I have disabled win updates with the freeware you have provided.Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
Fixlog.
Code:
Fix result of Farbar Recovery Scan Tool (x64) Version: 16.07.2024
Ran by Max (19-07-2024 11:02:42) Run:3
Running from C:\Users\Ripple\Desktop
Loaded Profiles: Max
Boot Mode: Normal
fixlist content:
start::
CreateRestorePoint:
EmptyTemp:
CloseProcesses:
EmptyEventLogs:
S3 SbieDrv; \??\d:\Program Files\Sandboxie\SbieDrv.sys [X]
C:\Users\Ripple\AppData\Roaming\obs-virtualcam.txt
AlternateDataStreams: C:\ProgramData\autoclickconfig.ini:07021500A6 [5162]
AlternateDataStreams: C:\ProgramData\empty.ico:8C1C1B484F [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\desktop.ini:B1DA6C571C [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Access.lnk:A1B76439FE [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks 5.lnk:088221F38A [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks Multi-Instance Manager.lnk:FE00AE19CB [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\desktop.ini:41964AA945 [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Excel.lnk:B96E9B8455 [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox Private Browsing.lnk:C5112377E0 [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox.lnk:980850BA8A [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk:8096E45125 [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes.lnk:C5D586BE93 [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Edge.lnk:E77773B271 [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OneNote.lnk:60EC9648C0 [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Outlook.lnk:5465085A2F [5162]
AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PowerPoint.lnk:1DC1525F34 [5162]
Folder: C:\Windows\System32\Tasks
StartBatch:
WMIC SERVICE WHERE Name="dcomlaunch" set startmode="auto"
WMIC SERVICE WHERE Name="nsi" set startmode="auto"
WMIC SERVICE WHERE Name="dhcp" set startmode="auto"
WMIC SERVICE WHERE Name="rpcss" set startmode="auto"
WMIC SERVICE WHERE Name="rpceptmapper" set startmode="auto"
WMIC SERVICE WHERE Name="winmgmt" set startmode="auto"
WMIC SERVICE WHERE Name="sdrsvc" set startmode="manual"
WMIC SERVICE WHERE Name="vss" set startmode="manual"
WMIC SERVICE WHERE Name="eventlog" set startmode="auto"
WMIC SERVICE WHERE Name="bfe" set startmode="auto"
WMIC SERVICE WHERE Name="eventsystem" set startmode="auto"
WMIC SERVICE WHERE Name="msiserver" set startmode="manual"
WMIC SERVICE WHERE Name="sstpsvc" set startmode="manual"
WMIC SERVICE WHERE Name="rasman" set startmode="manual"
WMIC SERVICE WHERE Name="trustedinstaller" set startmode="auto"
net start sdrsvc
net start vss
net start rpcss
net start eventsystem
net start winmgmt
net start msiserver
net start bfe
net start trustedinstaller
"%WINDIR%\SYSTEM32\lodctr.exe" /R
"%WINDIR%\SysWOW64\lodctr.exe" /R
NETSH winsock reset catalog
NETSH int ipv4 reset reset.log
NETSH int ipv6 reset reset.log
ipconfig /release
ipconfig /renew
ipconfig /flushdns
ipconfig /registerdns
netsh winhttp reset proxy
bitsadmin /list /allusers
bitsadmin /reset /allusers
Winmgmt /salvagerepository
Winmgmt /resetrepository
Winmgmt /resyncperf
netsh advfirewall reset
netsh advfirewall set allprofiles state on
del /f /s /q %windir%\prefetch\*.*
sc stop sysmain
sc config sysmain start= disabled
sc stop DiagTrack
sc config DiagTrack start= disabled
sc stop dmwappushservice
sc config dmwappushservice start= disabled
sc stop WSearch
sc config WSearch start= disabled
sc stop lfsvc
sc config lfsvc start= disabled
Endbatch:
CMD: del /s /q "%userprofile%\AppData\Local\temp\*.*"
ExportKey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\TurnOffAnonymousBlock
ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce
ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run
ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run32
ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\StartupFolder
ExportKey: HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions
emptytemp:
Reboot:
End::
=========== EmptyEventLogs: ==========
1173 Event logs cleared.
HKLM\System\CurrentControlSet\Services\SbieDrv => removed successfully
SbieDrv => service removed successfully
C:\Users\Ripple\AppData\Roaming\obs-virtualcam.txt => moved successfully
C:\ProgramData\autoclickconfig.ini => ":07021500A6" ADS removed successfully
C:\ProgramData\empty.ico => ":8C1C1B484F" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\desktop.ini => ":B1DA6C571C" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Access.lnk => ":A1B76439FE" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks 5.lnk => ":088221F38A" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks Multi-Instance Manager.lnk => ":FE00AE19CB" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\desktop.ini => ":41964AA945" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Excel.lnk => ":B96E9B8455" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox Private Browsing.lnk => ":C5112377E0" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox.lnk => ":980850BA8A" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk => ":8096E45125" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes.lnk => ":C5D586BE93" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Edge.lnk => ":E77773B271" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OneNote.lnk => ":60EC9648C0" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Outlook.lnk => ":5465085A2F" ADS removed successfully
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PowerPoint.lnk => ":1DC1525F34" ADS removed successfully
========================= Folder: C:\Windows\System32\Tasks ========================
2024-07-12 11:51 - 2024-07-19 10:56 - 000003016 ____A [FDD89532680206F2087B6AA027D1AD51] () C:\Windows\System32\Tasks\BlueStacksHelper_nxt
2024-07-12 11:51 - 2024-07-12 11:51 - 000002590 ____A [350F8795900C9A972AA532E9BF5BA8F1] () C:\Windows\System32\Tasks\CreateExplorerShellUnelevatedTask
2024-07-12 11:51 - 2024-07-19 10:57 - 000003298 ____A [E20BAC84A3A554F637B9DEA74AFC7BDD] () C:\Windows\System32\Tasks\MicrosoftEdgeUpdateTaskMachineCore
2024-07-12 11:51 - 2024-07-19 10:57 - 000003522 ____A [03005B4CD693085373FE2B3CC22206E2] () C:\Windows\System32\Tasks\MicrosoftEdgeUpdateTaskMachineUA
2024-07-12 11:51 - 2024-07-19 10:57 - 000002220 ____A [E71112CEB89B93A87C0D288BCCFE0EFA] () C:\Windows\System32\Tasks\npcapwatchdog
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\GoogleSystem
2024-07-12 11:51 - 2024-07-19 10:32 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\GoogleSystem\GoogleUpdater
2024-07-19 00:58 - 2024-07-19 10:56 - 000003342 ____A [54D1A30F0D8EE26D828AF8130A77917A] () C:\Windows\System32\Tasks\GoogleSystem\GoogleUpdater\GoogleUpdaterTaskSystem128.0.6537.3{1EF25398-1393-46D7-9025-1FC7773C3FA4}
2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft
2024-07-12 11:51 - 2024-07-12 12:06 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Office
2024-07-12 11:51 - 2024-07-12 12:06 - 000005128 ____A [78FA3BE0DB89F79D4C1CB5E6984A43AA] () C:\Windows\System32\Tasks\Microsoft\Office\Office Automatic Updates 2.0
2024-07-12 11:51 - 2024-07-19 10:56 - 000003512 ____A [329938F0F00402FDCF288EF89A7C135D] () C:\Windows\System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor
2024-07-12 11:51 - 2024-07-12 12:06 - 000007256 ____A [6711BDD62C8C6CA1B147758423907878] () C:\Windows\System32\Tasks\Microsoft\Office\Office Feature Updates
2024-07-12 11:51 - 2024-07-12 12:06 - 000004332 ____A [AD6DC17A43C5A6AEAEFC6CA714B15B82] () C:\Windows\System32\Tasks\Microsoft\Office\Office Feature Updates Logon
2024-07-12 11:51 - 2024-07-19 10:56 - 000003038 ____A [42965EB2BC7528317952C570F9178AAB] () C:\Windows\System32\Tasks\Microsoft\Office\Office Performance Monitor
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\OneCore
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\OneCore\DirectX
2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\.NET Framework
2024-07-12 11:51 - 2024-07-13 16:20 - 000003706 ____A [770D3B37566D20D56592A3DF3DBBCFD5] () C:\Windows\System32\Tasks\Microsoft\Windows\.NET Framework\.NET Framework NGEN v4.0.30319
2024-07-12 11:51 - 2024-07-13 16:20 - 000003712 ____A [A2275832D00F717F0CCFC51C32C7FE28] () C:\Windows\System32\Tasks\Microsoft\Windows\.NET Framework\.NET Framework NGEN v4.0.30319 64
2024-07-12 11:51 - 2024-07-12 12:51 - 000002882 ____A [C32239A18C997402DB95FAF8A4F764D2] () C:\Windows\System32\Tasks\Microsoft\Windows\.NET Framework\.NET Framework NGEN v4.0.30319 64 Critical
2024-07-12 11:51 - 2024-07-12 12:51 - 000002876 ____A [B86EBF660E5832FE736763B4098BF591] () C:\Windows\System32\Tasks\Microsoft\Windows\.NET Framework\.NET Framework NGEN v4.0.30319 Critical
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client
2024-07-12 11:51 - 2024-07-12 11:51 - 000003978 ____A [4354BDCD3AEDEAB8BBE2281D6899D42D] () C:\Windows\System32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client\AD RMS Rights Policy Template Management (Automated)
2024-07-12 11:51 - 2024-07-12 11:51 - 000003426 ____A [D9E587010F978D667F0212B2144C44E1] () C:\Windows\System32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client\AD RMS Rights Policy Template Management (Manual)
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\AppID
2024-07-12 11:51 - 2024-07-12 11:51 - 000003436 ____A [0EF7D29DB858D8D00DC3F2F1DE323E6A] () C:\Windows\System32\Tasks\Microsoft\Windows\AppID\EDP Policy Manager
2024-07-12 11:51 - 2024-07-12 11:51 - 000002722 ____A [EEE41022E55AAEB619210E8366C2E048] () C:\Windows\System32\Tasks\Microsoft\Windows\AppID\PolicyConverter
2024-07-12 11:51 - 2024-07-12 11:51 - 000003346 ____A [AA4CCBF36BBBDBCC9BA1074FD310083D] () C:\Windows\System32\Tasks\Microsoft\Windows\AppID\VerifiedPublisherCertStoreCheck
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience
2024-07-12 11:51 - 2024-07-19 10:56 - 000003420 ____A [5E522D6EF23C53474BF8458A52B47719] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\MareBackup
2024-07-12 11:51 - 2024-07-12 11:51 - 000003344 ____A [3297209B6C9718B80C32CE0663C4505E] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser
2024-07-12 11:51 - 2024-07-12 12:10 - 000004368 ____A [9F0ACCD368DEBDA3AA6D8B29423CF3EE] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\PcaPatchDbTask
2024-07-12 11:51 - 2024-07-12 12:10 - 000004366 ____A [293A942896EA2C9DA850662689C2BDA5] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\PcaWallpaperAppDetect
2024-07-12 11:51 - 2024-07-12 11:51 - 000003430 ____A [320E240137DB59A95346BBF332557E80] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\SdbinstMergeDbTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000003090 ____A [0BDE2A4342F763D8A55251395C14AF63] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\StartupAppTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData
2024-07-12 11:51 - 2024-07-12 11:51 - 000003316 ____A [EBD4D1229A8BAFE4D9E0624280E20596] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\appuriverifierdaily
2024-07-12 11:51 - 2024-07-12 11:51 - 000003422 ____A [90FC38AE67C7E55DA1445FFCD73AAAEA] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\appuriverifierinstall
2024-07-12 11:51 - 2024-07-12 11:51 - 000003052 ____A [B97EEB6111E0CAFC5660C41463BB20B4] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\CleanupTemporaryState
2024-07-12 11:51 - 2024-07-12 11:51 - 000002716 ____A [BDCC5D5AEA37EEC6B1BEDC1EA832B098] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\DsSvcCleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\AppListBackup
2024-07-12 11:51 - 2024-07-12 11:51 - 000002796 ____A [59C40D50E5F6CA2A929033554F3EC102] () C:\Windows\System32\Tasks\Microsoft\Windows\AppListBackup\Backup
2024-07-12 11:51 - 2024-07-12 11:51 - 000003086 ____A [9DF05D3978AA95FD6661C7F171055114] () C:\Windows\System32\Tasks\Microsoft\Windows\AppListBackup\BackupNonMaintenance
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\AppxDeploymentClient
2024-07-12 11:51 - 2024-07-13 16:20 - 000003086 ____A [39622D5C2D4710EDA8BE8FD1D127EC79] () C:\Windows\System32\Tasks\Microsoft\Windows\AppxDeploymentClient\Pre-staged app cleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000002546 ____A [95BD3C2A2156CBA24141D2A7765CF72B] () C:\Windows\System32\Tasks\Microsoft\Windows\AppxDeploymentClient\UCPD velocity
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Autochk
2024-07-12 11:51 - 2024-07-12 11:51 - 000002870 ____A [072DCBFD73085D1358EBACE36C1EE1F9] () C:\Windows\System32\Tasks\Microsoft\Windows\Autochk\Proxy
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\BitLocker
2024-07-12 11:51 - 2024-07-12 11:51 - 000002496 ____A [6D44CDECB427D524A30AA40A5C3869F7] () C:\Windows\System32\Tasks\Microsoft\Windows\BitLocker\BitLocker Encrypt All Drives
2024-07-12 11:51 - 2024-07-12 11:51 - 000002344 ____A [AB84CA8B1D44095F680E4C04F7B5A96F] () C:\Windows\System32\Tasks\Microsoft\Windows\BitLocker\BitLocker MDM policy Refresh
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Bluetooth
2024-07-12 11:51 - 2024-07-12 11:51 - 000002328 ____A [A90757604458D5A881FA829AB95E8FE1] () C:\Windows\System32\Tasks\Microsoft\Windows\Bluetooth\UninstallDeviceTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\BrokerInfrastructure
2024-07-12 11:51 - 2024-07-12 11:51 - 000003088 ____A [E1F8756D91FD0DE5CB739AC623134242] () C:\Windows\System32\Tasks\Microsoft\Windows\BrokerInfrastructure\BgTaskRegistrationMaintenanceTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\capabilityaccessmanager
2024-07-12 11:51 - 2024-07-12 11:51 - 000003082 ____A [9EEA2079AC92ECB0EAFEAC68A79CDA00] () C:\Windows\System32\Tasks\Microsoft\Windows\capabilityaccessmanager\maintenancetasks
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient
