Computer attempts to wake from sleep, and then has issues
Pyro
PCHF Advisor
1,184
239
My computer has recently started having a weird issue that I can't seem to pin down.
When I put it to sleep, the process goes normally, the computer turns off the displays and runs the lights on my KB/M and case fans until it eventually shuts down.
However, when attempting to wake it up, it makes the click noise it usually does, then immediately powers off and restarts(Or at least acts like it's restarting). However, once it has restarted or whatever it does that shuts the fans and peripherals off, there is no output to the monitors, and the keyboard and mouse do not light up of show any signs of functionality. I can tell it's on because the fans are running.
My tower has a reset switch that does not seem to work when this happens, pressing and holding the power button is the only way to get it to reset and bring the display/devices back. This of course greets me with the expected error telling me there was an issue and asking me to boot into BIOS.
I have attempted:
Changing the power plan
Running updates (GPU, Mobo, Windows)
Unplugging/replugging the devices when they are not responding
Changing networking adapter options (Disabling unused ones such as WiFi since I use a LAN cable, and disabling VM connections), I run a virtual machine occasionally.
None of these seem to make the issue better.
Here are my system specs:
Intel i7-8700k
Asus Z390-E Gaming (With a warning Q-LED that seems to indicate a VGA/video problem that I was never able to identify)
EVGA NVidia RTX 2080 Black (This unit was recently received as a refurbished warranty from EVGA, there are no issues with it as far as I can tell)
32 Corsair Vengeance ram running at 3200MHz
Samsung 860 EVO SSD (1TB) (BOOT)
Seagate Barracuda HDD (2TB)
Seasonic FOCUS Plus Platinum 750 W 80+ Platinum (Fully modular)
Peripherals:
Asus TUF Gaming VG279QM (x2) (Running at 240hz not overclocked)
Corsair K70 Mk.2
Corsair Harpoon
A few quick side thoughts:
I have been looking at the "Optional Updates" and wondering if it's possibly one of those, maybe something I have is not as it should be?
I have Windows 10 Home
Version 21H2
OS build 19044.1503
When I got my replacement GPU, I did NOT run DDU, I figured that the card is almost if not completely identical (it did go from a 2 slot to 3 slot card.
Furthermore, I recently enable virtualization on my computer, however, all of these changes have happened the better part of a month ago at this point, nothing I have done recently feels like it should have made and issue like this.
Thank you,
Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
MiniToolBox Scan
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Click Go post the result.
HijackThis.
2- Run the program.
5- Copy paste the log here.
Thank you, here is the requested links/info.
Speccy:
HijackThis:
Code:
Logfile of HiJackThis Fork by Alex Dragokas v.2.10.0.16
Platform:  x64 Windows 10 (Home), 10.0.19044.1503 (ReleaseId: 2009, 21H2), Service Pack: 0
Time:      04.02.2022 - 19:41 (UTC-06:00)
Language:  OS: English (0x409). Display: English (0x409). Non-Unicode: English (0x409)
Elevated:  Yes
Ran by:    Repai    (group: Administrators) on CONSOLE-KILLER, FirstRun: yes
Firefox: 96.0.3.8061
Internet Explorer: 11.0.19041.1202
Default: "C:\Program Files\Mozilla Firefox\firefox.exe" -osint -url "%1" (Firefox)
Boot mode: Normal
Running processes:
Number | Path
   5  C:\Program Files (x86)\ASUS\ArmouryDevice\asus_framework.exe
   1  C:\Program Files (x86)\ASUS\ArmouryDevice\dll\AcPowerNotification\AcPowerNotification.exe
   1  C:\Program Files (x86)\ASUS\ArmouryDevice\dll\ArmourySocketServer\ArmourySocketServer.exe
   1  C:\Program Files (x86)\ASUS\ArmouryDevice\dll\ArmourySocketServer\ArmouryWebBrowserEdge.exe
   1  C:\Program Files (x86)\ASUS\ArmouryDevice\dll\SwAgent\ArmourySwAgent.exe
   1  C:\Program Files (x86)\ASUS\AsusCertService\AsusCertService.exe
   1  C:\Program Files (x86)\ASUS\AsusFanControlService\2.01.12\AsusFanControlService.exe
   1  C:\Program Files (x86)\ASUS\AXSP\4.02.12\atkexComSvc.exe
   1  C:\Program Files (x86)\ASUS\ROG Live Service\ROGLiveService.exe
   1  C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
   1  C:\Program Files (x86)\Common Files\Steam\SteamService.exe
   1  C:\Program Files (x86)\Common Files\VMware\USB\vmware-usbarbitrator64.exe
   1  C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\Corsair.Service.CpuIdRemote64.exe
   1  C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\Corsair.Service.DisplayAdapter.exe
   1  C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\Corsair.Service.exe
   1  C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\CueLLAccessService.exe
   1  C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\iCUE.exe
   1  C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
   1  C:\Program Files (x86)\LightingService\LightingService.exe
   6  C:\Program Files (x86)\Microsoft\EdgeWebView\Application\97.0.1072.76\msedgewebview2.exe
   1  C:\Program Files (x86)\No-IP\ducservice.exe
   1  C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
   1  C:\Program Files (x86)\Origin\OriginWebHelperService.exe
   8  C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe
   1  C:\Program Files (x86)\Steam\steam.exe
   2  C:\Program Files\ASUS\AacExtCard\extensionCardHal_x86.exe
   3  C:\Program Files\ASUS\AacMB\Aac3572MbHal_x86.exe
   1  C:\Program Files\ASUS\ARMOURY CRATE Lite Service\ArmouryCrate.Service.exe
   1  C:\Program Files\ASUS\ARMOURY CRATE Lite Service\ArmouryCrate.UserSessionHelper.exe
   2  C:\Program Files\ASUS\ASUS_Aac_DRAM\Aac3572DramHal_x86.exe
   1  C:\Program Files\ASUS\KINGSTON_Aac_DRAM\AacKingstonDramHal_x64.exe
   2  C:\Program Files\ASUS\KINGSTON_Aac_DRAM\AacKingstonDramHal_x86.exe
   1  C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
   1  C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
   1  C:\Program Files\HPPrintScanDoctor\HPPrintScanDoctorService.exe
   1  C:\Program Files\Intel\WiFi\bin\EvtEng.exe
   1  C:\Program Files\Intel\WiFi\bin\ZeroConfigService.exe
   1  C:\Program Files\LGHUB\lghub_updater.exe
   1  C:\Program Files\Macrium\Common\MacriumService.exe
   1  C:\Program Files\Macrium\Common\ReflectMonitor.exe
   1  C:\Program Files\Macrium\Common\ReflectUI.exe
  13  C:\Program Files\Mozilla Firefox\firefox.exe
   3  C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
   3  C:\Program Files\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
   1  C:\Program Files\NVIDIA Corporation\ShadowPlay\nvsphelper64.exe
   1  C:\Program Files\NZXT CAM\resources\app.asar.unpacked\node_modules\@nzxt\rust-cam\dist\target\x86_64-pc-windows-msvc\release\service.exe
   1  C:\Program Files\Oculus\Support\oculus-runtime\OVRRedir.exe
   1  C:\Program Files\Oculus\Support\oculus-runtime\OVRServer_x64.exe
   1  C:\Program Files\Oculus\Support\oculus-runtime\OVRServiceLauncher.exe
