Really unusual audio problem for hardcore troubleshooters only.
notimeforthat
7
36
Hello.
Gigabyte ga-b85-hd3.
built in - Realtek high definition Audio.
Windows 7.
Headset with microphone.
So I woke up this morning and I found out that my microphone isn't working. I started troubleshooting the issue.
-Played around with all the options from playback devices, recording devices - looks fine.
-Windows seems to properly discover that the microphone has been connected and i'm getting "you can now record audio from this device".
-Tried headset on another pc - works just fine.
-Tried connecting a headphones jack from the headset to microphone jack port - surprisingly, it works. I can speak through headphones but not through microphone.
-Tried connecting a headphones jack from the headset to microphone jack port and speakers to audio jack port - all works fine, i can speak to my headphones and hear sound on speakers.
-Tried reinstalling all the drivers by downloading the latest ones from gigabyte, also tried running on windows default drivers - no results.
-Tried connecting through front-panel jacks - same result.
-Tried clearing microphone jack with a knife - no results.
For clarification:
Whenever i connect microphone jack from headphones to microphone jack port - I'm getting 0 microphone reaction meaning in recording devices those little rectangles measuring the strength of sound do NOT move at all. Whenever i connect headphones jack from headphones to microphone jack port - It's all working fine.
It seems that the only thing that is not working is the microphone - only on this PC though.
Any ideas, please?
Hello Notimeforthat and welcome to PCHelpForum. We can assist you with the issue you are reporting.
First let us get some more information -
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Please attach the results in your next reply. This will help us help you :).
Flush DNS
Flush DNS
For safety purposes I've hidden some entries there with *** for example some IP addresses and my PC name but I don't think these are relevant here.
Ran by *** (administrator) on 30-11-2017 at 11:10:30
Running from "C:\Users\***\Desktop"
Microsoft Windows 7 Ultimate Service Pack 1 (X64)
Model: B85-HD3 Manufacturer: Gigabyte Technology Co., Ltd.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Realtek PCIe GBE Family Controller = Local Area Connection (Connected)
TAP-Windows Adapter V9 = Local Area Connection 2 (Hardware not present)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
add address name="Local Area Connection 2" address=169.254.123.128 mask=255.255.0.0
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : ***-PC
Node Type . . . . . . . . . . . . : Mixed
DNS Suffix Search List. . . . . . : chello.pl
Connection-specific DNS Suffix . : chello.pl
Physical Address. . . . . . . . . : 74-**-**-**-56-1D
Link-local IPv6 Address . . . . . : fe80::****:387b:ee01:a0a5%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.248
Lease Obtained. . . . . . . . . . : Thursday, November 30, 2017 10:52:16 AM
Lease Expires . . . . . . . . . . : Friday, December 01, 2017 10:52:15 AM
DHCPv6 IAID . . . . . . . . . . . : 276***957
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-32-F7-12-74-D4-35-6F-56-1D
DNS Servers . . . . . . . . . . . : 62.179.1.**
62.179.1.**
Tunnel adapter isatap.chello.pl:
Server: pl-waw4a-*****.chello.pl
Address: 62.179.1.**
Addresses: 2a00:1450:401b:802::200e
216.58.209.78
Pinging google.com [172.217.20.174] with 32 bytes of data:
Reply from 172.217.20.174: bytes=32 time=8ms TTL=55
Reply from 172.217.20.174: bytes=32 time=7ms TTL=55
Ping statistics for 172.217.20.174:
Minimum = 7ms, Maximum = 8ms, Average = 7ms
Server: pl-waw4a-****.chello.pl
Addresses: 2001:4998:c:e33::53
2001:4998:58:2201::73
2001:4998:44:204::100d
206.190.39.42
98.138.252.38
98.139.180.180
Pinging yahoo.com [206.190.39.42] with 32 bytes of data:
Reply from 206.190.39.42: bytes=32 time=203ms TTL=50