2024-07-12 11:51 - 2024-07-12 11:51 - 000002936 ____A [24D6991FFA5884C59005B31E87CBEC5E] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\AikCertEnrollTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000002830 ____A [64CA400E3ED6B9B6070691BD8836EB9B] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\CryptoPolicyTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000005486 ____A [CF6B96BBA76C987B91CBE4D4291DEF1A] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\KeyPreGenTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000003694 ____A [B79F280F8B06288D6A92623C7360E01E] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\SystemTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000004816 ____A [AF919660DAC7699D4C89E0F7D8160781] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\UserTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000003554 ____A [DA89EF2A15ED103DC6F29B1E9E1A4E4F] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\UserTask-Roam
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Chkdsk
2024-07-12 11:51 - 2024-07-12 11:51 - 000002780 ____A [BD35E15531B75FEDAAC17A4F070AC2F1] () C:\Windows\System32\Tasks\Microsoft\Windows\Chkdsk\ProactiveScan
2024-07-12 11:51 - 2024-07-12 11:51 - 000002448 ____A [1B083E31B0725873A0AE644ABEB9F777] () C:\Windows\System32\Tasks\Microsoft\Windows\Chkdsk\SyspartRepair
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Clip
2024-07-12 11:51 - 2024-07-12 11:51 - 000003428 ____A [9678E6CF1E5E28843E456B0F5D0182C7] () C:\Windows\System32\Tasks\Microsoft\Windows\Clip\License Validation
2024-07-12 11:51 - 2024-07-12 11:51 - 000003688 ____A [FD80F9E471C41C65D8FE84FFB386CE92] () C:\Windows\System32\Tasks\Microsoft\Windows\Clip\LicenseImdsIntegration
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\CloudExperienceHost
2024-07-12 11:51 - 2024-07-12 11:51 - 000002240 ____A [888E9CEB54341183623016C2A2747CEF] () C:\Windows\System32\Tasks\Microsoft\Windows\CloudExperienceHost\CreateObjectTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\CloudRestore
2024-07-12 11:51 - 2024-07-12 11:51 - 000003358 ____A [C78EF9AC5A72B7BB979EFCF7A1AB84A7] () C:\Windows\System32\Tasks\Microsoft\Windows\CloudRestore\Backup
2024-07-12 11:51 - 2024-07-12 11:51 - 000002970 ____A [050212FCC2D02B05466BC1D5FA716598] () C:\Windows\System32\Tasks\Microsoft\Windows\CloudRestore\Restore
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ConsentUX
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ConsentUX\UnifiedConsent
2024-07-12 11:51 - 2024-07-12 11:51 - 000003252 ____A [32E9A5C09BABC1A0260137A41DFC422E] () C:\Windows\System32\Tasks\Microsoft\Windows\ConsentUX\UnifiedConsent\UnifiedConsentSyncTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Customer Experience Improvement Program
2024-07-12 11:51 - 2024-07-12 11:51 - 000003030 ____A [5D240C0C8A68AFA288D765EC717BECC8] () C:\Windows\System32\Tasks\Microsoft\Windows\Customer Experience Improvement Program\Consolidator
2024-07-12 11:51 - 2024-07-12 11:51 - 000003162 ____A [A6B83AE2E4B0CA541CE97AA8E6E3C8FB] () C:\Windows\System32\Tasks\Microsoft\Windows\Customer Experience Improvement Program\UsbCeip
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan
2024-07-12 11:51 - 2024-07-12 11:51 - 000003594 ____A [8A1D6C76B26AF75382D80096E6AA0346] () C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan\Data Integrity Check And Scan
2024-07-12 11:51 - 2024-07-12 11:51 - 000002862 ____A [A1B1EC66118786EBF58DADB125429C52] () C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan\Data Integrity Scan
2024-07-12 11:51 - 2024-07-12 11:51 - 000003354 ____A [6DDAD9C9B84F54A3FE6B533D8FEE3815] () C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan\Data Integrity Scan for Crash Recovery
2024-07-12 11:51 - 2024-07-12 12:02 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Defrag
2024-07-12 11:51 - 2024-07-12 12:02 - 000003472 ____A [FFD43E95164AD372649A627E587CE473] () C:\Windows\System32\Tasks\Microsoft\Windows\Defrag\ScheduledDefrag
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Device Information
2024-07-12 11:51 - 2024-07-12 11:51 - 000004326 ____A [F38FCAE149103B3E4628A11A9FD487D1] () C:\Windows\System32\Tasks\Microsoft\Windows\Device Information\Device
2024-07-12 11:51 - 2024-07-12 11:51 - 000002866 ____A [6A4748317A0246A14D7333C05A463661] () C:\Windows\System32\Tasks\Microsoft\Windows\Device Information\Device User
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Device Setup
2024-07-12 11:51 - 2024-07-12 11:51 - 000002984 ____A [7C69AFA443BB72C29624594C91745CBB] () C:\Windows\System32\Tasks\Microsoft\Windows\Device Setup\Metadata Refresh
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient
2024-07-12 11:51 - 2024-07-12 11:51 - 000002784 ____A [6BE0FF19B4D3A2CB575BAAFD4D293C58] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\HandleCommand
2024-07-12 11:51 - 2024-07-12 11:51 - 000002784 ____A [238CF788E1B152FDCBA470D99673F00B] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\HandleWnsCommand
2024-07-12 11:51 - 2024-07-12 11:51 - 000003440 ____A [FF684A54E3421C6060CF17E2598A1545] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\IntegrityCheck
2024-07-12 11:51 - 2024-07-12 11:51 - 000002810 ____A [11EC9F0F4711DE11619E3FE7A8C5D1F0] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\LocateCommandUserSession
2024-07-12 11:51 - 2024-07-12 11:51 - 000003404 ____A [EF174D6265FBFB667B6E793BCABA40E1] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceAccountChange
2024-07-12 11:51 - 2024-07-12 11:51 - 000003546 ____A [449904DDE28B518BDB71A1CE06633B22] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceLocationRightsChange
2024-07-12 11:51 - 2024-07-12 11:51 - 000003682 ____A [1AFCBE7783B0FCBD1BC6DD7021D66A48] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDevicePeriodic24
2024-07-12 11:51 - 2024-07-12 11:51 - 000003402 ____A [5BAF84542B623A4AADB5718E35A75E22] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDevicePolicyChange
2024-07-12 11:51 - 2024-07-12 11:51 - 000003154 ____A [7EC49C1A80A2A7D2AECCCA22C75CA05F] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceProtectionStateChanged
2024-07-12 11:51 - 2024-07-12 11:51 - 000003414 ____A [CA5C44EE39FFD765101D68AC694BE348] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceSettingChange
2024-07-12 11:51 - 2024-07-12 11:51 - 000003520 ____A [0E6145D43CCD097F0E256EAA9A1564C5] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterUserDevice
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Diagnosis
2024-07-12 11:51 - 2024-07-12 11:51 - 000003852 ____A [73A2725B3CCAE7953393FE61B89340F7] () C:\Windows\System32\Tasks\Microsoft\Windows\Diagnosis\RecommendedTroubleshootingScanner
2024-07-12 11:51 - 2024-07-12 11:51 - 000003092 ____A [7850154410AFA2EB17A602F025E6EC5E] () C:\Windows\System32\Tasks\Microsoft\Windows\Diagnosis\Scheduled
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DirectX
2024-07-12 11:51 - 2024-07-16 10:05 - 000003630 ____A [9A95ACC899B1EDAD3D08BC8EC92A8C59] () C:\Windows\System32\Tasks\Microsoft\Windows\DirectX\DirectXDatabaseUpdater
2024-07-12 11:51 - 2024-07-12 11:51 - 000002900 ____A [EE2D333C377AFF6C922639E7947A60CC] () C:\Windows\System32\Tasks\Microsoft\Windows\DirectX\DXGIAdapterCache
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DiskCleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000003200 ____A [3E282B45FB904C517BC11B132923443F] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskCleanup\SilentCleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DiskDiagnostic
2024-07-12 11:51 - 2024-07-12 11:51 - 000003034 ____A [A76EA9910F9DCDBF48784B6F05B728AB] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticDataCollector
2024-07-12 11:51 - 2024-07-12 11:51 - 000002766 ____A [580B7B4B4D02CBB334C86B2FD3E72D47] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticResolver
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DiskFootprint
2024-07-12 11:51 - 2024-07-12 11:51 - 000002398 ____A [6434B8D98519D8507799B75F77278A8E] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskFootprint\Diagnostics
2024-07-12 11:51 - 2024-07-12 11:51 - 000002366 ____A [502CD952702469DBD01DD879142E78C4] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskFootprint\StorageSense
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DUSM
2024-07-12 11:51 - 2024-07-12 11:51 - 000002384 ____A [3013C7C46E9F8FB3A3FD86D945E18A2B] () C:\Windows\System32\Tasks\Microsoft\Windows\DUSM\dusmtask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\EDP
2024-07-12 11:51 - 2024-07-12 11:51 - 000002302 ____A [7E0493D9879855F5FC2BCFACA888240E] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\EDP App Launch Task
2024-07-12 11:51 - 2024-07-12 11:51 - 000002284 ____A [837912F46B2DE20227F1DA00239270C1] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\EDP Auth Task
2024-07-12 11:51 - 2024-07-12 11:51 - 000002348 ____A [CF66586664BB7592FA145CA49FE70581] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\EDP Inaccessible Credentials Task
2024-07-12 11:51 - 2024-07-12 11:51 - 000002344 ____A [DBBB4F8594EE96D519644858AACA2184] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\StorageCardEncryption Task
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\EnterpriseMgmt
2024-07-12 11:51 - 2024-07-12 11:51 - 000002182 ____A [C11C1CBFA7B00CEEAFB8EF5FE319679A] () C:\Windows\System32\Tasks\Microsoft\Windows\EnterpriseMgmt\MDMMaintenenceTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ExploitGuard
2024-07-12 11:51 - 2024-07-12 11:51 - 000003172 ____A [840EEBFA16F463D5D0ED2977838DC228] () C:\Windows\System32\Tasks\Microsoft\Windows\ExploitGuard\ExploitGuard MDM policy Refresh
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Feedback
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Feedback\Siuf
2024-07-12 11:51 - 2024-07-12 11:51 - 000002880 ____A [E31D70482F0F894D02FD3BE61780C3B8] () C:\Windows\System32\Tasks\Microsoft\Windows\Feedback\Siuf\DmClient
2024-07-12 11:51 - 2024-07-12 11:51 - 000002998 ____A [E63288313283C274D13D8C8A11253568] () C:\Windows\System32\Tasks\Microsoft\Windows\Feedback\Siuf\DmClientOnScenarioDownload
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\File Classification Infrastructure
2024-07-12 11:51 - 2024-07-12 11:51 - 000003596 ____A [B165A04C8788CFFDA6E77F111C4E36C0] () C:\Windows\System32\Tasks\Microsoft\Windows\File Classification Infrastructure\Property Definition Sync
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\FileHistory
2024-07-12 11:51 - 2024-07-12 11:51 - 000002996 ____A [E8553B036871891D2902976B5D8DFB4A] () C:\Windows\System32\Tasks\Microsoft\Windows\FileHistory\File History (maintenance mode)
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Flighting
2024-07-12 11:51 - 2024-07-12 12:10 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig
2024-07-12 12:10 - 2024-07-13 12:15 - 000004352 ____A [1142E92D0F511DDB9D2ED8BF520A167C] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\BootstrapUsageDataReporting
2024-07-12 11:51 - 2024-07-12 12:10 - 000005892 ____A [893A23A4438EB17A85241AF25EE962E1] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\ReconcileFeatures
2024-07-12 11:51 - 2024-07-12 12:10 - 000004532 ____A [53504124F16A8BB58E7B06423CBFF684] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\UsageDataFlushing
2024-07-12 11:51 - 2024-07-12 12:10 - 000004288 ____A [060D5462F12AE442CF7E48DCD4F0C10A] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\UsageDataReporting
2024-07-12 11:51 - 2024-07-12 12:10 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\OneSettings
2024-07-12 11:51 - 2024-07-19 10:48 - 000004756 ____A [A88364DCAED847CD423239A12D58A075] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\OneSettings\RefreshCache
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Input
2024-07-12 11:51 - 2024-07-12 11:51 - 000002850 ____A [6B2C276E41A107CD4AA743B6F3A76AB4] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\InputSettingsRestoreDataAvailable
2024-07-12 11:51 - 2024-07-12 11:51 - 000002754 ____A [38F682826E79ED251ABD657147F939A0] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\LocalUserSyncDataAvailable
2024-07-12 11:51 - 2024-07-12 11:51 - 000002738 ____A [281D46016A4A1E8DCF1BD89613030037] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\MouseSyncDataAvailable
2024-07-12 11:51 - 2024-07-12 11:51 - 000002730 ____A [0C640C60B154EC97631A3CE62E449006] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\PenSyncDataAvailable
2024-07-12 11:51 - 2024-07-12 11:51 - 000002714 ____A [CACAC5A847741F80B4D8C1DBE67A5E96] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\syncpensettings
2024-07-12 11:51 - 2024-07-12 11:51 - 000002750 ____A [1097778E348B283A2739CB02710B3D76] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\TouchpadSyncDataAvailable
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\InstallService
2024-07-12 11:51 - 2024-07-12 11:51 - 000002612 ____A [07C0F5F0572596060737AAFB43E9C791] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\RestoreDevice
2024-07-12 11:51 - 2024-07-12 11:51 - 000003452 ____A [D9DB0431F925B621E4AC64847EF13879] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\ScanForUpdates
2024-07-12 11:51 - 2024-07-12 11:51 - 000002596 ____A [F263B544D83C8C2BFADD39E7295649A9] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\ScanForUpdatesAsUser
2024-07-12 11:51 - 2024-07-18 10:20 - 000005154 ____A [8A0506DD02041A5E544AE85E4F887E4E] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\SmartRetry
2024-07-12 11:51 - 2024-07-12 11:51 - 000002572 ____A [4BB817BD0B97E53D9C7D8D53CC488467] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\WakeUpAndContinueUpdates
2024-07-12 11:51 - 2024-07-12 11:51 - 000003028 ____A [52D4F47FF729418D1FB032A5AB0B85E4] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\WakeUpAndScanForUpdates
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\International
2024-07-12 11:51 - 2024-07-12 11:51 - 000003276 ____A [9291F9B9D3C9680975E47D30422AE9BB] () C:\Windows\System32\Tasks\Microsoft\Windows\International\Synchronize Language Settings
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Kernel
2024-07-12 11:51 - 2024-07-12 11:51 - 000002916 ____A [2878D4D00E81FAF4D5B8170555F1E6E8] () C:\Windows\System32\Tasks\Microsoft\Windows\Kernel\La57Cleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller
2024-07-12 11:51 - 2024-07-12 11:51 - 000003450 ____A [3959FC3E32785F26E488CC9AF61D2F0E] () C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller\Installation
2024-07-12 11:51 - 2024-07-12 11:51 - 000003242 ____A [AAEB417B86E1311F35082C762B8092D2] () C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller\ReconcileLanguageResources
2024-07-12 11:51 - 2024-07-16 10:19 - 000003232 ____A [2416C715152434A0F8A173FC7AFE2C7C] () C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller\Uninstallation
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\License Manager
2024-07-12 11:51 - 2024-07-12 11:51 - 000003340 ____A [9DC1C49D39C701F6355891C2E7B8AFAF] () C:\Windows\System32\Tasks\Microsoft\Windows\License Manager\TempSignedLicenseExchange
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Live
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Live\Roaming
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Location
2024-07-12 11:51 - 2024-07-12 11:51 - 000002638 ____A [8BE17095C256CF953E79F61B0673D198] () C:\Windows\System32\Tasks\Microsoft\Windows\Location\Notifications
2024-07-12 11:51 - 2024-07-12 11:51 - 000002572 ____A [C6255EBB1E0F758FEE929CC972836ED6] () C:\Windows\System32\Tasks\Microsoft\Windows\Location\WindowsActionDialog
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Maintenance
2024-07-12 11:51 - 2024-07-12 11:51 - 000003002 ____A [53A65939335DBCAA6F8BB6C5EE27214F] () C:\Windows\System32\Tasks\Microsoft\Windows\Maintenance\WinSAT
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Management
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Management\Autopilot
2024-07-12 11:51 - 2024-07-12 11:51 - 000003016 ____A [00B3720E4C2502AB4B63D449554454BF] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Autopilot\DetectHardwareChange
2024-07-12 11:51 - 2024-07-12 11:51 - 000002866 ____A [1ECE3F7368920E96D1F3AE6D1BAAFE38] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Autopilot\RemediateHardwareChange
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning
2024-07-12 11:51 - 2024-07-12 11:51 - 000002690 ____A [F13D37482360D587C450373A25D5F24F] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\Cellular
2024-07-12 11:51 - 2024-07-12 11:51 - 000002704 ____A [5E70A09926C6A4D555066D9E1DD4F687] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\Logon
2024-07-12 11:51 - 2024-07-12 11:51 - 000002602 ____A [C07737CD1D39B7BA06676EFA060F1ED8] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\MdmDiagnosticsCleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000002610 ____A [698DBE142A766FEA4FC67199DBFA4073] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\Retry
2024-07-12 11:51 - 2024-07-12 11:51 - 000002634 ____A [0649BFE3C5F75154409407BE5DA66D1B] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\RunOnReboot
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Maps
2024-07-12 11:51 - 2024-07-12 11:51 - 000003010 ____A [CBE62B6F890796A60DD13B650F63ADEA] () C:\Windows\System32\Tasks\Microsoft\Windows\Maps\MapsToastTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000003474 ____A [762819BB0E3F48F605CECA2F7D519830] () C:\Windows\System32\Tasks\Microsoft\Windows\Maps\MapsUpdateTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\MemoryDiagnostic
2024-07-12 11:51 - 2024-07-12 11:51 - 000005826 ____A [9F0D6291BCC9164234AE00909F8424E5] () C:\Windows\System32\Tasks\Microsoft\Windows\MemoryDiagnostic\ProcessMemoryDiagnosticEvents
2024-07-12 11:51 - 2024-07-12 11:51 - 000003506 ____A [700CD5CDE28679001B9E8A17B9A00CDE] () C:\Windows\System32\Tasks\Microsoft\Windows\MemoryDiagnostic\RunFullMemoryDiagnostic
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\MUI
2024-07-12 11:51 - 2024-07-12 11:51 - 000002726 ____A [0EAFF333690E2140CF92E358F647A07F] () C:\Windows\System32\Tasks\Microsoft\Windows\MUI\LPRemove
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Multimedia
2024-07-12 11:51 - 2024-07-12 11:51 - 000002574 ____A [728007430D778A49687344A5AFF65046] () C:\Windows\System32\Tasks\Microsoft\Windows\Multimedia\SystemSoundsService
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\NetTrace
2024-07-12 11:51 - 2024-07-12 11:51 - 000002444 ____A [82B51B2A4AF7173131DE09C6BA1D9D33] () C:\Windows\System32\Tasks\Microsoft\Windows\NetTrace\GatherNetworkInfo
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\NlaSvc
2024-07-12 11:51 - 2024-07-12 11:51 - 000002992 ____A [63C5DC8F8BD4C7AD339EDD8F05D87417] () C:\Windows\System32\Tasks\Microsoft\Windows\NlaSvc\WiFiTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Offline Files
2024-07-12 11:51 - 2024-07-12 11:51 - 000003170 ____A [FEEDE6809FF58339369FE0536AEDAE27] () C:\Windows\System32\Tasks\Microsoft\Windows\Offline Files\Background Synchronization
2024-07-12 11:51 - 2024-07-12 11:51 - 000002840 ____A [7360A82DD523D27126372EC7CFB7A8A3] () C:\Windows\System32\Tasks\Microsoft\Windows\Offline Files\Logon Synchronization
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PI
2024-07-12 11:51 - 2024-07-12 11:51 - 000003676 ____A [6121E96EAF2C0087D1793A481E5F4F87] () C:\Windows\System32\Tasks\Microsoft\Windows\PI\SecureBootEncodeUEFI
2024-07-12 11:51 - 2024-07-12 11:51 - 000003516 ____A [28F354CB33B3C006B0EA951585ECF2C2] () C:\Windows\System32\Tasks\Microsoft\Windows\PI\Secure-Boot-Update
2024-07-12 11:51 - 2024-07-12 11:51 - 000002880 ____A [C554CC00ACC83521585043B7494191D6] () C:\Windows\System32\Tasks\Microsoft\Windows\PI\Sqm-Tasks
2022-05-07 11:09 - 2022-05-07 11:09 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PLA
2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PLA\System
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play
2024-07-12 11:51 - 2024-07-12 11:51 - 000002972 ____A [7006D76C475F875686CC2B3A16F7E268] () C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play\Device Install Group Policy
2024-07-12 11:51 - 2024-07-12 11:51 - 000003028 ____A [D61490D56D6D66C8B9298A1220F43F49] () C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play\Device Install Reboot Required
2024-07-12 11:51 - 2024-07-12 11:51 - 000002338 ____A [EF7774860D9C4EE92A88CA23247087E2] () C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play\Sysprep Generalize Drivers
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Power Efficiency Diagnostics
2024-07-12 11:51 - 2024-07-12 11:51 - 000003128 ____A [180AAD66C4F7FA7B250B31B9DE349BF1] () C:\Windows\System32\Tasks\Microsoft\Windows\Power Efficiency Diagnostics\AnalyzeSystem
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Printing
2024-07-12 11:51 - 2024-07-12 11:51 - 000002590 ____A [B5CA0D4927CE89C08F3A71BE170ED4F5] () C:\Windows\System32\Tasks\Microsoft\Windows\Printing\EduPrintProv
2024-07-12 11:51 - 2024-07-12 11:51 - 000002840 ____A [984C26E454D816DDD581D058D43746C0] () C:\Windows\System32\Tasks\Microsoft\Windows\Printing\PrinterCleanupTask
2024-07-12 11:51 - 2024-07-12 12:00 - 000002900 ____A [E8F50C7157BF421A74B6D64A6F0DEA58] () C:\Windows\System32\Tasks\Microsoft\Windows\Printing\PrintJobCleanupTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PushToInstall
2024-07-12 11:51 - 2024-07-12 11:51 - 000003274 ____A [ACD87914D6481E5AB186D19716317A65] () C:\Windows\System32\Tasks\Microsoft\Windows\PushToInstall\LoginCheck
2024-07-12 11:51 - 2024-07-19 10:36 - 000004280 ____A [A7E8C14FC851794901E536CDF8081205] () C:\Windows\System32\Tasks\Microsoft\Windows\PushToInstall\Registration
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Ras
2024-07-12 11:51 - 2024-07-12 11:51 - 000003462 ____A [CD108933BF9D3A1C35833955F6309B15] () C:\Windows\System32\Tasks\Microsoft\Windows\Ras\MobilityManager
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RecoveryEnvironment
2024-07-12 11:51 - 2024-07-12 11:51 - 000003420 ____A [BF34A1CF5753F0832452E40502974461] () C:\Windows\System32\Tasks\Microsoft\Windows\RecoveryEnvironment\VerifyWinRE
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Registry
2024-07-12 11:51 - 2024-07-12 11:51 - 000003218 ____A [05777A5442924D1153176D5AC129E733] () C:\Windows\System32\Tasks\Microsoft\Windows\Registry\RegIdleBackup
2022-05-07 11:09 - 2022-05-07 11:09 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RemoteApp and Desktop Connections Update
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RemoteAssistance
2024-07-12 11:51 - 2024-07-12 11:51 - 000003796 ____A [2A9FA9855B9BA3E94FC4DAA7CC3F2837] () C:\Windows\System32\Tasks\Microsoft\Windows\RemoteAssistance\RemoteAssistanceTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RetailDemo
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Security
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Security\Pwdless
2024-07-12 11:51 - 2024-07-12 11:51 - 000003412 ____A [00000000000000000000000000000000] () C:\Windows\System32\Tasks\Microsoft\Windows\Security\Pwdless\IntelligentPwdlessTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Servicing
2024-07-12 11:51 - 2024-07-12 11:51 - 000002502 ____A [8699B124702DE82A8AFA348B36FE7338] () C:\Windows\System32\Tasks\Microsoft\Windows\Servicing\StartComponentCleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SettingSync
2024-07-12 11:51 - 2024-07-15 09:43 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Setup
2024-07-12 11:51 - 2024-07-12 11:51 - 000002838 ____A [8CAF365DE578AA10C0703CBF8106CAC9] () C:\Windows\System32\Tasks\Microsoft\Windows\Setup\SetupCleanupTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SharedPC
2024-07-12 11:51 - 2024-07-12 11:51 - 000002766 ____A [691CA16FBAA65A6D4983D0949F678F8B] () C:\Windows\System32\Tasks\Microsoft\Windows\SharedPC\Account Cleanup
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Shell
2024-07-12 11:51 - 2024-07-12 11:51 - 000002636 ____A [E478D400176B927DF62A1EC131E0CE77] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\CreateObjectTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000002622 ____A [DDCFF84B918E9D6465CB7B28FB0A7612] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\FamilySafetyMonitor
2024-07-12 11:51 - 2024-07-12 11:51 - 000003200 ____A [C4ECBFD478D78881435DA7E15FE76105] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\FamilySafetyRefreshTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000002858 ____A [98BC4202BE211FC77B0D36B4900DEDA6] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\IndexerAutomaticMaintenance
2024-07-12 11:51 - 2024-07-12 11:51 - 000002482 ____A [2CACFCD99A7F0BA4A7BD3FAFFAE8AE11] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\ThemeAssetTask_SyncFODState
2024-07-12 11:51 - 2024-07-12 11:51 - 000003104 ____A [132925FD74EAD847954F40D6F94A6C6D] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\ThemesSyncedImageDownload
2024-07-12 11:51 - 2024-07-12 11:51 - 000002330 ____A [C6C43C44DEE21EB257D9439E733138DF] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\UpdateUserPictureTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform
2024-07-12 11:51 - 2024-07-19 11:02 - 000004676 ____A [B6223A1AADF05B1884A905835FA2B32E] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcRestartTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000003312 ____A [8CBC84881481158749FD559D1D305C46] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcRestartTaskLogon
2024-07-12 11:51 - 2024-07-12 12:11 - 000003984 ____A [302A119B87944C644B8463363D118378] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcRestartTaskNetwork
2024-07-12 11:51 - 2024-07-12 11:51 - 000003322 ____A [3FED7DA36547FB494449DFD6072DE650] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcTrigger
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SpacePort
2024-07-12 11:51 - 2024-07-12 11:51 - 000003006 ____A [C68AC5388FB517EE7473E7CE3057D4AC] () C:\Windows\System32\Tasks\Microsoft\Windows\SpacePort\SpaceAgentTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000003066 ____A [9E43447E0BF6F4548FD49B4CBAE4C81C] () C:\Windows\System32\Tasks\Microsoft\Windows\SpacePort\SpaceManagerTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Speech
2024-07-12 11:51 - 2024-07-12 11:51 - 000003276 ____A [0FED9B1246FE5B26E9EBB2B6D068447C] () C:\Windows\System32\Tasks\Microsoft\Windows\Speech\SpeechModelDownloadTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\StateRepository
2024-07-12 11:51 - 2024-07-12 11:51 - 000003112 ____A [183D04307BA05AC13166A073984CC57B] () C:\Windows\System32\Tasks\Microsoft\Windows\StateRepository\MaintenanceTasks
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Storage Tiers Management
2024-07-12 11:51 - 2024-07-12 11:51 - 000003204 ____A [B40EBFE0838AB7047C24F94B422FD580] () C:\Windows\System32\Tasks\Microsoft\Windows\Storage Tiers Management\Storage Tiers Management Initialization
2024-07-12 11:51 - 2024-07-12 11:51 - 000003290 ____A [FB566A50AF497D794A624B19D509616E] () C:\Windows\System32\Tasks\Microsoft\Windows\Storage Tiers Management\Storage Tiers Optimization
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Subscription
2024-07-12 11:51 - 2024-07-12 11:51 - 000004684 ____A [86718857482C80C6C6A4E87C8CE54D82] () C:\Windows\System32\Tasks\Microsoft\Windows\Subscription\EnableLicenseAcquisition
2024-07-12 11:51 - 2024-07-12 11:51 - 000003758 ____A [C8CBEE3BB05636F7C0D1C98530C66A93] () C:\Windows\System32\Tasks\Microsoft\Windows\Subscription\LicenseAcquisition
2022-05-07 11:09 - 2022-05-07 11:09 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SyncCenter
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain
2024-07-12 11:51 - 2024-07-12 11:51 - 000003056 ____A [E9F1539E90748BC8F9AF47003D83870D] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\HybridDriveCachePrepopulate
2024-07-12 11:51 - 2024-07-12 11:51 - 000003126 ____A [B251415191CB5DF30ABC19C607FB9570] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\HybridDriveCacheRebalance
2024-07-12 11:51 - 2024-07-12 11:51 - 000002972 ____A [93AC0F9DCF4B395B1D047FBDE22D886E] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\ResPriStaticDbSync
