Issues with Factory Reset
(I don't have a spare USB lying around atm to do it myself)
Thanks!
you can pick them up from almost any retail shop, from the electronics section.
you simply need an 8GB USB stick to load Windows onto via the creation tool.
but if you are upgrading that laptop to a SSD, then yes, might as well get the shop to do it all for you. (y)
Reactions: Zasko
It’s easy to do a clean install, just ensure you save your personal files to an external hard drive or even better image your drive using Macrium or your preferred disk imaging software.
Make sure you have your PC‘s driver installation disc (if provided) or visit the manufacturer’s website & download all the drivers which are required.
Gather your software installation discs & downloaded software.
Download the Windows 10 media creation tool & choose to create USB media.
Insert the USB drive & reboot the PC, as soon as you see the manufacturer’s logo click the key which corresponds to the temporary boot menu key - this is often F7, F8,F12 depending on the PC maker.
Follow instructions to delete the partition containing Windows & continue with the installation. Once complete you should be asked to set up the PC again, when you reach the part where you’re asked to enter a key you should skip this & the PC will activate once connected to the internet If you sign in with a Microsoft account.
I don't have a USB I can use at the moment.
From what I understand, my USB will be wiped during the process, which is why I'm going to have my PC repair guy do it for me.
I'm having them install an SSD and some RAM anyways.