Ping statistics for 206.190.39.42:
Minimum = 203ms, Maximum = 203ms, Average = 203ms
Interface List
11...74 d4 ** ** 56 1d ......Realtek PCIe GBE Family Controller
13...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.3 10
192.168.0.0 255.255.255.248 On-link 192.168.0.3 266
192.168.0.3 255.255.255.255 On-link 192.168.0.3 266
192.168.0.7 255.255.255.255 On-link 192.168.0.3 266
224.0.0.0 240.0.0.0 On-link 192.168.0.3 266
255.255.255.255 255.255.255.255 On-link 192.168.0.3 266
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 306 ::1/128 On-link
11 266 fe80::/64 On-link
11 266 fe80::88a7:387b:ee01:a0a5/128
On-link
1 306 ff00::/8 On-link
11 266 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\Windows\SysWOW64\NLAapi.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [20992] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [232448] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\NLAapi.dll [70656] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [28672] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [326144] (Microsoft Corporation)
Application errors:
Error: (11/30/2017 10:52:21 AM) (Source: WinMgmt) (User: )
Description: //./root/CIMV2SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 990x80041003
Error: (11/29/2017 07:42:08 PM) (Source: WinMgmt) (User: )
Error: (11/29/2017 10:55:16 AM) (Source: WinMgmt) (User: )
Error: (11/28/2017 01:28:00 PM) (Source: SideBySide) (User: )
Description: Activation context generation failed for "assemblyIdentity1".Error in manifest or policy file "assemblyIdentity2" on line assemblyIdentity3.
The value "*" of attribute "language" in element "assemblyIdentity" is invalid.
Error: (11/28/2017 11:29:48 AM) (Source: WinMgmt) (User: )
Error: (11/28/2017 11:27:40 AM) (Source: WinMgmt) (User: )
Error: (11/28/2017 10:34:31 AM) (Source: WinMgmt) (User: )
Error: (11/28/2017 09:22:38 AM) (Source: WinMgmt) (User: )
Error: (11/28/2017 09:21:13 AM) (Source: WinMgmt) (User: )
Error: (11/28/2017 09:09:47 AM) (Source: WinMgmt) (User: )
System errors:
Error: (11/30/2017 10:52:35 AM) (Source: Service Control Manager) (User: )
Description: The Peer Networking Grouping service depends on the Peer Name Resolution Protocol service which failed to start because of the following error:
%%-2140993535
Description: The Peer Name Resolution Protocol service terminated with the following error:
%%-2140993535
%%-2140993535
%%-2140993535
Error: (11/30/2017 10:52:35 AM) (Source: PNRPSvc) (User: )
Description: 0x80630801
Error: (11/30/2017 10:52:24 AM) (Source: Service Control Manager) (User: )
%%-2140993535
%%-2140993535
Error: (11/30/2017 10:52:24 AM) (Source: PNRPSvc) (User: )
Error: (11/30/2017 10:52:21 AM) (Source: Service Control Manager) (User: )
Description: The Spybot-S&D 2 Security Center Service service failed to start due to the following error:
%%577 = Windows cannot verify the digital signature for this file. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Microsoft Office Sessions:
Error: (11/30/2017 10:52:21 AM) (Source: WinMgmt)(User: )
Error: (11/29/2017 07:42:08 PM) (Source: WinMgmt)(User: )
Error: (11/29/2017 10:55:16 AM) (Source: WinMgmt)(User: )
Error: (11/28/2017 01:28:00 PM) (Source: SideBySide)(User: )
Description: assemblyIdentitylanguage*c:\program files (x86)\spybot - search & destroy\DelZip179.dllc:\program files (x86)\spybot - search & destroy\DelZip179.dll8
Error: (11/28/2017 11:29:48 AM) (Source: WinMgmt)(User: )
Error: (11/28/2017 11:27:40 AM) (Source: WinMgmt)(User: )
Error: (11/28/2017 10:34:31 AM) (Source: WinMgmt)(User: )
Error: (11/28/2017 09:22:38 AM) (Source: WinMgmt)(User: )
Error: (11/28/2017 09:21:13 AM) (Source: WinMgmt)(User: )
Error: (11/28/2017 09:09:47 AM) (Source: WinMgmt)(User: )
CodeIntegrity Errors:
Date: 2017-11-30 10:52:21.210
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume2\Program Files (x86)\Spybot - Search & Destroy 2\SDWSCSvc.exe because the set of per-page image hashes could not be found on the system.
