Hi, Iβve recently have gotten a Ethernet cord for my pc for low ping in games, but it doesnβt work on it, the port and everything is clean and both my laptops work with the ethernet but not my desktop. Is there anything i can do to fix this???
Ethernet
Yes it says that but its not workingOriginally posted by Bruceright click the Start button and select Device Manager.
expand Network Adapters, you should see your ethernet port listed, probably called Realtek PCIe or such.
double click it and in Device Status it should say it is working properly.Comment
When you say that it is not working what specifically do you mean?
What are the speeds that you are suppose to be getting?
What are the speed test showing that you ate getting?
Here are a few that you can try.
SpeedOf.Me is a broadband speed test that allows you to easily measure your actual Internet speed on all your devices like desktop, mobile, tablet, game console, smart TV, etc.
How fast is your download speed? In seconds, FAST.com's simple Internet speed test will estimate your ISP speed.
Have you tried resetting the network?
turn them off then on?
Modem
Router
computer
Have you tried resetting the network settings on the computer and what about other devices?Comment
I mean like the it says itβs working properly but im not getting anything, Iβm not connected at all, i tried the network reset and it didnβt work, i even followed instructions on a few yt videos using cmd but never workedOriginally posted by RustysWhen you say that it is not working what specifically do you mean?
Modem
Router
computer
Like the command prompt (yes i ran it as administratior) Iβve tried a list of things likeOriginally posted by RustysYou never clarified.
What commands?
Netsh int ip reset c:\resetlog.txt
Netsh winsock reset
Ipconfig/flushdns
And it still doesnβt seem to workComment
Once the modem and router comes back on completely
Access the modem and router and see if ither one of them are blocking the
IP Address
MAC Address
Make sure that the security protocols are not blocking that system at all?
EDITED
Lets also get a speccy repoert may reveal more as to what maybe going on
Include the make and model of the Power Supply Unit if this is a Desktop.
Speccy publishes the profile and displays a second Publish Snapshot. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.Comment
Ok ill try it out and let you know tomorrow, thank you so much for attempting to help meOriginally posted by RustysOnce the modem and router comes back on completely
IP Address
MAC Address
EDITED
I know it sounds silly and no one could possibly forgetβ¦but I have seen it happen that Ops have not installed the internet driver off the MB disk. Drivers never loaded with windows so had to use disk. Also could go to support from MB ManufacturerComment
