help, screen making weird pixel things sometimes
loismke
3
24
so i have made my own desktop about 2-3 months ago
amd radeon 5700xt
amd ryzen 5 3600x
asus x570 a pro motherboard
16gb ram
with windows 10
but since a week ago when i was just random watching youtube i got some weird purple squares in my screen (picture attached) and it maybe stays for a few seconds and then goes away it has happened a few times since then. not sure if this is a software or hardware issue.
thx in advance for the help!
i have watched my gpu temps and loads and temps stay around 59degrees and load around 30 when watching a vid
Colored squares usually means the card is failing. Do you get the odd colors during the boot sequence?
no, they only come while gaming or watching youtube they come and dissapear again, and the weird thing is when i take a screebshot they are on the screenshot too
I concur with veeg, hardware is failing.
you could remove the GPU, wipe it down with a brush and wipe the contacts both on the card and in the mobo slot.
reseat it and see how that goes.
if it only happened during YouTube, I would suggest upgrading your browser to the latest version or even trying another browser to verify that fact.
but since you say it's also durng games, that would suggest a faulty graphics card to me.
Reactions: veeg