   1  C:\Program Files\WindowsApps\A-Volute.28054DF1F58B4_3.16.21.0_x64__w2gh52qy24etm\SonicRadar3.exe
   1  C:\Program Files\WindowsApps\A-Volute.SonicStudio3_3.16.21.0_x64__w2gh52qy24etm\SonicStudio3.exe
   1  C:\Program Files\WindowsApps\Microsoft.549981C3F5F10_3.2111.12605.0_x64__8wekyb3d8bbwe\Cortana.exe
   1  C:\Program Files\WindowsApps\Microsoft.549981C3F5F10_3.2111.12605.0_x64__8wekyb3d8bbwe\Win32Bridge.Server.exe
   1  C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2021.21090.10008.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
   1  C:\Program Files\WindowsApps\Microsoft.WindowsCalculator_10.2103.8.0_x64__8wekyb3d8bbwe\Calculator.exe
   1  C:\Program Files\WindowsApps\Microsoft.YourPhone_1.21121.250.0_x64__8wekyb3d8bbwe\YourPhone.exe
   1  C:\Program Files\WindowsApps\Microsoft.ZuneMusic_10.21102.11411.0_x64__8wekyb3d8bbwe\Music.UI.exe
   1  C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.21111.10511.0_x64__8wekyb3d8bbwe\Video.UI.exe
   1  C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.2111.5-0\MpCopyAccelerator.exe
   1  C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.2111.5-0\MsMpEng.exe
   1  C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.2111.5-0\NisSrv.exe
   7  C:\Users\Repai\AppData\Local\Discord\app-1.0.9003\Discord.exe
   1  C:\Users\Repai\AppData\Local\NhNotifSys\sonicstudio\asusns.exe
   1  C:\Users\Repai\Downloads\HiJackThis_test\HiJackThis.exe
   1  C:\Windows\explorer.exe
   1  C:\Windows\ImmersiveControlPanel\SystemSettings.exe
   1  C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\PresentationFontCache.exe
   1  C:\Windows\System32\ApplicationFrameHost.exe
   1  C:\Windows\System32\audiodg.exe
   1  C:\Windows\System32\CompPkgSrv.exe
   5  C:\Windows\System32\conhost.exe
   1  C:\Windows\System32\CorsairGamingAudioCfgService64.exe
   2  C:\Windows\System32\csrss.exe
   1  C:\Windows\System32\ctfmon.exe
   2  C:\Windows\System32\dasHost.exe
   3  C:\Windows\System32\dllhost.exe
   1  C:\Windows\System32\DriverStore\FileRepository\dal.inf_amd64_b5484efd38adbe8d\jhi_service.exe
   1  C:\Windows\System32\DriverStore\FileRepository\igcc_dch.inf_amd64_54b736e5be5b50b2\OneApp.IGCC.WinService.exe
   2  C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_31a2adf8c49e7799\Display.NvContainer\NVDisplay.Container.exe
   1  C:\Windows\System32\dwm.exe
   2  C:\Windows\System32\fontdrvhost.exe
   1  C:\Windows\System32\lsass.exe
   1  C:\Windows\System32\msdtc.exe
   1  C:\Windows\System32\NahimicService.exe
   2  C:\Windows\System32\NahimicSvc64.exe
   1  C:\Windows\System32\oobe\UserOOBEBroker.exe
   2  C:\Windows\System32\RtkAudUService64.exe
   1  C:\Windows\System32\rundll32.exe
  10  C:\Windows\System32\RuntimeBroker.exe
   1  C:\Windows\System32\SearchIndexer.exe
   1  C:\Windows\System32\SecurityHealthService.exe
   1  C:\Windows\System32\SecurityHealthSystray.exe
   1  C:\Windows\System32\services.exe
   1  C:\Windows\System32\SettingSyncHost.exe
   1  C:\Windows\System32\SgrmBroker.exe
   1  C:\Windows\System32\sihost.exe
   1  C:\Windows\System32\smartscreen.exe
   1  C:\Windows\System32\smss.exe
   1  C:\Windows\System32\spoolsv.exe
  87  C:\Windows\System32\svchost.exe
   1  C:\Windows\System32\taskhostw.exe
   1  C:\Windows\System32\wbem\unsecapp.exe
   3  C:\Windows\System32\wbem\WmiPrvSE.exe
   1  C:\Windows\System32\wininit.exe
   1  C:\Windows\System32\winlogon.exe
   1  C:\Windows\SystemApps\Microsoft.LockApp_cw5n1h2txyewy\LockApp.exe
   1  C:\Windows\SystemApps\Microsoft.Windows.Search_cw5n1h2txyewy\SearchApp.exe
   1  C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
   1  C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\TextInputHost.exe
   1  C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
   2  C:\Windows\SysWOW64\NahimicSvc32.exe
   1  C:\Windows\SysWOW64\vmnat.exe
   1  C:\Windows\SysWOW64\vmnetdhcp.exe
   1  D:\VMware\VMware Workstation\vmware-authd.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main: [Start Page] = http://dell17win10.msn.com/?pc=DCTE
O2 - HKLM\..\BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre1.8.0_321\bin\jp2ssv.dll
O2 - HKLM\..\BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.8.0_321\bin\ssv.dll
O4 - HKCU\..\Run: [Discord] = C:\Users\Repai\AppData\Local\Discord\Update.exe --processStart Discord.exe
O4 - HKCU\..\StartupApproved\Run: [ConnectDetector] = C:\Users\Repai\AppData\Roaming\Adobe\Connect\connectdetector.exe (file missing) (2021/11/06)
O4 - HKCU\..\StartupApproved\Run: [LGHUB] = C:\Program Files\LGHUB\lghub.exe --background (2020/11/02)
O4 - HKCU\..\StartupApproved\Run: [OneDrive] = C:\Users\Repai\AppData\Local\Microsoft\OneDrive\OneDrive.exe /background (2021/10/30)
O4 - HKCU\..\StartupApproved\Run: [Steam] = C:\Program Files (x86)\Steam\steam.exe -silent (2022/01/07)
O4 - HKLM\..\Run: [Reflect UI] = C:\Program Files\Macrium\Common\ReflectUI.exe
O4 - HKLM\..\Run: [RtkAudUService] = C:\Windows\System32\RtkAudUService64.exe -background
O4 - HKLM\..\StartupApproved\Run32: [TeamsMachineUninstallerLocalAppData] = C:\Users\Repai\AppData\Local\Microsoft\Teams\Update.exe --uninstall --msiUninstall --source=default (2021/04/09)
O4 - HKLM\..\StartupApproved\Run32: [vmware-tray.exe] = D:\VMware\VMware Workstation\vmware-tray.exe (2022/01/30)
O4 - HKU\S-1-5-18\..\Run: [Synapse3] = C:\Program Files (x86)\Razer\Synapse3\WPFUI\Framework\Razer Synapse 3 Host\Razer Synapse 3.exe /StartMinimized (file missing) (User 'LocalSystem')
O4-32 - HKLM\..\Run: [CORSAIR iCUE Software] = C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\iCUE Launcher.exe --autorun
O4-32 - HKLM\..\Run: [SunJavaUpdateSched] = C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
O4-32 - HKLM\..\Run: [TeamsMachineUninstallerProgramData] = C:\ProgramData\Microsoft\Teams\Update.exe --uninstall --msiUninstall --source=default (file missing)
O10 - Unknown file in Winsock LSP: C:\WINDOWS\system32\vsocklib.dll
O15 - Trusted Zone: https://mnscu-files.sharepoint.com
O15 - Trusted Zone: https://mnscu-myfiles.sharepoint.com
O17 - DHCP DNS 1: 75.75.75.75
O17 - DHCP DNS 2: 75.75.76.76
O22 - BITS Job: (download) {0A7E9058-3334-4565-A3F9-A7088C9F3D25} - MicrosoftMapsBingGeoStore - (no URL)
O22 - BITS Job: Fix all (including legit)
O22 - Task (.job): (disabled) (Not scheduled) CreateExplorerShellUnelevatedTask.job - C:\WINDOWS\explorer.exe
