
                Alright I’ll check it out. I bought a larger case today so I can try out the pcie ethernet card I got a couple weeks back. I wont be around my pc until later tonight… When I get home Ill build it in the new case and try Quick CPU and maybe lower the monitor’s refresh rate too.
                • PeterOz
                  • Mar 2021
                  • 4181
                  #68
                  If you have ethernet cable I doubt that you would have this.
                  • Jakeeer
                    • Jan 2023
                    • 56
                    #69
                    Sorry for the late reply. I tried running Quick CPU per the instructions in the video as well as the new ethernet card and it didnt help at all unfortunately. Only thing I didnt try was lowering my refresh rate, I’ll try that tomorrow I guess. Not really sure what else to try.
                      #70
                      any luck with the refresh rate change?
                      have any of the issues been resolved?
                      • Jakeeer
                        • Jan 2023
                        • 56
                        #71
                        Unfortunately no, the issues with my game still happen nearly everytime Ive tried to play.
                        The DNS issue I think is fixed… It hasnt been resetting my DNS server and nslookup hasnt been timing out like it had been
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #72
                          what refresh rate did you use.
                          • Jakeeer
                            • Jan 2023
                            • 56
                            #73
                            60hz and 120hz
                            • Jakeeer
                              • Jan 2023
                              • 56
                              #74
                              Jakeeer:
                              I’m gonna end up testing the game on a relative’s gaming laptop to see if it does the same thing. Because I honestly dont have any clue if it’s a hardware problem, a network problem on my end, or some weird electrical issue at my place. I’ve been reading a little bit about dirty power and how some people say it can cause these problems. I ordered a multimeter to test some of the outlets and next week I’m gonna turn everything in my house off via the breaker accept for my pc and internet just to see if there’s any difference.
                              Might even see about bringing my set up to my relative’s house but that’s a bit of work.
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #75
                                Keep us posted please
