Audio popping while playing EA FC 25
juusk
3
24
Hello,
hopefully someone here could assist me with the problem I'm having.
For a few FC games now, the audio of the game has been crackling/popping while playing but it gets worse during cutscenes. l've been able to resolve this problem by capping FPS, but on FC 25 that doesn't work. I've also had this problem on my old PC. I've never played an FC game before the actual release so maybe it will get fixed with an update?
I tried updating my audio drivers and bios and the issue still persists.
It doesn't matter if it's in-game audio or external.
My specs
Motherboard: Gigabyte Z790 Gaming X AX So.1700 DDR5 (version F11d)
CPU: Intel Core i7-13700K
GPU: 12GB Palit GeForce RTX 4070 Ti
CPU cooler: Phanteks Glacier One 360MP 60.511 CFM Liquid CPU Cooler
RAM: 32GB Kingston FURY Beast DDR5-5600
SSDs: Samsung 980 Pro 2TB M.2 and Samsung 970 EVO 500GB
HDD: WDC WD1003FZEX-00K3CA0
PSU: 750 Watt be quiet! Straight Power 11 Modular 80+ Platinum (its 1.5 years old)
Chassis: Phanteks Eclipse G500A
OS: Windows 10 Home 64-bit
Monitor: GIGABYTE M27Q-EK and Zowie XL2411P
Thank you.
Let's get some information from your machine:
Download the PCHFLogTool
Unzip to your desktop
Right Click run as admin.
Click Gather logs.
A new .txt named PCHF.txt will appear on your desktop.
Copy paste or attach that.
Click install Speccy:
Right click run as admin
Upon Completion:
Hit File
Publish Snap Shot
A link will appear, post that link.
@Pyro Once logs are posted. @veeg Leave open till Pyro Chimes in. (y)
Just checking in- OP
Let's get some more information:
Download and run the free version of speccy.
Once you have ran speccy, publish the scan by going to: File > Publish Snapshot.
Thanks for the replys everyone.
Sorry couldn't reply sooner, I was away for a few days.
Here is the information you requested:
Speccy Snapshot: https://speccy.piriform.com/results/5LltnXHBiGSKuJVRX4ZZIxm
Edit: https://www.gigabyte.com/Motherboard/Z790-GAMING-X-AX-rev-1x#kf
Code:
Malnutrition-Tool (x64) Log Collector https://pchelpforum.net/
Ran by lipov (administrator) on DESKTOP-RRESPFA at 2024-09-28 19:58:13
Running from:
System Information:
Operating System: Microsoft Windows 10 Home Version 10.0.19045 (True)
Architecture: 64-bit
Processor: 13th Gen Intel(R) Core(TM) i7-13700K (16 Cores, 24 Logical Processors)
Installed RAM: 31.77 GB
Available RAM: 22.31 GB
BIOS Version: F11d
Serial Number: Default string
Manufacturer: Gigabyte Technology Co., Ltd.
Model: Z790 GAMING X AX
Drive Information:
1 Drive C: () (Fixed) (Total:1862.28 GB) (Free:738.76 GB) NTFS
2 Drive D: () (Fixed) (Total:931.51 GB) (Free:255.81 GB) NTFS
3 Drive E: (Rezerviran sistem) (Fixed) (Total:0.05 GB) (Free:0.02 GB) NTFS
4 Drive F: (Local disk) (Fixed) (Total:465.03 GB) (Free:464.37 GB) NTFS
5 Drive G: () (Fixed) (Total:223.52 GB) (Free:53.64 GB) NTFS
6 Drive H: (ESD-USB) (Removable) (Total:14.54 GB) (Free:14.51 GB) FAT32
Interface List:
...4C-03-4F-4C-F8-23......Bluetooth Network Connection
...74-56-3C-37-60-22......Ethernet
...4C-03-4F-4C-F8-1F......WiFi
.........Wintun
...4E-03-4F-4C-F8-1F......Local Area Connection* 2
IP Configuration:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-RRESPFA
   Primary Dns Suffix  . . . . . . . :
   DNS Suffix Search List. . . . . . : fritz.box
Unknown adapter Wintun:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : PolarBear Tunnel
   Physical Address. . . . . . . . . :
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . : fritz.box
   Description . . . . . . . . . . . : Realtek Gaming 2.5GbE Family Controller
   Physical Address. . . . . . . . . : 74-56-3C-37-60-22
   IPv6 Address. . . . . . . . . . . : 2a00:ee2:700:2900:c335:523d:b4f3:e326(Preferred)
   Temporary IPv6 Address. . . . . . : 2a00:ee2:700:2900:2159:eced:82a7:ffc6(Preferred)
   Link-local IPv6 Address . . . . . : fe80::e41e:3cd0:1593:841%19(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.178.47(Preferred)
   Lease Obtained. . . . . . . . . . : Saturday, 28 September 2024 10:01:46
   Lease Expires . . . . . . . . . . : Sunday, 29 September 2024 10:01:45
   Default Gateway . . . . . . . . . : fe80::b2f2:8ff:fe73:673b%19
                                       192.168.178.1
   DHCP Server . . . . . . . . . . . : 192.168.178.1
   DHCPv6 IAID . . . . . . . . . . . : 108287548
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2C-D8-48-CD-74-56-3C-37-60-22
   DNS Servers . . . . . . . . . . . : 2a07:a8c0::bd:b9c6
                                       2a07:a8c1::bd:b9c6
                                       45.90.28.0
                                       45.90.30.0
Wireless LAN adapter WiFi:
   Description . . . . . . . . . . . : Intel(R) Wi-Fi 6E AX210 160MHz
   Physical Address. . . . . . . . . : 4C-03-4F-4C-F8-1F
Wireless LAN adapter Local Area Connection* 1:
   Physical Address. . . . . . . . . : 4C-03-4F-4C-F8-20
Wireless LAN adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : 4E-03-4F-4C-F8-1F
   Link-local IPv6 Address . . . . . : fe80::588f:f722:6b47:eea5%9(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.137.1(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 156107599
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 4C-03-4F-4C-F8-23
Running services and their registry name and file path:
Application Layer Gateway Service                            | ALG                              | C:\Windows\System32\alg.exe
Application Information                                      | Appinfo                          | C:\Windows\system32\svchost.exe -k netsvcs -p
AppX Deployment Service (AppXSVC)                            | AppXSvc                          | C:\Windows\system32\svchost.exe -k wsappx -p
Windows Audio Endpoint Builder                               | AudioEndpointBuilder             | C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Windows Audio                                                | Audiosrv                         | C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted -p
Base Filtering Engine                                        | BFE                              | C:\Windows\system32\svchost.exe -k LocalServiceNoNetworkFirewall -p
Background Intelligent Transfer Service                      | BITS                             | C:\Windows\System32\svchost.exe -k netsvcs -p
Background Tasks Infrastructure Service                      | BrokerInfrastructure             | C:\Windows\system32\svchost.exe -k DcomLaunch -p
Bluetooth Audio Gateway Service                              | BTAGService                      | C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted
AVCTP service                                                | BthAvctpSvc                      | C:\Windows\system32\svchost.exe -k LocalService -p
Bluetooth Support Service                                    | bthserv                          | C:\Windows\system32\svchost.exe -k LocalService -p
Capability Access Manager Service                            | camsvc                           | C:\Windows\system32\svchost.exe -k appmodel -p
Connected Devices Platform Service                           | CDPSvc                           | C:\Windows\system32\svchost.exe -k LocalService -p
Microsoft Office Click-to-Run Service                        | ClickToRunSvc                    | "C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe" /service
Client License Service (ClipSVC)                             | ClipSVC                          | C:\Windows\System32\svchost.exe -k wsappx -p
CMigrationService                                            | CMigrationService                | "C:\Program Files (x86)\Samsung\Samsung Magician\MigrationService\MigrationService.exe"
CoreMessaging                                                | CoreMessagingRegistrar           | C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork -p
Intel(R) Content Protection HDCP Service                     | cplspcon                         | C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_effe9612081e9042\IntelCpHDCPSvc.exe
Cryptographic Services                                       | CryptSvc                         | C:\Windows\system32\svchost.exe -k NetworkService -p
DCOM Server Process Launcher                                 | DcomLaunch                       | C:\Windows\system32\svchost.exe -k DcomLaunch -p
Device Association Service                                   | DeviceAssociationService         | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Device Install Service                                       | DeviceInstall                    | C:\Windows\system32\svchost.exe -k DcomLaunch -p
DevQuery Background Discovery Broker                         | DevQueryBroker                   | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
DHCP Client                                                  | Dhcp                             | C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Connected User Experiences and Telemetry                     | DiagTrack                        | C:\Windows\System32\svchost.exe -k utcsvc -p
