Ethernet
  • Spiritfox
    • Nov 2019
    • 11
    Ethernet
    Hi, I’ve recently have gotten a Ethernet cord for my pc for low ping in games, but it doesn’t work on it, the port and everything is clean and both my laptops work with the ethernet but not my desktop. Is there anything i can do to fix this???
    right click the Start button and select Device Manager.
    expand Network Adapters, you should see your ethernet port listed, probably called Realtek PCIe or such.
    double click it and in Device Status it should say it is working properly.
    • Spiritfox
      • Nov 2019
      • 11
      Yes it says that but its not working
      • Rustys
        • 7862
        When you say that it is not working what specifically do you mean?
        What are the speeds that you are suppose to be getting?
        What are the speed test showing that you ate getting?
        Here are a few that you can try.
        SpeedOf.Me is a broadband speed test that allows you to easily measure your actual Internet speed on all your devices like desktop, mobile, tablet, game console, smart TV, etc.
        Use Speedtest on all your devices with our free desktop and mobile apps.
        How fast is your download speed? In seconds, FAST.com's simple Internet speed test will estimate your ISP speed.
        Have you tried resetting the network?
        turn them off then on?
        Modem
        Router
        computer
        Have you tried resetting the network settings on the computer and what about other devices?
        • Spiritfox
          • Nov 2019
          • 11
          Modem
          Router
          computer
          I mean like the it says it’s working properly but im not getting anything, I’m not connected at all, i tried the network reset and it didn’t work, i even followed instructions on a few yt videos using cmd but never worked
          • Rustys
            • 7862
            Modem
            Router
            computer
            You never clarified.
            What commands?
            • Spiritfox
              • Nov 2019
              • 11
              What commands?
              Like the command prompt (yes i ran it as administratior) I’ve tried a list of things like
              Netsh int ip reset c:\resetlog.txt
              Netsh winsock reset
              Ipconfig/flushdns
              And it still doesn’t seem to work
              • Rustys
                • 7862
                The reset of the questions in Post #6
                • Spiritfox
                  • Nov 2019
                  • 11
                  Post 6 didn’t work but I’ll try it again very shortly
                  • Rustys
                    • 7862
                    #10
                    Once the modem and router comes back on completely
                    Access the modem and router and see if ither one of them are blocking the
                    IP Address
                    MAC Address
                    Make sure that the security protocols are not blocking that system at all?
                    EDITED
                    Lets also get a speccy repoert may reveal more as to what maybe going on
                    Include the make and model of the Power Supply Unit if this is a Desktop.
                    • Spiritfox
                      • Nov 2019
                      • 11
                      #11
                      IP Address
                      MAC Address
                      EDITED
                      Ok ill try it out and let you know tomorrow, thank you so much for attempting to help me
                      • Rustys
                        • 7862
                        #12
                        You can also create a second windows account and see if the same issue happen there.
                        • hackerballs
                          • Jan 2021
                          • 46
                          #13
                          I know it sounds silly and no one could possibly forget…but I have seen it happen that Ops have not installed the internet driver off the MB disk. Drivers never loaded with windows so had to use disk. Also could go to support from MB Manufacturer
                          • Rustys
                            • 7862
                            #14
                            Is there an update?
                            • Rustys
                              • 7862
                              #15
                              Lack of response closed
