Tip
If using a computer and not a mobile phone, please avoid adding multiple posts
while waiting for us to reply to your last, edit your last post to include anything that you wish to add, this will ensure nothing gets overlooked which can sometimes happen if a thread has more than one page.
Weird, you seem to have Fat 32 file system info on the HDD,
any idea how this has come to be as Fat 32 is normally associated with USB devices.
Before we suggest anything can you answer the above question for us.
We need to first check the integrity of the HDD and then Windows itself, we can`t use the info in the second dmp file atm because the info is not reliable but fwiw a problem between the AV and Nvidea drivers was partially to blame.
Some info
here regarding the error being flagged up in the first dmp.
Debug session time: Fri Dec 21 03:45:31.917 2018 (UTC - 5:00)
System Uptime: 0 days 21:34:21.709
* Bugcheck Analysis *
CACHE_MANAGER (34)
See the comment for FAT_FILE_SYSTEM (0x23)
Arguments:
Arg1: 0000000000051352
Arg2: fffff98d9d27edf8
Arg3: fffff98d9d27e640
Arg4: fffff80261e8f001
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff80261e1d000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 0
EXCEPTION_RECORD: fffff98d9d27edf8 -- (.exr 0xfffff98d9d27edf8)
ExceptionAddress: fffff80261e8f001 (nt+0x0000000000072001)
ExceptionCode: c000001d (Illegal instruction)
ExceptionFlags: 00000000
NumberParameters: 0
CONTEXT: fffff98d9d27e640 -- (.cxr 0xfffff98d9d27e640)
rax=fffff98d9d27f220 rbx=0000000000000003 rcx=fffff98d9d27f220
rdx=fffff98d9d27f220 rsi=0000000000000000 rdi=fffff98d9d27f140
rip=fffff80261e8f001 rsp=fffff98d9d27f038 rbp=0000000000000001
r8=0000007ffffffff8 r9=0000000000000000 r10=0000000fffffffff
r11=0000000000000001 r12=fffff45dc7962800 r13=000000000000000f
r14=fffff98d9d27f220 r15=ffffcb82bc1cb208
iopl=0 nv up ei ng nz na pe nc
cs=0010 ss=0000 ds=002b es=002b fs=0053 gs=002b efl=00010282
nt+0x72001:
fffff802`61e8f001 0fb78170010000 movzx eax,word ptr [rcx+170h] ds:002b:fffff98d`9d27f390=0010
Resetting default scope
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x34
CURRENT_IRQL: 0
EXCEPTION_STR: 0x0
LAST_CONTROL_TRANSFER: from fffff8026201b8ad to fffff80261e8f001
STACK_TEXT:
fffff98d`9d27f038 fffff802`6201b8ad : 00000000`00000000 fffff802`6288ca84 00001f80`0010000f 0053002b`002b0010 : nt+0x72001
fffff98d`9d27f040 00000000`00000000 : fffff802`6288ca84 00001f80`0010000f 0053002b`002b0010 00000202`0000002b : nt+0x1fe8ad
FOLLOWUP_IP:
nt+72001
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt+72001
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
STACK_COMMAND: .cxr 0xfffff98d9d27e640 ; kb
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