Display Policy Service                                       | DispBrokerDesktopSvc             | C:\Windows\system32\svchost.exe -k LocalService -p
Display Enhancement Service                                  | DisplayEnhancementService        | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
DNS Client                                                   | Dnscache                         | C:\Windows\system32\svchost.exe -k NetworkService -p
Delivery Optimization                                        | DoSvc                            | C:\Windows\System32\svchost.exe -k NetworkService -p
Diagnostic Policy Service                                    | DPS                              | C:\Windows\System32\svchost.exe -k LocalServiceNoNetwork -p
DtsHPXV2Apo4Service                                          | DtsHPXV2Apo4Service              | C:\Windows\System32\DTS\HP\APO4x\DtsHPXV2Apo4Service.exe
Data Usage                                                   | DusmSvc                          | C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted -p
EABackgroundService                                          | EABackgroundService              | "C:\Program Files\Electronic Arts\EA Desktop\EA Desktop\EABackgroundService.exe"
EasyTuneEngineService                                        | EasyTuneEngineService            | "C:\Program Files (x86)\Gigabyte\EasyTuneEngineService\EasyTuneEngineService.exe"
Windows Event Log                                            | EventLog                         | C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted -p
COM+ Event System                                            | EventSystem                      | C:\Windows\system32\svchost.exe -k LocalService -p
Windows Font Cache Service                                   | FontCache                        | C:\Windows\system32\svchost.exe -k LocalService -p
Gaming Services                                              | GamingServices                   | C:\Program Files\WindowsApps\Microsoft.GamingServices_24.93.16001.0_x64__8wekyb3d8bbwe\GamingServices.exe
Gaming Services                                              | GamingServicesNet                | C:\Program Files\WindowsApps\Microsoft.GamingServices_24.93.16001.0_x64__8wekyb3d8bbwe\GamingServicesNet.exe
Group Policy Client                                          | gpsvc                            | C:\Windows\system32\svchost.exe -k netsvcs -p
GraphicsPerfSvc                                              | GraphicsPerfSvc                  | C:\Windows\System32\svchost.exe -k GraphicsPerfSvcGroup
Human Interface Device Service                               | hidserv                          | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Windows Mobile Hotspot Service                               | icssvc                           | C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Intel(R) Graphics Command Center Service                     | igccservice                      | "C:\Windows\System32\DriverStore\FileRepository\igcc_dch.inf_amd64_8f2d0015d04700ee\OneApp.IGCC.WinService.exe"
Microsoft Store Install Service                              | InstallService                   | C:\Windows\System32\svchost.exe -k netsvcs -p
IP Helper                                                    | iphlpsvc                         | C:\Windows\System32\svchost.exe -k NetSvcs -p
Intel(R) Dynamic Application Loader Host Interface Service   | jhi_service                      | C:\Windows\System32\DriverStore\FileRepository\dal.inf_amd64_af50fdb80983f7bc\jhi_service.exe
CNG Key Isolation                                            | KeyIso                           | C:\Windows\system32\lsass.exe
Server                                                       | LanmanServer                     | C:\Windows\system32\svchost.exe -k netsvcs -p
Workstation                                                  | LanmanWorkstation                | C:\Windows\System32\svchost.exe -k NetworkService -p
Geolocation Service                                          | lfsvc                            | C:\Windows\system32\svchost.exe -k netsvcs -p
LGHUB Updater Service                                        | LGHUBUpdaterService              | "C:\Program Files\LGHUB\lghub_updater.exe" --run-as-service
Windows License Manager Service                              | LicenseManager                   | C:\Windows\System32\svchost.exe -k LocalService -p
TCP/IP NetBIOS Helper                                        | lmhosts                          | C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted -p
Local Session Manager                                        | LSM                              | C:\Windows\system32\svchost.exe -k DcomLaunch -p
Malwarebytes Service                                         | MBAMService                      | "C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe"
Microsoft Defender Core Service                              | MDCoreSvc                        | "C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24080.9-0\MpDefenderCoreService.exe"
Windows Defender Firewall                                    | mpssvc                           | C:\Windows\system32\svchost.exe -k LocalServiceNoNetworkFirewall -p
Network Connection Broker                                    | NcbService                       | C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Network Connections                                          | Netman                           | C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Network List Service                                         | netprofm                         | C:\Windows\System32\svchost.exe -k LocalService -p
Network Setup Service                                        | NetSetupSvc                      | C:\Windows\System32\svchost.exe -k netsvcs -p
NextDNS DNS53 to DoH proxy.                                  | NextDNSService                   | "C:\Program Files (x86)\NextDNS\NextDNSService.exe"
Microsoft Passport Container                                 | NgcCtnrSvc                       | C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Microsoft Passport                                           | NgcSvc                           | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Network Location Awareness                                   | NlaSvc                           | C:\Windows\System32\svchost.exe -k NetworkService -p
Network Store Interface Service                              | nsi                              | C:\Windows\system32\svchost.exe -k LocalService -p
NVIDIA LocalSystem Container                                 | NvContainerLocalSystem           | "C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe" -s NvContainerLocalSystem -a -f "C:\ProgramData\NVIDIA\NvContainerLocalSystem.log" -l 3 -d "C:\Program Files\NVIDIA Corporation\NvContainer\plugins\LocalSystem" -r -p 30000 -st "C:\Program Files\NVIDIA Corporation\NvContainer\NvContainerTelemetryApi.dll" -ert
NVIDIA Display Container LS                                  | NVDisplay.ContainerLocalSystem   | C:\Windows\System32\DriverStore\FileRepository\nvrfi.inf_amd64_a228a42067af1a48\Display.NvContainer\NVDisplay.Container.exe -s NVDisplay.ContainerLocalSystem -f C:\ProgramData\NVIDIA\NVDisplay.ContainerLocalSystem.log -l 3 -d C:\Windows\System32\DriverStore\FileRepository\nvrfi.inf_amd64_a228a42067af1a48\Display.NvContainer\plugins\LocalSystem -r -p 30000 -cfg NVDisplay.ContainerLocalSystem\LocalSystem /ert
Program Compatibility Assistant Service                      | PcaSvc                           | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Plex Update Service                                          | PlexUpdateService                | C:\Program Files\Plex\Plex Media Server\Plex Update Service.exe
Plug and Play                                                | PlugPlay                         | C:\Windows\system32\svchost.exe -k DcomLaunch -p
Power                                                        | Power                            | C:\Windows\system32\svchost.exe -k DcomLaunch -p
User Profile Service                                         | ProfSvc                          | C:\Windows\system32\svchost.exe -k netsvcs -p
Quality Windows Audio Video Experience                       | QWAVE                            | C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation -p
Remote Access Connection Manager                             | RasMan                           | C:\Windows\System32\svchost.exe -k netsvcs
Radio Management Service                                     | RmSvc                            | C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted
RPC Endpoint Mapper                                          | RpcEptMapper                     | C:\Windows\system32\svchost.exe -k RPCSS -p
Remote Procedure Call (RPC)                                  | RpcSs                            | C:\Windows\system32\svchost.exe -k rpcss -p
