Laptop boots up after a few tries
emilehmedlivevo
6
25
Hi, my laptop is HP Probook 4730s, I have a problem that occurred by itself for about a month. I put the laptop in sleep mode, after hours when I try to open, laptop isn't opening. Screen stays black and fan starts spin fast after 3 seconds later. And I hold power button, laptop turns off, again I trying boot up, same thing happening, after 4-5 tries, laptop boots up. What is the problem?
Have you tried what was suggested on the other forum and or looked into?
Might need a good cleaning and you may need to look at the power configurations.
Had this issue with a Dell once and had to replace the power switch.
There's nothing wrong with power switch. I've been searching for a long time but I couldn't find anything in other forums.
All HP systems have a Diagnostic tool that can be run (or can be ran if you wish...) on StartUp.
Just press ESC and then select Diagnostics.
See if you get anything.
Reactions: veeg
What is the issue that is going on you title states
What about the other things that were mentioned in Post #6
What about what @georgeks suggested
What about what you were suggested on other forums did you try Windows 10?
I formatted the laptop 2 times, just cleaned it, updated the bios and reset it, I don't think it has anything to do with the operating system, because bios doesn't even come up on screen.
You mentioned that you updated the BIOS and reset it -what do you mean by "reset" BTW?.
If something went wrong while updating the BIOS then it's no surprise the system does not even POST.
