Sorry if this is in the wrong place, this is my first time ever posting to a forum
I lent a computer to someone for a couple of months and got it back about a month ago. It wouldn't boot when I got it back, an "Install Windows" error box popped up when the windows spinning thing appeared saying "The computer restarted unexpectedly or encountered an unexpected error. This was the first of my problems. I took the Rx 580 out and put an Rx 480 in, reset the bios by shorting the pins on the motherboard, wiped the drives in the UEFI, and freshly installed windows.
The backstory is over, the issues I'm currently facing are random freezing which sometimes makes my display go to sleep, installing new drivers, and trying to launch a game with OpenGL (Minecraft) which then says the driver does not support OpenGL. Occasionally after that error, adrenaline will give me an error saying driver and software versions do not match.
I've tried using DDU and reinstalling drivers, I've tried using driver easy to bypass adrenaline entirely, I've updated the UEFI and tried again, windows was always up to date, and I've turned off windows automatic driver updates, I've reseated every component, and checked for damage on everything. This is my last resort asking for my specific case, I've looked over other similar cases, but none of the fixes seemed to work, or I couldn't even get close with the computer freezing on me and having to force a shutdown with the power button.
The Rx 580 is now in my personal computer that I took the Rx 480 from, the 580 worked before and after switching, and the 480 worked before also, just not now.
Specs:
Asus tuf gaming b360 pro wifi rev 1
intel core i5-8600
8GB 2666mhz ram
Radeon Rx 480
128 GB Adata m.2 SSD
3 TB Seagate HDD
Specs:
intel core i5-8600
8GB 2666mhz ram
Radeon Rx 480
3 TB Seagate HDD