Date: 2017-11-30 10:52:17.018
Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\LMIRfsDriver.sys because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Date: 2017-11-30 10:52:16.988
Date: 2017-11-30 10:52:16.958
Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\LMIInfo.sys because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Date: 2017-11-30 10:52:16.938
Date: 2017-11-30 10:52:16.908
Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\lirsgt.sys because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Date: 2017-11-30 10:52:16.878
Date: 2017-11-30 10:52:16.258
Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\atksgt.sys because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Date: 2017-11-30 10:52:16.228
Date: 2017-11-29 19:42:08.299
.NET Core SDK 1.0.4 (x64) (HKLM\...\{11ACCE3C-C179-472C-A8CA-0F467702B2DA}) (Version: 4.1.5012 - Microsoft Corporation) Hidden
.NET Core SDK 1.0.4 (x64) (HKLM-x32\...\{c56e80af-58a4-490b-a1cd-5718290133b9}) (Version: 1.0.4 - Microsoft Corporation)
1602 A.D. (HKLM-x32\...\1602 A.D.) (Version: - )
7-Zip 9.20 (x64 edition) (HKLM\...\{23170F69-40C1-2702-0920-000001000000}) (Version: 9.20.00.0 - Igor Pavlov)
Active Directory Authentication Library for SQL Server (HKLM\...\{32C0D7B2-1046-43AC-98AD-B748E1910916}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
Adobe Acrobat Reader DC - Polish (HKLM-x32\...\{AC76BA86-7AD7-1045-7B44-AC0F074E4100}) (Version: 18.009.20044 - Adobe Systems Incorporated)
Adobe Flash Player 27 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 27.0.0.187 - Adobe Systems Incorporated)
Adobe Shockwave Player 12.1 (HKLM-x32\...\Adobe Shockwave Player) (Version: 12.1.3.153 - Adobe Systems, Inc.)
AIDA64 Extreme v4.50 (HKLM-x32\...\AIDA64 Extreme_is1) (Version: 4.50 - FinalWire Ltd.)
Apple Application Support (HKLM-x32\...\{D9DAD0FF-495A-472B-9F10-BAE430A26682}) (Version: 3.0.3 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{787136D2-F0F8-4625-AA3F-72D7795AC842}) (Version: 7.1.1.3 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}) (Version: 2.1.3.127 - Apple Inc.)
Audacity 2.1.2 (HKLM-x32\...\Audacity®_is1) (Version: 2.1.2 - Audacity Team)
Audio Speed Changer Pro 1.5 (HKLM-x32\...\Audio Speed Changer Pro) (Version: 1.5 - SuperUtils.com Software)
AVG (HKLM\...\{E61E6143-4937-43FC-8C12-06B8A987484D}) (Version: 1.211.3 - AVG Technologies) Hidden
AVG AntiVirus FREE (HKLM-x32\...\AVG Antivirus) (Version: 17.8.3036 - AVG Technologies)
AVG SafeGuard toolbar (HKLM-x32\...\AVG SafeGuard toolbar) (Version: 19.7.0.632 - AVG Technologies)
ClickOnce Bootstrapper Package for Microsoft .NET Framework (HKLM-x32\...\{E598B692-764A-413C-8530-59163D6B4AE3}) (Version: 4.6.01590 - Microsoft Corporation) Hidden
CPUID HWMonitor 1.29 (HKLM\...\CPUID HWMonitor_is1) (Version: - )
CyberGhost 6 (HKLM\...\CyberGhost 6_is1) (Version: - CyberGhost S.R.L.)
