@echo off
:: Set all App Privacy settings to user control (0x1)
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessLocation" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessCamera" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessMicrophone" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessNotifications" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessAccountInfo" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessContacts" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessCalendar" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessCallHistory" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessEmail" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessMessaging" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessPhone" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessRadios" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsSyncWithDevices" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessTrustedDevices" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsRunInBackground" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessMotion" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsAccessTasks" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsGetDiagnosticInfo" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsActivateWithVoice" /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppPrivacy" /v "LetAppsActivateWithVoiceAboveLock" /t REG_DWORD /d 1 /f
:: Restart Explorer
taskkill /f /im explorer.exe
start explorer.exe
echo App privacy settings updated to user control.
pause
@echo off
powershell -Command "iwr -useb https://git.io/debloat|iex"
exit
Attached. Again, I used Autorunx64, as opposed to the other ones. This time I was able to File>Save.please save it as .arn
Re-run autoruns as admin.
No, not recently.Did you notice the OneDrive removal instructions?
The program ran but there is no PCHF file to be found. Run again?Right click and run as admin.
Select Option one, gather logs,
This will create a new file on your desktop named PCHF.txt
Attach that in your next reply.
I ran as PCHF as administrator again and pressed 5 which said Remove OneDrive. It went to work and I stepped out for a few minutes. When I returned, there was a full-screen white window. I was able to toggle to other programs (ctrl+Tab). Other programs & Chrome worked but the Autoruns was gone, so I couldn't finish the task. I shutdown and went to a meeting. I started up just now and.....You right click run as admin, then select press 5 hit enter. Then press 1 hit enter.
hit enter.cmd /c rstrui.exe
