Solved BAse Filtering Engine Access Denied Error 5
FRST Fix.
Download attached fixlist.txt file and save it to the Desktop. NOTE. It's important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
Ok.
Let's do this....
FRST Fix.
Step2:
ZHP cleaner Scan.
Once you have started the program, you will need to click the scanner button.
Once the scan is completed, the you will want to click the Repair button.
At the end of the process you may be asked to reboot your machine.
After you reboot a report will open on your desktop.
Attach the report here in your next reply.
Step 3:
ZHP Diag Scan Click here to download.
Save to your desktop.
Right Click Run as Admin.
Click the Options button.
Click on Check All
Then click close.
Click the Scanner button.
A notepad will open... attach the report in your next reply.
As far as adware cleaner, right click run as admin, if nothing is found then run the basic repair.
Use everything search engine.
Copy and paste
ZHPCleaner.txt
click on that open log, paste here.
Do I set it up in a Installation and install or do I run as Administrator?
just install run as admin.
sorry this is confusing me. so click run as admin from here?
Then after that post the other logs requested and run the fix from post 19
Im about to call it a night.
Can we pick this up tomorrow?
Yep run the last FRST fix when you can and we will go from there.
Hi Again!
So two things I've noticed with the FRST fixing is that Windows Security blocks some changes that FRST64 tries to make. For instance,
And the file: fix list.txt always deletes after restarting the computer from the fix. Thanks for you time.
Make sure and save the fix attached below to your desktop.
Download Runx save it to your desktop.
Drag and drop FRST onto the RunX program.
Then run the fix below.
If that fails
Download Power Run
Unzip it to your desktop.
Open the folder.
Run power run x64
Click file .... Add file.
Under file location paste the following.
Do not include the word code!!
Code:
C:\Users\User\Desktop\FRST64.exe
Then when FRST is open, click fix.
FRST Fix.
Reactions: thiisnacc
If that fails
Download Power Run
Open the folder.
Run power run x64
Code:
FRST Fix.
^ This is what it should look like before I hit run and then fix on FRST64 right? I have no clue why it keeps saying OneDrive instead of C:\Users\User\Desktop like you said.
If that fails
Download Power Run
Open the folder.
Run power run x64
Code:
FRST Fix.
everything you've asked me to put in Desktop has been placed in desktop.
Turn this feature off.
Thats fine go ahead and run frst thru Runx, doing this allows FRST to bypass anything restricting it.
Ok I turned the feature off. I finally looked up and saw that my User/Desktop directory was in fact different from my OneDrive because It was completely empty. I went to desktop located under this pc and changed the location to C:/User/Desktop and it moved everything from OneDrive I guess 🤝 Now I guess its back to FRST and trying that again?
It's made a small step...
Code:
========= sc config bfe start=auto =========
[SC] ChangeServiceConfig SUCCESS
========= sc config MpsSvc start=auto =========
Download and install the All in one repair tool, reboot into safe mode.
Drag the All in one repair tool onto Powerrunx64 after you download and unzip to your desktop.
Run the All in one tool with all items ticked.
Reboot and check the issue.