DAEMON Tools Lite (HKLM-x32\...\DAEMON Tools Lite) (Version: 4.49.1.0356 - Disc Soft Ltd)
DiagnosticsHub_CollectionService (HKLM\...\{90A561D7-0C29-464D-94E1-2A7E1C553230}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
DiskInternals Linux Reader (HKLM-x32\...\DiskInternals Linux Reader) (Version: 2.3.0.3 - DiskInternals Research)
Entity Framework 6.1.3 Tools for Visual Studio 15 (HKLM-x32\...\{F8C0447E-D45C-4E52-94E8-C6340AAC9DB8}) (Version: 6.1.60104.0 - Microsoft Corporation) Hidden
FMW 1 (HKLM\...\{36133E9F-B129-4206-9FB4-13F707787542}) (Version: 1.226.3 - AVG Technologies) Hidden
foobar2000 v1.3.2 (HKLM-x32\...\foobar2000) (Version: 1.3.2 - Peter Pawlowski)
Gameforge Live 2.0.12 (HKLM-x32\...\{9C98989A-3A15-42DA-A3B9-D20331437D67}}_is1) (Version: 2.0.12 - Gameforge)
Geeks3D FurMark 1.18.2.0 (HKLM-x32\...\{2397CAD4-2263-4CD0-96BE-E43A980B9C9A}_is1) (Version: - Geeks3D)
GG (HKCU\...\GG) (Version: 12 - GG Network S.A.)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 62.0.3202.94 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.7 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
Gothic III (HKLM-x32\...\{02B244A2-7F6A-42E8-A36F-8C385D7A1625}) (Version: 1.0.0 - JoWooD Productions Software AG)
HeavyLoad V3.4 (64 bit) (HKLM\...\HeavyLoad_is1) (Version: 3.4 - JAM Software)
icecap_collection_neutral (HKLM-x32\...\{64F3E6FC-68E3-4062-9C2C-ABD93FDFF309}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
icecap_collection_x64 (HKLM\...\{0AD162D1-4973-4315-97E9-5DE9A92B4049}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
icecap_collectionresources (HKLM-x32\...\{12C50688-5919-4A7A-8784-B26A7238FCEE}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
icecap_collectionresourcesx64 (HKLM-x32\...\{400E7885-8851-43F1-849C-5A720CB4F001}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
IIS 10.0 Express (HKLM\...\{0148E8AA-4A50-4673-B532-DB9F30F804BE}) (Version: 10.0.1737 - Microsoft Corporation)
IIS Express Application Compatibility Database for x64 (HKLM\...\{08274920-8908-45c2-9258-8ad67ff77b09}.sdb) (Version: - ) Hidden
IIS Express Application Compatibility Database for x86 (HKLM\...\{ad846bae-d44b-4722-abad-f7420e08bcd9}.sdb) (Version: - ) Hidden
Intel Processor Diagnostic Tool 64bit (HKLM\...\{D011AAF9-F756-43AB-8E91-47ADF0D86394}) (Version: 4.0.0.29 - Intel Corporation)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.15.1730 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 10.18.10.3355 - Intel Corporation)
Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32\...\{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 3.0.0.16 - Intel Corporation)
IntelliTraceProfilerProxy (HKLM-x32\...\{51783942-DFB0-4452-97CC-BDF2D4AB3A48}) (Version: 15.0.24.0 - Microsoft Corporation) Hidden
iTunes (HKLM\...\{5A68A656-979F-4168-8795-E2E368AA4DC2}) (Version: 11.2.2.3 - Apple Inc.)