Realtek Audio Universal Service                              | RtkAudioUniversalService         | C:\Windows\System32\DriverStore\FileRepository\realtekservice.inf_amd64_9f05190a2befb920\RtkAudUService64.exe
Security Accounts Manager                                    | SamSs                            | C:\Windows\system32\lsass.exe
SamsungMagicianSVC                                           | SamsungMagicianSVC               | "C:\Program Files (x86)\Samsung\Samsung Magician\SamsungMagicianSVC.exe"
Task Scheduler                                               | Schedule                         | C:\Windows\system32\svchost.exe -k netsvcs -p
Windows Security Service                                     | SecurityHealthService            | C:\Windows\system32\SecurityHealthService.exe
Payments and NFC/SE Manager                                  | SEMgrSvc                         | C:\Windows\system32\svchost.exe -k LocalService -p
System Event Notification Service                            | SENS                             | C:\Windows\system32\svchost.exe -k netsvcs -p
System Guard Runtime Monitor Broker                          | SgrmBroker                       | C:\Windows\system32\SgrmBroker.exe
Internet Connection Sharing (ICS)                            | SharedAccess                     | C:\Windows\System32\svchost.exe -k netsvcs -p
Shell Hardware Detection                                     | ShellHWDetection                 | C:\Windows\System32\svchost.exe -k netsvcs -p
Print Spooler                                                | Spooler                          | C:\Windows\System32\spoolsv.exe
SSDP Discovery                                               | SSDPSRV                          | C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation -p
Secure Socket Tunneling Protocol Service                     | SstpSvc                          | C:\Windows\system32\svchost.exe -k LocalService -p
State Repository Service                                     | StateRepository                  | C:\Windows\system32\svchost.exe -k appmodel -p
Steam Client Service                                         | Steam Client Service             | "C:\Program Files (x86)\Common Files\Steam\steamservice.exe" /RunAsService
Storage Service                                              | StorSvc                          | C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted -p
SysMain                                                      | SysMain                          | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
System Events Broker                                         | SystemEventsBroker               | C:\Windows\system32\svchost.exe -k DcomLaunch -p
Touch Keyboard and Handwriting Panel Service                 | TabletInputService               | C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Remote Desktop Services                                      | TermService                      | C:\Windows\System32\svchost.exe -k NetworkService
Themes                                                       | Themes                           | C:\Windows\System32\svchost.exe -k netsvcs -p
Time Broker                                                  | TimeBrokerSvc                    | C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Web Account Manager                                          | TokenBroker                      | C:\Windows\system32\svchost.exe -k netsvcs -p
Distributed Link Tracking Client                             | TrkWks                           | C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted -p
UPnP Device Host                                             | upnphost                         | C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation -p
User Manager                                                 | UserManager                      | C:\Windows\system32\svchost.exe -k netsvcs -p
Update Orchestrator Service                                  | UsoSvc                           | C:\Windows\system32\svchost.exe -k netsvcs -p
Credential Manager                                           | VaultSvc                         | C:\Windows\system32\lsass.exe
VSSrv                                                        | VSSrv                            | "C:\Windows\System32\VSSrv.exe"
Windows Connection Manager                                   | Wcmsvc                           | C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Diagnostic Service Host                                      | WdiServiceHost                   | C:\Windows\System32\svchost.exe -k LocalService -p
Microsoft Defender Antivirus Network Inspection Service      | WdNisSvc                         | "C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24080.9-0\NisSrv.exe"
Microsoft Defender Antivirus Service                         | WinDefend                        | "C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24080.9-0\MsMpEng.exe"
WinHTTP Web Proxy Auto-Discovery Service                     | WinHttpAutoProxySvc              | C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Windows Management Instrumentation                           | Winmgmt                          | C:\Windows\system32\svchost.exe -k netsvcs -p
WLAN AutoConfig                                              | WlanSvc                          | C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Microsoft Account Sign-in Assistant                          | wlidsvc                          | C:\Windows\system32\svchost.exe -k netsvcs -p
Intel(R) Management Engine WMI Provider Registration         | WMIRegistrationService           | C:\Windows\System32\DriverStore\FileRepository\mewmiprov.inf_amd64_d51901c26227fb29\WMIRegistrationService.exe
Windows Push Notifications System Service                    | WpnService                       | C:\Windows\system32\svchost.exe -k netsvcs -p
Security Center                                              | wscsvc                           | C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted -p
Windows Search                                               | WSearch                          | C:\Windows\system32\SearchIndexer.exe /Embedding
Windows Update                                               | wuauserv                         | C:\Windows\system32\svchost.exe -k netsvcs -p
Xbox Live Auth Manager                                       | XblAuthManager                   | C:\Windows\system32\svchost.exe -k netsvcs -p
GIGABYTE Update Service                                      | GigabyteUpdateService            | C:\Windows\system32\GigabyteUpdateService.exe 2\C:\Windows\system32\
BluetoothUserService_57cba                                   | BluetoothUserService_57cba       | C:\Windows\system32\svchost.exe -k BthAppGroup -p
cbdhsvc_57cba                                                | cbdhsvc_57cba                    | C:\Windows\system32\svchost.exe -k ClipboardSvcGroup -p
CDPUserSvc_57cba                                             | CDPUserSvc_57cba                 | C:\Windows\system32\svchost.exe -k UnistackSvcGroup
OneSyncSvc_57cba                                             | OneSyncSvc_57cba                 | C:\Windows\system32\svchost.exe -k UnistackSvcGroup
PimIndexMaintenanceSvc_57cba                                 | PimIndexMaintenanceSvc_57cba     | C:\Windows\system32\svchost.exe -k UnistackSvcGroup
UnistoreSvc_57cba                                            | UnistoreSvc_57cba                | C:\Windows\System32\svchost.exe -k UnistackSvcGroup
UserDataSvc_57cba                                            | UserDataSvc_57cba                | C:\Windows\system32\svchost.exe -k UnistackSvcGroup
WpnUserService_57cba                                         | WpnUserService_57cba             | C:\Windows\system32\svchost.exe -k UnistackSvcGroup
Running Processes and their appended file path:
AggregatorHost             - C:\Windows\System32\AggregatorHost.exe
alg                        - C:\Windows\System32\alg.exe
ApplicationFrameHost       - C:\Windows\system32\ApplicationFrameHost.exe
audiodg                    - C:\Windows\system32\AUDIODG.EXE
backgroundTaskHost         - C:\Windows\system32\backgroundTaskHost.exe
BakkesMod                  - C:\Program Files\BakkesMod\BakkesMod.exe
BsgLauncher                - C:\Battlestate Games\BsgLauncher\BsgLauncher.exe
chrome                     - C:\Program Files\Google\Chrome\Application\chrome.exe
CompPkgSrv                 - C:\Windows\System32\CompPkgSrv.exe
conhost                    - C:\Windows\system32\conhost.exe
ctfmon                     - C:\Windows\system32\ctfmon.exe
dasHost                    - C:\Windows\system32\dashost.exe
Discord                    - C:\Users\lipov\AppData\Local\Discord\app-1.0.9164\Discord.exe
dllhost                    - C:\Windows\system32\DllHost.exe
DtsHPXV2Apo4Service        - C:\Windows\System32\DTS\HP\APO4x\DtsHPXV2Apo4Service.exe
dwm                        - C:\Windows\system32\dwm.exe
EABackgroundService        - C:\Program Files\Electronic Arts\EA Desktop\EA Desktop\EABackgroundService.exe