2024-07-12 11:51 - 2024-07-16 10:24 - 000003858 ____A [F1C1C8BDD3D71C4DA978A1703159E4AF] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\WsSwapAssessmentTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SystemRestore
2024-07-12 11:51 - 2024-07-12 11:51 - 000002976 ____A [7B4EF601179BED6FE32DB84939A55905] () C:\Windows\System32\Tasks\Microsoft\Windows\SystemRestore\SR
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Task Manager
2024-07-12 11:51 - 2024-07-12 11:51 - 000002762 ____A [62248D9B519AEB9F06998AF03D3023EE] () C:\Windows\System32\Tasks\Microsoft\Windows\Task Manager\Interactive
2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\TaskScheduler
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\TextServicesFramework
2024-07-12 11:51 - 2024-07-12 11:51 - 000002622 ____A [688479812C2BAFE266ACDAF952BBC332] () C:\Windows\System32\Tasks\Microsoft\Windows\TextServicesFramework\MsCtfMonitor
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Time Synchronization
2024-07-12 11:51 - 2024-07-12 11:51 - 000003190 ____A [A957215CABCE94ADADD28EBDD76C67CA] () C:\Windows\System32\Tasks\Microsoft\Windows\Time Synchronization\ForceSynchronizeTime
2024-07-12 11:51 - 2024-07-12 11:51 - 000002900 ____A [1CA85B19D81E65D657F8538DC95055E5] () C:\Windows\System32\Tasks\Microsoft\Windows\Time Synchronization\SynchronizeTime
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Time Zone
2024-07-12 11:51 - 2024-07-12 11:51 - 000002600 ____A [33BB30ACA14F3F52139EDD37581D0B9F] () C:\Windows\System32\Tasks\Microsoft\Windows\Time Zone\SynchronizeTimeZone
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\TPM
2024-07-12 11:51 - 2024-07-12 11:51 - 000002816 ____A [3AD67DD47B006D6D20419FEE24BF399B] () C:\Windows\System32\Tasks\Microsoft\Windows\TPM\Tpm-HASCertRetr
2024-07-12 11:51 - 2024-07-12 11:51 - 000003592 ____A [DBBA597DD8D026AB3AF7295B476D1D13] () C:\Windows\System32\Tasks\Microsoft\Windows\TPM\Tpm-Maintenance
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\UNP
2024-07-12 11:51 - 2024-07-12 11:51 - 000003084 ____A [3282993A8B7FC8573AEAEBBF6E116167] () C:\Windows\System32\Tasks\Microsoft\Windows\UNP\RunUpdateNotificationMgr
2024-07-12 11:51 - 2024-07-17 15:14 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator
2024-07-12 11:51 - 2024-07-19 11:02 - 000003380 ____A [3672DB8374F857B00F74FFBB516A6BAF] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Report policies
2024-07-12 11:51 - 2024-07-12 11:51 - 000002324 ____A [4A1207C912587C864073A62A3CDE142A] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Maintenance Work
2024-07-12 11:51 - 2024-07-19 11:02 - 000002730 ____A [84C9EE948CDD912FC4EDCC553F551AED] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Scan
2024-07-12 11:51 - 2024-07-19 11:02 - 000004382 ____A [732319BCE149DAA5C92D20A19ECE3BB5] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Scan Static Task
2024-07-12 11:51 - 2024-07-12 12:08 - 000003376 ____A [390C4CA7F90CE9FA8EE7729CD56A6D64] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Wake To Work
2024-07-12 11:51 - 2024-07-19 10:46 - 000003362 ____A [B8E743E5D182065A3A0C9B02EF4EC645] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Work
2024-07-12 11:51 - 2024-07-19 11:02 - 000003114 ____A [18FDD08EAAF67C3EA084F8AD2F8EC79A] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Start Oobe Expedite Work
2024-07-12 11:51 - 2024-07-19 11:02 - 000003064 ____A [67BF07D344697161CD2F5D2B3B53A612] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\StartOobeAppsScan_LicenseAccepted
2024-07-12 11:51 - 2024-07-19 11:02 - 000003086 ____A [5225EF2E8CBDE5FF4BB3E8E33C333318] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\StartOobeAppsScanAfterUpdate
2024-07-12 11:51 - 2024-07-19 11:02 - 000003058 ____A [98130A24A8DFE0CE84822E2DF2DEADB4] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\UUS Failover Task
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\UPnP
2024-07-12 11:51 - 2024-07-12 11:51 - 000002328 ____A [614592EEDDA9F8208953550A929CAE63] () C:\Windows\System32\Tasks\Microsoft\Windows\UPnP\UPnPHostConfig
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\USB
2024-07-12 11:51 - 2024-07-12 11:51 - 000003496 ____A [4EE9864F2A542BF944A9014E6E0ABDA5] () C:\Windows\System32\Tasks\Microsoft\Windows\USB\Usb-Notifications
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\User Profile Service
2024-07-12 11:51 - 2024-07-12 11:51 - 000003650 ____A [F990F1B964EBE5E6DACE8C3B5C01E76F] () C:\Windows\System32\Tasks\Microsoft\Windows\User Profile Service\HiveUploadTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WaaSMedic
2024-07-12 11:51 - 2024-07-12 11:51 - 000003218 ____A [8D6B6FE629C79A128E46A71063DF3F53] () C:\Windows\System32\Tasks\Microsoft\Windows\WaaSMedic\PerformRemediation
2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WCM
2024-07-12 11:51 - 2024-07-12 11:51 - 000002922 ____A [1DEEF230FFB132F3B772664DB91C1660] () C:\Windows\System32\Tasks\Microsoft\Windows\WCM\WiFiTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WDI
2024-07-12 11:51 - 2024-07-12 11:51 - 000002892 ____A [452959337E560E3F54599166FDACA2CD] () C:\Windows\System32\Tasks\Microsoft\Windows\WDI\ResolutionHost
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Activation Technologies
2024-07-12 11:51 - 2024-07-16 10:24 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender
2024-07-12 11:51 - 2024-07-16 10:24 - 000003816 ____A [0E1835929C6BAFBC49F6C5A83CB1CD41] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Cache Maintenance
2024-07-12 11:51 - 2024-07-16 10:24 - 000003770 ____A [760E277C5B22309528E33EEC2ADC4E20] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Cleanup
2024-07-12 11:51 - 2024-07-16 10:24 - 000003822 ____A [5075AF368DC7A5B1574A5B0DB6E327D0] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Scheduled Scan
2024-07-12 11:51 - 2024-07-16 10:24 - 000003800 ____A [A47CE15091E55D020CAE8643F7DC3DD9] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Verification
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Error Reporting
2024-07-12 11:51 - 2024-07-12 11:51 - 000004522 ____A [A870165FA94D21282A70FCABDFFBBEFF] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Error Reporting\QueueReporting
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Filtering Platform
2024-07-12 11:51 - 2024-07-12 11:51 - 000003288 ____A [C169971DBB83A272CD3925491D102517] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Filtering Platform\BfeOnServiceStartTypeChange
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Media Sharing
2024-07-12 11:51 - 2024-07-12 11:51 - 000003420 ____A [29788CF87DCF702A9516AEBC3EEDD0FC] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Media Sharing\UpdateLibrary
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Subsystem For Linux
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WindowsBackup
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WindowsColorSystem
2024-07-12 11:51 - 2024-07-12 11:51 - 000003164 ____A [94AD66D07959598F514279EE85F6FFCA] () C:\Windows\System32\Tasks\Microsoft\Windows\WindowsColorSystem\Calibration Loader
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WindowsUpdate
2024-07-12 11:51 - 2024-07-19 11:02 - 000003072 ____A [D87322B7AF634AFB0047B945AECD259C] () C:\Windows\System32\Tasks\Microsoft\Windows\WindowsUpdate\Refresh Group Policy Cache
2024-07-12 11:51 - 2024-07-19 11:01 - 000004022 ____A [E83DCDCBAC2DAD168E9716CBBAC7E338] () C:\Windows\System32\Tasks\Microsoft\Windows\WindowsUpdate\Scheduled Start
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Wininet
2024-07-12 11:51 - 2024-07-12 11:51 - 000002564 ____A [652CA5AE0B16AC099DF8E45F72730C2B] () C:\Windows\System32\Tasks\Microsoft\Windows\Wininet\CacheTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WlanSvc
2024-07-12 11:51 - 2024-07-12 11:51 - 000002646 ____A [0E02197D41CBC25A6C969377F286A8C3] () C:\Windows\System32\Tasks\Microsoft\Windows\WlanSvc\CDSSync
2024-07-12 11:51 - 2024-07-12 11:51 - 000002860 ____A [A1E75931A6DC62F4D2C77E32E5BE632B] () C:\Windows\System32\Tasks\Microsoft\Windows\WlanSvc\MoProfileManagement
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WOF
2024-07-12 11:51 - 2024-07-12 11:51 - 000003060 ____A [8275A4BA11503CA1901151E1B5D556A4] () C:\Windows\System32\Tasks\Microsoft\Windows\WOF\WIM-Hash-Management
2024-07-12 11:51 - 2024-07-12 11:51 - 000002794 ____A [6AC7FCDC9047FAF56AC5BDEAC9B8D013] () C:\Windows\System32\Tasks\Microsoft\Windows\WOF\WIM-Hash-Validation
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Work Folders
2024-07-12 11:51 - 2024-07-12 11:51 - 000002790 ____A [4896237B881AA3E758AC1B0DDD3160AC] () C:\Windows\System32\Tasks\Microsoft\Windows\Work Folders\Work Folders Logon Synchronization
2024-07-12 11:51 - 2024-07-12 11:51 - 000003090 ____A [066A2DB4C72E617E8F1C2B15AE02494A] () C:\Windows\System32\Tasks\Microsoft\Windows\Work Folders\Work Folders Maintenance Work
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join
2024-07-12 11:51 - 2024-07-12 11:51 - 000003832 ____A [B17F649F80963DE7EE1CC18C573840E3] () C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join\Automatic-Device-Join
2024-07-12 11:51 - 2024-07-12 11:51 - 000003150 ____A [58B1C87F937EADB70ADDE26B8D5EAB2A] () C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join\Device-Sync
2024-07-12 11:51 - 2024-07-12 11:51 - 000002848 ____A [EF4E679D9823AE2D2A995E4FE7116B0D] () C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join\Recovery-Check
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WS
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WwanSvc
2024-07-12 11:51 - 2024-07-12 11:51 - 000003012 ____A [273C6C8ECD0A76FF04F5033EB2F5F00D] () C:\Windows\System32\Tasks\Microsoft\Windows\WwanSvc\NotificationTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000004292 ____A [04D9E30E380A9096A53D2872ED950BBF] () C:\Windows\System32\Tasks\Microsoft\Windows\WwanSvc\OobeDiscovery
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\XblGameSave
2024-07-12 11:51 - 2024-07-12 11:51 - 000002622 ____A [C60657E94BB87AD4189FA676C3248E39] () C:\Windows\System32\Tasks\Microsoft\XblGameSave\XblGameSaveTask
2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Mozilla
2024-07-12 11:51 - 2024-07-19 10:57 - 000004114 ____A [AB9267BB9DCBBFB3BB41ADCEA9587E35] () C:\Windows\System32\Tasks\Mozilla\Firefox Background Update 308046B0AF4A39CB
2024-07-12 11:51 - 2024-07-19 10:57 - 000003980 ____A [E9A76796016850AA782FA4D45D155F6F] () C:\Windows\System32\Tasks\Mozilla\Firefox Default Browser Agent 308046B0AF4A39CB
====== End of Folder: ======
========= Batch: =========
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="DcomLaunch"'
Property(s) update successful.
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="nsi"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="Dhcp"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="RpcSs"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="RpcEptMapper"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="Winmgmt"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="SDRSVC"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="VSS"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="EventLog"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="BFE"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="EventSystem"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="msiserver"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="SstpSvc"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="RasMan"'
Updating property(s) of '\\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name="TrustedInstaller"'
The Windows Backup service is starting.
The Windows Backup service was started successfully.
The requested service has already been started.
More help is available by typing NET HELPMSG 2182.
The Windows Installer service is starting.
The Windows Installer service was started successfully.
The Windows Modules Installer service is starting.
The Windows Modules Installer service was started successfully.
Info: Successfully rebuilt performance counter setting from system backup store
Sucessfully reset the Winsock Catalog.
You must restart the computer in order to complete the reset.
Resetting Compartment Forwarding, OK!
Resetting Compartment, OK!
Resetting Control Protocol, OK!
Resetting Echo Sequence Request, OK!
Resetting Global, OK!
Resetting Interface, OK!
Resetting Anycast Address, OK!
Resetting Multicast Address, OK!
Resetting Unicast Address, OK!
Resetting Neighbor, OK!
Resetting Path, OK!
Resetting Potential, OK!
Resetting Prefix Policy, OK!
Resetting Proxy Neighbor, OK!
Resetting Route, OK!
Resetting Site Prefix, OK!
Resetting Subinterface, OK!
Resetting Wakeup Pattern, OK!
Resetting Resolve Neighbor, OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , failed.
Access is denied.
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Restart the computer to complete this action.
Resetting Path, OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , failed.
Access is denied.
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Windows IP Configuration
No operation can be performed on Wi-Fi while it has its media disconnected.
No operation can be performed on Local Area Connection* 1 while it has its media disconnected.
No operation can be performed on Local Area Connection* 10 while it has its media disconnected.
No operation can be performed on Bluetooth Network Connection while it has its media disconnected.
Ethernet adapter Ethernet:
IPv6 Address. . . . . . . . . . . : 2404:7c00:48:9fb2:9a:a2a0:cf95:ea69
Temporary IPv6 Address. . . . . . : 2404:7c00:48:9fb2:193:4a21:b946:6f0a
Link-local IPv6 Address . . . . . : fe80::f61b:df1b:1949:74bd%11
Default Gateway . . . . . . . . . : fe80::82f7:a6ff:fe26:b28c%11
Wireless LAN adapter Wi-Fi:
Wireless LAN adapter Local Area Connection* 1:
Wireless LAN adapter Local Area Connection* 10:
Ethernet adapter Bluetooth Network Connection:
IPv4 Address. . . . . . . . . . . : 192.168.101.2
192.168.101.1
Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.