Java 8 Update 31 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F83218031F0}) (Version: 8.0.310 - Oracle Corporation)
KaM Remake Full r6720 (HKLM-x32\...\{FDE049C8-E4B2-4EB5-A534-CF5C581F5D32}_is1) (Version: - )
Knights and Merchants - The Peasants Rebellion (HKLM-x32\...\Knights and Merchants - The Peasants Rebellion_is1) (Version: - GOG.com)
LAME v3.99.3 (for Windows) (HKLM-x32\...\LAME_is1) (Version: - )
League of Legends (HKLM-x32\...\{79BF4901-1EC4-4726-B3C2-A7859706C6E7}) (Version: 3.0.1 - Riot Games) Hidden
League of Legends (HKLM-x32\...\League of Legends 3.0.1) (Version: 3.0.1 - Riot Games)
Lineage II (HKLM-x32\...\{076A6FD8-EE45-4A83-B3C9-C7C34E7CAFDD}) (Version: 90.7.2281 - NCSoft)
Lineage II (HKLM-x32\...\{23664DA8-8872-4CF4-A2F2-327CC539823B}) (Version: 4.0.0.2 - NC Interactive, LLC)
Logitech SetPoint 6.65 (HKLM\...\sp6) (Version: 6.65.62 - Logitech)
Mafia III (HKLM-x32\...\Mafia III_R.G. Mechanics_is1) (Version: - R.G. Mechanics, markfiter)
Microsoft .NET Framework 4.6.1 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft ODBC Driver 11 for SQL Server (HKLM\...\{A106FA6F-E94C-44C9-8A0F-C34BD82C9FE6}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft Office Professional Plus 2010 (HKLM-x32\...\Office14.PROPLUS) (Version: 14.0.4734.1000 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.30514.0 - Microsoft Corporation)
Microsoft SQL Server 2008 Setup Support Files (HKLM\...\{6292D514-17A4-403F-98F9-E150F10C043D}) (Version: 10.3.5500.0 - Microsoft Corporation)
Microsoft SQL Server 2012 Native Client (HKLM\...\{1385D3DB-8E80-427B-91D2-B7535862B8E4}) (Version: 11.3.6518.0 - Microsoft Corporation)
Microsoft SQL Server 2014 (64-bit) (HKLM\...\Microsoft SQL Server SQLServer2014) (Version: - Microsoft Corporation)
Microsoft SQL Server 2014 Setup (English) (HKLM\...\{0EEBDCCA-EF5D-4896-9FEA-D7D410A57E8A}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2014 Transact-SQL ScriptDom (HKLM\...\{020CDFE0-C127-4047-B571-37C82396B662}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2016 LocalDB (HKLM\...\{E359515A-92E6-4FA3-A2C9-E1BA02D8DE6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2016 (HKLM\...\{96EB5054-C775-4BEF-B7B9-AA96A295EDCD}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2016 (HKLM-x32\...\{84C23ECA-FE4D-494F-9247-3EBAD57E7F0C}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32\...\{a2199617-3609-410f-a8e8-e8806c73545b}) (Version: 11.0.61030.0 - Корпорация Майкрософт)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 (HKLM-x32\...\{f0080ca2-80ae-4958-b6eb-e8fa916d744a}) (Version: 11.0.61030.0 - Корпорация Майкрософт)
Microsoft Visual C++ 2017 Redistributable (x64) - 14.10.25008 (HKLM-x32\...\{f1e7e313-06df-4c56-96a9-99fdfd149c51}) (Version: 14.10.25008.0 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x86) - 14.10.25008 (HKLM-x32\...\{c239cea1-d49e-4e16-8e87-8c055765f7ec}) (Version: 14.10.25008.0 - Microsoft Corporation)
Microsoft Visual Studio 2017 (HKLM-x32\...\{6F320B93-EE3C-4826-85E0-ADF79F8D4C61}) (Version: 1.10.30637.0 - Microsoft Corporation)
Microsoft VSS Writer for SQL Server 2014 (HKLM\...\{366CD715-2FF4-40B4-A8B4-A05E5D21A945}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft Web Deploy 3.6 (HKLM\...\{5CB4DD27-6252-4C08-BFCF-22F6A110CBFA}) (Version: 10.0.1972 - Microsoft Corporation)
Mozilla Firefox 56.0 (x86 en-US) (HKLM-x32\...\Mozilla Firefox 56.0 (x86 en-US)) (Version: 56.0 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 56.0.0.6478 - Mozilla)
MPC-HC 1.7.10 (64-bit) (HKLM\...\{2ACBF1FA-F5C3-4B19-A774-B22A31F231B9}_is1) (Version: 1.7.10 - MPC-HC Team)
My.com Game Center (HKCU\...\MyComGames) (Version: 3.215 - My.com B.V.)
