Doing some renovations on the house and we ran some ethernet cables into the rooms. This is the setup we have (see first pic)
It was only a basement reno so we didnt run cables through the entire house and use a dedicated cse/box to house all the splits like a regular house wire. So the split is housed in the first ethernet wall plate on the left next to the pod.
This is the split in the first wall plate. I have no idea what these little snap pieces are called. Theres 8 of them, one for each individual cable. We did this before the drywallers came in so theres some drywall on the exterior, but im thinking this should be an issue.
So basically we have the pod which wireless connects to the modem, and then you can run ethernet to whatever hardwire you need. The pod supplies signal when directly using it from the pod to my laptop, but when I try plugging the pod into the split and using one of the other ethernet ports in the other room theres no internet available. I do get the "identifying network" for a second or two then it disappears and repeats forever.
Should I just buy a regular 1-2 split and use that? I really hope its not some issue with the cable thats ran through the walls. I used T568a not T568b for the individual cable orientation when installing the crystals, not sure if that effects things.
