Solved Weird red circle
Sorry worked a long day yesterday didn’t have time to look. Please see the instructions for pc hunter as well. I’ll take a look today after work
Post 18
Download attached fixlist.txt file and save it to the Desktop.
NOTE. It's important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work.
NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system
Run FRST/FRST64 and press the Fix button just once and wait.
If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
If not the cause of this issue it needs immediate attention and before doing anything else;
Partition 1
Disk Letter: C:
File System: NTFS
Volume Serial Number: 0CBE5680
Used Space: 104 GB (93%)
Free Space: 7,16 GB (7%)
For Windows to be able to run efficiently and to be able to update you need to have between 20 and 25% of the partition or drive available as free storage space at all times, if you don`t you risk Windows becoming corrupt or not being able to update which puts you at risk of malware attack.
Uninstall as many unused programs, games, videos and music files as you can and get yourself another means of backing up to, post back when you have between 20 and 25% free storage on the C: drive/partition and we can go from there.
Can I ask that you do not quote every reply, it really does not help and just makes for unnecessary reading, thanks.
Ok so i deleted some stuff and there's now over 50 GB of space in storage and I reset my pc and the circle is still there?