NCSOFT Game Launcher (HKLM-x32\...\NCLauncher_NCWest) (Version: - NCSOFT)
Network Addon Mod (HKCU\...\Network Addon Mod) (Version: 34 - The NAM Team)
Notepad++ (HKLM-x32\...\Notepad++) (Version: 6.6.8 - Notepad++ Team)
NVIDIA GeForce Experience 3.1.2.31 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.1.2.31 - NVIDIA Corporation)
NVIDIA Graphics Driver 372.90 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 372.90 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.1.2.31 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 1.2.0.0 - NVIDIA Corporation) Hidden
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Quick Screen Recorder 1.5 (HKLM-x32\...\Quick Screen Recorder 1.5_is1) (Version: 1.5 - Etru Software Development)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7727 - Realtek Semiconductor Corp.)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0340 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.1.2.31 - NVIDIA Corporation) Hidden
Skype™ 7.33 (HKLM-x32\...\{3B7E914A-93D5-4A29-92BB-AF8C3F66C431}) (Version: 7.33.105 - Skype Technologies S.A.)
SpeedFan (remove only) (HKLM-x32\...\SpeedFan) (Version: - )
Spybot - Search & Destroy (HKLM-x32\...\{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1) (Version: 1.6.2 - Safer Networking Limited)
Spybot - Search & Destroy (HKLM-x32\...\{B4092C6D-E886-4CB2-BA68-FE5A99D31DE7}_is1) (Version: 2.4.40 - Safer-Networking Ltd.)
SQL Server 2014 Common Files (HKLM\...\{BD1CD96B-FE4B-4EAE-83D4-6EF55AB5779C}) (Version: 12.0.2000.8 - Microsoft Corporation) Hidden
SQL Server 2014 Common Files (HKLM\...\{F7012F84-80F5-4C25-852E-B1BA03276FE6}) (Version: 12.0.2000.8 - Microsoft Corporation) Hidden
SQL Server 2014 Database Engine Services (HKLM\...\{17531BCD-C627-46A2-9F1E-7CC920E0E94A}) (Version: 12.0.2000.8 - Microsoft Corporation) Hidden
SQL Server 2014 Database Engine Services (HKLM\...\{5082A9F3-AEE5-4639-9BA7-C19661BA7331}) (Version: 12.0.2000.8 - Microsoft Corporation) Hidden
SQL Server 2014 Database Engine Shared (HKLM\...\{ACC530B8-B6B4-40D6-B59B-152468CF47D0}) (Version: 12.0.2000.8 - Microsoft Corporation) Hidden
SQL Server 2014 Database Engine Shared (HKLM\...\{D1B847A9-B06B-4264-9EF0-78E6E1571E65}) (Version: 12.0.2000.8 - Microsoft Corporation) Hidden
SQL Server Browser for SQL Server 2014 (HKLM-x32\...\{3204DE95-97D2-4261-A286-98A262E171D4}) (Version: 12.0.2000.8 - Microsoft Corporation)
Sql Server Customer Experience Improvement Program (HKLM\...\{6476DB81-F263-4C04-8574-AAD31136C304}) (Version: 12.0.2000.8 - Microsoft Corporation) Hidden
SSDlife Pro (HKLM-x32\...\{6F104B6D-535A-4D27-9A11-8525368AEB1F}) (Version: 2.5.82 - BinarySense Inc.)
