Wifi problem
If you are still unable to connect. Then post a fresh minitoolbox log, so I can see where you stand.
Unisntall Avast and Utorrent.
Run this tool then see if you can connect. If not a new minitoolbox log please. :)
Zoek Scan
Note: Zoek Can take up to an hour to run, this is normal. Do not try and stop it even it if seems to be stalled. Let it run it's course!
---- Please run this tool from Safe Mode.----- If it has trouble starting in normal mode.
Disable your antivirus prior to this scan.
Download Zoek
Save the file to your desktop.
Right click Zoek.exe and run as administrator. (Xp Users double click)
Copy and paste the items in red below and paste them into Zoek.
createsrpoint;
emptyfolderscheck;delete
emptyclsid;
emptyalltemp;
ipconfig /flushdns;b
ResetHosts;
autoclean;
Now hit the run script button.
The log will appear after a reboot, also you can find it on the C: drive.
Post the log in your next reply.
Alright, we should certainly be able to get the machine online. These types of issues just take a while to solve sometimes. :)
Posting for easier research....
Ran by interista (administrator) on 24-01-2017 at 00:27:28
Running from "C:\Users\interista\Desktop"
Microsoft Windows 7 Professional Service Pack 1 (X64)
Model: X550VB Manufacturer: ASUSTeK COMPUTER INC.
Boot Mode: Normal
Windows IP Configuration
Could not flush the DNS Resolver Cache: Function failed during execution.
Proxy is not enabled.
No Proxy Server is set.
127.0.0.1 localhost
Mediatek MT7630E 802.11bgn Wi-Fi Adapter = Wireless Network Connection (Connected)
Realtek PCIe GBE Family Controller = Local Area Connection (Media disconnected)
Microsoft Virtual WiFi Miniport Adapter = Wireless Network Connection 3 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : interista-PC
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Mediatek MT7630E 802.11bgn Wi-Fi Adapter
Physical Address. . . . . . . . . : 48-5A-B6-27-A7-F7
IPv4 Address. . . . . . . . . . . : 192.168.1.101(Preferred)
Lease Obtained. . . . . . . . . . : 24. sijeźnja 2017. 0:15:51
Lease Expires . . . . . . . . . . : 27. sijeźnja 2017. 0:15:57
Wireless LAN adapter Wireless Network Connection 3:
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #2
Physical Address. . . . . . . . . : 48-5A-B6-27-A7-F6
Physical Address. . . . . . . . . : BC-EE-7B-1D-8A-BE
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.1
Ping request could not find host google.com. Please check the name and try again.
Server: UnKnown
Ping request could not find host yahoo.com. Please check the name and try again.
Interface List
16...48 5a b6 27 a7 f7 ......Mediatek MT7630E 802.11bgn Wi-Fi Adapter
17...48 5a b6 27 a7 f6 ......Microsoft Virtual WiFi Miniport Adapter #2
11...bc ee 7b 1d 8a be ......Realtek PCIe GBE Family Controller
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.101 25
192.168.1.0 255.255.255.0 On-link 192.168.1.101 281
192.168.1.101 255.255.255.255 On-link 192.168.1.101 281
192.168.1.255 255.255.255.255 On-link 192.168.1.101 281
224.0.0.0 240.0.0.0 On-link 192.168.1.101 281
255.255.255.255 255.255.255.255 On-link 192.168.1.101 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 306 ::1/128 On-link
1 306 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\Windows\SysWOW64\NLAapi.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [20992] (Microsoft Corporation)
Catalog5 07 C:\Windows\SysWOW64\wshbth.dll [36352] (Microsoft Corporation)
Catalog5 08 c:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [134528] (Microsoft Corporation)
Catalog5 09 c:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [134528] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 11 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\NLAapi.dll [70656] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [28672] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [47104] (Microsoft Corporation)
x64-Catalog5 08 c:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [168304] (Microsoft Corporation)
x64-Catalog5 09 c:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [168304] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
Application errors:
Error: (01/24/2017 12:17:18 AM) (Source: Winlogon) (User: )
Description: Windows license activation failed. Error 0x80070005.