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{04779c30-06ac-40bc-a6fc-5a76684360c6} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{04779c30-06ac-40bc-a6fc-5a76684360c6} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{05009524-4e18-4ad5-8a5f-8172470b6f50} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{05009524-4e18-4ad5-8a5f-8172470b6f50} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{06b87bcd-be40-457e-b9f6-c759b0306c45} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{06b87bcd-be40-457e-b9f6-c759b0306c45} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0812cb9e-30c9-497a-87e1-a7d0c301e107} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0812cb9e-30c9-497a-87e1-a7d0c301e107} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0829884a-7983-48ae-b851-bf3a51b2331b} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0829884a-7983-48ae-b851-bf3a51b2331b} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0866ea55-3931-415e-863b-0c1074fb1785} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0866ea55-3931-415e-863b-0c1074fb1785} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0b1714d8-6b48-4af0-94a6-6cff890bb44a} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0b1714d8-6b48-4af0-94a6-6cff890bb44a} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0bc68036-9c4b-4676-aad8-8e82e3b46822} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0bc68036-9c4b-4676-aad8-8e82e3b46822} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0c641e77-dac8-49f9-8659-94d2c56d36ea} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0c641e77-dac8-49f9-8659-94d2c56d36ea} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0cc84d79-ca97-4e82-92f1-57f378b09d50} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0cc84d79-ca97-4e82-92f1-57f378b09d50} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0fb5ba1e-16e0-4b21-ab7b-a51f2a9fa774} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0fb5ba1e-16e0-4b21-ab7b-a51f2a9fa774} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0fd19b9f-d486-4b64-a602-6b2ae753c57d} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0fd19b9f-d486-4b64-a602-6b2ae753c57d} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{12766402-484b-4234-800c-9dd31d1987d2} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{12766402-484b-4234-800c-9dd31d1987d2} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{13d7256c-cebd-4521-95b7-fb0b5cc112d3} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{13d7256c-cebd-4521-95b7-fb0b5cc112d3} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1768daef-9171-4dc8-ae43-65b6f355a1da} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1768daef-9171-4dc8-ae43-65b6f355a1da} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{19593376-5cc9-4499-8299-5fd476420f89} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{19593376-5cc9-4499-8299-5fd476420f89} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1e0f73de-36c9-4296-8c7f-2fa2b0c172bd} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1e0f73de-36c9-4296-8c7f-2fa2b0c172bd} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1f01f9fa-7ee8-4021-b58a-19519106af38} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1f01f9fa-7ee8-4021-b58a-19519106af38} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1f29242d-c222-4756-b966-f39d178cbbf4} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1f29242d-c222-4756-b966-f39d178cbbf4} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{261a60be-aba9-4d8d-9234-b004f7a21d5b} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{261a60be-aba9-4d8d-9234-b004f7a21d5b} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{29c2aa6a-30b4-490e-8b45-c508db57ac33} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{29c2aa6a-30b4-490e-8b45-c508db57ac33} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{2e8f0512-576d-4105-a076-91acca3a68fa} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{2e8f0512-576d-4105-a076-91acca3a68fa} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{2efa0df1-8685-4033-9a02-caf34050f3ca} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{2efa0df1-8685-4033-9a02-caf34050f3ca} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{3482c5f2-216a-4afc-ba9c-8cde768d9359} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{3482c5f2-216a-4afc-ba9c-8cde768d9359} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{36354d23-7234-47b2-8e4b-f13e08a8dd42} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{36354d23-7234-47b2-8e4b-f13e08a8dd42} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{3d43bc53-59e8-4b67-b687-8f01830cf90e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{3d43bc53-59e8-4b67-b687-8f01830cf90e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{3ecc7b60-1f51-4d5e-b410-af685315610e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{3ecc7b60-1f51-4d5e-b410-af685315610e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{40cea54c-9b8d-4b48-b900-4675dce61053} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{40cea54c-9b8d-4b48-b900-4675dce61053} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{474e8431-63fa-43cc-9e65-5eabb2addf8d} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{474e8431-63fa-43cc-9e65-5eabb2addf8d} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{4834802c-53d6-4936-9271-30536c79c148} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{4834802c-53d6-4936-9271-30536c79c148} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{491cca91-f08c-4576-a4eb-151b4110b32a} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{491cca91-f08c-4576-a4eb-151b4110b32a} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{49bf4d38-86b4-452d-8297-10fa1166d73d} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{49bf4d38-86b4-452d-8297-10fa1166d73d} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{4d05a090-16c2-46fd-a831-2469ef602a15} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{4d05a090-16c2-46fd-a831-2469ef602a15} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{54c2b434-23e6-4427-8410-aafc1b20fc63} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{54c2b434-23e6-4427-8410-aafc1b20fc63} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5553d9e5-aa40-4540-ac93-616a3a7610a3} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5553d9e5-aa40-4540-ac93-616a3a7610a3} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5621d0a4-a086-4ca1-80e7-bb3d1d0a5a92} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5621d0a4-a086-4ca1-80e7-bb3d1d0a5a92} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{59eaf14c-6a79-46e5-bc9a-a42835aa2f9e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{59eaf14c-6a79-46e5-bc9a-a42835aa2f9e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5aa5d9d0-ad0a-4f72-b424-a237cb914257} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5aa5d9d0-ad0a-4f72-b424-a237cb914257} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5cdc63b5-4b2a-44db-b266-2ad605d7c291} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5cdc63b5-4b2a-44db-b266-2ad605d7c291} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5ffddc35-7d1e-4000-9e96-17a5e2ea1b97} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{5ffddc35-7d1e-4000-9e96-17a5e2ea1b97} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6166742c-17aa-49ec-93a4-c919715f5c3e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6166742c-17aa-49ec-93a4-c919715f5c3e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{63a155c2-1f83-4245-9fc4-