Audio very stuttery and scratchy
raysunicorn
27
I was cleaning my computer and when I put it back together it was fine. Except the audio was stuttering and sounds extremely scratchy (best way I can describe it).
I made sure that the problem wasn't coming from the speakers or headphones. Both work on my laptop just fine. I updated my driver's, I deleted them and reinstalled them. I tried messing with the audio settings in the bios.
I am out of ideas. Could the problem be due to a damaged motherboard? Should I get a sound card?
One simple thing you can do.. When you plug the connection in the audio port,rotate the audio plug in the port.. If this doesn't work it may be another hardware issue..
