To me I would expect an error code if monitors are off before bootingOn a slightly off-topic sidenote, is it possible this has something to do with that VGA warning "Q-LED" my motherboard shoots up when the monitors are not turned on before the computer?
Correct. That is what they should be doingHowever, it should be noted that if they are off, or even unplugged it will come back on
Correct. That is what they should be doingPretty much, all of them flash during the POST,
I completely understand, thank you for you patience.no sweat Pyro, we can keep the thread open a bit longer to see how you go.
but eventually someone will want it closed as threads are closed once they have run their course.
if that happens, you can always start a new one.![]()
If the monitor is off or not plugged in you will get the vga error as it is not getting a post feed back.if they are off, or even unplugged it will come back on, even when plugged into the onboard DP-out on the motherboard.
In direct response to this, you are absolutely right, the light will go away if I put the computer to sleep and then wake it up with the screens on, strange that it wouldn't go away after it starts outputting video.If the monitor is off or not plugged in you will get the vga error as it is not getting a post feed back.
The lights will always flash when the computer is started from a complete shutdown.
The lights are doing exactly what they should be doing.
Monitor off or unplugged means no signal. No signal means error. Error means turn Qled on