43c1e0ee60af} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{63a155c2-1f83-4245-9fc4-43c1e0ee60af} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{658b04af-2c8a-41a6-8728-6d7ea309d6b2} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{658b04af-2c8a-41a6-8728-6d7ea309d6b2} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{676ef263-e7d5-4604-9313-445345ce5e2f} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{676ef263-e7d5-4604-9313-445345ce5e2f} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6a096986-63b6-4f9d-8563-3135ebe5c5f5} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6a096986-63b6-4f9d-8563-3135ebe5c5f5} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6b08f154-6134-4e28-a2c3-ad03126ffc85} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6b08f154-6134-4e28-a2c3-ad03126ffc85} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6d9be5db-87e9-4c56-89f2-df6c4fe9b7ff} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6d9be5db-87e9-4c56-89f2-df6c4fe9b7ff} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6dfe319d-4ba6-4bdd-afdc-ee1cabe7ee1a} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6dfe319d-4ba6-4bdd-afdc-ee1cabe7ee1a} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{72f7316f-7760-4d4b-949c-38efac366b02} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{72f7316f-7760-4d4b-949c-38efac366b02} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{73529c52-42b8-4593-a68b-fadc9c84e9b5} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{73529c52-42b8-4593-a68b-fadc9c84e9b5} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{744401eb-b9ca-4566-8b4e-3dfd6774aadb} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{744401eb-b9ca-4566-8b4e-3dfd6774aadb} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{764c8a6c-bdc8-404f-847a-0f238214c1a4} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{764c8a6c-bdc8-404f-847a-0f238214c1a4} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{78d99817-3159-416b-b5b9-61dbed8bd976} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{78d99817-3159-416b-b5b9-61dbed8bd976} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{7bc0ba21-48ed-461a-9fa9-9d9a2f1a19d0} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{7bc0ba21-48ed-461a-9fa9-9d9a2f1a19d0} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{81632642-6dcc-4589-bf8d-e783604a08b9} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{81632642-6dcc-4589-bf8d-e783604a08b9} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{83769482-538a-4d49-8151-6b5d5084562e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{83769482-538a-4d49-8151-6b5d5084562e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{839baaa0-11d0-442c-ad87-b88fd1df4656} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{839baaa0-11d0-442c-ad87-b88fd1df4656} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{86138662-baec-40b0-af61-f49af1ec72c6} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{86138662-baec-40b0-af61-f49af1ec72c6} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{866b4bf0-7955-4f75-aa7d-8ff7f7e31581} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{866b4bf0-7955-4f75-aa7d-8ff7f7e31581} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{882ca1b1-03b3-421e-b56f-91f1df2aa54c} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{882ca1b1-03b3-421e-b56f-91f1df2aa54c} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{89600103-6ef9-4758-9ee2-69ddf270e2b5} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{89600103-6ef9-4758-9ee2-69ddf270e2b5} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{89dd01bf-6783-45ad-9c5a-336003b15663} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{89dd01bf-6783-45ad-9c5a-336003b15663} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{89dfccbb-00f2-46b3-85d8-624ec9ae39b6} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{89dfccbb-00f2-46b3-85d8-624ec9ae39b6} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8adac268-fafa-4065-870e-f02ea0b7659d} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8adac268-fafa-4065-870e-f02ea0b7659d} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8af1d410-ee2b-4951-8430-5fdfb4a588f0} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8af1d410-ee2b-4951-8430-5fdfb4a588f0} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8cb117f3-24e3-46b8-b76f-e1fb4c6608bf} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8cb117f3-24e3-46b8-b76f-e1fb4c6608bf} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8f6de2ea-9228-4d68-8a72-ba92ecb400ef} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8f6de2ea-9228-4d68-8a72-ba92ecb400ef} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8f9e2843-64fc-4173-b611-3e6949ab04fe} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8f9e2843-64fc-4173-b611-3e6949ab04fe} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{92605502-e54f-47af-9039-fcb3277b49ba} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{92605502-e54f-47af-9039-fcb3277b49ba} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{95352157-4d90-4c14-98d6-07e2273eb5ee} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{95352157-4d90-4c14-98d6-07e2273eb5ee} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{97eb494b-88d4-48cd-b16e-f71fded7aff8} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{97eb494b-88d4-48cd-b16e-f71fded7aff8} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9a2836b8-be86-4a5f-b450-93dc73195577} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9a2836b8-be86-4a5f-b450-93dc73195577} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9b972b4d-242b-49af-8eea-724628c23c52} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9b972b4d-242b-49af-8eea-724628c23c52} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9c0bb9df-9b04-40bc-ad16-596c06fc7996} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9c0bb9df-9b04-40bc-ad16-596c06fc7996} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9e86177d-f111-4d96-8dcb-633a4ebf614d} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{9e86177d-f111-4d96-8dcb-633a4ebf614d} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a0265856-35ed-40e5-a9cd-e6b34ebfde7c} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a0265856-35ed-40e5-a9cd-e6b34ebfde7c} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a06aeec4-e6c0-453a-850c-aad7081f67e4} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a06aeec4-e6c0-453a-850c-aad7081f67e4} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a0b2b3b0-4eb7-432e-8969-4805388980f4} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a0b2b3b0-4eb7-432e-8969-4805388980f4} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a2746ae5-5196-4873-a98b-dc48ef963805} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a2746ae5-5196-4873-a98b-dc48ef963805} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a28d9865-0176-4e55-982a-d8803ca06b5e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