Solved starter problems - language, finding items
Regarding the Dutch language, the factory settings were reverted but still shows Dutch for many apps, but I think that's because it recognises my location as NL
That is correct that it sometimes will happen.
Did you change the language in the browser?
Can you post a screen shot of the Language settings for Windows?
yes. It is happening less now but the odd window shows up in Dutch. Honeslty about the language it is becoming less noticable, and I am more likely going to have to reset it again anyway for a temp fix to sort the brightness problem. The screen is so dark I can barely see it and I need to get work done anyway.
Have you attempted to adjust the brightness on the monitor?
Otherwise you will need to create a new thread covering the screen brightness issue.
