Here's the Zoek report:
Zoek.exe v5.0.0.1 Updated 27-09-2015
Tool run by User on 16/02/2017 at 1:34:09.35.
Microsoft Windows XP Professional 5.1.2600 Service Pack 3 x86
Running in: Normal Mode No Internet Access Detected
Launched: C:\Documents and Settings\User\My Documents\Downloads\zoek.exe [Scan all users] [Script inserted]
==== System Restore Info ======================
16/02/2017 01:34:38 Zoek.exe System Restore Point Created Successfully.
==== Reset Hosts File ======================
# Copyright (c) 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
==== Empty Folders Check ======================
C:\Program Files\GRETECH deleted successfully
C:\Program Files\MediaViewV1 deleted successfully
C:\Program Files\MSXML 4.0 deleted successfully
C:\Program Files\TeamViewer deleted successfully
C:\Program Files\VS Revo Group deleted successfully
C:\Program Files\Zemana AntiMalware deleted successfully
C:\Program Files\Common Files\Apple deleted successfully
C:\Program Files\Common Files\Wondershare deleted successfully
C:\Documents and Settings\User\Start Menu\Programs\Iplay Games deleted successfully
C:\Documents and Settings\LocalService\Application Data\Apple Computer deleted successfully
C:\Documents and Settings\NetworkService\Application Data\Apple Computer deleted successfully
C:\Documents and Settings\User\Local Settings\Application Data\WMTools Downloaded Files deleted successfully
==== Deleting CLSID Registry Keys ======================
HKEY_USERS\S-1-5-21-329068152-606747145-1417001333-1003\Software\Microsoft\Internet Explorer\SearchScopes\{A124161E-878F-427F-815E-2075E72F3986} deleted successfully
HKEY_USERS\S-1-5-21-329068152-606747145-1417001333-1003\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{2318C2B1-4965-11D4-9B18-009027A5CD4F} deleted successfully
HKEY_USERS\S-1-5-21-329068152-606747145-1417001333-1003\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{2318C2B1-4965-11D4-9B18-009027A5CD4F} deleted successfully
==== Deleting CLSID Registry Values ======================
HKEY_USERS\S-1-5-21-329068152-606747145-1417001333-1003\Software\Microsoft\Internet Explorer\Approved Extensions\{21EAF666-26B3-4a3c-ABD0-CA2F5A326744} deleted successfully
HKEY_USERS\S-1-5-21-329068152-606747145-1417001333-1003\Software\Microsoft\Internet Explorer\Approved Extensions\{5A60B6BB-FA81-4EFA-AB9C-A820E2143736} deleted successfully
HKEY_USERS\S-1-5-21-329068152-606747145-1417001333-1003\Software\Microsoft\Internet Explorer\Approved Extensions\{34A0D84B-CDDC-4EC4-AFDD-4F1DDE1D14E5} deleted successfully
HKEY_USERS\S-1-5-21-329068152-606747145-1417001333-1003\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\{2318C2B1-4965-11D4-9B18-009027A5CD4F} deleted successfully
==== Deleting Services ======================
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ZAMSvc deleted successfully
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet004\Services\ZAMSvc deleted successfully
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\gusvc deleted successfully
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet004\Services\gusvc deleted successfully
==== Batch Command(s) Run By Tool======================
==== Deleting Files \ Folders ======================
C:\Program Files\GRETECH not found
C:\Program Files\MediaViewV1 not found
C:\Program Files\TeamViewer not found
C:\Program Files\VS Revo Group not found
C:\Program Files\Zemana AntiMalware not found
C:\Program Files\ComPlus Applications deleted
C:\Program Files\WindowsUpdate deleted
C:\Program Files\Driver Support deleted
C:\Program Files\SopCast deleted
C:\extensions.sqlite deleted
C:\extensions.ini deleted
C:\Documents and Settings\NetworkService\Application Data\WB.CFG deleted
C:\DOCUME~1\ALLUSE~1\APPLIC~1\Package Cache deleted
C:\Documents and Settings\User\Local Settings\Application Data\Wondershare deleted
C:\WINDOWS\system32\GroupPolicy\Machine deleted
C:\WINDOWS\system32\GroupPolicy\User deleted
C:\WINDOWS\system32\GroupPolicy\gpt.ini deleted
==== Firefox Extensions Registry ======================
[HKEY_LOCAL_MACHINE\Software\Mozilla\Firefox\Extensions]
"{20a82645-c095-46ed-80e3-08825760534b}"="c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension" [29/11/2013 23:03]
==== Chromium Look ======================
Google Chrome Version: 46.0.2490.86
HKEY_LOCAL_MACHINE\SOFTWARE\Google\Chrome\Extensions
feajbcdehmkchlonkhplmkhhhgokakni - C:\Program Files\MediaViewerV1\MediaViewerV1alpha1260\ch\MediaViewerV1alpha1260.crx[]
flliilndjeohchalpbbcdekjklbdgfkk - No path found[]
ifgdafdnkjbdnofenjbplmnkepdipkcm - C:\Program Files\MediaViewV1\MediaViewV1alpha1343\ch\MediaViewV1alpha1343.crx[]