EACefSubProcess            - C:\Program Files\Electronic Arts\EA Desktop\EA Desktop\EACefSubProcess.exe
EADesktop                  - C:\Program Files\Electronic Arts\EA Desktop\EA Desktop\EADesktop.exe
EALocalHostSvc             - C:\Program Files\Electronic Arts\EA Desktop\EA Desktop\EALocalHostSvc.exe
EasyTuneEngineService      - C:\Program Files (x86)\Gigabyte\EasyTuneEngineService\EasyTuneEngineService.exe
explorer                   - C:\Windows\Explorer.EXE
fontdrvhost                - C:\Windows\system32\fontdrvhost.exe
gamingservices             - C:\Program Files\WindowsApps\Microsoft.GamingServices_24.93.16001.0_x64__8wekyb3d8bbwe\GamingServices.exe
gamingservicesnet          - C:\Program Files\WindowsApps\Microsoft.GamingServices_24.93.16001.0_x64__8wekyb3d8bbwe\GamingServicesNet.exe
GCC                        - C:\Program Files\GIGABYTE\Control Center\GCC.exe
GigabyteUpdateService      - C:\Windows\system32\GigabyteUpdateService.exe
G-PANEL                    - C:\Program Files\Thunder Master\UI\G-PANEL.exe
GraphicsCardEngine         - C:\Program Files (x86)\GIGABYTE\EasyTuneEngineService\GraphicsCardEngine.exe
IntelCpHDCPSvc             - C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_effe9612081e9042\IntelCpHDCPSvc.exe
jhi_service                - C:\Windows\System32\DriverStore\FileRepository\dal.inf_amd64_af50fdb80983f7bc\jhi_service.exe
lghub_agent                - C:\Program Files\LGHUB\lghub_agent.exe
lghub_system_tray          - C:\Program Files\LGHUB\system_tray\lghub_system_tray.exe
lghub_updater              - C:\Program Files\LGHUB\lghub_updater.exe
Lightshot                  - C:\Program Files (x86)\Skillbrains\lightshot\5.5.0.7\Lightshot.exe
LockApp                    - C:\Windows\SystemApps\Microsoft.LockApp_cw5n1h2txyewy\LockApp.exe
logi_crashpad_handler      - C:\Program Files\LGHUB\logi_crashpad_handler.exe
lsass                      - C:\Windows\system32\lsass.exe
Malwarebytes               - C:\Program Files\Malwarebytes\Anti-Malware\Malwarebytes.exe
MigrationService           - C:\Program Files (x86)\Samsung\Samsung Magician\MigrationService\MigrationService.exe
MoUsoCoreWorker            - C:\Windows\System32\mousocoreworker.exe
msedgewebview2             - C:\Program Files (x86)\Microsoft\EdgeWebView\Application\129.0.2792.52\msedgewebview2.exe
NextDNS                    - C:\Program Files (x86)\NextDNS\NextDNS.exe
NextDNSService             - C:\Program Files (x86)\NextDNS\NextDNSService.exe
NGenuity2Helper            - C:\Program Files\WindowsApps\33C30B79.HyperXNGenuity_5.27.4.0_x64__0a78dr3hq0pvt\Assets\Native\NGenuity2Helper.exe
nvcontainer                - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
NVDisplay.Container        - C:\Windows\System32\DriverStore\FileRepository\nvrfi.inf_amd64_a228a42067af1a48\Display.NvContainer\NVDisplay.Container.exe
NVIDIA Share               - C:\Program Files\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
NVIDIA Web Helper          - C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
nvsphelper64               - C:\Program Files\NVIDIA Corporation\ShadowPlay\nvsphelper64.exe
OfficeClickToRun           - C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe
OneApp.IGCC.WinService     - C:\Windows\System32\DriverStore\FileRepository\igcc_dch.inf_amd64_8f2d0015d04700ee\OneApp.IGCC.WinService.exe
PCHFLogTool                - C:\Users\lipov\Desktop\PCHFLogTool.exe
PhoneExperienceHost        - C:\Program Files\WindowsApps\Microsoft.YourPhone_1.24082.137.0_x64__8wekyb3d8bbwe\PhoneExperienceHost.exe
Plex Update Service        - C:\Program Files\Plex\Plex Media Server\Plex Update Service.exe
RtkAudUService64           - C:\Windows\System32\DriverStore\FileRepository\realtekservice.inf_amd64_9f05190a2befb920\RtkAudUService64.exe
rundll32                   - C:\Windows\system32\rundll32.exe
RuntimeBroker              - C:\Windows\System32\RuntimeBroker.exe
SamsungMagicianSVC         - C:\Program Files (x86)\Samsung\Samsung Magician\SamsungMagicianSVC.exe
SDXHelper                  - C:\Program Files (x86)\Microsoft Office\Root\Office16\SDXHelper.exe
SearchApp                  - C:\Windows\SystemApps\Microsoft.Windows.Search_cw5n1h2txyewy\SearchApp.exe
SearchFilterHost           - C:\Windows\system32\SearchFilterHost.exe
SearchIndexer              - C:\Windows\system32\SearchIndexer.exe
SearchProtocolHost         - C:\Windows\system32\SearchProtocolHost.exe
SecurityHealthSystray      - C:\Windows\System32\SecurityHealthSystray.exe
ShellExperienceHost        - C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
sihost                     - C:\Windows\system32\sihost.exe
smartscreen                - C:\Windows\System32\smartscreen.exe
SoundSwitch                - C:\Program Files\SoundSwitch\SoundSwitch.exe
spoolsv                    - C:\Windows\System32\spoolsv.exe
Spotify                    - C:\Program Files\WindowsApps\SpotifyAB.SpotifyMusic_1.247.364.0_x64__zpdnekdrzrea0\Spotify.exe
StartMenuExperienceHost    - C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
steam                      - C:\Program Files (x86)\Steam\steam.exe
steamservice               - C:\Program Files (x86)\Common Files\Steam\steamservice.exe
steamwebhelper             - C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe
svchost                    - C:\Windows\system32\svchost.exe
svchost                    - C:\Windows\System32\svchost.exe
taskhostw                  - C:\Windows\system32\taskhostw.exe
TextInputHost              - C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\TextInputHost.exe
ThPanel                    - C:\Program Files\Thunder Master\ThPanel.exe
unsecapp                   - C:\Windows\system32\wbem\unsecapp.exe
UserOOBEBroker             - C:\Windows\System32\oobe\UserOOBEBroker.exe
VSHelper                   - C:\Windows\system32\VSHelper.exe
VSSrv                      - C:\Windows\System32\VSSrv.exe
WhatsApp                   - C:\Program Files\WindowsApps\5319275A.WhatsAppDesktop_2.2438.5.0_x64__cv1g1gvanyjgm\WhatsApp.exe
winlogon                   - C:\Windows\system32\winlogon.exe
wlanext                    - C:\Windows\system32\WLANExt.exe
WmiPrvSE                   - C:\Windows\system32\wbem\wmiprvse.exe
WMIRegistrationService     - C:\Windows\System32\DriverStore\FileRepository\mewmiprov.inf_amd64_d51901c26227fb29\WMIRegistrationService.exe
WUDFHost                   - C:\Windows\System32\WUDFHost.exe
XboxPcAppFT                - C:\Program Files\WindowsApps\Microsoft.GamingApp_2410.1001.41.0_x64__8wekyb3d8bbwe\XboxPcAppFT.exe
Scheduled Tasks:
C:\Windows\system32\tasks\DragonStart
C:\Windows\system32\tasks\GCC
C:\Windows\system32\tasks\GraphicsCardEngine
C:\Windows\system32\tasks\MicrosoftEdgeUpdateTaskMachineCore
C:\Windows\system32\tasks\MicrosoftEdgeUpdateTaskMachineUA
C:\Windows\system32\tasks\npcapwatchdog
C:\Windows\system32\tasks\NvDriverUpdateCheckDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NVIDIA GeForce Experience SelfUpdate_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NvTmRep_CrashReport1_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NvTmRep_CrashReport2_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NvTmRep_CrashReport3_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\NvTmRep_CrashReport4_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
C:\Windows\system32\tasks\Overwolf Updater Task
C:\Windows\system32\tasks\SamsungMagician
C:\Windows\system32\tasks\ThunderMaster
C:\Windows\system32\tasks\update-S-1-5-21-3048504298-3322334050-2174572363-1001
C:\Windows\system32\tasks\update-sys
C:\Windows\system32\tasks\GoogleSystem\GoogleUpdater\GoogleUpdaterTaskSystem130.0.6679.0{40520BC0-EF51-49A2-85A8-D3ABB6C08CAC}
C:\Windows\system32\tasks\Mozilla\Firefox Background Update 308046B0AF4A39CB
C:\Windows\system32\tasks\Mozilla\Firefox Default Browser Agent 308046B0AF4A39CB
Recent Application Errors:
TimeGenerated : 28/09/2024 19:46:04
Source        : Microsoft-Windows-CAPI2
Message       : Cryptographic Services failed while processing the OnIdentity() call in the System Writer Object.
                Details:
                AddLegacyDriverFiles: Unable to back up image of binary Microsoft Link-Layer Discovery Protocol.
                System Error:
                Access is denied.
TimeGenerated : 28/09/2024 01:22:53
                Details:
                System Error:
                Access is denied.
TimeGenerated : 26/09/2024 09:32:54
                Details:
                System Error:
                Access is denied.
TimeGenerated : 26/09/2024 09:32:52
                Details:
                System Error:
                Access is denied.
TimeGenerated : 26/09/2024 09:32:49
                Details:
                System Error:
                Access is denied.
TimeGenerated : 26/09/2024 09:32:46
                Details:
                System Error:
                Access is denied.
TimeGenerated : 25/09/2024 22:43:15
                Details:
                System Error:
                Access is denied.
TimeGenerated : 25/09/2024 18:39:00
                Details:
                System Error:
                Access is denied.