Current WinHTTP proxy settings:
Direct access (no proxy server).
BITSADMIN version 3.0
BITS administration utility.
(C) Copyright Microsoft Corp.
Listed 0 job(s).
0 out of 0 jobs canceled.
WMI repository is consistent
WMI repository has been reset
Ok.
Ok.
Deleted file - C:\WINDOWS\prefetch\0.DAT-78DFFE22.pf
Deleted file - C:\WINDOWS\prefetch\0.DAT-AEC11D05.pf
Deleted file - C:\WINDOWS\prefetch\126.0.6478.128_CHROME_INSTALL-38D806D2.pf
Deleted file - C:\WINDOWS\prefetch\3RVX.EXE-5383B269.pf
Deleted file - C:\WINDOWS\prefetch\7ZFM.EXE-44040917.pf
Deleted file - C:\WINDOWS\prefetch\7ZG.EXE-D9AA3A0B.pf
Deleted file - C:\WINDOWS\prefetch\ACCOUNTSCONTROLHOST.EXE-3ED0EE8B.pf
Deleted file - C:\WINDOWS\prefetch\ADDINUTIL.EXE-4E6085D4.pf
Deleted file - C:\WINDOWS\prefetch\AGGREGATORHOST.EXE-8DA5EB72.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA.EXE-78CA83B0.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.103.0.EX-18A92BEB.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.120.0.EX-42F42326.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.125.0.EX-C7F1EF2F.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.134.0.EX-1D973267.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.150.0.EX-C6E29A6D.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.50.0.EXE-2A7F4D80.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.60.0.EXE-01241FED.pf
Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.66.0.EXE-07217B2B.pf
Deleted file - C:\WINDOWS\prefetch\APPINSTALLER.EXE-B75F1120.pf
Deleted file - C:\WINDOWS\prefetch\APPINSTALLERFULLTRUSTAPPSERVI-7A4B47DE.pf
Deleted file - C:\WINDOWS\prefetch\APPLICATIONFRAMEHOST.EXE-8CE9A1EE.pf
Deleted file - C:\WINDOWS\prefetch\APPVSHNOTIFY.EXE-FB3C42F5.pf
Deleted file - C:\WINDOWS\prefetch\AUDIODG.EXE-AB22E9A6.pf
Deleted file - C:\WINDOWS\prefetch\AUTOHOTKEYU64.EXE-6FF3B212.pf
Deleted file - C:\WINDOWS\prefetch\AUTOHOTKEYUX.EXE-28C1E1E8.pf
Deleted file - C:\WINDOWS\prefetch\AUTOLOGGER.EXE-11748E4D.pf
Deleted file - C:\WINDOWS\prefetch\AUTORUNS64.EXE-7ED120A7.pf
Deleted file - C:\WINDOWS\prefetch\AV_Z.EXE-4D174C78.pf
Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTASKHOST.EXE-6D58042C.pf
Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTASKHOST.EXE-97CA74D0.pf
Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTASKHOST.EXE-DFDB6B55.pf
Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTRANSFERHOST.EXE-1DD38560.pf
Deleted file - C:\WINDOWS\prefetch\BCDEDIT.EXE-FE221428.pf
Deleted file - C:\WINDOWS\prefetch\BITSADMIN.EXE-61856B04.pf
Deleted file - C:\WINDOWS\prefetch\BYTECODEGENERATOR.EXE-FB938A53.pf
Deleted file - C:\WINDOWS\prefetch\CALCULATORAPP.EXE-3E92A9D6.pf
Deleted file - C:\WINDOWS\prefetch\CHCP.COM-2CF9B15C.pf
Deleted file - C:\WINDOWS\prefetch\CHECKNETISOLATION.EXE-B39F2C30.pf
Deleted file - C:\WINDOWS\prefetch\CHECK_FOR_64BIT_VISUAL_STUDIO-CE2ADCF6.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA3C.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA3D.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA3E.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA40.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA45.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA46.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA47.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA48.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA49.pf
Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA4A.pf
Deleted file - C:\WINDOWS\prefetch\CHSIME.EXE-450F47D5.pf
Deleted file - C:\WINDOWS\prefetch\CHXSMARTSCREEN.EXE-2D9D9C45.pf
Deleted file - C:\WINDOWS\prefetch\CLEARLNK.EXE-63D5F4B4.pf
Deleted file - C:\WINDOWS\prefetch\CLIPUP.EXE-4C5C7B66.pf
Deleted file - C:\WINDOWS\prefetch\CMD.EXE-0BD30981.pf
Deleted file - C:\WINDOWS\prefetch\CMD.EXE-6D6290C5.pf
Deleted file - C:\WINDOWS\prefetch\COMPATTELRUNNER.EXE-B7A68ECC.pf
Deleted file - C:\WINDOWS\prefetch\COMPPKGSRV.EXE-4780F0C1.pf
Deleted file - C:\WINDOWS\prefetch\COMPUTERHARDWAREIDS.EXE-21FB5DC0.pf
Deleted file - C:\WINDOWS\prefetch\CONHOST.EXE-0C6456FB.pf
Deleted file - C:\WINDOWS\prefetch\CONSENT.EXE-40419367.pf
Deleted file - C:\WINDOWS\prefetch\CROSSDEVICESERVICE.EXE-1987D0F6.pf
Deleted file - C:\WINDOWS\prefetch\CSC.EXE-B6D5E435.pf
Deleted file - C:\WINDOWS\prefetch\CSLOL-DIAG.EXE-9AB04EE5.pf
Deleted file - C:\WINDOWS\prefetch\CSLOL-MANAGER.EXE-CE44A2A0.pf
Deleted file - C:\WINDOWS\prefetch\CTFMON.EXE-795F8130.pf
Deleted file - C:\WINDOWS\prefetch\CVTRES.EXE-BBD3ED93.pf
Deleted file - C:\WINDOWS\prefetch\DATAEXCHANGEHOST.EXE-8B66795C.pf
Deleted file - C:\WINDOWS\prefetch\DBINSTALLER.EXE-284684E2.pf
Deleted file - C:\WINDOWS\prefetch\DEFAULTTOOL.EXE-41C87A60.pf
Deleted file - C:\WINDOWS\prefetch\DEFRAG.EXE-3D9E8D72.pf
Deleted file - C:\WINDOWS\prefetch\DEVCON.EXE-66458A35.pf
Deleted file - C:\WINDOWS\prefetch\DIRECTXDATABASEUPDATER.EXE-7B8AED66.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF221.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF222.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF223.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF224.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF225.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF229.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D66.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D67.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D68.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D69.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D6A.pf
Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D6E.pf
Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER.EXE-39E1795B.pf
Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER.EXE-73597721.pf
Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER64.EXE-326CF78D.pf
Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER64.EXE-4CB86EF3.pf
Deleted file - C:\WINDOWS\prefetch\DISM.EXE-AA0F2086.pf
Deleted file - C:\WINDOWS\prefetch\DISMHOST.EXE-9ED88D89.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-0BCCFE33.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-1BAE06BB.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-47BE07DC.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-51C0C0B8.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-6F625E57.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-7D5CE0CA.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-858FE9DA.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-97AE7A57.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-A3CD2B45.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-A6DA1980.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-B8720A9F.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-D200FEC3.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-DEEF2761.pf
Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-F7FC6593.pf
Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C84.pf
Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C85.pf
Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C86.pf
Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C8C.pf
Deleted file - C:\WINDOWS\prefetch\DOUYIN_LAUNCHER.EXE-3CA6CE73.pf
Deleted file - C:\WINDOWS\prefetch\DOUYIN_TRAY.EXE-CB951C9B.pf
Deleted file - C:\WINDOWS\prefetch\DRVINST.EXE-39D9EAC7.pf
Deleted file - C:\WINDOWS\prefetch\DSMUSERTASK.EXE-853A6893.pf
Deleted file - C:\WINDOWS\prefetch\DUMP_REPORTER.EXE-A2CA3D84.pf
Deleted file - C:\WINDOWS\prefetch\DWM.EXE-314E93C5.pf
Deleted file - C:\WINDOWS\prefetch\dynrespri.7db
Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-4FCD2BB0.pf
Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-527613F3.pf
Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-87CAB08F.pf
Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-8B683CA8.pf
Deleted file - C:\WINDOWS\prefetch\EVERYTHING-1.4.1.1024.X64-SET-9A7A990B.pf
Deleted file - C:\WINDOWS\prefetch\EVERYTHING.EXE-2260A499.pf
Deleted file - C:\WINDOWS\prefetch\EVERYTHING.EXE-5F5BA4E5.pf
Deleted file - C:\WINDOWS\prefetch\EXCEL.EXE-FE860005.pf
Deleted file - C:\WINDOWS\prefetch\EXPLORER.EXE-54012F5E.pf
Deleted file - C:\WINDOWS\prefetch\EXPLORER.EXE-D5E97654.pf
Deleted file - C:\WINDOWS\prefetch\FIND.EXE-66A35B26.pf
Deleted file - C:\WINDOWS\prefetch\FIREFOX.EXE-66015FD1.pf
Deleted file - C:\WINDOWS\prefetch\FRST64.EXE-8A45F98D.pf
Deleted file - C:\WINDOWS\prefetch\FSQUIRT.EXE-A8FF1DEB.pf
Deleted file - C:\WINDOWS\prefetch\GAMEBARPRESENCEWRITER.EXE-5ADEE7C2.pf
Deleted file - C:\WINDOWS\prefetch\GCUSERVICE.EXE-B6520827.pf
Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-1CD184BF.pf
Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-3BB6BE9E.pf
Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-7F0CD7C6.pf
Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-83F04398.pf
Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-9B08747A.pf
Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-B433E1C8.pf
Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-E3E71DA6.pf
Deleted file - C:\WINDOWS\prefetch\GEEK64.EXE-69B8A6E8.pf
Deleted file - C:\WINDOWS\prefetch\GET-GRAPHICS-OFFSETS32.EXE-DA327B27.pf
Deleted file - C:\WINDOWS\prefetch\GET-GRAPHICS-OFFSETS64.EXE-313543E8.pf
Deleted file - C:\WINDOWS\prefetch\GPU_ENCODER_HELPER.EXE-3534FDB9.pf
Deleted file - C:\WINDOWS\prefetch\GPU_ENCODER_HELPER.EXE-5578D93C.pf
Deleted file - C:\WINDOWS\prefetch\GRPCONV.EXE-A548DBA8.pf
Deleted file - C:\WINDOWS\prefetch\GSDK-VULKAN-INIT.EXE-2B90F7F0.pf
Deleted file - C:\WINDOWS\prefetch\HIJACKTHIS.EXE-43AA66B9.pf
Deleted file - C:\WINDOWS\prefetch\IDENTITY_HELPER.EXE-B1938933.pf
Deleted file - C:\WINDOWS\prefetch\IDMAN.EXE-82E77CDF.pf
Deleted file - C:\WINDOWS\prefetch\IDMGRHLP.EXE-C29D073D.pf
Deleted file - C:\WINDOWS\prefetch\IDMINTEGRATOR64.EXE-6B94A449.pf
Deleted file - C:\WINDOWS\prefetch\IDMMSGHOST.EXE-9A561A25.pf
Deleted file - C:\WINDOWS\prefetch\IEXPLORE.EXE-058FE8F5.pf
Deleted file - C:\WINDOWS\prefetch\IEXPLORE.EXE-A033F7A0.pf
Deleted file - C:\WINDOWS\prefetch\INSTALLUTIL.EXE-BB270139.pf
Deleted file - C:\WINDOWS\prefetch\INTEGRATOR.EXE-873C4A60.pf
Deleted file - C:\WINDOWS\prefetch\IPCONFIG.EXE-BFEC2AD0.pf
Deleted file - C:\WINDOWS\prefetch\IPF_HELPER.EXE-337CFBF9.pf
Deleted file - C:\WINDOWS\prefetch\IPF_UF.EXE-93A855E0.pf
Deleted file - C:\WINDOWS\prefetch\JAVAW.EXE-44DB5C38.pf
Deleted file - C:\WINDOWS\prefetch\Layout.ini
Deleted file - C:\WINDOWS\prefetch\LEAGUE OF LEGENDS.EXE-BE4BA152.pf
Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENT.EXE-F9AC060C.pf
Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUX.EXE-67EA7345.pf
Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUXRENDER.EXE-3C47C0AE.pf
Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUXRENDER.EXE-3C47C0AF.pf
Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUXRENDER.EXE-3C47C0B5.pf
Deleted file - C:\WINDOWS\prefetch\LEAGUECRASHHANDLER64.EXE-1095281E.pf
Deleted file - C:\WINDOWS\prefetch\LEAGUECRASHHANDLER64.EXE-EBE229AC.pf
Deleted file - C:\WINDOWS\prefetch\LOCKAPP.EXE-7ED5B9D8.pf
Deleted file - C:\WINDOWS\prefetch\LODCTR.EXE-21DD01F9.pf
Deleted file - C:\WINDOWS\prefetch\LODCTR.EXE-57DC4D95.pf
Deleted file - C:\WINDOWS\prefetch\LOGONUI.EXE-F639BD7E.pf
Deleted file - C:\WINDOWS\prefetch\MDSCHED.EXE-21C4D84D.pf
Deleted file - C:\WINDOWS\prefetch\METAEDITOR.EXE-7164C368.pf
Deleted file - C:\WINDOWS\prefetch\MICROSOFTEDGEUPDATE.EXE-7A595326.pf
Deleted file - C:\WINDOWS\prefetch\MMC.EXE-410C5F73.pf
Deleted file - C:\WINDOWS\prefetch\MOBSYNC.EXE-B307E1CC.pf
Deleted file - C:\WINDOWS\prefetch\MOD-TOOLS.EXE-24AA5448.pf
Deleted file - C:\WINDOWS\prefetch\MOFCOMP.EXE-5225C32D.pf
Deleted file - C:\WINDOWS\prefetch\MONOTIFICATIONUX.EXE-23180524.pf
Deleted file - C:\WINDOWS\prefetch\MONOTIFICATIONUX.EXE-62024999.pf
Deleted file - C:\WINDOWS\prefetch\MOUSECLICKER.EXE-4DEF9CEE.pf
Deleted file - C:\WINDOWS\prefetch\MOUSOCOREWORKER.EXE-44A01CE7.pf
Deleted file - C:\WINDOWS\prefetch\MPCMDRUN.EXE-766ACDEA.pf
Deleted file - C:\WINDOWS\prefetch\MPCMDRUN.EXE-82616995.pf
Deleted file - C:\WINDOWS\prefetch\MPDEFENDERCORESERVICE.EXE-9657D0C8.pf
Deleted file - C:\WINDOWS\prefetch\MPRECOVERY.EXE-F2C7680F.pf
Deleted file - C:\WINDOWS\prefetch\MPSIGSTUB.EXE-5D0450B3.pf
Deleted file - C:\WINDOWS\prefetch\MPSIGSTUB.EXE-FD441709.pf
Deleted file - C:\WINDOWS\prefetch\MSCORSVW.EXE-16B291C4.pf
Deleted file - C:\WINDOWS\prefetch\MSCORSVW.EXE-8CE1A322.pf
Deleted file - C:\WINDOWS\prefetch\MSDT.EXE-D579957D.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9A.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9B.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9C.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9E.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA5.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA6.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA7.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA8.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FAA.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758A.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758B.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758C.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758E.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE7594.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE7595.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE7598.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4AF.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B0.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B1.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B3.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B9.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4BA.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4BC.pf
Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4BD.pf
Deleted file - C:\WINDOWS\prefetch\MSIEXEC.EXE-8FFB1633.pf
Deleted file - C:\WINDOWS\prefetch\MSIEXEC.EXE-CDBFC0F7.pf
Deleted file - C:\WINDOWS\prefetch\MSMPENG.EXE-37E24A32.pf
Deleted file - C:\WINDOWS\prefetch\MSMPENG.EXE-AC5FF58F.pf
Deleted file - C:\WINDOWS\prefetch\MSPAINT.EXE-CB27A74E.pf
Deleted file - C:\WINDOWS\prefetch\N2NIMHE1.EXE-EE203998.pf
Deleted file - C:\WINDOWS\prefetch\NET.EXE-0225D674.pf
Deleted file - C:\WINDOWS\prefetch\NET.EXE-A0964F30.pf
Deleted file - C:\WINDOWS\prefetch\NET1.EXE-091D8149.pf
Deleted file - C:\WINDOWS\prefetch\NET1.EXE-509326A5.pf
Deleted file - C:\WINDOWS\prefetch\NETSH.EXE-A596235F.pf
Deleted file - C:\WINDOWS\prefetch\NGEN.EXE-4A8DA13E.pf
Deleted file - C:\WINDOWS\prefetch\NGEN.EXE-734C6620.pf
Deleted file - C:\WINDOWS\prefetch\NGENTASK.EXE-0E6CEC17.pf
Deleted file - C:\WINDOWS\prefetch\NGENTASK.EXE-849BFD75.pf
Deleted file - C:\WINDOWS\prefetch\NISSRV.EXE-72EC3F25.pf
Deleted file - C:\WINDOWS\prefetch\NISSRV.EXE-98CC5D80.pf
Deleted file - C:\WINDOWS\prefetch\NOTEPAD.EXE-162FBFE7.pf
Deleted file - C:\WINDOWS\prefetch\NVCLEANSTALL_1.16.0.EXE-01060082.pf
Deleted file - C:\WINDOWS\prefetch\NVCLEANSTALL_7ZIP.EXE-1A9B9602.pf
Deleted file - C:\WINDOWS\prefetch\NVDISPCO64.EXE-FA73F936.pf
Deleted file - C:\WINDOWS\prefetch\NVDISPLAY.CONTAINER.EXE-EE9DB6A0.pf
Deleted file - C:\WINDOWS\prefetch\NVIDIA-SMI.EXE-43C94612.pf
Deleted file - C:\WINDOWS\prefetch\NVIDIA-SMI.EXE-5733439B.pf
Deleted file - C:\WINDOWS\prefetch\NVNGX_UPDATE.EXE-CB453E5D.pf
Deleted file - C:\WINDOWS\prefetch\NVSHIM.EXE-C1BF347B.pf
Deleted file - C:\WINDOWS\prefetch\NYTJDFGLX1N.EXE-488A4B0B.pf
Deleted file - C:\WINDOWS\prefetch\OAWRAPPER.EXE-C9A635FF.pf
Deleted file - C:\WINDOWS\prefetch\OBS-BACKGROUNDREMOVAL-1.1.13--0C530748.pf
Deleted file - C:\WINDOWS\prefetch\OBS-BACKGROUNDREMOVAL-1.1.13--1593CFC8.pf
Deleted file - C:\WINDOWS\prefetch\OBS-BACKGROUNDREMOVAL-1.1.13--BD4C73AB.pf
Deleted file - C:\WINDOWS\prefetch\OBS-BROWSER-PAGE.EXE-B650FAFD.pf
Deleted file - C:\WINDOWS\prefetch\OBS-BROWSER-PAGE.EXE-B650FAFE.pf
Deleted file - C:\WINDOWS\prefetch\OBS-BROWSER-PAGE.EXE-B650FB04.pf
Deleted file - C:\WINDOWS\prefetch\OBS-NVENC-TEST.EXE-256562AF.pf
Deleted file - C:\WINDOWS\prefetch\OBS-QSV-TEST.EXE-C01625D7.pf
Deleted file - C:\WINDOWS\prefetch\OBS-STUDIO-30.2.0-WINDOWS-INS-40CB636A.pf
Deleted file - C:\WINDOWS\prefetch\OBS64.EXE-40AD00BD.pf
Deleted file - C:\WINDOWS\prefetch\OFFICECLICKTORUN.EXE-4587B16B.pf
Deleted file - C:\WINDOWS\prefetch\OFFICECLICKTORUN.EXE-F5CCE208.pf
Deleted file - C:\WINDOWS\prefetch\OMEGAT.EXE-3F06549A.pf
Deleted file - C:\WINDOWS\prefetch\ONEDRIVESETUP.EXE-2F4C4906.pf
Deleted file - C:\WINDOWS\prefetch\OPENCONSOLE.EXE-A617E510.pf
Deleted file - C:\WINDOWS\prefetch\OPENWITH.EXE-8B50D58B.pf
Deleted file - C:\WINDOWS\prefetch\PERFBOOST.EXE-D7CAB4F4.pf
Deleted file - C:\WINDOWS\prefetch\PfPre_2fa6a7e2.mkd
Deleted file - C:\WINDOWS\prefetch\PHOTOS.EXE-1D3AFA6C.pf
Deleted file - C:\WINDOWS\prefetch\PICKERHOST.EXE-DE4B8E61.pf
Deleted file - C:\WINDOWS\prefetch\PING.EXE-0314C2F7.pf
Deleted file - C:\WINDOWS\prefetch\PINGSENDER.EXE-B4914655.pf
Deleted file - C:\WINDOWS\prefetch\PLUGIN-CONTAINER.EXE-C6EE3785.pf
Deleted file - C:\WINDOWS\prefetch\PNPUTIL.EXE-372B05C1.pf
Deleted file - C:\WINDOWS\prefetch\POQEXEC.EXE-567EE1A6.pf
Deleted file - C:\WINDOWS\prefetch\POWERSHELL.EXE-AE8EDC9B.pf
Deleted file - C:\WINDOWS\prefetch\POWERSHELL.EXE-CA1AE517.pf
Deleted file - C:\WINDOWS\prefetch\PREMID-INSTALLER.EXE-C47DB514.pf
Deleted file - C:\WINDOWS\prefetch\PREMID.EXE-DFD65C30.pf
Deleted file - C:\WINDOWS\prefetch\PREMID.EXE-DFD65C32.pf
Deleted file - C:\WINDOWS\prefetch\PREMID.EXE-DFD65C38.pf
Deleted file - C:\WINDOWS\prefetch\PROCEXP64.EXE-9F0720F4.pf
Deleted file - C:\WINDOWS\prefetch\PWAHELPER.EXE-93ECA8BC.pf
Deleted file - C:\WINDOWS\prefetch\QBITTORRENT.EXE-97E1315C.pf
Deleted file - C:\WINDOWS\prefetch\QS76K3X5.EXE-9501BC5C.pf
Deleted file - C:\WINDOWS\prefetch\QUALIFICATION_APP.EXE-C5E6086A.pf
Deleted file - C:\WINDOWS\prefetch\RAZERINSTALLER.EXE-108EAF16.pf
Deleted file - C:\WINDOWS\prefetch\RAZERSYNAPSEINSTALLER_PRODDIS-4FE6294D.pf
Deleted file - C:\WINDOWS\prefetch\REG.EXE-0AC99A87.pf
Deleted file - C:\WINDOWS\prefetch\REG.EXE-A93A1343.pf
Deleted file - C:\WINDOWS\prefetch\REGEDIT.EXE-DAB4D60B.pf
Deleted file - C:\WINDOWS\prefetch\REGSVR32.EXE-03D3FB87.pf
Deleted file - C:\WINDOWS\prefetch\REGSVR32.EXE-B31EC963.pf
Deleted file - C:\WINDOWS\prefetch\ResPriUHMStaticDb.ebd
Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D0153.pf
Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D0154.pf
Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D0155.pf
Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D015A.pf
Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D015B.pf
Deleted file - C:\WINDOWS\prefetch\RIOTCLIENTCRASHHANDLER.EXE-56653DA5.pf
Deleted file - C:\WINDOWS\prefetch\RIOTCLIENTSERVICES.EXE-0C7DC176.pf
Deleted file - C:\WINDOWS\prefetch\RSITX64.EXE-68FCBFCB.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-012D304A.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-0B0F028C.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-26F63A71.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-27E52A2D.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-29B5A95A.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-6E75ABA4.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-7241955C.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-75313621.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-880E5BDF.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-A751CE9B.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-A7DB9FAD.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-C0159C27.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-C575CB2E.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-C87919CF.pf
Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-CCD98664.pf
Deleted file - C:\WINDOWS\prefetch\RUNONCE.EXE-BD8A4C8F.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-0C405ED0.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-28060877.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-3B032F93.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-4163B14B.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-4551A062.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-489B63D4.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-4D3D38F0.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-5B4167E1.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-7475E422.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-967B2208.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-AB37D56F.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-B408371A.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-B5475AD7.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-B95961EC.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-C6D4F558.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-CEE04A22.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-D0F9CBDE.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-D9F8A976.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-DE17AACA.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-E0A7F531.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-E404484C.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-E4296D27.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-F0E0C793.pf
Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-FE5973AE.pf
Deleted file - C:\WINDOWS\prefetch\RZS3WIZARDPKGS3.EXE-8AEC2626.pf
Deleted file - C:\WINDOWS\prefetch\SBIECTRL.EXE-2EAD5991.pf
Deleted file - C:\WINDOWS\prefetch\SBIESVC.EXE-1FFD779C.pf
Deleted file - C:\WINDOWS\prefetch\SBIESVC.EXE-3C641EB1.pf
Deleted file - C:\WINDOWS\prefetch\SC.EXE-6C4D4413.pf
Deleted file - C:\WINDOWS\prefetch\SC.EXE-F4E1A8F7.pf
Deleted file - C:\WINDOWS\prefetch\SCHTASKS.EXE-8B6144A9.pf
Deleted file - C:\WINDOWS\prefetch\SDBINST.EXE-49E8B208.pf
Deleted file - C:\WINDOWS\prefetch\SDIAGNHOST.EXE-B3171AA1.pf
Deleted file - C:\WINDOWS\prefetch\SDXHELPER.EXE-832215EB.pf
Deleted file - C:\WINDOWS\prefetch\SEARCHFILTERHOST.EXE-44162447.pf
Deleted file - C:\WINDOWS\prefetch\SEARCHHOST.EXE-8F97BC4E.pf
Deleted file - C:\WINDOWS\prefetch\SEARCHHOST.EXE-BA67C789.pf
Deleted file - C:\WINDOWS\prefetch\SEARCHINDEXER.EXE-1CF42BC6.pf
Deleted file - C:\WINDOWS\prefetch\SEARCHPROTOCOLHOST.EXE-69C456C3.pf
Deleted file - C:\WINDOWS\prefetch\SECEDIT.EXE-B8517D62.pf
Deleted file - C:\WINDOWS\prefetch\SECHEALTHUI.EXE-EF8E0FA0.pf
Deleted file - C:\WINDOWS\prefetch\SECURITYHEALTHHOST.EXE-2216DC19.pf
Deleted file - C:\WINDOWS\prefetch\SECURITYHEALTHSERVICE.EXE-91B5FB98.pf
Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-5C4105FE.pf
Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-5C410602.pf
Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-9C1B62B2.pf
Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-D24E177E.pf
Deleted file - C:\WINDOWS\prefetch\SFC.EXE-425529A1.pf
Deleted file - C:\WINDOWS\prefetch\SHELLEXPERIENCEHOST.EXE-6EC78D4F.pf
Deleted file - C:\WINDOWS\prefetch\SIHCLIENT.EXE-98C47F6C.pf
Deleted file - C:\WINDOWS\prefetch\SMARTSCREEN.EXE-EACC1250.pf
Deleted file - C:\WINDOWS\prefetch\SNIPPINGTOOL.EXE-80F9E627.pf
Deleted file - C:\WINDOWS\prefetch\SONAR.DEVINST.EXE-A075643E.pf
Deleted file - C:\WINDOWS\prefetch\SPECCY64.EXE-943BD3B0.pf
Deleted file - C:\WINDOWS\prefetch\SPLWOW64.EXE-57576C25.pf
Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D5529.pf
Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D552A.pf
Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D552B.pf
Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D5531.pf
Deleted file - C:\WINDOWS\prefetch\SPPEXTCOMOBJ.EXE-7D45A1AB.pf
Deleted file - C:\WINDOWS\prefetch\SPPSVC.EXE-96070FE0.pf
Deleted file - C:\WINDOWS\prefetch\SPSETUP133.EXE-241F9597.pf
Deleted file - C:\WINDOWS\prefetch\SRTASKS.EXE-3C9D2EEC.pf
Deleted file - C:\WINDOWS\prefetch\SSDTSHPX_SETUP.EXE-B1FC74F8.pf
Deleted file - C:\WINDOWS\prefetch\SSHZEXECUTOR.EXE-EBDA1112.pf
Deleted file - C:\WINDOWS\prefetch\START.EXE-6188BADF.pf
Deleted file - C:\WINDOWS\prefetch\STARTMENUEXPERIENCEHOST.EXE-4DCEE2F2.pf
Deleted file - C:\WINDOWS\prefetch\STEELSERIESENGINE.EXE-217B9D8D.pf
Deleted file - C:\WINDOWS\prefetch\STEELSERIESGG.EXE-030ABABB.pf
Deleted file - C:\WINDOWS\prefetch\STEELSERIESGGINSTALLERDOWNLOA-437312BD.pf
Deleted file - C:\WINDOWS\prefetch\STEELSERIESGGINSTALLERSWC.EXE-B91581C3.pf
Deleted file - C:\WINDOWS\prefetch\STEELSERIESGGWEBINSTALLER-1.3-09C38D87.pf
Deleted file - C:\WINDOWS\prefetch\STEELSERIESPRISM.EXE-14A76429.pf
Deleted file - C:\WINDOWS\prefetch\STEELSERIESSONAR.EXE-34591847.pf
Deleted file - C:\WINDOWS\prefetch\STOREDESKTOPEXTENSION.EXE-FAFBC5D3.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-09F4AEA4.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-0A049705.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-117C4441.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-13304EB0.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-1454AA18.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-14E28BF5.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-18C5C6E4.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-19B557B1.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-1B73F444.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-2FFEC382.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-3CDB0077.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-41084AF7.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-44191FB8.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4B98D760.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4BD0A607.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4D0E9C8C.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4E79CC0D.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-502A129B.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-529F9AC1.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-59780EBF.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-5F87ABED.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-62105D0D.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-677C0885.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-6867B1E5.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-6A4A44E7.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-73D024B2.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-764FA25C.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-768E59F7.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-77C41F85.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-7AAD9645.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-7CA96BCB.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-84F32335.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-852EC587.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-8A4EB855.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-952637C2.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-9A28EB78.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-9D041ABC.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-A9721AD5.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-AA89143F.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-B18C213B.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-BE3D0421.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C2DA4F6F.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C38EF8DD.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C625B657.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C88A2A3B.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-CAEF0A6A.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-D2385079.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-D5481872.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-D8C907E1.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-DF14C859.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-E5CD0034.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-EA9BB143.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-EBBF67E6.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F1E39519.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F57A5173.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F5E1DCD3.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F952D9A9.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-FA38241C.pf
Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-FC46CD61.pf
Deleted file - C:\WINDOWS\prefetch\SYSTEMINFO.EXE-14DA5704.pf
Deleted file - C:\WINDOWS\prefetch\SYSTEMSETTINGS.EXE-084BB8F9.pf
Deleted file - C:\WINDOWS\prefetch\SYSTEMSETTINGSADMINFLOWS.EXE-F74198E7.pf
Deleted file - C:\WINDOWS\prefetch\SYSTEMSETTINGSBROKER.EXE-8BBE2894.pf
Deleted file - C:\WINDOWS\prefetch\SYSTRAYCOMPONENT.EXE-C9F17BFE.pf
Deleted file - C:\WINDOWS\prefetch\TASKHOSTW.EXE-2E5D4B75.pf
Deleted file - C:\WINDOWS\prefetch\TASKKILL.EXE-0ECD41EC.pf
Deleted file - C:\WINDOWS\prefetch\TASKKILL.EXE-BE180FC8.pf
Deleted file - C:\WINDOWS\prefetch\TASKLIST.EXE-4641012C.pf
Deleted file - C:\WINDOWS\prefetch\TASKMGR.EXE-4C8500BA.pf
Deleted file - C:\WINDOWS\prefetch\TELEGRAM.EXE-4045FED7.pf
Deleted file - C:\WINDOWS\prefetch\TERMINAL.EXE-138A7F7E.pf
Deleted file - C:\WINDOWS\prefetch\TEXTINPUTHOST.EXE-861368C0.pf
Deleted file - C:\WINDOWS\prefetch\TIWORKER.EXE-65F8DEAA.pf
Deleted file - C:\WINDOWS\prefetch\TRUSTEDINSTALLER.EXE-766EFF52.pf
Deleted file - C:\WINDOWS\prefetch\UNINS000.EXE-FAB5105F.pf
Deleted file - C:\WINDOWS\prefetch\UNINST.EXE-0066B9B0.pf
Deleted file - C:\WINDOWS\prefetch\UNINST.EXE-8DB82EF2.pf
Deleted file - C:\WINDOWS\prefetch\UNINSTALL.EXE-16C50215.pf
Deleted file - C:\WINDOWS\prefetch\UNINSTALL.EXE-C8A9BD2C.pf
Deleted file - C:\WINDOWS\prefetch\UN_A.EXE-25687529.pf
Deleted file - C:\WINDOWS\prefetch\UPDATE.EXE-D390C843.pf
Deleted file - C:\WINDOWS\prefetch\UPDATEPLATFORM.AMD64FRE.EXE-804667A0.pf
Deleted file - C:\WINDOWS\prefetch\UPDATER.EXE-8551D93C.pf
Deleted file - C:\WINDOWS\prefetch\UPDATER.EXE-8B065B0B.pf
Deleted file - C:\WINDOWS\prefetch\UPDATER.EXE-8CA706AA.pf
Deleted file - C:\WINDOWS\prefetch\UPDATERSETUP.EXE-0CC28D5F.pf
Deleted file - C:\WINDOWS\prefetch\USERINIT.EXE-5114915C.pf
Deleted file - C:\WINDOWS\prefetch\USEROOBEBROKER.EXE-65584ADF.pf
Deleted file - C:\WINDOWS\prefetch\USOCLIENT.EXE-4ADC110B.pf
Deleted file - C:\WINDOWS\prefetch\VGC.EXE-1D5BD981.pf
Deleted file - C:\WINDOWS\prefetch\VLC.EXE-F1ED81B3.pf
Deleted file - C:\WINDOWS\prefetch\VSSVC.EXE-6C8F0C66.pf
Deleted file - C:\WINDOWS\prefetch\WAB.EXE-5899287B.pf
Deleted file - C:\WINDOWS\prefetch\WERFAULT.EXE-155C56CF.pf
Deleted file - C:\WINDOWS\prefetch\WERFAULT.EXE-19E0D4EB.pf
Deleted file - C:\WINDOWS\prefetch\WERFAULT.EXE-661188F3.pf
Deleted file - C:\WINDOWS\prefetch\WEVTUTIL.EXE-1E154F39.pf
Deleted file - C:\WINDOWS\prefetch\WINDOWSCAMERA.EXE-8A1EBB0D.pf
Deleted file - C:\WINDOWS\prefetch\WINDOWSPACKAGEMANAGERSERVER.E-201C94F9.pf
Deleted file - C:\WINDOWS\prefetch\WINDOWSTERMINAL.EXE-DD240BFA.pf
Deleted file - C:\WINDOWS\prefetch\WINMGMT.EXE-C981BB27.pf
Deleted file - C:\WINDOWS\prefetch\WINPILOT.EXE-38CA5639.pf
Deleted file - C:\WINDOWS\prefetch\WINSAT.EXE-C345C80B.pf
Deleted file - C:\WINDOWS\prefetch\WINSTORE.APP.EXE-743DDED5.pf
Deleted file - C:\WINDOWS\prefetch\WIN_DRIVER_INSTALLER.EXE-1B3E4E9D.pf
Deleted file - C:\WINDOWS\prefetch\WLRMDR.EXE-A7C36FDD.pf
Deleted file - C:\WINDOWS\prefetch\WMIADAP.EXE-BB21CD77.pf
Deleted file - C:\WINDOWS\prefetch\WMIAPSRV.EXE-FC8436DD.pf
Deleted file - C:\WINDOWS\prefetch\WMIC.EXE-311B5CB4.pf
Deleted file - C:\WINDOWS\prefetch\WMIC.EXE-98223A30.pf
Deleted file - C:\WINDOWS\prefetch\WMIPRVSE.EXE-39F97B2D.pf
Deleted file - C:\WINDOWS\prefetch\WMIPRVSE.EXE-E8B8DD29.pf
Deleted file - C:\WINDOWS\prefetch\WT.EXE-26219B2E.pf
Deleted file - C:\WINDOWS\prefetch\WUAUCLTCORE.EXE-07BDE0CF.pf
Deleted file - C:\WINDOWS\prefetch\WUAUCLTCORE.EXE-84257BB2.pf
Deleted file - C:\WINDOWS\prefetch\WUB_X64.EXE-2FDFC964.pf
Deleted file - C:\WINDOWS\prefetch\WWAHOST.EXE-02A78870.pf
Deleted file - C:\WINDOWS\prefetch\WWAHOST.EXE-37768102.pf
Deleted file - C:\WINDOWS\prefetch\ZHPCLEANER(1).EXE-0803C826.pf
Deleted file - C:\WINDOWS\prefetch\ZHPCLEANER.EXE-285CB844.pf
Deleted file - C:\WINDOWS\prefetch\_IU14D2N.TMP-5860BBFB.pf
Deleted file - C:\WINDOWS\prefetch\_UNINSTALL36096-4F505AA8.pf
Deleted file - C:\WINDOWS\prefetch\ReadyBoot\rblayout.xin
Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace5.fx
Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace6.fx
Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace7.fx
Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace8.fx
Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace9.fx
SERVICE_NAME: sysmain
TYPE : 30 WIN32
STATE : 3 STOP_PENDING
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x2710
[SC] ChangeServiceConfig SUCCESS
SERVICE_NAME: DiagTrack
TYPE : 10 WIN32_OWN_PROCESS
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_PRESHUTDOWN)
CHECKPOINT : 0x3
WAIT_HINT : 0x0
[SC] ControlService FAILED 1062:
The service has not been started.
SERVICE_NAME: WSearch
(NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
CHECKPOINT : 0x2
WAIT_HINT : 0x7530
========= End of Batch: =========
========= del /s /q "%userprofile%\AppData\Local\temp\*.*" =========
Deleted file - C:\Users\Ripple\AppData\Local\temp\000e5e9f-7d5c-47ed-bece-e4b3a9f8e489.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\02b41375-20bc-4178-82a8-7d79c6dd972f.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\02d6d97e-57a7-4f5b-8b86-1d4d7aee209e.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\03abe1be-d0f9-4d83-ad08-a84666c67f6e.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\03f1d3f2-dfa7-432e-9d6f-fd2e323f1fdd.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\06138131-2e01-430b-b7b0-0e1d3ce56283.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\08700c85-9fd2-4b5c-8c90-91384e7cf119.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\088c9fd0-bdf2-4842-b685-e29dbb58516f.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\093458cb-86fc-42c3-9315-596d51ff84d0.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\0afb4d07-1702-4797-850a-10695459ba40.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\0cb06e50-5646-4c83-86fd-a9c31fc15dc6.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\0cbf380a-2f78-4068-b803-00728fbedebd.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\0cbf7ec3-ee7f-4206-9be7-fb50aca61686.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\0e0ceef9-336f-49d9-8351-8af09ed69779.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\0ecb665c-226d-4506-b269-cced8d56e4cb.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\10aaf4a2-d7b4-464b-b5ee-acdadd5ca921.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\1614f8ee-618f-426d-9ae5-ca38c20c60e2.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\16cccebf-448e-4687-83ee-4a7d398d228f.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\17441628-b533-4877-a6c5-1c511eb17268.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\176feff4-ea9c-4845-a35a-30874496cd88.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\17bd9ba8-7db2-46f4-b5f6-5108238cada0.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\1c72bf29-00cd-43ca-97fd-87591a9a6bb9.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\1d1f8f16-996c-4e23-8169-ae043ec340ef.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\1d5a225b-a358-4f0f-a6b9-0d1c8d5894bb.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\1dd4593a-633f-4e25-b949-fac232ef6027.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\1ee7981f-f33a-4ed6-8f4c-a22f0d5c0b85.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\204a4cbb-83e4-4f76-a043-1f611d14723e.tmp.ico
Deleted file - C:\Users\Ripple\AppData\Local\temp\21335448-da85-430b-b419-96768265981c.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\248b5755-f492-4993-b76e-fb26130c40a3.tmp.ico
Deleted file - C:\Users\Ripple\AppData\Local\temp\24fd1dd6-6c8a-4654-a272-06dd14af86e4.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\25707d32-0881-4764-8973-a570016eec35.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\27494c44-3aec-4e87-949a-ff68182ec350.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\27e535e4-1283-4c8a-a8ad-ba058dcb06d8.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\287bd5f8-3eb1-463b-8d2f-d1196f3385eb.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\29936927-270b-458b-89c0-c8f9f884c85c.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\29d85551-f32c-4e2a-8d7b-39a5673cc143.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\2a4967d1-b182-4468-a0c4-5d806ede8b6c.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\2b149659-240a-43e2-b48d-bc76b0158a33.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\2ca61c94-6aa7-4df3-b2e4-0f75bad6ceb4.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\2f2b59ff-f9ab-4c3e-9735-51c35422d600.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\311fb624-90d2-4b3b-a0e0-b48bcb9cf58c.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\3455ca0d-8d8b-4aa7-83ba-22e2341d7115.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\351ce3e0-0b65-42cb-8caa-93085de012d4.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\37fe0948-ad3d-4240-8463-cd5ba34b9662.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\38837797-6bc5-47da-9e21-8dec95bf3b50.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\3924a4c2-4690-4ecd-bad5-ddb372f26bcd.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\3a0ed51f-7d30-4035-8258-a82d21edf81b.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\3aa97a99-8548-4839-abbb-0fbbbd9b4f87.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\3b9ce3b0-2da4-4cc7-95dd-f59ffb55dec3.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\3d10391a-fb94-4263-9b0d-7337718dea25.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\3e6c5a28-9b4c-4c69-b195-dbbb4a080a3d.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\3fc83836-a399-435c-8e9c-d1f7f63bd47e.tmp.ico
Deleted file - C:\Users\Ripple\AppData\Local\temp\40c45357-cf97-4711-af24-eca4b32821df.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\40f9dbff-fbee-488b-a618-3762a62ccd93.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\413c2a73-afdb-4b42-aea5-df8bf843b093.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\425739d1-241e-44de-8ce0-007d20c6310c.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\4435737d-28af-4f51-bf9d-92065d21c468.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\4a2dc72c-bc9d-455c-b856-a1a71f33d15f.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\4bcf2b7c-8980-4d21-9835-62ac0ecffe52.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\4be11248-6d34-4f17-aae0-3f9211e8618e.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\4ccf16a8-4a2b-42b7-a677-e883b32c0ac5.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\4d32bdcd-ab79-45a3-b134-1007cfdafb38.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\4eb46d45-df26-4f77-b3c7-9bc51dcc2003.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\4f24f544-5c7a-4957-bedc-12aa402d9285.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\513be19d-c1df-4125-81ba-26c67ab1029b.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\51b19fde-1ab0-4b8a-a622-d038b6f3d5cd.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\5444c64b-adfa-4d72-a548-23c3e55e0dc3.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\5639ed6e-d1e7-4d06-870c-d5a0e372a5eb.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\5755d083-91b4-46b6-9111-0d54287bf465.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\5784b4ca-a0ff-4696-9bb5-57acde18753f.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\57a6846f-df91-4f99-b2cf-3aec2c875832.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\5eb3413a-05bf-4913-849b-3ef1e5f7bfc4.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\60360540-3a45-41e5-9378-70f60fc6a9d0.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\618d26df-503f-4dec-ab74-2499d16ea330.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\6417fc96-3c41-4131-92fb-c90594f30dcf.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\67959dc3-cd78-40cd-9874-72dec185826d.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\691fec44-ca19-4165-b24e-5ffbd32a9e0b.tmp.ico
Deleted file - C:\Users\Ripple\AppData\Local\temp\69ada4e2-6e07-459b-a553-ba15cdd85186.tmp.ico
