Low performance / Frame drops in Rocket League on Zephyrus G15
Hi @Bruce, I'm sorry. I said a few times already that I did follow all the instructions and asked some questions and advice that haven't been answered. If you can't help it's okay, in that case you can close the thread
Thank you all for your help!
There were a lot of steps laid out for you, the speccy links indicate that you did not follow instructions as we set for you.
Only step that you took from my instruction was to remove Avast.
Everything else was not done.
It is your machine, and you do with it what you please that much is for sure.
These are only troubleshooting steps and it makes it hard for us to help when you choose what you want to do only and then say you did everything with null result.
How about you create a restore point and actually follow the instructions, and if you do not like the result, then revert to that restore point.
I personally have delt with thousand of computers as have @Pyro and @Bruce
Maybe, just maybe if you consider following the steps laid out you will be happy with the result. Again it is your choice. :)