TimeGenerated : 25/09/2024 18:05:03
Source        : Application Error
Message       : Faulting application name: svchost.exe_AppXSvc, version: 10.0.19041.4355, time stamp: 0x9ce47784
                Faulting module name: appxdeploymentserver.dll, version: 10.0.19041.4894, time stamp: 0xd3d51e5c
                Exception code: 0xc0000005
                Fault offset: 0x00000000002f7809
                Faulting process ID: 0x11ec
                Faulting application start time: 0x01db0f64ad38c3bb
                Faulting application path: C:\Windows\system32\svchost.exe
                Faulting module path: c:\windows\system32\appxdeploymentserver.dll
                Report ID: 8beb05f8-0e5c-4d70-95eb-41f68321e972
                Faulting package full name:
TimeGenerated : 24/09/2024 22:00:46
                Faulting process ID: 0x18d0
                Faulting application start time: 0x01db0ebc377b12c7
                Report ID: 69bfc823-75f0-4a6f-9f0a-af5ed27e5746
Recent System Errors:
TimeGenerated : 28/09/2024 18:00:01
Source        : Microsoft-Windows-TPM-WMI
Message       : The Secure Boot update failed to update a Secure Boot variable with error -2147020471. For more
                information, please see https://go.microsoft.com/fwlink/?linkid=2169931
TimeGenerated : 28/09/2024 10:04:46
TimeGenerated : 28/09/2024 10:01:49
Source        : Service Control Manager
Message       : The Razer Synapse Service service depends on the following service: Razer Game Manager Service. This
                service might not be installed.
Source        : NETLOGON
Message       : This computer is configured as a member of a workgroup, not as
                a member of a domain. The Netlogon service does not need to run in this
                configuration.
TimeGenerated : 27/09/2024 18:10:04
Source        : Microsoft-Windows-WindowsUpdateClient
Message       : Installation Failure: Windows failed to install the following update with error 0x80073d02:
                9MV0B5HZVK9Z-Microsoft.GamingApp.
TimeGenerated : 27/09/2024 18:10:00
                9NCBCSZSJRSB-SpotifyAB.SpotifyMusic.
TimeGenerated : 27/09/2024 18:09:03
                9P1TBXR6QDCX-33C30B79.HyperXNGenuity.
TimeGenerated : 27/09/2024 18:00:01
TimeGenerated : 27/09/2024 09:44:51
Zipping minidump files:
Installed programs:
Name: 7-Zip 24.08 (x64)
Version: 24.08
Publisher: Igor Pavlov
Install Date: N/A
Uninstall String: "C:\Program Files\7-Zip\Uninstall.exe"
Version: 15.0.2405.347
Publisher: N/A
Install Date: N/A
Uninstall String: C:\Program Files\AntiCheatExpert\Uninstaller.exe
Version: 1.1.7.4
Publisher: Electronic Arts, Inc.
Install Date: N/A
Uninstall String: "C:\Program Files\Common Files\EAInstaller\Apex\Cleanup.exe" uninstall_game -autologging
Version: 3.6.1
Publisher: Audacity Team
Install Date: 20240815
Uninstall String: "C:\Program Files\Audacity\unins000.exe"
Name: Awakened PoE Trade 3.23.10002
Version: 3.23.10002
Publisher: Alexander Drozdov
Install Date: N/A
Uninstall String: "C:\Users\lipov\AppData\Local\Programs\Awakened PoE Trade\Uninstall Awakened PoE Trade.exe" /currentuser
Name: BakkesMod version 3.0
Version: 3.0
Publisher: BakkesMod
Install Date: 20240217
Uninstall String: "C:\Program Files\BakkesMod\unins000.exe"
Version: N/A
Publisher: Blizzard Entertainment
Install Date: N/A
Uninstall String: "C:\ProgramData\Battle.net\Agent\Blizzard Uninstaller.exe" --lang=enUS --uid=battle.net --displayname="Battle.net"
Name: Battlestate Games Launcher 14.3.3.2672
Version: 14.3.3.2672
Publisher: Battlestate Games
Install Date: 20240918
Uninstall String: "C:\Battlestate Games\BsgLauncher\unins000.exe"
Name: Call of Duty
Version: N/A
Install Date: N/A
Uninstall String: "C:\ProgramData\Battle.net\Agent\Blizzard Uninstaller.exe" --lang=enUS --uid=auks --displayname="Call of Duty"
Version: N/A
Publisher: Valve
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/730
Name: CPUID CPU-Z 2.08
Version: 2.08
Publisher: CPUID, Inc.
Install Date: 20231120
Uninstall String: "C:\Program Files\CPUID\CPU-Z\unins000.exe"
Version: N/A
Publisher: Red Hook Studios
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/262060
Version: 1.0.9021
Publisher: Discord Inc.
Install Date: 20230004
Uninstall String: C:\Users\lipov\AppData\Local\Discord\Update.exe --uninstall
Version: 6
Publisher: Realtek
Install Date: 20231104
Uninstall String: "C:\Program Files (x86)\InstallShield Installation Information\{3C8FA4F4-8471-4C60-9002-9B9F78B7B483}\setup.exe" -runfromtemp -l0x0409  -removeonly
Name: Dragon's Dogma 2
Version: N/A
Publisher: CAPCOM Co., Ltd.
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/2054970
Name: Dynamic Application Loader Host Interface Service
Version: 1.0.0.0
Publisher: Intel Corporation
Uninstall String: MsiExec.exe /I{FD2C01C4-F511-4B2E-BA8B-AAE44D4C3C7F}
Version: 13.305.0.5818
Install Date: 20240303
Uninstall String: MsiExec.exe /I{C2622085-ABD2-49E5-8AB9-D3D6A642C091}
Install Date: N/A
Uninstall String: "C:\Program Files\Electronic Arts\EA Desktop\EA Desktop\EAUninstall.exe" /uninstall
Name: EA SPORTS FC 25
Version: 1.0.116.295
Install Date: N/A
Uninstall String: "C:\Program Files\Common Files\EAInstaller\EA SPORTS FC 25\Cleanup.exe" uninstall_game -autologging
Version: 1.23.1017
Publisher: GIGABYTE
Uninstall String: MsiExec.exe /I{964575C3-5820-4642-A89A-754255B5EFE1}
Version: 1.23.1017
Publisher: GIGABYTE
Uninstall String: "C:\Program Files (x86)\InstallShield Installation Information\{964575C3-5820-4642-A89A-754255B5EFE1}\setup.exe" -runfromtemp -l0x0409  -removeonly
Version: N/A
Publisher: FromSoftware Inc.
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/1245620
Name: ENE Video Capture Box HAL
Version: 1.0.5.15
Publisher: Ene Tech.
Uninstall String: MsiExec.exe /I{A096611D-BA11-4A1A-8D09-0A0462D7C8F2}
Version: 1.0.5.15
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{974259bf-3ed1-4cd6-9ed1-40c7f601a786}\AacSetup.exe"  /uninstall
Version: 1.0.7.0
Publisher: ENE TECHNOLOGY INC.
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{887e18fb-6bc3-4cd4-b34e-32d9ff71bbae}\AacSetup.exe"  /uninstall
Version: 1.0.7.0
Uninstall String: MsiExec.exe /I{085E2365-0A70-4230-B664-02D5E4FE7E9C}
Version: 1.0.6.4
Uninstall String: MsiExec.exe /I{2DCB701C-AD09-45C8-9433-2F5000BF3F78}
Version: 1.0.6.4
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{1715a4ae-8409-40a1-95ee-184ccde65b8d}\AacSetup.exe"  /uninstall
Version: 1.0.10.1
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{6b617af3-c8f4-45a8-bf47-b32ffb4da1cc}\AacSetup.exe"  /uninstall
Version: 1.0.10.1
Uninstall String: MsiExec.exe /I{37A48B7F-D4EA-4863-844E-A284E2AA3C5D}
Version: 1.0.12.7
Publisher: ENE Tech
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{a7b1cf47-d8f0-423d-9494-568195f1c864}\AacSetup.exe"  /uninstall
Version: 1.0.12.7
Publisher: ENE Tech
Uninstall String: MsiExec.exe /I{2B8E611F-0B51-4FAC-87BB-AF50D82E7DDA}
Version: 1.0.1.8
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{bf256b46-8ff7-48be-ab7f-5661e9a0651f}\AacSetup.exe"  /uninstall
Version: 1.0.1.8
Uninstall String: MsiExec.exe /I{9E97178A-ADB8-4778-BE60-7E28E2A72721}
Version: 1.0.6.3
Uninstall String: MsiExec.exe /I{CF703694-01C6-4062-B797-84DB215662BC}
Version: 1.0.6.3
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{c662a481-d76a-4188-95d2-6eb4ffd55542}\AacSetup.exe"  /uninstall
Name: Epic Games Launcher
Version: 1.3.93.0
Publisher: Epic Games, Inc.