a28d9865-0176-4e55-982a-d8803ca06b5e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a58ba9b4-ac2a-41ec-83bc-b37a87d63b90} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a58ba9b4-ac2a-41ec-83bc-b37a87d63b90} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a6aaddff-6450-40ec-b947-f0d6e71ea131} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a6aaddff-6450-40ec-b947-f0d6e71ea131} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a6ca0dc3-12c6-4e52-ad23-888a71437ce7} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a6ca0dc3-12c6-4e52-ad23-888a71437ce7} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a71971e8-83a7-4c77-8e37-a3427a2b3714} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a71971e8-83a7-4c77-8e37-a3427a2b3714} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a8850d2e-861c-4353-9f72-34f270ccf423} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{a8850d2e-861c-4353-9f72-34f270ccf423} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{aa198217-6c50-471b-a60f-1d051c2bf4c2} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{aa198217-6c50-471b-a60f-1d051c2bf4c2} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ac3f1bce-fa7d-47d6-a355-24bb912d59ac} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ac3f1bce-fa7d-47d6-a355-24bb912d59ac} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ad38f978-23c7-4a45-84fb-1fe26db7d01f} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ad38f978-23c7-4a45-84fb-1fe26db7d01f} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ad630628-a459-436c-8cb5-611f5b0bdb10} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ad630628-a459-436c-8cb5-611f5b0bdb10} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ada70400-1bda-44b4-9539-247ffeb7d435} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ada70400-1bda-44b4-9539-247ffeb7d435} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{adbf7563-558f-442f-9c91-b2fe405f52ce} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{adbf7563-558f-442f-9c91-b2fe405f52ce} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ae48f10d-aed6-4bae-a552-26875927903e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ae48f10d-aed6-4bae-a552-26875927903e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{afc8e390-7693-47cd-a3dc-3ba7b10d0733} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{afc8e390-7693-47cd-a3dc-3ba7b10d0733} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b0e1c570-82bf-4e14-aa16-5fda4c647e8c} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b0e1c570-82bf-4e14-aa16-5fda4c647e8c} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b1049737-8674-4a7d-9b7c-7d114581c825} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b1049737-8674-4a7d-9b7c-7d114581c825} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b248d6e9-355c-4fec-b82c-486a1b43b2c9} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b248d6e9-355c-4fec-b82c-486a1b43b2c9} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b2fb4324-7771-445f-a089-215da3e422c7} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b2fb4324-7771-445f-a089-215da3e422c7} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b3d35c0c-7e17-4a20-ba98-f526c6092d13} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b3d35c0c-7e17-4a20-ba98-f526c6092d13} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b4ed3618-3de4-4444-9fb2-6ea0132d6c46} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b4ed3618-3de4-4444-9fb2-6ea0132d6c46} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b6ade9da-67e0-4ca8-89f2-45635db9569d} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b6ade9da-67e0-4ca8-89f2-45635db9569d} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b7121513-17ea-4683-9a31-ac135907d4c8} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b7121513-17ea-4683-9a31-ac135907d4c8} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b8f92ea8-3d20-499c-a233-8a94ead7e484} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b8f92ea8-3d20-499c-a233-8a94ead7e484} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b989d91d-50db-457d-91fc-5c0ec6a6b23a} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{b989d91d-50db-457d-91fc-5c0ec6a6b23a} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ba061a8e-0092-41b7-9b92-acdb32369a08} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ba061a8e-0092-41b7-9b92-acdb32369a08} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{bada7beb-c5a7-41d0-8e84-82d7949aa0af} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{bada7beb-c5a7-41d0-8e84-82d7949aa0af} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{bef1048b-ca65-4d64-96ea-39c748fc09df} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{bef1048b-ca65-4d64-96ea-39c748fc09df} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{bf4851cd-5fb5-4464-bf2a-aac3133140ab} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{bf4851cd-5fb5-4464-bf2a-aac3133140ab} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c0944ecd-c1d7-4e96-b33a-f9cad6959297} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c0944ecd-c1d7-4e96-b33a-f9cad6959297} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c0c00fae-44b7-405e-a74b-7645503e1c42} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c0c00fae-44b7-405e-a74b-7645503e1c42} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c3edcaec-0e46-4799-a87a-124d9fe4856c} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c3edcaec-0e46-4799-a87a-124d9fe4856c} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c4519dd4-0d45-4aed-a040-94d5567f2c68} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c4519dd4-0d45-4aed-a040-94d5567f2c68} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c50ed1db-e505-4d9d-a3fd-c7c31c8dc8b9} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c50ed1db-e505-4d9d-a3fd-c7c31c8dc8b9} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c8682efe-3279-4091-a333-072e241a5745} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{c8682efe-3279-4091-a333-072e241a5745} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ca5f061d-d96e-40bc-b313-9af34d92a764} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ca5f061d-d96e-40bc-b313-9af34d92a764} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{cae9712a-b94a-4205-9e4d-a50c1b04c808} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{cae9712a-b94a-4205-9e4d-a50c1b04c808} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{caedc023-fcd1-457e-b156-12d3f67f115e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{caedc023-fcd1-457e-b156-12d3f67f115e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{cef4611b-1850-4465-a934-c75775d31dfa} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{cef4611b-1850-4465-a934-c75775d31dfa} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d0a0b63d-5b54-4f4f-8d3f-4f07bdfb38e0} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d0a0b63d-5b54-4f4f-8d3f-4f07bdfb38e0} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d1976e48-b857-4a16-b352-85156c4d8a9b} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d1976e48-b857-4a16-b352-85156c4d8a9b} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d25a32ab-ef41-44cd-b04c-ba0a1c8ca1c2} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d25a32ab-ef41-44cd-b04c-ba0a1c8ca1c2} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d2f8c650-8640-4692-b5e9-18f1856ad142} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d2f8c650-8640-4692-b5e9-18f1856ad142} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d36099c6-c104-4c41-b076-a01839318c9e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d36099c6-c104-4c41-b076-a01839318c9e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d575db22-3765-4bbf-b4d1-464cd1bd983f} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d575db22-3765-4bbf-b4d1-464cd1bd983f} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d5aaecc3-f9b1-462d-af9d-75271684797f} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d5aaecc3-f9b1-462d-af9d-75271684797f} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d7916e1a-2783-485c-9b2c-9d7048f48612} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d7916e1a-2783-485c-9b2c-9d7048f48612} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d7f86ca7-0e44-4ac1-b3ff-4991c69e56e0} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d7f86ca7-0e44-4ac1-b3ff-4991c69e56e0} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d9b7303c-7046-4390-bd3f-afdce148c553} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{d9b7303c-7046-4390-bd3f-afdce148c553} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{dc425f46-3a57-4ab7-8746-9d60b2ab39e5} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{dc425f46-3a57-4ab7-8746-9d60b2ab39e5} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ddef15f2-b8a4-43be-ad7f-7417f42cc28e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ddef15f2-b8a4-43be-ad7f-7417f42cc28e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{df5a7fc6-7b51-40e2-b259-bd932ea1eb5c} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{df5a7fc6-7b51-40e2-b259-bd932ea1eb5c} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e0c07065-3e0e-42b0-9bba-324176fe9236} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e0c07065-3e0e-42b0-9bba-324176fe9236} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e1f96352-6f70-41bd-b125-6f6162f134df} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e1f96352-6f70-41bd-b125-6f6162f134df} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e2d5cbc4-4748-4521-9b9d-94db542f69df} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e2d5cbc4-4748-4521-9b9d-94db542f69df} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e8540601-74b4-4d77-8b20-ef1293536c20} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{e8540601-74b4-4d77-8b20-ef1293536c20} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ecf45013-4129-4ee5-87f8-7125e65a22a4} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ecf45013-4129-4ee5-87f8-7125e65a22a4} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{edeac079-3c10-4bce-afa7-42b30caf41ad} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{edeac079-3c10-4bce-afa7-42b30caf41ad} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{edf6f9b3-5ad2-4be1-b984-e7ea994eb621} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{edf6f9b3-5ad2-4be1-b984-e7ea994eb621} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ee9b47a3-7708-4c2b-a511-882e34dd51df} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ee9b47a3-7708-4c2b-a511-882e34dd51df} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ef08ed3c-1e80-44a5-a661-64afbb73f86b} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ef08ed3c-1e80-44a5-a661-64afbb73f86b} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f0ad19d3-8b40-46e7-99a4-05af0831614e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f0ad19d3-8b40-46e7-99a4-05af0831614e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f1b288dc-7b47-4cff-aab2-c092daaeea3e} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f1b288dc-7b47-4cff-aab2-c092daaeea3e} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f51b1f87-404c-43dc-9530-81aad8abc65b} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f51b1f87-404c-43dc-9530-81aad8abc65b} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f6be10b1-dbc8-4376-aa55-b82a79fe8bad} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f6be10b1-dbc8-4376-aa55-b82a79fe8bad} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f6e2a06a-93bf-4e93-bdc7-12336b3281b3} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f6e2a06a-93bf-4e93-bdc7-12336b3281b3} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f9950e19-698e-4adb-bdcd-bcd34c93b012} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{f9950e19-698e-4adb-bdcd-bcd34c93b012} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{fb087f1e-1c4e-43bd-826d-ac3516f58135} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{fb087f1e-1c4e-43bd-826d-ac3516f58135} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{fb839a05-c2f2-4166-ab4e-e2d90efc92a2} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{fb839a05-c2f2-4166-ab4e-e2d90efc92a2} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{fcdc2f6e-6518-41b4-8a2b-3d1f1fbf318b} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{fcdc2f6e-6518-41b4-8a2b-3d1f1fbf318b} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ff037226-9a84-40c7-8b23-8f25b24d4744} -  (no xml)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ff037226-9a84-40c7-8b23-8f25b24d4744} - (no key)
O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\HP (empty)
O22 - Task: (disabled) \Agent Activation Runtime\S-1-5-21-2397946789-4143666385-3375303073-1001 - C:\WINDOWS\System32\AgentActivationRuntimeStarter.exe
O22 - Task: (disabled) \Microsoft\Windows\Management\Provisioning\Retry - C:\WINDOWS\system32\ProvTool.exe /turn 5 /source ProvRetryTask (Microsoft)
O22 - Task: (disabled) \Microsoft\Windows\Management\Provisioning\RunOnReboot - C:\WINDOWS\system32\ProvTool.exe /turn 5 /source ContinueSessionTask (Microsoft)
O22 - Task: (disabled) \Microsoft\Windows\UpdateOrchestrator\Schedule Maintenance Work - C:\WINDOWS\system32\usoclient.exe StartMaintenanceWork (Microsoft)
O22 - Task: (disabled) \Microsoft\Windows\UpdateOrchestrator\Schedule Wake To Work - C:\WINDOWS\system32\usoclient.exe StartWork (Microsoft)
O22 - Task: (disabled) \S-1-5-21-2397946789-4143666385-3375303073-1001\DataSenseLiveTileTask - C:\WINDOWS\System32\DataUsageLiveTileTask.exe
O22 - Task: (telemetry) \Microsoft\Office\OfficeTelemetryAgentFallBack2016 - C:\Program Files (x86)\Microsoft Office\root\Office16\msoia.exe scan upload mininterval:2880 (Microsoft)
O22 - Task: (telemetry) \Microsoft\Office\OfficeTelemetryAgentLogOn2016 - C:\Program Files (x86)\Microsoft Office\root\Office16\msoia.exe scan upload (Microsoft)
