Solved dllhost.exe COM Surrogate /Processid:{49A33422-EFF8-4925-805
Hello @rspulma how are you moving along with the instructions? Have you got an update for us?
Please update this thread within 48 hours, or it will be closed. You can however have it re-opened at any time, by sending a private message to a staff member. :)
Note: This tool will clean your browsing history as well.
  • Download CCleaner from here.
  • After install Click Options.
  • Go to monitoring.
  • Uncheck All Monitoring items.
  • Go to advanced -- Click close program after cleaning.
  • Go to settings -- click run ccleaner when the computer starts.
  • Now that you have ccleaner installed and set-up:
  • Open the program.
  • Go to Tools
  • Go to Startup
  • Now double click each item. To Disable.
  • Leave only your antivirus enabled.
  • Then disable All items in your scheduled task as well.
  • Unless they are related to windows defender.Or your antivirus.
  • Reboot the machine.
Rogue Killer Scan.
Download RogueKiller -- (Portable) -- from one of the following links and save it to your Desktop:
Link 1
Link 2
  • Close all other the running programs
  • Disable ALL Antivirus -- Antimalware -- Applications.
  • Right Click Rogue Killer and Run as Administrator.
  • Click the Start Scan button.
  • Allow the scan to run -- it can take ten minutes or more.
  • Once the scan is complete check All items for removal.
  • upload_2017-2-23_10-55-54-png.1658
  • After All items are checked then press Remove Selected.
  • Wait until the Status box shows Deleting Finished.
  • Click on open report -- then open txt
  • Copy the content of the report and paste it here in your next reply.
JRT Scan.
  • Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.
  • Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.
  • The tool will open and start scanning your system.
  • Please be patient as this can take a while to complete depending on your system's specifications.
  • On completion, a log is saved to your desktop and will automatically open.
  • Please post the JRT log.
Eliminate restrictive settings with this tool.
  • Temporarily disable your antivirus
  • Download SupRestric.exe save to your desktop.
  • Close all running programs.
  • Double click the file to launch it.
  • Windows: 7/8/10 Vista and run as administrator
  • Click Yes at any prompt.
  • The analysis takes only a few moments.
  • The report is on the desktop ( CTR.txt )
  • Copy paste report in next reply.
  • A reboot is needed to complete the repairs.
Adware Cleaner Scan.
  • Close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Scan button.
  • When the scan has finished click on Clean button.
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • Please post the contents of that logfile with your next reply.
  • You can find the logfile at C:\AdwCleaner[S1].txt as well.
Thank you guys! The problem is solved. It wasn't a virus. It was about
c:\Windows\System32\iMobileDisk.dll
I deleted this file and problem is solved. But I think this dll still registered how to unregiter it?..
Should still do the scans...
But there is no need to un register the .dll, deleting is fine.
Glad to have helped!! Please tell a friend ...... or two about us.
Optimize your internet connection.
Click here for instructions.
suggest the following in place of adblock.
Alternate DNS Server. Ad Blocking DNS.
Ublock Origin.
Anti Ad Block Killer.
Also, keep your browsing private with these tools:
Self Destructing Cookies.
Self Destructing Cookies Chrome.
Some items to keep you safe on the internet.
VooDoo Shield. control of what is running on your machine
Qualys BrowserCheck
To update plugins.
Web Of Trust To Avoid Shady Websites.
Unchecky To Avoid Bundled Software.
Privazer To Clean up your mahcine.
Now Lets Clean up the tools we used and remove old restore points.
Download DelFix by "Xplode" to your Desktop.
Right Click the tool and Run as Admin ( Xp Users Double Click)
Put a check mark next the items below:
Remove disinfection tools
Create registry backup
Purge System Restore
Now click on "Run" button.
allow the program to complete its work.
all the tools we used will be removed.
Tool will create and open a log report (DelFix.txt)
Note: The report can be located at the following location C:\DelFix.txt
Reactions: rspulma