Install Date: 20231105
Uninstall String: MsiExec.exe /X{B85FAA6E-A9AA-4655-9029-E1A4EDC05E1A}
Name: Epic Games Launcher Prerequisites (x64)
Version: 1.0.0.0
Uninstall String: MsiExec.exe /X{F9C5C994-F6B9-4D75-B3E7-AD01B84073E9}
Name: Epic Online Services
Version: 2.0.44.0
Uninstall String: MsiExec.exe /X{57A956AB-4BCC-45C6-9B40-957E4E125568}
Name: Escape from Tarkov
Version: 0.15.2.0.32678
Install Date: N/A
Uninstall String: C:\Battlestate Games\Escape from Tarkov\Uninstall.exe
Name: Escape from Tarkov: Arena
Version: 0.2.1.0.32595
Install Date: N/A
Uninstall String: C:\Battlestate Games\Escape from Tarkov Arena\Uninstall.exe
Name: Euro Truck Simulator 2
Version: N/A
Publisher: N/A
Install Date: 20231111
Uninstall String: "G:\Euro Truck Simulator 2\unins000.exe"
Name: Far Cry 6
Version: N/A
Publisher: N/A
Install Date: 20231129
Uninstall String: "G:\Far Cry 6\unins000.exe"
Name: Farming Simulator 22
Version: N/A
Publisher: Giants Software
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/1248130
Version: 23.10.25.01
Publisher: GIGABYTE
Install Date: N/A
Uninstall String: C:\Program Files\GIGABYTE\Control Center\Lib\GBT_MB_Update\uninst.exe
Name: GBT_RGB_Sync_Control 23.10.27.01
Version: 23.10.27.01
Publisher: GIGABYTE
Install Date: N/A
Uninstall String: C:\Program Files\GIGABYTE\Control Center\Lib\GBT_RGB_Sync_Control\uninst.exe
Name: GBT_rgbMotherboard_UC 23.09.11.01
Version: 23.09.11.01
Publisher: GIGABYTE
Install Date: N/A
Uninstall String: C:\Program Files\GIGABYTE\Control Center\Lib\GBT_rgbMotherboard_UC\uninst.exe
Version: 1.23.0717
Publisher: Gigabyte
Uninstall String: "C:\Program Files (x86)\InstallShield Installation Information\{759D7F2F-1F0D-461E-A3CD-BF58FC60DB2F}\setup.exe" -runfromtemp -l0x0409  -removeonly
Version: 1.23.0717
Publisher: Gigabyte
Uninstall String: MsiExec.exe /I{759D7F2F-1F0D-461E-A3CD-BF58FC60DB2F}
Name: GIGABYTE Control Center 23.10.23.01
Version: 23.10.23.01
Publisher: GIGABYTE
Install Date: N/A
Uninstall String: C:\Program Files\GIGABYTE\Control Center\uninst.exe
Name: GIGABYTE Performance Library
Version: 23.10.19.01
Publisher: GIGABYTE
Install Date: N/A
Uninstall String: C:\Program Files\GIGABYTE\Control Center\Lib\MBEasyTune\uninst.exe
Name: GIGABYTE Storage Library
Version: 23.10.18.01
Publisher: GIGABYTE
Install Date: N/A
Uninstall String: C:\Program Files\GIGABYTE\Control Center\Lib\MBStorage\uninst.exe
Version: 129.0.6668.70
Publisher: Google LLC
Install Date: 20240924
Uninstall String: "C:\Program Files\Google\Chrome\Application\129.0.6668.70\Installer\setup.exe" --uninstall --channel=stable --system-level --verbose-logging
Name: Grand Theft Auto San Andreas
Version: 1.00
Publisher: Релиз от R.G. Steamgames
Install Date: 20240406
Uninstall String: "C:\Program Files (x86)\Grand Theft Auto San Andreas\unins000.exe"
Name: Grand Theft Auto V
Version: 1.0.3179.0
Publisher: Rockstar Games
Install Date: N/A
Uninstall String: "C:\Program Files\Rockstar Games\Grand Theft Auto V\uninstall.exe" -enableFullMode -uninstall=gta5
Name: Guild Wars 2
Version: N/A
Publisher: NCsoft Corporation, Ltd.
Install Date: N/A
Uninstall String: "C:\Program Files\Guild Wars 2\Gw2-64.exe" -uninstall
Version: 7.66
Publisher: Martin Malik, REALiX s.r.o.
Uninstall String: "C:\Program Files\HWiNFO64\unins000.exe"
Name: Intel(R) Chipset Device Software
Version: 10.1.19502.8391
Publisher: Intel(R) Corporation
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{e7892987-b2d0-4c0d-951c-86af011df195}\SetupChipset.exe"  /uninstall
Uninstall String: MsiExec.exe /X{D666FBA1-39CE-48D2-9336-9256827EB308}
Name: Intel(R) HID Event Filter
Version: 2.2.1.386
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Intel\Intel(R) HID Event Filter\Uninstall\install.exe" -uninstall
Version: 1.0.0.0
Uninstall String: MsiExec.exe /I{731E6324-F594-4C19-AA7A-B9145A331BD2}
Name: Intel(R) Management Engine Components
Version: 1.0.0.0
Uninstall String: MsiExec.exe /I{E2021C1F-CC6F-43F5-B4FF-F21E3091DEF1}
Version: 2331.5.20.0
Install Date: N/A
Uninstall String: "C:\ProgramData\Intel Package Cache {1CEAC85D-2590-4760-800F-8DE5E91F3700}\SetupME.exe" -uninstall
Name: Intel(R) Management Engine Driver
Version: 1.0.0.0
Uninstall String: MsiExec.exe /I{03F18B6E-52BA-4906-8993-9EA0AD0D6DD2}
Name: Intel(R) ME WMI Provider
Version: 1.0.0.0
Uninstall String: MsiExec.exe /I{492E26A3-3FB9-4ECA-913E-426EEA93E5FB}
Name: Intel(R) Serial IO
Version: 30.100.2237.26
Install Date: N/A
Uninstall String: "C:\ProgramData\Intel\Package Cache\{9FD91C5C-44AE-4D9D-85BE-AE52816B0294}\Setup.exe" -uninstall
Uninstall String: MsiExec.exe /I{47D5774F-BBF9-401C-B909-B056C0391B39}
Name: Intel(R) Wireless Bluetooth(R)
Version: 22.250.0.2
Uninstall String: MsiExec.exe /I{00000250-0220-1033-84C8-B8D95FA3C8C3}
Name: Launcher Prerequisites (x64)
Version: 1.0.0.0
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{43a03b9c-4770-409c-a999-587b60700b63}\LauncherPrereqSetup_x64.exe"  /uninstall
Name: League of Legends
Version: N/A
Publisher: Riot Games, Inc
Install Date: N/A
Uninstall String: "C:\Riot Games\Riot Client\RiotClientServices.exe" --uninstall-product=league_of_legends --uninstall-patchline=live
Version: 5.5.0.7
Publisher: Skillbrains
Uninstall String: "C:\Program Files (x86)\Skillbrains\lightshot\unins000.exe"
Name: Logitech G HUB
Version: 2024.7.625196
Publisher: Logitech
Install Date: N/A
Uninstall String: "C:\Program Files\LGHUB\lghub_software_manager.exe"
Name: Malwarebytes version 5.1.10.127
Version: 5.1.10.127
Publisher: Malwarebytes
Uninstall String: "C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\mb5uns.exe"
Name: Microsoft Edge Update
Version: 1.3.195.19
Publisher: N/A
Install Date: N/A
Uninstall String: N/A
Name: Mozilla Firefox (x64 en-US)
Version: 127.0
Publisher: Mozilla
Install Date: N/A
Uninstall String: "C:\Program Files\Mozilla Firefox\uninstall\helper.exe"
Name: Mozilla Maintenance Service
Version: 122.0
Publisher: Mozilla
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Mozilla Maintenance Service\uninstall.exe"
Version: v1.6.0
Publisher: Multi Theft Auto
Install Date: N/A
Uninstall String: C:\Program Files (x86)\MTA San Andreas 1.6\Uninstall.exe
Version: N/A
Publisher: N/A
Uninstall String: "G:\MXGP 2021 - The Official Motocross Videogame\unins000.exe"
Name: Need for Speed™ Heat
Version: 1.0.60.7040
Install Date: N/A
Uninstall String: "C:\Program Files\Common Files\EAInstaller\Need for Speed Heat\Cleanup.exe" uninstall_game -autologging
Name: Nefarius Virtual Gamepad Emulation Bus Driver
Version: 1.17.333.0
Publisher: Nefarius Software Solutions e.U.