O22 - Task: (telemetry) \Microsoft\Windows\Application Experience\PcaPatchDbTask - C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\system32\PcaSvc.dll,PcaPatchSdbTask (Microsoft)
O22 - Task: (telemetry) NvTmRep_CrashReport1_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\NvBackend\NvTmRep.exe
O22 - Task: (telemetry) NvTmRep_CrashReport2_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\NvBackend\NvTmRep.exe
O22 - Task: (telemetry) NvTmRep_CrashReport3_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\NvBackend\NvTmRep.exe
O22 - Task: (telemetry) NvTmRep_CrashReport4_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\NvBackend\NvTmRep.exe
O22 - Task: \ASUS\AcPowerNotification - C:\Program Files (x86)\ASUS\ArmouryDevice\dll\AcPowerNotification\AcPowerNotification.exe
O22 - Task: \ASUS\ArmouryAIOFanServer - C:\Program Files (x86)\ASUS\ArmouryDevice\dll\AIOFanSDK\ArmouryAIOFanServer.exe (file missing)
O22 - Task: \ASUS\ArmourySocketServer - C:\Program Files (x86)\ASUS\ArmouryDevice\dll\ArmourySocketServer\ArmourySocketServer.exe
O22 - Task: \ASUS\ASUSUpdateTaskMachineCore1d54007bde24789 - C:\Program Files (x86)\ASUS\Update\AsusUpdate.exe /c
O22 - Task: \ASUS\ASUSUpdateTaskMachineUA - C:\Program Files (x86)\ASUS\Update\AsusUpdate.exe /ua /installsource scheduler
O22 - Task: \ASUS\Framework Service - C:\Program Files (x86)\ASUS\ArmouryDevice\asus_framework.exe
O22 - Task: \ASUS\NoiseCancelingEngine - C:\Program Files (x86)\ASUS\ArmouryDevice\dll\MBLedSDK\NoiseCancelingEngine.exe
O22 - Task: \ASUS\P508PowerAgent_sdk - C:\Program Files (x86)\ASUS\ArmouryDevice\dll\ShareFromArmouryIII\Mouse\ROG STRIX CARRY\P508PowerAgent.exe (file missing)
O22 - Task: \Microsoft\Office\Office Serviceability Manager - C:\Program Files\Common Files\Microsoft Shared\ClickToRun\officesvcmgr.exe /checkin (Microsoft)
O22 - Task: \Mozilla\Firefox Background Update 308046B0AF4A39CB - C:\Program Files\Mozilla Firefox\firefox.exe --MOZ_LOG sync,prependheader,timestamp,append,maxsize:1,Dump:5 --MOZ_LOG_FILE C:\ProgramData\Mozilla\updates\308046B0AF4A39CB\backgroundupdate.moz_log --backgroundtask backgroundupdate
O22 - Task: \Mozilla\Firefox Default Browser Agent 308046B0AF4A39CB - C:\Program Files\Mozilla Firefox\default-browser-agent.exe do-task "308046B0AF4A39CB"
O22 - Task: Intel PTT EK Recertification - C:\WINDOWS\System32\DriverStore\FileRepository\iclsclient.inf_amd64_76523213b78d9046\lib\IntelPTTEKRecertification.exe
O22 - Task: NahimicSvc32Run - C:\WINDOWS\SysWOW64\NahimicSvc32.exe $(Arg0) $(Arg1) $(Arg2) $(Arg3) $(Arg4) $(Arg5) $(Arg6) $(Arg7)
O22 - Task: NahimicSvc64Run - C:\WINDOWS\system32\NahimicSvc64.exe $(Arg0) $(Arg1) $(Arg2) $(Arg3) $(Arg4) $(Arg5) $(Arg6) $(Arg7)
O22 - Task: NahimicTask32 - C:\WINDOWS\system32\..\SysWOW64\NahimicSvc32.exe $(Arg0) $(Arg1) $(Arg2) $(Arg3) $(Arg4) $(Arg5) $(Arg6) $(Arg7)
O22 - Task: NahimicTask64 - C:\WINDOWS\system32\.\NahimicSvc64.exe $(Arg0) $(Arg1) $(Arg2) $(Arg3) $(Arg4) $(Arg5) $(Arg6) $(Arg7)
O22 - Task: NvDriverUpdateCheckDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe -d "C:\Program Files\NVIDIA Corporation\NvDriverUpdateCheck" -l 3 -f C:\ProgramData\NVIDIA\NvContainerDriverUpdateCheck.log
O22 - Task: NVIDIA GeForce Experience SelfUpdate_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA GeForce Experience.exe
O22 - Task: NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe --launcher=TaskScheduler
O22 - Task: NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe
O22 - Task: NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe
O22 - Task: OneDrive Reporting Task-S-1-5-21-2397946789-4143666385-3375303073-1001 - C:\Users\Repai\AppData\Local\Microsoft\OneDrive\OneDriveStandaloneUpdater.exe /reporting
O23 - Service R2: ARMOURY CRATE Service - (ArmouryCrateService) - C:\Program Files\ASUS\ARMOURY CRATE Lite Service\ArmouryCrate.Service.exe
O23 - Service R2: ASUS Com Service - (asComSvc) - C:\Program Files (x86)\ASUS\AXSP\4.02.12\atkexComSvc.exe
O23 - Service R2: AsusCertService - C:\Program Files (x86)\ASUS\AsusCertService\AsusCertService.exe
O23 - Service R2: AsusFanControlService - C:\Program Files (x86)\ASUS\AsusFanControlService\2.01.12\AsusFanControlService.exe
O23 - Service R2: CAM Service - (CAMService) - C:\Program Files\NZXT CAM\resources\app.asar.unpacked\node_modules\@nzxt\rust-cam\dist\target\x86_64-pc-windows-msvc\release\service.exe
O23 - Service R2: Corsair Gaming Audio Configuration Service - (CorsairGamingAudioConfig) - C:\Windows\System32\CorsairGamingAudioCfgService64.exe
O23 - Service R2: Corsair LLA Service - (CorsairLLAService) - C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\CueLLAccessService.exe
O23 - Service R2: Corsair Service - (CorsairService) - C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\Corsair.Service.exe
O23 - Service R2: HP Print Scan Doctor Service - (HPPrintScanDoctorService) - C:\Program Files\HPPrintScanDoctor\HPPrintScanDoctorService.exe
O23 - Service R2: Intel(R) Dynamic Application Loader Host Interface Service - (jhi_service) - C:\WINDOWS\System32\DriverStore\FileRepository\dal.inf_amd64_b5484efd38adbe8d\jhi_service.exe
O23 - Service R2: Intel(R) Graphics Command Center Service - (igccservice) - C:\WINDOWS\System32\DriverStore\FileRepository\igcc_dch.inf_amd64_54b736e5be5b50b2\OneApp.IGCC.WinService.exe
O23 - Service R2: Intel(R) Management and Security Application Local Management Service - (LMS) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service R2: Intel(R) PROSet/Wireless Event Log - (EvtEng) - C:\Program Files\Intel\WiFi\bin\EvtEng.exe
O23 - Service R2: Intel(R) PROSet/Wireless Registry Service - (RegSrvc) - C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
O23 - Service R2: Intel(R) PROSet/Wireless Zero Configuration Service - (ZeroConfigService) - C:\Program Files\Intel\WiFi\bin\ZeroConfigService.exe
O23 - Service R2: LGHUB Updater Service - (LGHUBUpdaterService) - C:\Program Files\LGHUB\lghub_updater.exe --run-as-service
O23 - Service R2: LightingService - C:\Program Files (x86)\LightingService\LightingService.exe
O23 - Service R2: Macrium Service - (MacriumService) - C:\Program Files\Macrium\Common\MacriumService.exe
O23 - Service R2: Nahimic service - (NahimicService) - C:\WINDOWS\system32\NahimicService.exe
O23 - Service R2: NO-IP DUC v4.1.1 - (NoIPDUCService4) - C:\Program Files (x86)\No-IP\ducservice.exe
O23 - Service R2: NVIDIA Display Container LS - (NVDisplay.ContainerLocalSystem) - C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_31a2adf8c49e7799\Display.NvContainer\NVDisplay.Container.exe -s NVDisplay.ContainerLocalSystem -f C:\ProgramData\NVIDIA\NVDisplay.ContainerLocalSystem.log -l 3 -d C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_31a2adf8c49e7799\Display.NvContainer\plugins\LocalSystem -r -p 30000 -cfg NVDisplay.ContainerLocalSystem\LocalSystem