Deleted file - C:\Users\Ripple\AppData\Local\temp\6d85d38b-8e82-45ab-af85-012b70fb7581.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\6d8c8f66-ae4e-4398-bad8-9e0ca89f8353.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\70abf38e-1d69-4297-8822-bb87db05a360.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\721accb8-627f-47f9-a013-41850aa79c6c.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\7596c69a-c92e-4f95-b6db-b5a65767f2b0.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\7657ad3a-4232-4164-bf13-dc6a7a5f71b0.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\76f88e00-93f8-465d-bd5f-93b01b0c3875.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\770b3f09-b127-43d0-a649-e43d05162934.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\7a0c3507-014b-43f8-9c15-35b24bd6d521.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\7a1ffb21-31ca-4c7a-a44a-c1058cd75655.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\7b02d9c3-e735-4813-90ed-674897c45f3b.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\7c26c876-2108-48e5-a39d-d8a95d6e9616.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\7e36632a-e85c-4e14-b35e-3a26185fcc46.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\7f5615f7-211c-4be2-8dfa-cf7bc2edc8b3.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\8055d93b-ac18-4ccc-814c-c45572be4c14.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\8155a832-a0e7-4ef7-b274-cf6ccfdf680a.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\86112906-5a25-48b8-99c7-dd8113615d2d.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\865b672f-2f32-49a9-b3b1-e7d803d57797.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\86e3a39b-a064-4080-be3e-fdd05e2e30de.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\87b5246a-58df-4838-957f-e6df90eb2686.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\88fc2d63-a850-4da2-aa6f-c9ab174a0b59.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\89728c09-073b-4df4-aecf-8e2b090b2728.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\8c8385c7-43d0-4a56-bad8-ff63a32d16fc.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\8c91d6e5-60ce-4c11-9ba7-ae2b5e267a17.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\8cdde2ad-c3c9-44ed-8c95-c71644ff8cf1.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\90d30e15-48f8-4bbe-bbe3-406a5d316bc8.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\92aef77e-6e97-4582-ac88-770c83c0c0af.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\944e102a-8553-4341-8ea2-0cc9805ee6dc.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\960ccb30-35cd-4de8-80b3-5aa9f9a2fbc9.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\98d5bee4-678e-4a4a-b48d-9af5c2b030c7.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\9a9caf36-52a6-4161-b091-93cf367b9d06.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\a19680ac-2604-45b8-9f5c-8b42946fb7c3.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\a5d738e1-d562-457a-8c03-2ebbef19d9a4.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\a618582a-4ba6-4f99-a637-e0a94bf1d14a.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\a949ed98-7d65-4e7c-b27e-271a998c5dcd.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\a9777db5-5567-4d29-8c01-a5224b014a02.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\a9c653a5-e7ab-4689-9bdc-ae30439b48bd.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\a9d3e8ae-acc7-4e7c-9760-b85c615a86ef.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\ae0175f7-c336-4a14-99e7-fb214faf0d8f.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\APPX.2169egdoy7qu5rh34oy90fv8b.tmp
Deleted file - C:\Users\Ripple\AppData\Local\temp\APPX.7lovvdpy3mblafavt9wyc1vkc.tmp
C:\Users\Ripple\AppData\Local\temp\APPX.kwf676q8r6twf8bkzi07nqsid.tmp
Deleted file - C:\Users\Ripple\AppData\Local\temp\APPX.s265uzbfpfah7wm0i0itwjfwh.tmp
C:\Users\Ripple\AppData\Local\temp\APPX.v8kwcn_j_m7mnd4yboxyd047e.tmp
C:\Users\Ripple\AppData\Local\temp\APPX._ez70vzve9365tweu4ympi64f.tmp
Deleted file - C:\Users\Ripple\AppData\Local\temp\b4de437e-e8d7-43ae-8f20-971eac8e48d5.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\b5d9e86a-6e00-4ace-9e48-e63159ae2105.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\b60c01ac-6c78-4cba-8f56-21c2fab12805.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\b9e99d52-a542-483f-84a9-390c97017f56.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\be7ba3ec-3fcc-4d79-a2e1-ca07fcde311c.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\bf2a244a-0153-4a3d-96f9-23bf51c36570.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\c15e2da8-c50c-49c6-8853-1580d39f3fd2.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\c2bace452413230a505b65c1d241e36f-{87A94AB0-E370-4cde-98D3-ACC110C5967D}
Deleted file - C:\Users\Ripple\AppData\Local\temp\c3d7bd22-ea4c-40b9-aaab-4c298545c248.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\c4d819b2-d497-4abb-9f50-de72a85adfc1.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\c4ff978a-8b24-4142-bbf6-906b3a3f209f.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\c6aca8c4-b3f5-47e6-baca-371ffb2b04ff.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\c7d7f1be-8852-42b0-a0f1-cc5d11df12a2.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\c83a8131-6cce-43de-828b-5f1151073217.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\c9015c66-4923-4a86-a0fd-b5e7ade91538.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\cbac82aa-a649-4899-b990-9393ea8c2a15.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\ClearLNK.ini
Deleted file - C:\Users\Ripple\AppData\Local\temp\d0bd2760-c657-497e-acad-5ecd0ee39a1a.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\d0dc2a04-621b-4f2d-96ee-8ce1d95cf0f6.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\d2b3f8f6-c8a8-4b29-b5e7-4733c0823a88.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\d53eaaa9-fb79-4131-892a-47c7f4c44061.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\d5cece84-ea35-47c5-9bce-52f346977511.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\d6830396-a513-4ed4-ad84-f826246fb6dc.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\dd1cc1e5-c9c8-4bfb-a812-09badee09a5f.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\e01e56fe-a4fd-44bc-9004-d85cd2103bb6.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\e12650c9-e916-43e9-a356-488596d824f8.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\e5d4df96-707d-4387-b2b1-8c6a4e1faca9.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\e60f3cf9-fe64-49db-8f32-6fa8c5bbe7d3.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\e6e63636-6238-4bba-a721-a15a6969a253.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\e881c859-4c42-4819-8b4d-62bb71df687c.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\e9a88954-c9b4-4e44-8b0f-9374dc3161a4.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\ed2a61dc-809a-428a-bf0b-22e32796fd1f.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\ef29dbeb-3c17-4e12-9b7f-2c08058f596b.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\f44592c3-f326-46a3-8288-5c35bd50592d.tmp.html
Deleted file - C:\Users\Ripple\AppData\Local\temp\f4c5f64c-f29d-403d-9506-b92ed11a8a5a.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\f59fd667-7f1c-4e58-a928-ba841a6dbb26.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\f6e4fea1-df00-4642-b45b-cb33136d3085.tmp.ico
Deleted file - C:\Users\Ripple\AppData\Local\temp\f7c82924-7b58-4679-9a67-830da1124521.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\f8481d58-863f-40b2-951b-aac7d2841379.tmp.css
Deleted file - C:\Users\Ripple\AppData\Local\temp\fa61fb9b-990e-4828-937b-ee410cf14bf5.tmp.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\faa9cd7c-f566-4cf5-952d-5bed0fb54074.tmp.ttf
Deleted file - C:\Users\Ripple\AppData\Local\temp\fd7efcc0-5fda-41b9-a35b-acaae0b3bf12.tmp.woff2
Deleted file - C:\Users\Ripple\AppData\Local\temp\fddf17ad-c871-4c55-b7b4-8958051cf628.tmp.js
Deleted file - C:\Users\Ripple\AppData\Local\temp\geek64.exe
Deleted file - C:\Users\Ripple\AppData\Local\temp\jna4911560465259692089.hunspell-win-x86-64.dll
Deleted file - C:\Users\Ripple\AppData\Local\temp\jna8232274705723621799.hunspell-win-x86-64.dll
Deleted file - C:\Users\Ripple\AppData\Local\temp\{45B1D970-9886-4A4D-9212-28ADD3F319DD} - OProcSessId.dat
Deleted file - C:\Users\Ripple\AppData\Local\temp\{4E1B62C6-B77E-48EF-9334-E9EE6DC0B96F} - OProcSessId.dat
Deleted file - C:\Users\Ripple\AppData\Local\temp\{B86C5B59-9C82-44EB-8ED2-40A6B223770B} - OProcSessId.dat
Deleted file - C:\Users\Ripple\AppData\Local\temp\{CA82AAAF-6622-47A0-9831-A0225D73F433} - OProcSessId.dat
Deleted file - C:\Users\Ripple\AppData\Local\temp\7zO462FA464\622.csv
Deleted file - C:\Users\Ripple\AppData\Local\temp\8b24d924-537b-459b-a0ab-cc06ba89e145_geek.7z.145\geek.exe
Deleted file - C:\Users\Ripple\AppData\Local\temp\bafc3223-ebf9-45b3-b865-ade479cb0537_geek.7z.537\geek.exe
Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Primary1721209092230134600_6B5745FF-DCF1-4A62-B90D-E6DB8088F33B.log
Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Primary1721209092231158800_6B5745FF-DCF1-4A62-B90D-E6DB8088F33B.log
Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Additional\Additional1721209092231715100_6B5745FF-DCF1-4A62-B90D-E6DB8088F33B.log
Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Additional\Additional1721209092232561400_6B5745FF-DCF1-4A62-B90D-E6DB8088F33B.log
Deleted file - C:\Users\Ripple\AppData\Local\temp\jna-77124\jna10132358105755066225.dll
Deleted file - C:\Users\Ripple\AppData\Local\temp\jna-77124\jna10132358105755066225.dll.x
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632_109146484\2032b01729dfe2104b52920da5d09b0e.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632_109146484\6c9718f1d954c09fb3dc8d410b704522.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632_109146484\71c066cc37aa2518ca6ebfebae2a0e58.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632_109146484\cdf383ff3876c44ae2c876a3579c9387.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632_109146484\f1ff99935cbf2dcc8247ddb580c640c1.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_240717956\6c4e70c602352c04108faae6415f9299.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_240717956\814a388d5d40c07857a4a94a5a6d0281.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_240717956\84d4e23663500c265a42412358bbb81e.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_240717956\a0df42cc9edc6f9eb5d2d0b78d287790.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_240717956\b8e6d1a5e8a307e7a2a5601107b2c420.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_240717956\ca7300b352a09d1fa44864da6f46dcab.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_240717956\de99dc7c3dd658f382a1850e1b439e7c.png
Deleted file - C:\Users\Ripple\AppData\Local\temp\SmartScreen\RemoteData\LastPing
Deleted file - C:\Users\Ripple\AppData\Local\temp\SmartScreen\RemoteData\windowsSettings
Deleted file - C:\Users\Ripple\AppData\Local\temp\SmartScreen\RemoteData\windowsSettings_1.0-7e3544113374bc2769af5f67e125ab81de1b4b64c07fe68e2a7bc03646c85dfc
================== ExportKey: ===================
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\TurnOffAnonymousBlock]
"HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\TurnOffAnonymousBlock" => not found
[HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Run]
"3RVX"="D:\Program Files (x86)\3RVX\3RVX.exe"
"electron.app.BlueStacks Services"="C:\Users\Ripple\AppData\Local\Programs\bluestacks-services\BlueStacksServices.exe --hidden"
"PreMiD"=""C:\Users\Ripple\AppData\Roaming\PreMiD\PreMiD.exe" --hidden"
=== End of ExportKey ===
[HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\RunOnce]
[HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run]
"MicrosoftEdgeAutoLaunch_2D11F281AFD682F6488A744B0F127922"="020000000000000000000000"
"OneDrive"="020000000000000000000000"
"RiotClient"="020000000000000000000000"
"Discord"="03000000d94903f7dccdda01"
"IDMan"="020000000000000000000000"
"3RVX"="020000000000000000000000"
"electron.app.BlueStacks Services"="03000000345b2cb6355bda01"
"SandboxieControl"="020000000000000000000000"
"Synapse3"="03000000c9f6f665ccbbda01"
"PreMiD"="020000000000000000000000"
[HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run32]
"HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run32" => not found
[HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\StartupFolder]
"Rainmeter.lnk"="03000000a5a1eaf5bb2eda01"
"FANTECH X4S MACRO Gaming Mouse.lnk"="030000004a4552ac5136da01"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Defender\Exclusions]
[HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\Extensions]
[HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\IpAddresses]
[HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\Paths]
"C:\Windows\System32\SppExtComObjHook.dll"="0"
"C:\Users\Ripple\AppData\Local\WinRAR"="0"
"C:\Program Files (x86)\Internet Explorer"="0"
"C:\Windows\Microsoft.NET"="0"
[HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\Processes]
"Rar64.exe"="0"
"aspnet_compiler.exe"="0"
"RuntimeBroker.exe"="0"
"CrashReporter.exe"="0"
"RegAsm.exe"="0"
"ngentask.exe"="0"
"WsatConfig.exe"="0"
"taskhostw.exe"="0"
[HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\TemporaryPaths]
FlushDNS => completed
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 12680561 B
Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 395746794 B
Windows/system/drivers => 2096490 B
Edge => 0 B
Chrome => 10721977 B
Firefox => 1162885094 B
Opera => 0 B
Default => 0 B
ProgramData => 0 B
Public => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 2340 B
Ripple => 32536 B
RecycleBin => 0 B
EmptyTemp: => 1.5 GB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 11:04:17 ====
