Solved Pc shuts down and fans go full blast
First blue screen:
Bugcheck code: 0x20001(0x26, 0x0, 0xFFFFF80172027F1B, 0xFFFFA981855C6E70)
Bugcheck name: HYPERVISOR_ERROR
Bug check description: The hypervisor has encountered a fatal error.
I have a suspicion this is from my Ram. Should I bring down the voltage a bit? This is the first time ever I get this type of blue screen.
Do note: I have 4 dimms, of the exact same brand but bought at different times so the 2 newer ones have different version number on them. These are stacked 1st-2nd slot for the old ones and 3rd-4th for the newer ones.
The RAM should be placed as matching pairs in the corresponding slots as in the two old in slots A2 and B2 and the new in in A1 and B1, if you have problems you then try switching the two in the primary A2 and B2 into the secondary A1 and B1 slots.
Any further BSOD please start a new thread on the appropriate BSOD forum where we can analyse the dmp files.
Ok that is done, dimms in correct positions. I'll give it some time now. It is encouraging a bit that up until now I haven't got any of the old BSOD's.
Being that the OP revisited the forum but left no reply this thread will be marked and closed.