Error: (01/24/2017 12:17:14 AM) (Source: WinMgmt) (User: )
Description: //./root/CIMV2SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 990x80041003
Error: (01/24/2017 12:13:50 AM) (Source: Winlogon) (User: )
Error: (01/24/2017 12:12:28 AM) (Source: WinMgmt) (User: )
Error: (01/23/2017 09:32:09 PM) (Source: Software Protection Platform Service) (User: )
Description: License Activation Scheduler (sppuinotify.dll) failed with the following error code:
0x80070005
Error: (01/23/2017 08:32:09 PM) (Source: Software Protection Platform Service) (User: )
0x80070005
Error: (01/23/2017 07:44:26 PM) (Source: WinMgmt) (User: )
Error: (01/23/2017 07:42:19 PM) (Source: Winlogon) (User: )
Error: (01/22/2017 01:32:25 AM) (Source: Software Protection Platform Service) (User: )
0x80070005
Error: (01/22/2017 12:22:52 AM) (Source: WinMgmt) (User: )
System errors:
Error: (01/24/2017 12:16:27 AM) (Source: Service Control Manager) (User: )
Description: The Intel Security True Key service failed to start due to the following error:
%%1053 = The service did not respond to the start or control request in a timely fashion.
Description: A timeout was reached (30000 milliseconds) while waiting for the Intel Security True Key service to connect.
Error: (01/24/2017 12:15:57 AM) (Source: Service Control Manager) (User: )
Description: The Torch Crash Handler service failed to start due to the following error:
%%2 = The system cannot find the file specified.
Error: (01/24/2017 12:15:53 AM) (Source: Service Control Manager) (User: )
Description: The Service Installer TrueKey service failed to start due to the following error:
Error: (01/24/2017 12:14:03 AM) (Source: DCOM) (User: )
Description: 1084EventSystem{1BE1F766-5536-11D1-B726-00C04FB926AF}
Error: (01/24/2017 12:13:56 AM) (Source: DCOM) (User: )
Description: 1084ShellHWDetection{DD522ACC-F821-461A-A407-50B198B896DC}
Error: (01/24/2017 12:13:30 AM) (Source: Service Control Manager) (User: )
Description: The following boot-start or system-start driver(s) failed to load:
aswRvrt
aswSnx
aswSP
aswVmm
discache
F06DEFF2-5B9C-490D-910F-35D3A91196222
spldr
Wanarpv6
Error: (01/24/2017 12:11:05 AM) (Source: Service Control Manager) (User: )
Error: (01/24/2017 12:11:02 AM) (Source: Service Control Manager) (User: )
Error: (01/24/2017 12:10:13 AM) (Source: Service Control Manager) (User: )
Description: The Server service failed to start due to the following error:
%%1115 = A system shutdown is in progress.
Microsoft Office Sessions:
Error: (01/24/2017 12:17:18 AM) (Source: Winlogon)(User: )
Description: 0x800700050x00000000
Error: (01/24/2017 12:17:14 AM) (Source: WinMgmt)(User: )
Error: (01/24/2017 12:13:50 AM) (Source: Winlogon)(User: )
Error: (01/24/2017 12:12:28 AM) (Source: WinMgmt)(User: )
Error: (01/23/2017 09:32:09 PM) (Source: Software Protection Platform Service)(User: )
Error: (01/23/2017 08:32:09 PM) (Source: Software Protection Platform Service)(User: )
Error: (01/23/2017 07:44:26 PM) (Source: WinMgmt)(User: )
Error: (01/23/2017 07:42:19 PM) (Source: Winlogon)(User: )
Error: (01/22/2017 01:32:25 AM) (Source: Software Protection Platform Service)(User: )
Error: (01/22/2017 12:22:52 AM) (Source: WinMgmt)(User: )
µTorrent (HKCU\...\uTorrent) (Version: 3.4.9.43085 - BitTorrent Inc.)
