Slow wifi speeds
  • LesCM19
    • Nov 2022
    • 11
    Slow wifi speeds
    My Acer Aspire 5349 W7/64 machine has been losing bars on the signal strength for a while now, occasionally disconnecting.
    In the same room as the router it’s 35M, pretty much what I always used to get, over ethernet 55M but in the next room over wifi it’s usually 1-2M but sometimes as high as 17M. My netbook and phone both agree that wifi in the next room should be 35m at least, so it’s a problem with the laptop?
    So I swapped out the Intel Centrino N100 adapter for an N6205 (as this is more readily available than the older N100) and it works but same problem with speed, 1-2 bars signal strength and usually 1m download speed.
    It’s not like I’ve recently started using the laptop in a walk in safe or anything, o why has my speed degraded but only on this laptop?
  • Malnutrition
    PCHF Moderator
    • 7041
    Welcome to PCHF
    These logs will help others assist you better.
    Get System Info Log.
    Include in your next reply a Get System Info log.
    Save it to your desktop when complete.
    Once you have the file on your desktop, then upload it here, and Here.
    Copy the URL after your report is loaded.
    Then send us the link.
    Please downloaded MINITOOLBOX unzip to your desktop and run it as admin.
    Checkmark following boxes:
    Flush DNS
    Reset FF proxy Settings
    Reset Ie Proxy Settings
    Report IE Proxy Settings
    Report FF Proxy Settings
    List content of Hosts
    List IP configuration
    List Winsock Entries
    List last 10 Event Viewer log
    List Installed Programs
    List Devices (problems only)
    Click Go and Attach the log in your reply.
      some things to also try…
      reboot the modem/router.
      take the laptop into the same room as the wifi router to prove it’s not a distance thing, or something interfering.
      • LesCM19
        • Nov 2022
        • 11
        Router has been rebooted, including when BT got involved. AS in OP, the connection is decent in the same room as the router but falls off to next to nothing with a wall in between. Didn’t do it before and other devices aren’t affected.
        • LesCM19
          • Nov 2022
          • 11
          MTB log attached, getting 2-3 bars and 15M download at the moment :unsure:
          Links: GSI, Catbox
            make/model of modem/router?
            • LesCM19
              • Nov 2022
              • 11
              m
              Bruce:
              BT Home hub 5.0B
              See attached for network details from Speccy
                have you logged into the menu of the BTHub5 and seen if you can change the power level of the wifi signal?
                those signal strength figures in the report are very low for something that is only one room apart.
                make sure the BTHub is as high as it can go and there is nothing around it, specifically metallic, electronic, or human as we are mostly water and absorb the wireless radiation very well !
                since it has internal aerials that you can’t control, try turning the whole unit slightly to different spots and see if the signal strength improves.
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  Uninstall the following with Geek Uninstaller. You can reinstall Microsoft Security Essentials after a reboot. Sometimes for no particular reason an antivirus will slow a machine and removing and reinstalling will often fix the issue.
                  Acer Registration (HKLM-x32...\Acer Registration) (Version: 1.04.3502 - Acer Incorporated)
                  Acer Updater (HKLM-x32...{EE171732-BEB4-4576-887D-CB62727F01CA}) (Version: 1.02.3500 - Acer Incorporated)
                  Intel Driver && Support Assistant (HKLM-x32...{578E6A4F-CA2B-42D1-BDA7-0890885BD753}) (Version: 22.7.44.6 - Intel) Hidden
                  Intel(R) Computing Improvement Program (HKLM...{EFE4A88A-FF8B-4D0E-8354-E0B7C3ED9E50}) (Version: 2.4.08840 - Intel Corporation)
                  Microsoft Security Essentials (HKLM...\Microsoft Security Client) (Version: 4.10.209.0 - Microsoft Corporation)
                  uTorrent
                  Disable from startup these, if you could. They are constantly running and use bndwidth, you can start these any time you want manually.
                  Dropbox
                  MEGAsync
                  DAEMON Tools Lite
                  Google\Drive File Stream
                  Adobe Flash Player is no longer supported and is a security risk.
                  [li]Download Adobe Flash Player Uninstaller and save it to your Desktop[/li][li]Right click on the icon and select Run as administrator[/li][li]Click Uninstall then Done to reboot your computer.[/li][/ul]
                  Uninstall this left over driver, if you can not find it, then use Everything Search Engine. You may need to boot into safe mode to remove it, as it is active.
                  C:\Windows\system32\DRIVERS\phantomtap.sys
                  Open your device manager and uninstall your wireless driver, then reboot your machine. Do not tick the box that reads delete the driver software for this device. Once you reboot the machine, windows will auto reinstall it and clear any setttings appended to it; starting you fresh.
                  Intel(R) Centrino(R) Advanced-N 6205 = Wireless Network Connection 4 (Connected)
                  Find the best DNS server for your machine.
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #10
                    @LesCM19 any update?
                    • LesCM19
                      • Nov 2022
                      • 11
                      #11
                      Will try these suggestions soon. I’m thinking broken antenna as this model only has one,especially as I swapped the adapter.
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #12
                        Ok. Thanks for the update. Let us know. ???
                          #13
                          Both adapters, N100 & N6205, should have 2 antennas attached.
                          What do you mean when you say ”broken antenna as this model only has one”?
                          as it only ever had one, or was it broken when you swapped the adapters?
                          and broken how - at the push on plug or the cable?
                          • LesCM19
                            • Nov 2022
                            • 11
                            #14
                            True, both old & replacement adapters have 2 sockets but there’s only 1 antenna and always has been, or that’s what was there when I took the back off. Plugged into socket 1 on the original. So I’m starting to think maybe it’s got a break at the hinge where it gets bent every time the lid opens.
                            But I’ll try to do the power increase thing on the modem once I log in. Password on the back of the router seems to have been changed.
                              #15
                              changing the default factory password on modems/routers should always be the very first thing anyone does when setting up those devices.
                              if you can’t remember its password, you are going to have to hit its reset button, but then you’ll lose your internet connection details if your provider requires any.
                              I can’t recall ever seeing a wifi adapter with only one cable - always thought one was for transmitting and the other for receiving.
                              maybe some others have some more insights - @PeterOz @Bastet @Pyro @Malnutrition
