Solved System Thread Exception Not Handled BSOD
I'll check if I can upload the dump file when i get home.
The game is Wolfenstein 2, this is the only game it does this for and it's at the very beginning when I try and load it up.
Any updates from you guys? Nothing has been fixed, and I’ve gotten no feedback in a week.
Sorry @Huddled. I was sick and haven't been active that much.
If it's only doing it during a specific game, it might be a game bug or a bad installation.
If it's on Steam, did you verify the integrity of the files and make sure the game is fully up to date?
I'm not sure why it's not letting you zip the BSOD files. Do you remember what the BSOD said? The error message?
I’ve uninstalled and reinstalled the game twice now from steam and I get the same error every time
Stop code: SYSTEM_THREAD_EXCEPTION_NOT _HANDLED
What failed: atikmdag.sys
Run Driver Verifier -
- Windows 7 & Vista - START | type verifier
- Windows 8.1, 8, and 10 - Press WIN +X keys | select "Command Prompt (Admin)" | type verifier
Make these selections -
1.
Select 2nd option - Create custom settings (for code developers)
2. Select 2nd option - Select individual settings from a full list
3. Check these boxes -
▪ Special Pool
▪ Pool Tracking
▪ Force IRQL checking
▪ Deadlock Detection
▪ Security Checks (new as of Windows 7)
▪ Concurrency Stress Test (new as of Windows 8)
▪ DDI compliance checking (new as of Windows 8)
▪ Miscellaneous Checks
4. Select last option - Select driver names from a list
5. Click on the Provider heading - sorts list by Provider
6. Check ALL boxes where "Microsoft" IS NOT the Provider
7. Click on Finish
8. Re-boot
Well whatever that did worked and I can play the game now, I appreciate the help and I’ll get back to you guys if any other problems persist. Thank you :)
Reactions: veeg and jmarket