StarCraft II (HKLM-x32\...\StarCraft II) (Version: - Blizzard Entertainment)
Stranded Deep (HKLM\...\Steam App 313120) (Version: - Beam Team Games)
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
TAP-Windows 9.9.2 (HKLM\...\TAP-Windows) (Version: 9.9.2 - )
TeamSpeak 3 Client (HKCU\...\TeamSpeak 3 Client) (Version: 3.0.16 - TeamSpeak Systems GmbH)
TypeScript Power Tool (HKLM-x32\...\{F0B4CA92-9642-4BE6-8449-A786AD4FA628}) (Version: 2.2.3.0 - Microsoft Corporation) Hidden
Update for (KB2504637) (HKLM-x32\...\{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}.KB2504637) (Version: 1 - Microsoft Corporation)
vcpp_crt.redist.clickonce (HKLM-x32\...\{93FDC294-0726-48EA-989D-50E89C67ABF0}) (Version: 14.10.25008 - Microsoft Corporation) Hidden
Visual Studio 2012 x64 Redistributables (HKLM\...\{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
Visual Studio 2012 x86 Redistributables (HKLM-x32\...\{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
VS JIT Debugger (HKLM\...\{2901E697-0E9C-404B-B7D0-6E2D43F64CE5}) (Version: 16.0.59.0 - Microsoft Corporation) Hidden
VS Script Debugging Common (HKLM\...\{3B64C68E-14E0-4214-A53D-502E9FBD32E7}) (Version: 16.0.59.0 - Microsoft Corporation) Hidden
vs_BlendMsi (HKLM-x32\...\{1070C8E8-4DFB-419F-984A-5C835828897E}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsi (HKLM-x32\...\{B9F4AA09-F4AC-4108-ADA0-27CDD45FCEC3}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsires (HKLM-x32\...\{AEF5E0F2-31D1-454A-A992-C523C0007B4D}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
vs_clickoncesigntoolmsi (HKLM-x32\...\{DE8B48BF-82B9-434A-B254-1EA2306E5FBA}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
vs_communitymsi (HKLM-x32\...\{A041943F-C97B-48F6-8F23-C5078F99BB3A}) (Version: 15.0.26323 - Microsoft Corporation) Hidden
vs_communitymsires (HKLM-x32\...\{1210EE60-E253-407D-B537-D36898049CF0}) (Version: 15.0.26228 - Microsoft Corporation) Hidden
vs_devenvmsi (HKLM-x32\...\{581E5656-26E2-4A02-9711-48C8E4998310}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
vs_filehandler_amd64 (HKLM-x32\...\{15D591B0-7B40-4957-B6C0-EB7452B5AAB6}) (Version: 15.0.26228 - Microsoft Corporation) Hidden
vs_filehandler_x86 (HKLM-x32\...\{DC296244-0701-4EDE-9696-05B9C1D017B3}) (Version: 15.0.26228 - Microsoft Corporation) Hidden
vs_FileTracker_Singleton (HKLM-x32\...\{11230C85-1813-4BC3-9C24-E0B74B59653E}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
vs_minshellinteropmsi (HKLM-x32\...\{9477F337-FD16-4ACA-8217-E2D7A0F92603}) (Version: 15.0.26301 - Microsoft Corporation) Hidden
vs_minshellmsi (HKLM-x32\...\{497A5ACE-DA03-4412-A110-910B2C450720}) (Version: 15.0.26424 - Microsoft Corporation) Hidden
vs_minshellmsires (HKLM-x32\...\{A8B77523-13AB-46B9-B54F-5483E09668F9}) (Version: 15.0.26228 - Microsoft Corporation) Hidden
vs_SQLClickOnceBootstrappermsi (HKLM-x32\...\{D396CF10-5F2B-417D-9571-0B669B99440E}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
vs_tipsmsi (HKLM-x32\...\{A32A9CF6-E7AA-48B8-A3D3-50C157E69F53}) (Version: 15.0.26208 - Microsoft Corporation) Hidden
Vulkan Run Time Libraries 1.0.26.0 (HKLM\...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
Warface My.Com (HKCU\...\Warface My.Com) (Version: 1.48 - My.com B.V.)
WinCDEmu (HKLM-x32\...\WinCDEmu) (Version: 4.1 - Sysprogs)
WinDirStat 1.1.2 (HKCU\...\WinDirStat) (Version: - )
Wondershare MobileGo(Version 8.0.0) (HKLM-x32\...\{1E04C795-7359-4E05-8A0E-5644F777AA09}_is1) (Version: 8.0.0 - Wondershare)
Name: TAP-Windows Adapter V9
Description: TAP-Windows Adapter V9
Class Guid: {4d36e972-****-****-bfc1-08002be10318}
Manufacturer: TAP-Windows Provider V9
Service: tap0901
Device ID: ROOT\NET\0000
Problem: : This device is disabled. (Code 22)
Resolution: In Device Manager, click "Action", and then click "Enable Device". This starts the Enable Device wizard. Follow the instructions.
