What about the CPU? I'm trying to remove the screws from the cooler but no luck so far.Only if the GPU temperature is high and the graphics card is turning off to protect itself.
Your VPN network Adaptor is called Famatech RadminSorry but I'm confused. I managed to remove Norton, but I didn't even know I have a VPN service, can you tell me it's name so I can look for it? Also what do you mean by disabling easy tune? I searched how to do that but all I found was how to uninstall it, not disable. And I didn't find anything for how to disable msi afterburner scheduled tasks. Do you mean not letting it run on startup?
Sorry for the confusion, but if possible could you please give a more detailed description of the things I need to do, or maybe just link some videos? Also about the turn off xmp mode in bios step, I'm gonna try it soon. Thanks.
Same there, only if you noticed the temps were high.What about the CPU? I'm trying to remove the screws from the cooler but no luck so far.
Ok then. It's probably not that anyway since the temperature isn't bad when I lose signal, I'm just trying to test everything. I'll do the things you said in one of your recent messages. Also I'm going to update the BIOS tomorrow.Same there, only if you noticed the tempos were high.
Had you been looking at the tempos at all?
Also, no offence meant, but if you are a novice at tinkering with PC's, the CPU wouldn't be the first job I'd be recommending you tackle.
It can go pear shaped quickly (and expensively) if mucked around with.
So, by all means have a craic, it's a good place to learn, but know your own limitations.
There is a plethora of videos on the web as well that you can watch.
Two ways to update your BIOS, yes, with a USB stick, or via the motherboards own software called @BIOS.Just to make sure, to update the bios I need to use a USB? If you have any tutorial recommendation or something like that it would be useful since I don't know how to update it. Thanks for the help so far.
I'd be surprised if the problem came back so fine to me. Do I have to mark it or you do it?Ok so mark as solved ?
