Solved BAse Filtering Engine Access Denied Error 5
Your machine has no malware. I've seen that it does not with the logs we have ran thru. You can check the machine with the Kaspersky Virus Removal Tool if you wish. :)
Download KpRM
Save to Desktop
Check Delete Tools'
Delete Restore points
Create Restore point.
Then click run.
I'll Mark this as solved for you.:)
