Going by that you should not have to tick/set anythingThe windows all in one repair tool, install it and then boot to safe mode run it as admin, with all default items ticked.
Thanks. There are many tabs there such as backup tools,repair-main, advanced repairs and advanced tools. Can you tell me which to select should I create a restore point before doing the repair.Going by that you should not have to tick/set anything
Thanks for the help given. I am at lost when I wrote to you this windows repair was working fine, but after confirming from you it was late at night so I shut down my PC for the day. The following day I was about to try the 'windows repair' application, the program after it start to scan check the files and when completed there was an error and could not open the program. I have attach the file for you information and hope you can help.Yes create a restore point prior to running the tool. The actual repair recycle bin is repair number 33, run it with those two ticked at first in safe mode, if that fails then Just use it with all repairs selected Also in safe mode. personally I'd run it with all options ticked the first time, but this is your machine.
Thanks Malnutrition and PeterOz. First I am not using any account password to my personnal PC, if that what you mean if not please show me how to do it if you think required. Secondary regarding PeterOz suggestion I create a new user account and try it. Create some text files and then delete it the recycle bin remain empty and the 'empty recycle bin' menu grey out, you have to click 'open' then delete the files there. I still hope to hear from you all for further help.or create a new user for testing - can be deleted later
Just to confirm whether to delete the Account Profile Fixer or not after deleting will it roll back to the earlier account.How to delete user in windows 7
How to Delete User Accounts in Windows 7
How to delete user accounts in Windows 7 including what steps you should take before removing the user account.www.lifewire.com
After deleting 'Account Profile Fixer' folder or updating windows updates the recyle bin now return back no auto refreshing. I am not sure whether one of this cause it to change. Do I need the Account Profile Fixer folder which it created and is it normal for it to run every reboot.Delete any account you wish. So long as you are logged into your account where you are posting from.
