Solved Broadcaster Channel pop-ups
Download DelFix by "Xplode" to your Desktop.
Right Click the tool and Run as Admin ( Xp Users Double Click)
Put a check mark next the items below:
Remove disinfection tools
Create registry backup
Purge System Restore
Now click on "Run" button.
allow the program to complete its work.
all the tools we used will be removed.
Tool will create and open a log report (DelFix.txt)
Note: The report can be located at the following location C:\DelFix.txt
# DelFix v1.013 - Logfile created 26/02/2017 at 09:59:05
# Updated 17/04/2016 by Xplode
# Username : sandra123 - SANDRA
# Operating System : Windows 8 Pro (32 bits)
~ Removing disinfection tools ...
Deleted : C:\AdwCleaner
Deleted : C:\Users\sandra123\Desktop\adwcleaner_6.043.exe
Deleted : C:\Users\sandra123\Desktop\JRT.exe
Deleted : C:\Users\sandra123\Desktop\JRT.txt
Deleted : C:\Users\Public\Desktop\RogueKiller.lnk
~ Creating registry backup ... OK
~ Cleaning system restore ...
Deleted : RP #90 [End of disinfection | 02/22/2017 20:10:44]
Deleted : RP #91 [Restore point | 02/22/2017 21:43:25]
Deleted : RP #92 [JRT Pre-Junkware Removal | 02/24/2017 14:09:21]
Deleted : RP #93 [ResetBrowser | 02/25/2017 09:49:36]
New restore point created !
########## - EOF - ##########
Here are couple of free antivirus that are really good. In order of my personal preference...
SecureAplus
-- Free for a year.
Panda Cloud Free.
Sophos Home -- Good but a little heavy on resources.
360 Total Security
Add these to the above for solid protection...
VooDooShield. -- Slightly annoying while it learns your machine, but after that a solid piece of software to have on your machine.
Ublock origin.
Anti Ad block Killer.
Ad Blocking DNS -- Set this on your router to block most ads on all your devices.
Thanks for your advice, but should I delete these, that are still in my laptop: Ccleaner, Zemana, ResetBrowser, Privazer, and these that I had already installed: Bitdefender, Wipe and Superantispyware? I should have only one anti-virus, right? But also some anti-malware or spyware? Sorry for being so lost, but i need to know exactly what to keep for better results, thanks.
Keep Ccleaner, Zemana, Privazer, -- run them once a week.
Delete the rest, if you choose to use another antivirus, then delete Bitdefender.