O23 - Service R2: NVIDIA LocalSystem Container - (NvContainerLocalSystem) - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe -s NvContainerLocalSystem -f "C:\ProgramData\NVIDIA\NvContainerLocalSystem.log" -l 3 -d "C:\Program Files\NVIDIA Corporation\NvContainer\plugins\LocalSystem" -r -p 30000 -st "C:\Program Files\NVIDIA Corporation\NvContainer\NvContainerTelemetryApi.dll"
O23 - Service R2: Oculus VR Runtime Service - (OVRService) - C:\Program Files\Oculus\Support\oculus-runtime\OVRServiceLauncher.exe
O23 - Service R2: Origin Web Helper Service - C:\Program Files (x86)\Origin\OriginWebHelperService.exe
O23 - Service R2: Realtek Audio Universal Service - (RtkAudioUniversalService) - C:\WINDOWS\System32\RtkAudUService64.exe
O23 - Service R2: ROG Live Service - C:\Program Files (x86)\ASUS\ROG Live Service\ROGLiveService.exe
O23 - Service R2: VMware Authorization Service - (VMAuthdService) - D:\VMware\VMware Workstation\vmware-authd.exe
O23 - Service R2: VMware DHCP Service - (VMnetDHCP) - C:\WINDOWS\SysWOW64\vmnetdhcp.exe
O23 - Service R2: VMware NAT Service - C:\WINDOWS\SysWOW64\vmnat.exe
O23 - Service R2: VMware USB Arbitration Service - (VMUSBArbService) - C:\Program Files (x86)\Common Files\VMware\USB\vmware-usbarbitrator64.exe
O23 - Service R3: Steam Client Service - C:\Program Files (x86)\Common Files\Steam\SteamService.exe /RunAsService
O23 - Service S2: ASUS Update Service (asus) - (asus) - C:\Program Files (x86)\ASUS\Update\AsusUpdate.exe /svc
O23 - Service S2: AsusUpdateCheck - C:\WINDOWS\System32\AsusUpdateCheck.exe
O23 - Service S2: Intel(R) Content Protection HDCP Service - (cplspcon) - C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\IntelCpHDCPSvc.exe
O23 - Service S2: Intel(R) HD Graphics Control Panel Service - (igfxCUIService2.0.0.0) - C:\WINDOWS\System32\DriverStore\FileRepository\cui_dch.inf_amd64_b8e01d9e8716d2a7\igfxCUIService.exe
O23 - Service S2: Intel(R) TPM Provisioning Service - C:\WINDOWS\System32\DriverStore\FileRepository\iclsclient.inf_amd64_76523213b78d9046\lib\TPMProvisioningService.exe
O23 - Service S3: ASUS Update Service (asusm) - (asusm) - C:\Program Files (x86)\ASUS\Update\AsusUpdate.exe /medsvc
O23 - Service S3: BattlEye Service - (BEService) - C:\Program Files (x86)\Common Files\BattlEye\BEService.exe
O23 - Service S3: Easy Anti-Cheat (Epic Online Services) - (EasyAntiCheat_EOS) - C:\Program Files (x86)\EasyAntiCheat_EOS\EasyAntiCheat_EOS.exe
O23 - Service S3: Intel(R) Capability Licensing Service TCP IP Interface - C:\WINDOWS\System32\DriverStore\FileRepository\iclsclient.inf_amd64_76523213b78d9046\lib\SocketHeciServer.exe
O23 - Service S3: Intel(R) Content Protection HECI Service - (cphs) - C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\IntelCpHeciSvc.exe
O23 - Service S3: Mozilla Maintenance Service - (MozillaMaintenance) - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe
O23 - Service S3: NVIDIA FrameView SDK service - (FvSvc) - C:\Program Files\NVIDIA Corporation\FrameViewSDK\nvfvsdksvc_x64.exe -service
O23 - Service S3: Oculus VR Library Service - (OVRLibraryService) - C:\Program Files\Oculus\Support\oculus-librarian\OVRLibraryService.exe
O23 - Service S3: Origin Client Service - C:\Program Files (x86)\Origin\OriginClientService.exe
O23 - Service S3: Rockstar Game Library Service - (Rockstar Service) - C:\Program Files\Rockstar Games\Launcher\RockstarService.exe
O23 - Service S3: Wireless PAN DHCP Server - (MyWiFiDHCPDNS) - C:\Program Files\Intel\WiFi\bin\PanDhcpDns.exe
End of file - Time spent: 11.7 sec. - 135054 bytes, CRC32: FFFFFFFF. Sign: ፔᎼ
My apologies, I looked right past that part.
Here it is:
Uninstall the following.
ASUS Update Helper (Hidden)
You can use Geek Uninstaller or D-Uninstaller to see hidden entries.
Disable Useless Startups.
  1. Download CCleaner from here.
  2. After installing click options.
  3. Go to monitoring.
  4. Uncheck all monitoring items.
  5. Go to advanced tab -- Click close program after cleaning.
  6. Go to settings -- Click run Ccleaner when the computer starts.
  7. Now that you have Ccleaner installed and set-up:
  8. Open the program.
  9. Go to Tools
  10. Go to Startup
  11. Now double click each item. To Disable.
  12. Leave only your antivirus enabled.
In your case. Leave only.
Steam - One Drive -and windows defender enabled.
  1. Then disable All items in your Scheduled Task as well.
  2. Unless they are related to Windows Defender -- Or your Antivirus.
Resetting your Hosts File
  1. Click here to download RstHosts v2.0\
  2. Save the file to your desktop.
  3. Right Click and Run as Administrator.
  4. Click on Restaurer, then click OK at the prompt.
  5. This will restore the default host file.
  • Close all open programs and internet browsers.
  • Right Click on adwcleaner.exe and run as admin to run the tool.
  • Click on Scan button.
  • When the scan has finished click on Clean button.
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • Please ATTACH the contents of that logfile with your next reply.
  • You can find the logfile at C:\AdwCleaner[S1].txt as well.
Should I be doing this all in one attempt or take it task by task testing to see if anything changes?
Thank you,
Just knock it all out, if you want something starting up with the machine you can just go back into CCleaner and re-enble it. Having all these things running on your machine is pointless. You can start them when you need to. Sort of like leaving lights on in your home when you are gone, benefits no one except the power company. Just wasting resources. And in my experience, whenever I am paid to fix an issue on a computer I always start with the simple stuff like I am having you do .
One last quick question before I jump into it,
What is the difference between using CCleaner and just disabling startup programs through Task Manager?
Can any of this be done through windows without the use of external programs or does it just make it easier? I'm not opposed to it either way.
Just easier. Also, CCleaner if configured as I suggest, can keep your machine clean of Temp files each time you boot the machine.
I see, if I were to uninstall it afterwords, would that be alright as well?
It is your computer, I would not care if you tossed it from a moving car on the freeway. (Joking of course) This is only to see if we can pin down the issue. :)
Reactions: Pyro
I wouldn't do that, I could lose my license!
Understood, I'm not a fan of anything really extra unless strictly necessary, I'll get right on that stuff you suggested earlier and keep you posted.
Thank you,
Reactions: Malnutrition
I understand.
Also, if you want you could just create a restore point before you jump in, and if things do not improve just restore the machine to that point. :)
In the process of doing this, I was able to uninstall Mozilla Maintenance Service, but nothing shows up under ASUS Update Helper when using Geek Uninstaller.
I see ASUS Framework service and ASUS Motherboard, but nothing else?
Followed through the rest of this, here is the requested log files:
