Yes, quite a lot faster than it was beforeThey are having server issues, that is why it may be taking a long time.
The internet for you is running fine other than that?
Do you need to see the scan report?
Of course. I really can't thank you enough for your help!Actually no, just remove anything found.
Can you call this matter solved?
Glad to have helped!! Please tell a friend ...... or two about us.![]()
Optimize your internet connection.
Click here for instructions.
suggest the following in place of adblock.
Alternate DNS Server. Ad Blocking DNS.
Ublock Origin.
Anti Ad Block Killer.
Also, keep your browsing private with these tools:
Self Destructing Cookies.
Self Destructing Cookies Chrome.
Some items to keep you safe on the internet.
Qualys BrowserCheck To update plugins.
Web Of Trust To Avoid Shady Websites.
Unchecky To Avoid Bundled Software.
Privazer To Clean up your mahcine.
Now Lets Clean up the tools we used and remove old restore points.
Download DelFix by "Xplode" to your Desktop.
Right Click the tool and Run as Admin ( Xp Users Double Click)
Put a check mark next the items below:
Remove disinfection tools
Create registry backup
Purge System Restore
Now click on "Run" button.
allow the program to complete its work.
all the tools we used will be removed.
Tool will create and open a log report (DelFix.txt)
Note: The report can be located at the following location C:\DelFix.txt