ACME gamepad (HKLM-x32\...\{FFF5AA19-FE65-43C5-B021-BEF78AF358CF}) (Version: 1.00.0000 - FDR)
Adobe Acrobat Reader DC - Croatian (HKLM-x32\...\{AC76BA86-7AD7-1050-7B44-AC0F074E4100}) (Version: 15.023.20053 - Adobe Systems Incorporated)
Adobe AIR (HKLM-x32\...\Adobe AIR) (Version: 24.0.0.180 - Adobe Systems Incorporated)
Adobe Flash Player 24 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 24.0.0.194 - Adobe Systems Incorporated)
Adobe Flash Player 24 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 24.0.0.194 - Adobe Systems Incorporated)
Akamai NetSession Interface (HKCU\...\Akamai) (Version: - Akamai Technologies, Inc)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 372.54 - NVIDIA Corporation) Hidden
Apple Software Update (HKLM-x32\...\{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}) (Version: 2.1.3.127 - Apple Inc.)
Atheros Bluetooth Suite (64) (HKLM\...\{230D1595-57DA-4933-8C4E-375797EBB7E1}) (Version: 7.4.0.170 - Atheros)
Avast Free Antivirus (HKLM-x32\...\Avast) (Version: 12.3.2280 - AVAST Software)
BS.Player FREE (HKLM-x32\...\BSPlayerf) (Version: 2.67.1076 - AB Team, d.o.o.)
CCleaner (HKLM\...\CCleaner) (Version: 5.26 - Piriform)
Clean Master (HKLM-x32\...\Clean Master) (Version: 1.0 - Cheetah Mobile)
DAEMON Tools Lite (HKLM\...\DAEMON Tools Lite) (Version: 5.0.1.0407 - Disc Soft Ltd)
FIFA 14 (HKLM-x32\...\{81D6AF80-A5A7-489C-BAA6-CB6220654368}) (Version: 6.0 - Black Box)
Foxit Reader (HKLM-x32\...\Foxit Reader_is1) (Version: 6.2.0.429 - Foxit Corporation)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 55.0.2883.87 - Google Inc.)
Google Toolbar for Internet Explorer (HKLM-x32\...\{18455581-E099-4BA8-BC6B-F34B2F06600C}) (Version: 1.0.0 - Google Inc.) Hidden
Google Toolbar for Internet Explorer (HKLM-x32\...\{2318C2B1-4965-11d4-9B18-009027A5CD4F}) (Version: 7.5.8231.2252 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.32.7 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
Intel Security True Key (HKLM\...\TrueKey) (Version: 4.11.110.1 - Intel Security)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 9.17.10.2963 - Intel Corporation)
Intel(R) SDK for OpenCL - CPU Only Runtime Package (HKLM-x32\...\{FCB3772C-B7D0-4933-B1A9-3707EBACC573}) (Version: 2.0.0.37149 - Intel Corporation)
Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32\...\{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 1.0.7.248 - Intel Corporation)
Java 8 Update 31 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F83218031F0}) (Version: 8.0.310 - Oracle Corporation)
Lightshot-5.4.0.1 (HKLM-x32\...\{30A5B3C9-2084-4063-A32A-628A98DE512B}_is1) (Version: 5.4.0.1 - Skillbrains)
Magic ISO Maker v5.4 (build 0239) (HKLM-x32\...\Magic ISO Maker v5.4 (build 0239)) (Version: - )
Mediatek Bluetooth (HKLM\...\{9ACFC67B-786F-CC9B-847A-D0350FF6F5E0}) (Version: 11.0.752.0 - Mediatek)
Microsoft .NET Framework 4.6.1 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Games for Windows - LIVE Redistributable (HKLM-x32\...\{F2508213-9989-4E85-A078-72BE483917EF}) (Version: 3.5.88.0 - Microsoft Corporation)
Microsoft Games for Windows Marketplace (HKLM-x32\...\{4CB0307C-565E-4441-86BE-0DF2E4FB828C}) (Version: 3.5.50.0 - Microsoft Corporation)
