Solved Stop printing unwanted copies
There were minor problems during the isntallation of Windows 10 (after the hard drive problems were solved), but if I have to reinstall every time there is a problem, it may take weeks to install Windows.
I hadn’t seen that suggestion about the two-waqy communication yet. I’ll probably try it this afternoon.
I reinstalled the printer as TCP/IP printer using already installed driver chosen by Windows. Test page printed fine. Printing from Foxit reader again resulted in an attempt to print extra copies.
On the tab ‘Poorten’ I disabled the setting ‘Ondersteuning in twee richtingen inschakelen’.
I again instructed the HP LaserJet 1022n to print from Foxit Reader and something extraordinary happened. It printed correctly without trying to print extra pages.
From LibreOffice Writer : the same.
So, it looks like the problem is solved. I wonder what the downside is of disabling two-way communiction.
Thank you for your help guys.
Monitor it for a little bit and see if anything out of the ordinary is happening. Don't forget to update us!