Name: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Description: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Class Guid: {4d36e96c-e325-11ce-bfc1-08002be10318}
Manufacturer: NVIDIA
Service: nvvad_WaveExtensible
Device ID: ROOT\UNNAMED_DEVICE\0000
Percentage of memory in use: 42%
Total physical RAM: 8138.31 MB
Available physical RAM: 4690.91 MB
Total Virtual: 8636.49 MB
Available Virtual: 4872.03 MB
1 Drive c: () (Fixed) (Total:111.69 GB) (Free:31.81 GB) NTFS
2 Drive d: (SYSTEM) (Fixed) (Total:1 GB) (Free:0.6 GB) NTFS
4 Drive f: (Windows) (Fixed) (Total:683.25 GB) (Free:37.65 GB) NTFS
5 Drive g: (HP_RECOVERY) (Fixed) (Total:12.38 GB) (Free:1.31 GB) NTFS
6 Drive h: (HP_TOOLS) (Fixed) (Total:1.99 GB) (Free:1.99 GB) FAT32
User accounts for \\***-PC
Administrator *** Guest
**** End of log ****
Since this has only recently began to occur, let us see if a possible Windows Update caused this issue.
Go ahead and look at your recently installed updates and post a screenshot please.
You can view your recently installed updates by doing the following -
Click start and then click Control Panel -> Programs -> Programs and Features -> Installed Updates.
That is impossible Sir, I'm preventing anybody to install anything on my PC. Automatic updates are turned off.
This is the noise I'm getting from microphone when testing audio on team speak3:
https://vocaroo.com/i/s0Tvi65p5V8x
That is not really a good thing.
If you are not allowing updates to be installed, you are putting yourself at a high security risk. This is due to not having the updates installed that patch things like security holes or even driver issues. I can understand not wanting them to automatically install, but not installing them at all is not safe. That is like going out in a rain storm without clothes or an umbrella and expecting not to get wet.
With that said, let us continue the process.
Lets go ahead and make sure all systems files are in working order.
You can do this by running a system file checker. See here for instructions on how to do so - https://support.microsoft.com/en-au...er-tool-to-repair-missing-or-corrupted-system
Please give the results in your next post.
The log file ends like this:
2017-11-30 21:16:10, Info CSI 00000304 [SR] Verify complete
2017-11-30 21:16:10, Info CSI 00000305 [SR] Verifying 37 (0x0000000000000025) components
2017-11-30 21:16:10, Info CSI 00000306 [SR] Beginning Verify and Repair transaction
2017-11-30 21:16:10, Info CSI 00000308 [SR] Verify complete
2017-11-30 21:16:10, Info CSI 00000309 [SR] Repairing 0 components
2017-11-30 21:16:10, Info CSI 0000030a [SR] Beginning Verify and Repair transaction
2017-11-30 21:16:10, Info CSI 0000030c [SR] Repair complete
I am gonna tag a few other members to get some more eyes on this issue.
@phillpower2 @Evan Omo
While waiting for another member to chime in here, let us make sure there is nothing on start up causing this issue.
We can do this by performing a clean boot.
See this article on how to perform a clean boot. - https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
When you have done this go ahead and check to see if the issue still continues. Please post the results in your next reply. Thank you.
I've performed a clean boot by unchecking "Load startup items" box and disabling all services that do not belong to Microsoft. Problem persists, absolutely no changes.
Thank you for the confirmation.
I've also double checked headset on laptop, it works perfectly fine. Next, as I do not have any extra microphone to hand, I connected headphones jack to microphone jack port to see whether I would be able to use headphones as microphone. Surprisingly it works amazingly well. That's not the way it should work though.
About the noise that I recorded, I do believe I've heard it already in the past (long time ago on a different pc) and I also do believe that back then, the solution was some kind of option/configuration stuff. Not sure what exactly though.
Reactions: TwitchisMental
Okay so I reminded myself that I do have another instance of windows on one of the drives. I ran this other instance of windows and well...the problem persists. I believe we're looking at some kind of hardware problem isn't it?
My next step will probably be checking on a different sound card.
Here's my question:
I noticed that my graphics has some kind of "virtual audio device". I believe it has something to do with connecting a screen through hdmi cable so the question is, will I be able to get some kind of hdmi -> jack thing and use this as a sound card only?
Any update for us notimeforthat? If unreplied to within 48hrs this thread will be closed.