Microsoft Office Professional Plus 2010 (HKLM-x32\...\Office14.PROPLUS) (Version: 14.0.4734.1000 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50901.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.21022 (HKLM\...\{350AA351-21FA-3270-8B7A-835434E766AD}) (Version: 9.0.21022 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32\...\{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32\...\{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
NBA 2K14, âĺđńč˙ 1.0.0.0 (HKLM-x32\...\NBA 2K14_is1) (Version: 1.0.0.0 - )
NVIDIA GeForce Experience 3.1.0.52 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.1.0.52 - NVIDIA Corporation)
NVIDIA Graphics Driver 372.54 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 372.54 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.24.2 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.24.2 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.1.0.52 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 1.2.0.0 - NVIDIA Corporation) Hidden
Opera Stable 42.0.2393.94 (HKLM-x32\...\Opera 42.0.2393.94) (Version: 42.0.2393.94 - Opera Software)
PDF24 Creator 6.7.0 (HKLM-x32\...\{81A6F461-0DBA-4F12-B56F-0E977EC10576}_is1) (Version: - PDF24.org)
Pro Evolution Soccer 2012 (HKLM-x32\...\{E737A098-F161-4B6F-AF22-86AAE34F6FBD}) (Version: 1.00.0000 - KONAMI)
Qualcomm Atheros Client Installation Program (HKLM-x32\...\{28006915-2739-4EBE-B5E8-49B25D32EB33}) (Version: 10.0 - Qualcomm Atheros)
Ralink RT2860 Wireless LAN Card (HKLM-x32\...\{8FC4F1DD-F7FD-4766-804D-3C8FF1D309B0}) (Version: 1.2.0.41 - Ralink)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.61.612.2012 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.6937 - Realtek Semiconductor Corp.)
Realtek PCIE Card Reader (HKLM-x32\...\{C1594429-8296-4652-BF54-9DBE4932A44C}) (Version: 6.1.7601.27015 - Realtek Semiconductor Corp.)
Safari (HKLM-x32\...\{C779648B-410E-4BBA-B75B-5815BCEFE71D}) (Version: 5.34.57.2 - Apple Inc.)
SafeZone Stable 1.51.2220.62 (HKLM-x32\...\SafeZone 1.51.2220.62) (Version: 1.51.2220.62 - Avast Software) Hidden
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0330 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.1.0.52 - NVIDIA Corporation) Hidden
Softonic Assistant (HKCU\...\SoftonicAssistant) (Version: 0.1.6 - Softonic International S.A.)
SuperSportPoker (HKLM-x32\...\{9E8DBA3B-D9BD-7BFB-1633-3FFF4ED798A6}) (Version: 1.0.4 - SuperSport d.o.o.) Hidden
SuperSportPoker (HKLM-x32\...\SuperSportPoker) (Version: 1.0.4 - SuperSport d.o.o.)
Telegram Desktop version 1.0 (HKCU\...\{53F49750-6209-4FBF-9CA8-7A333C87D1ED}_is1) (Version: 1.0 - Telegram Messenger LLP)
Torch (HKCU\...\Torch) (Version: 33.0.0.7723 - Torch Media, Inc)
Twin USB Gamepad (HKLM-x32\...\{0AD1F05D-15F6-476D-A3BE-E3D5E3E0E023}) (Version: 1.00.0000 - yanglx)
Ubisoft Game Launcher (HKLM-x32\...\{888F1505-C2B3-4FDE-835D-36353EBD4754}) (Version: 1.0.0.0 - UBISOFT)
Unity Web Player (HKCU\...\UnityWebPlayer) (Version: 4.6.6f2 - Unity Technologies ApS)
USB Network Driver (HKLM-x32\...\{66ED8E01-C915-41F5-B33E-C5C31F27B885}) (Version: 2007.07.3 - )
USB Network Joystick (HKLM-x32\...\{2A558A06-A44E-400D-95AD-D9FAA89AFD36}) (Version: V3.70a - )
USB Vibration Joystick (HKLM-x32\...\{D909BD8E-AE9A-4AAF-8B2A-D3AA46E630D3}) (Version: 09.28.2009 - FFDriver)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.1.5 - VideoLAN)
Vulkan Run Time Libraries 1.0.11.1 (HKLM\...\VulkanRT1.0.11.1) (Version: 1.0.11.1 - LunarG, Inc.) Hidden
Vulkan Run Time Libraries 1.0.11.1 (HKLM\...\VulkanRT1.0.11.1-2) (Version: 1.0.11.1 - LunarG, Inc.)
