why did you not replace it with the same model card
Slow wifi speeds
TrueOriginally posted by RustysOnly other thing than I could surmise is the WiFi card is a dud and or cannot handle that there is only one wire.
It could well be that the original card can handle one wire but the new card needs two wires
Thatβs why it is normally best to replace somethings with like for like.
I would hve the cable going to 1 not auxComment
Yes, it does according to what I have found.Originally posted by LesCM19Or just use ethernet wire as I donβt exactly go down internet cafes or airport terminals with it.
@PeterOz tried 5GHz, router doesnβt do it
https://www.businessdirect.bt.com/pr...8343-90RY.html
Wireless Transmission speed * 2.4GHz wireless: up to 300Mbps * 5 GHz wireless: up to 1300Mbps * Up to 300 Mbps (40MHz) * Up to 1300 Mbps (80MHz)
What was fine from the new unit?Originally posted by LesCM19Well it was fine from new until recently on the one antenna.
NoOriginally posted by LesCM19Do all antennas have the same little brass connection?Comment