mlalfllmboedbjfgnlponjjffoogfcii - C:\Program Files\MediaWatchV1\MediaWatchV1home3740\ch\MediaWatchV1home3740.crx[]
njagefbnbldfpnnejeglbbcmimbnnpmk - C:\Program Files\MediaViewV1\MediaViewV1alpha2928\ch\MediaViewV1alpha2928.crx[]
==== Chromium Fix ======================
C:\Documents and Settings\User\Local Settings\Application Data\Google\Chrome\User Data\Default\Local Storage\http_static.user-red.com_0.localstorage deleted successfully
C:\Documents and Settings\User\Local Settings\Application Data\Google\Chrome\User Data\Default\Local Storage\http_static.user-red.com_0.localstorage-journal deleted successfully
==== Set IE to Default ======================
Old Values:
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"Start Page"="
https://uk.search.yahoo.com/"
"Search Page"="
http://www.google.com"
"Search Bar"="
"Use Search Asst"="yes"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main]
"Start Page"="
[HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\SearchUrl]
"Default"="
www.google.com"
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchUrl]
"Default"="
www.google.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\AboutURLs]
"Tabs"="res://ieframe.dll/tabswelcome.htm"
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Search]
"Default_Search_URL"="
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes]
"DefaultScope"="{A124161E-878F-427F-815E-2075E72F3986}"
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{A124161E-878F-427F-815E-2075E72F3986}] not found
New Values:
"Search Page"="
http://go.microsoft.com/fwlink/?LinkId=54896"
"Search Bar"="
"Start Page"="
"Use Search Asst"="no"
"Start Page"="
http://go.microsoft.com/fwlink/?LinkId=69157"
"(Default)"="
http://search.msn.com/results.asp?q=%s"
"(Default)"="
"Tabs"="about:newtab"
"DefaultScope"="{012E1000-F331-11DB-8314-0800200C9A66}"
==== All HKCU SearchScopes ======================
{012E1000-F331-11DB-8314-0800200C9A66} Google Url="
http://www.google.com/search?q={searchTerms}"
{0633EE93-D776-472f-A0FF-E1416B8B2E3A} Bing Url="
http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IE8SRC"
{67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} Google Url="
http://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:{language}:{referrer:source}&ie={inputEncoding?}&oe={outputEncoding?}"
{94D7C464-B759-4591-9F83-837871D3CF50} Google Url="
http://www.google.com/search?q={searchTerms}&rls=com.microsoft:{language}:{referrer:source?}&ie={inputEncoding}&oe={outputEncoding}&sourceid=ie7"
==== Deleting Registry Keys ======================
HKEY_LOCAL_MACHINE\SOFTWARE\Google\Chrome\Extensions\feajbcdehmkchlonkhplmkhhhgokakni deleted successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Google\Chrome\Extensions\ifgdafdnkjbdnofenjbplmnkepdipkcm deleted successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Google\Chrome\Extensions\mlalfllmboedbjfgnlponjjffoogfcii deleted successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Google\Chrome\Extensions\njagefbnbldfpnnejeglbbcmimbnnpmk deleted successfully
==== Empty IE Cache ======================
C:\Documents and Settings\User\Local Settings\Temporary Internet Files\Content.IE5\index.dat will be deleted at reboot
==== Empty FireFox Cache ======================
No FireFox Profiles found
==== Empty Chrome Cache ======================
C:\Documents and Settings\User\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache emptied successfully
==== Empty All Flash Cache ======================
No Flash Cache Found
==== Empty All Java Cache ======================
Java Cache cleared successfully
==== C:\zoek_backup content ======================
C:\zoek_backup (files=134 folders=26 20520027 bytes)
==== Empty Temp Folders ======================
C:\Documents and Settings\Default User\Local Settings\Temp emptied successfully
C:\Documents and Settings\LocalService\Local Settings\Temp emptied successfully
C:\Documents and Settings\NetworkService\Local Settings\Temp emptied successfully
C:\Documents and Settings\User\Local Settings\Temp will be emptied at reboot
C:\WINDOWS\Temp will be emptied at reboot
==== After Reboot ======================
C:\WINDOWS\Temp successfully emptied
C:\DOCUME~1\User\LOCALS~1\Temp successfully emptied
==== Empty Recycle Bin ======================
C:\RECYCLER successfully emptied
==== Deleting Files / Folders ======================
"C:\Documents and Settings\User\Local Settings\Temporary Internet Files\Content.IE5\index.dat" not found
==== EOF on 16/02/2017 at 1:51:18.53 ======================
