yes
DNS timeouts, game lag, ethernet issues...
Once you complete the best dns server and set a static ip, reboot your computer run minitoolbox again, post the log.Comment
Originally posted by Malnutrition
Malnutrition:
Alright I wont be around my pc for a couple more hours but Ill do that. Hopefully it makes a difference.Once you complete the best dns server and set a static ip, reboot your computer run minitoolbox again, post the log.
And sorry for the weird formatting. I originally tried to reply to your first comment before I saw the last one.Comment
For the last few days when I turn on my PC I get a firewall popup for either Microsoft Edge or Steam that says βsome features of this app have been blockedβ. I didnt think much of it but it just happened again for edge and then when I restarted my pc after the batch file it popped up but for Steam. I think it also happened with Brave browser once as wellβ¦ Iβve checked the program files (86) folders for these programs and the executables look normal and not like " edge.exe.exe" or something fishy like that.. Not sure if thatβs normal or notβ¦Originally posted by MalnutritionAll good, update when you can.
Stay tuned and Ill post that minitoolbox info for you.Comment
Ok, the static ip is set, and the DNS server is set to 1.1.1.1β 1..0.0.1
Those DNS servers are what the batch file set for you, is that what came up after running the tool listed in the guide here.
Better question is, how is the gameplay now?
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : A8-A1-59-08-1D-11
IPv4 Address. . . . . . . . . . . : 192.168.1.236(Preferred)
[COLOR=rgb(184, 49, 47)] DNS Servers . . . . . . . . . . . : 1.0.0.1
1.1.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled[/COLOR]Comment
Also, hosts file is not listed correctly in the MTB log.
Reset your Hosts file.
[ol]
[li]Click here to download RstHosts v2.0[/li][li]Save the file to your desktop.[/li][li]Right Click and Run as Administrator.[/li][li]Click on Restaurer, then click OK at the prompt.[/li][li]This will restore the default host file.[/li][/ol]Comment
Unfortunately still having problems. Ive only played for a bit but so far itβs mostly my game stuttering when I get shot at.Originally posted by MalnutritionAlso, hosts file is not listed correctly in the MTB log.
[ol]
Perhaps the graphics driver?Originally posted by Jakeeeritβs mostly my game stuttering when I get shot at.
Open Msconfig then load the base video driver, reboot and test the game.
[ATTACH type=βfullβ]11459[/ATTACH]Comment
Wow, game feels much better. Hit detection feels better and no microstuttering.Originally posted by MalnutritionPerhaps the graphics driver?
[ATTACH type=βfullβ alt=β1675400231526.pngβ]11459[/ATTACH]
I will say the game works intermittently so thereβs a good chance in a couple games or in a day or 2 itll stop working, but Iβll update if it does.Comment
If overclocking ram in bios turn off.
Reduce display Hz Down from 240Hz - for testing purposes.
What version of Direct X do you have
[ol]
[li]To check which version of DirectX is on your PC using the DirectX Diagnostic Tool, select the Start button and type dxdiag in the search box, then press Enter.[/li][li]In the DirectX Diagnostic Tool, select the System tab, then check the DirectX version number under System Information.[/li][/ol]Comment