Windows Live ID Sign-in Assistant (HKLM\...\{9B48B0AC-C813-4174-9042-476A887592C7}) (Version: 6.500.3165.0 - Microsoft Corporation)
WinRAR 5.40 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
WWinCasino 1.0 (HKCU\...\WWinCasino) (Version: 1.0 - )
WWINPoker (HKLM-x32\...\{722E4F14-3039-6C28-791D-738F50398F22}) (Version: 2.4.8 - WILLIAMS d.o.o.) Hidden
WWINPoker (HKLM-x32\...\WWINPoker) (Version: 2.4.8 - WILLIAMS d.o.o.)
XEOX Gamepad SL-6566-BK (HKLM-x32\...\{6EDE966F-6CB9-4651-A4B9-70FBA678B8E9}) (Version: 1.00.0000 - )
Name: Microsoft PS/2 Mouse
Description: Microsoft PS/2 Mouse
Class Guid: {4d36e96f-e325-11ce-bfc1-08002be10318}
Manufacturer: Microsoft
Service: i8042prt
Device ID: ACPI\ETD0108\4&27C0A696&0
Problem: : This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)
Resolution: The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal.
After you remove the device, this error disappears.Remove the device, and this error should be resolved.
Name: USB2.0 HD UVC WebCam
Description: USB Video Device
Class Guid: {6bdd1fc6-810f-11d0-bec7-08002be2092f}
Service: usbvideo
Device ID: USB\VID_0BDA&PID_5606&MI_00\7&1FF5EAE7&0&0000
Problem: : This device is disabled. (Code 22)
Resolution: In Device Manager, click "Action", and then click "Enable Device". This starts the Enable Device wizard. Follow the instructions.
Name: Mediatek Bluetooth 4.0 Adapter
Description: Mediatek Bluetooth 4.0 Adapter
Class Guid: {e0cbf06c-cd8b-4647-bb8a-263b43f0f974}
Manufacturer: Ralink Corporation
Service: BTHUSB
Device ID: USB\VID_0E8D&PID_3001&REV_0100\8&FD71962&0&01
Name: Teredo Tunneling Pseudo-Interface
Description: Microsoft Teredo Tunneling Adapter
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Service: tunnel
Device ID: ROOT\*TEREDO\0000
Problem: : This device cannot start. (Code10)
Resolution: Device failed to start. Click "Update Driver" to update the drivers for this device.
On the "General Properties" tab of the device, click "Troubleshoot" to start the troubleshooting wizard.
Percentage of memory in use: 36%
Total physical RAM: 2779.62 MB
Available physical RAM: 1755.34 MB
Total Virtual: 10969.8 MB
Available Virtual: 9912.83 MB
1 Drive c: () (Fixed) (Total:685.13 GB) (Free:174.99 GB) NTFS
2 Drive d: () (Fixed) (Total:13.5 GB) (Free:13.4 GB) NTFS
User accounts for \\INTERISTA-PC
Administrator Guest interista
**** End of log ****
I am sorry man for not getting back to you,actually my stupid adapter broke,i have to get a new one or fix this one,and i ll post again.
That is a bit drastic, your machine shows signs of malware, there is likely something malicious running which is causing you the issues...
I never got to see the Zoek adware cleaner and jrt logs... Your choice, but it is not a good idea to back up an infected machine either way...