Install Date: 20231115
Uninstall String: MsiExec.exe /X{93D91F60-7C94-4A79-863F-EA713D2EB3F3}
Version: 3.0.13
Publisher: NextDNS
Install Date: N/A
Uninstall String: C:\Program Files (x86)\NextDNS\Uninstall.exe
Version: 1.78
Publisher: Nmap Project
Install Date: N/A
Uninstall String: "C:\Program Files\Npcap\uninstall.exe"
Version: 39.5.0.0
Publisher: NVIDIA Corporation
Install Date: 20240628
Name: NVIDIA Container
Version: 1.40
Name: NVIDIA FrameView SDK 1.3.8513.32290073
Version: 1.3.8513.32290073
Uninstall String: "C:\Windows\SysWOW64\RunDll32.EXE" "C:\Program Files\NVIDIA Corporation\Installer2\InstallerCore\NVI2.DLL",UninstallPackage FrameViewSdk
Name: NVIDIA GeForce Experience 3.28.0.417
Version: 3.28.0.417
Uninstall String: "C:\Windows\SysWOW64\RunDll32.EXE" "C:\Program Files\NVIDIA Corporation\Installer2\InstallerCore\NVI2.DLL",UninstallPackage Display.GFExperience
Name: NVIDIA GPX Common OSS binaries (POCO, OpenSSL, libprotobuf)
Version: 7.1
Name: NVIDIA Graphics Driver 561.09
Version: 561.09
Install Date: 20240911
Uninstall String: "C:\Windows\SysWOW64\RunDll32.EXE" "C:\Program Files\NVIDIA Corporation\Installer2\InstallerCore\NVI2.DLL",UninstallPackage Display.Driver
Name: NVIDIA HD Audio Driver 1.4.0.1
Version: 1.4.0.1
Uninstall String: "C:\Windows\SysWOW64\RunDll32.EXE" "C:\Program Files\NVIDIA Corporation\Installer2\InstallerCore\NVI2.DLL",UninstallPackage HDAudio.Driver
Name: NVIDIA Install Application
Version: 2.1002.418.0
Name: NVIDIA LocalSystem Container
Version: 1.40
Name: NVIDIA Message Bus for NvContainer
Version: 1.34
Name: NVIDIA NetworkService Container
Version: 1.40
Version: 3.28.0.417
Name: NVIDIA NVAPI Monitor plugin for NvContainer
Version: 1.0
Name: NVIDIA NvModuleTracker
Version: 6.14.26040.64835
Name: NVIDIA Optimus Update 39.5.0.0
Version: 39.5.0.0
Name: NVIDIA PhysX System Software 9.23.1019
Version: 9.23.1019
Install Date: 20240523
Uninstall String: "C:\Windows\SysWOW64\RunDll32.EXE" "C:\Program Files\NVIDIA Corporation\Installer2\InstallerCore\NVI2.DLL",UninstallPackage Display.PhysX
Name: NVIDIA Session Container
Version: 1.40
Name: NVIDIA ShadowPlay 3.28.0.417
Version: 3.28.0.417
Version: 3.28.0.417
Name: NVIDIA SHIELD Streaming
Version: 7.1.33903191
Name: NVIDIA SHIELD Wireless Controller Driver
Version: 3.27.0.116
Install Date: 20231114
Name: NVIDIA Telemetry Client
Version: 18.1.13.0
Name: NVIDIA TelemetryApi helper for NvContainer
Version: 1.40
Name: NVIDIA Update 39.5.0.0
Version: 39.5.0.0
Name: NVIDIA Update Core
Version: 39.5.0.0
Name: NVIDIA User Container
Version: 1.40
Name: NVIDIA Virtual Audio 4.65.0.3
Version: 4.65.0.3
Name: NVIDIA Virtual Host Controller
Version: 3.05.0.1
Name: NVIDIA Watchdog Plugin for NvContainer
Version: 1.40
Version: 0.258.1.7
Publisher: Overwolf Ltd.
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Overwolf\\OWUninstaller.exe" /S
Name: Path of Building Community
Version: 2.35.5
Publisher: Path of Building Community
Install Date: N/A
Uninstall String: "C:\Users\lipov\AppData\Roaming\Path of Building Community\Uninstall.exe"
Name: Path of Exile
Version: N/A
Publisher: Grinding Gear Games
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/238960
Name: Patriot Viper M2 SSD RGB
Version: 1.1.0.1
Publisher: Patriot Memory
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{07236f40-ec25-4646-8cb6-b6aaf1597324}\AacPatriotM2Setup.exe"  /uninstall
Version: 1.1.0.1
Uninstall String: MsiExec.exe /I{8B4C0A3D-C135-4E1F-98D8-3926494B4D61}
Version: 1.81.0
Publisher: Plex, Inc.
Install Date: N/A
Uninstall String: C:\Program Files\Plex\Plex\Uninstall.exe
Name: Plex Media Server 1.32.7.7621 (x64)
Version: 1.32.7.7621
Uninstall String: "C:\Program Files\Plex\Plex Media Server\unins000.exe"
Name: PyCharm Community Edition 2024.1.4
Version: 241.18034.82
Publisher: JetBrains s.r.o.
Install Date: N/A
Uninstall String: C:\Program Files\JetBrains\PyCharm Community Edition 2024.1.4\bin\Uninstall.exe
Name: Python 3.12.4 (64-bit)
Version: 3.12.4150.0
Publisher: Python Software Foundation
Install Date: N/A
Uninstall String: "C:\Users\lipov\AppData\Local\Package Cache\{fb355cb0-c07e-4095-85a7-81c5a2838da6}\python-3.12.4-amd64.exe"  /uninstall
Name: Python 3.12.4 Core Interpreter (64-bit)
Install Date: 20240630
Uninstall String: MsiExec.exe /I{4F815F87-CE9F-45CF-AEDE-EDF03728F8E6}
Name: Python 3.12.4 Development Libraries (64-bit)
Uninstall String: MsiExec.exe /I{7BFF8368-33A0-4DB3-9442-F5C881FE1B4D}
Name: Python 3.12.4 Documentation (64-bit)
Uninstall String: MsiExec.exe /I{AC7F58DC-CF45-4B28-9EAE-AE152C588907}
Name: Python 3.12.4 Executables (64-bit)
Uninstall String: MsiExec.exe /I{754A267E-52AE-4A9F-AFF4-F67EDC4B3610}
Name: Python 3.12.4 pip Bootstrap (64-bit)
Uninstall String: MsiExec.exe /I{EFA83559-2E1E-4671-85F7-B28AA1DD08D7}
Name: Python 3.12.4 Standard Library (64-bit)
Uninstall String: MsiExec.exe /I{62DD7DAF-6279-46FA-A06B-C4A541244045}
Name: Python 3.12.4 Tcl/Tk Support (64-bit)
Uninstall String: MsiExec.exe /I{71BC2876-3319-44FC-B5C5-1C0B86FC2733}
Name: Python 3.12.4 Test Suite (64-bit)
Uninstall String: MsiExec.exe /I{AC669800-A797-444D-A450-A5109BBC74DE}
Uninstall String: MsiExec.exe /X{3C4935A5-B72E-4DA4-809E-0287A0BC046F}
Version: 4.6.2
Publisher: The qBittorrent project
Install Date: N/A
Uninstall String: "C:\Program Files\qBittorrent\uninst.exe"
Version: 3.9.0229.022700
Publisher: Razer Inc.
Install Date: N/A
Uninstall String: "C:\Windows\Installer\Razer\Installer\App\RazerInstaller.exe" /uninstall
Name: Realtek Audio Driver
Version: 6.0.9689.1
Publisher: Realtek Semiconductor Corp.
Uninstall String: "C:\Program Files (x86)\InstallShield Installation Information\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}\setup.exe" -runfromtemp  -removeonly
Name: Realtek Ethernet Controller Driver
Version: 10.65.421.2023
Publisher: Realtek
Uninstall String: "C:\Program Files (x86)\InstallShield Installation Information\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}\setup.exe" -runfromtemp -removeonly
Version: N/A
Install Date: N/A
Uninstall String: "C:\Riot Games\Riot Client\RiotClientServices.exe" --uninstall-product=Riot_Client --uninstall-patchline=
Version: N/A
Publisher: Riot Games, Inc.
