Hello,
I'm attempting to do a full factory reset on a Windows 10 laptop of mine (Lenovo Legion Y520).
I plan on using it exclusively for educational/production purposes and would like to start completely fresh.
After resetting, windows prompts me to login to my account from before the reset instead of starting from the windows initialization setup. Upon entering my password, it won't allow me to login and instead gives me a message, which says:
"The User Profile Service service failed the sign-in. User Profile cannot be loaded."
Probably worth mentioning that I've tried clicking restart while holding shift to enter the troubleshooting menu and factory resetting again from there, but the same problem occurs.
Does anyone know a potential fix?
Any help is appreciated.
Thanks,
Thanks,
