No SorryIs there sometimes you wanted me to see from there, otherwise I have to create an account.
I think I am not able to do it as what I have seen in the system restore it do not have many restore points to select the most furthest back is about a week back. Actually I do not know when this problem started. Thanks.Try a system restore back before this started
scroll down to Windows 7
How to Use System Restore in Windows
How to use System Restore in Windows 11, 10, 8/8.1, 7, Vista, or XP. System Restore will 'undo' changes to important areas of the operating system.www.lifewire.com
DISM is run the same way as SFC, enter the first cmd & click enter, once finished then enter the second command & click enter.Thanks Bastet for your concern yes I have scan with SFC/SCANNOW and the result 'Windows Resource Protection did not find any integrity violations.'. Regarding DISM /Online /Cleanup-Image /StartComponentCleanup and DISM /Online /Cleanup-Image /RestoreHealth I have no idea how to use it. What are the steps to be taken before using it if any. I am not sure of what it mean by 'Also double check to ensure the correct icon is set for empty bin, if the full bin is set for empty then it’ll show full all the time.' How do you check it.
Hi Bastet I run the two DISM /Online /Cleanup-Image /StartComponentCleanup and DISM /Online /Cleanup-Image /RestoreHealth there was something about error:87 a long list in the log about 53KB. I do not understand what it mean, do you want me to send the dism log. This two ultilities does it automatically repair the found errors. ThanksDISM is run the same way as SFC, enter the first cmd & click enter, once finished then enter the second command & click enter.
There should be an option for changing the desktop icons under Settings>personalisation>themes>desktop icon settings change the empty recycle bin to the correct icon, if it is already set then change it to something else, click ok, restart the pc& see if the problem remains, if not then try changing the icon back to the empty recycle bin icon. It used to be available via the right click option on the desktop on older Windows versions.
If @Malnutrition fix doesn’t work (& it should as I have used this fix) then I am at a loss.Hi Bastet I run the two DISM /Online /Cleanup-Image /StartComponentCleanup and DISM /Online /Cleanup-Image /RestoreHealth there was something about error:87 a long list in the log about 53KB. I do not understand what it mean, do you want me to send the dism log. This two ultilities does it automatically repair the found errors. Thanks
