Computer help
This topic is closed.
  • mx_599
    • Nov 2024
    • 130
    #136
    USA
    you want me to be holding these keys a couple minutes during the white screen? I have before and it still did not do anything
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #137
      you keep holding until white screen disappears.
      You need to keep them pressed in.
      A different reset. There are about 4 types of resets for macs
      • mx_599
        • Nov 2024
        • 130
        #138
        I did not hold them always through white screen
        I can go back and repeat
        • PeterOz
          • Mar 2021
          • 4181
          #139
          Yes please
          • PeterOz
            • Mar 2021
            • 4181
            #140
            Option, Command, P, and R
            • mx_599
              • Nov 2024
              • 130
              #141
              did not work, which should I try next?
              • PeterOz
                • Mar 2021
                • 4181
                #142
                Just the option key
                • mx_599
                  • Nov 2024
                  • 130
                  #143
                  Can we do anything with this toolbar?
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #144
                    YES
                    • PeterOz
                      • Mar 2021
                      • 4181
                      #145
                      Click on utilities
                      Do you then see recovery
                      • mx_599
                        • Nov 2024
                        • 130
                        #146
                        Just this
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #147
                          Go here on how to use disk utility
                          Disk Utility can find and repair errors related to the formatting and directory structure of a Mac storage device. Errors can lead to unexpected behaviour when using your Mac, and significant errors might even prevent your Mac from starting up completely.
                          • mx_599
                            • Nov 2024
                            • 130
                            #148
                            Not sure what to do now
                            • PeterOz
                              • Mar 2021
                              • 4181
                              #149
                              With osx bas system highlighted can you click on first aid.
                              If not Click on Macintosh HD and click on first aid
                              • mx_599
                                • Nov 2024
                                • 130
                                #150
                                Not sure what I am doing. One failed and one worked