Install Date: N/A
Uninstall String: "C:\Program Files\Riot Vanguard\installer.exe"
Version: N/A
Publisher: Psyonix LLC
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/252950
Name: Rockstar Games Launcher
Version: 1.0.95.2152
Install Date: N/A
Uninstall String: "C:\Program Files\Rockstar Games\Launcher\uninstall.exe" -enableFullMode -uninstall=launcher
Name: Rockstar Games Social Club
Version: 2.3.6.5
Install Date: N/A
Uninstall String: C:\Program Files\Rockstar Games\Social Club\uninstallRGSCRedistributable.exe
Version: 8.0.1.1000
Publisher: Samsung Electronics
Install Date: 20240117
Uninstall String: "C:\Program Files (x86)\Samsung\Samsung Magician\unins000.exe"
Name: Slay the Spire
Version: N/A
Publisher: Mega Crit
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/646570
Version: 6.11.0.0
Publisher: Antoine Aflalo
Install Date: 20240613
Uninstall String: "C:\Program Files\SoundSwitch\unins000.exe"
Version: 1.32
Publisher: Piriform
Install Date: N/A
Uninstall String: "C:\Program Files\Speccy\uninst.exe"
Version: 2.10.91.91
Publisher: Valve Corporation
Install Date: N/A
Uninstall String: C:\Program Files (x86)\Steam\uninstall.exe
Version: N/A
Publisher: Unknown Worlds Entertainment
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/264710
Name: TavernWorker for Dark and Darker - Steam
Version: N/A
Publisher: IRONMACE
Install Date: N/A
Uninstall String: "C:\Program Files\IRONMACE\Tavern\Steam\TavernApp_1_1\TavernWorker Uninstaller.exe"
Name: THRONE AND LIBERTY
Version: N/A
Publisher: NCSOFT
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\Steam\steam.exe" steam://uninstall/2429640
Name: Thunder Master v4.14
Version: 4.14.0.1
Publisher: Palit Microsystems Ltd.
Install Date: 20231106
Uninstall String: "C:\Program Files\Thunder Master\unins000.exe"
Name: Thunderstore Mod Manager
Version: 1.34.0
Publisher: Overwolf app
Install Date: 20231216
Uninstall String: C:\Program Files (x86)\Overwolf\OWUninstaller.exe --uninstall-app=ahpflogoookodlegojjphcjpjaejgghjnfcdjdmi
Name: THX Spatial Audio USB 1532-0528
Version: 3.0.36.0
Publisher: THX
Install Date: 20231209
Uninstall String: "C:\ProgramData\Package Cache\{EE453AD6-BBA2-42FE-B4E7-202105CF03AB}\wixbs.exe" /burn.clean.room  /uninstall
Version: 3.0.36.0
Publisher: THX
Uninstall String: MsiExec.exe /I{CEB585C4-3215-4A32-9A6A-25ED597F42B6}
Version: 3.0.30.0
Publisher: THX
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{56cf1deb-74cc-4221-a1ff-5fb64b50f9e5}\thxapo-installer.exe"  /uninstall
Version: 3.0.30.0
Publisher: THX
Uninstall String: MsiExec.exe /X{28BA966E-2B76-4B90-B9EF-A000E6518EBB}
Name: THX V3 APO Presets
Version: 3.0.36.1
Publisher: THX
Uninstall String: MsiExec.exe /X{79D9121B-B9D9-47B7-AB23-9127DB0CB242}
Version: 3.0.18
Publisher: THX
Uninstall String: MsiExec.exe /X{502A568D-4A4A-4B8F-8B1A-5D0342D767AE}
Version: 3.0.18
Publisher: THX
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{655eda3c-5df1-4468-a44f-ad0e68cf4cb3}\installer.exe"  /uninstall
Version: 3.0.36.1
Publisher: THX
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{7058ec95-5f6b-4542-998d-e0c5bd701f43}\installer.exe"  /uninstall
Version: 147.0.10965
Publisher: Ubisoft
Install Date: N/A
Uninstall String: C:\Program Files (x86)\Ubisoft\Ubisoft Game Launcher\Uninstall.exe
Version: 1.5.4.0
Publisher: Tomasz Mon
Install Date: N/A
Uninstall String: "C:\Program Files\USBPcap\Uninstall.exe"
Version: 1.0.3.11
Publisher: Verbatim
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{d601832a-0d94-46ce-9b19-78e8a5887313}\AacSetup.exe"  /uninstall
Version: 1.0.3.11
Publisher: Verbatim
Uninstall String: MsiExec.exe /I{35CB65C6-A7E3-4EE7-AD40-738D70A72164}
Name: VLC media player
Version: 3.0.20
Publisher: VideoLAN
Install Date: N/A
Uninstall String: "C:\Program Files\VideoLAN\VLC\uninstall.exe"
Name: WD P40 Game Drive
Version: 1.0.2.18
Publisher: Western Digital Corporation
Uninstall String: MsiExec.exe /I{EE55DBAE-ECDD-4ADD-AAB5-23DE848B0996}
Version: 1.0.2.18
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{72b1a866-fc31-4381-bff3-fa6cd8823777}\AacSetup.exe"  /uninstall
Version: 1.55.0.0
Publisher: Winaero
Install Date: 20231230
Uninstall String: "C:\Program Files\Winaero Tweaker\unins000.exe"
Version: N/A
Publisher: N/A
Install Date: N/A
Uninstall String: "C:\Program Files (x86)\WinDirStat\Uninstall.exe"
Name: WinRAR 6.24 (64-bit)
Version: 6.24.0
Publisher: win.rar GmbH
Install Date: N/A
Uninstall String: C:\Program Files\WinRAR\uninstall.exe
Name: Wireshark 4.2.5 x64
Version: 4.2.5
Publisher: The Wireshark developer community, https://www.wireshark.org
Install Date: N/A
Uninstall String: "C:\Program Files\Wireshark\uninstall-wireshark.exe"
Name: Wise Auto Shutdown
Version: 2.0.5
Publisher: Lespeed Technology Co., Ltd.
Uninstall String: "C:\Program Files (x86)\Wise\Wise Auto Shutdown\unins000.exe"
Version: 1.0.103
Publisher: Entropy6
Install Date: N/A
Uninstall String: "C:\ProgramData\Package Cache\{c5b37839-d051-435a-8254-42eeabe03417}\XMetersSetup.exe"  /uninstall
Version: 1.0.103
Publisher: Entropy6
Install Date: 20231128
Uninstall String: MsiExec.exe /X{6E02C3C3-C6C9-4DAC-BC27-9B13C3D6FA77}
Version: 1.0
Publisher: Google\Chrome
Uninstall String: "C:\Program Files\Google\Chrome\Application\chrome.exe" --profile-directory=Default --uninstall-app-id=agimnkijcaahngcdmfeangaknmldooml
Startup items from the Run key:
BraveVpnWireguardService : "C:\Program Files\BraveSoftware\Brave-Browser\Application\121.1.62.156\BraveVpnWireguardService\brave_vpn_wireguard_service.exe" --interactive
NextDNS : "C:\Program Files (x86)\NextDNS\NextDNS.exe"
Riot Vanguard : "C:\Program Files\Riot Vanguard\vgtray.exe"
RtkAudUService : "C:\Windows\System32\DriverStore\FileRepository\realtekservice.inf_amd64_9f05190a2befb920\RtkAudUService64.exe" -background
SecurityHealth : C:\Windows\system32\SecurityHealthSystray.exe
Lightshot : C:\Program Files (x86)\Skillbrains\lightshot\Lightshot.exe
BakkesMod : "C:\Program Files\BakkesMod\BakkesMod.exe"
Battle.net : "C:\Program Files (x86)\Battle.net\Battle.net.exe" --autostarted
Discord : "C:\Users\lipov\AppData\Local\Discord\Update.exe" --processStart Discord.exe
DualSenseX : C:\Users\lipov\AppData\Local\DualSenseX\DualSenseX.exe
EADM : "C:\Program Files\Electronic Arts\EA Desktop\EA Desktop\EALauncher.exe" -silent
EpicGamesLauncher : "C:\Program Files (x86)\Epic Games\Launcher\Portal\Binaries\Win64\EpicGamesLauncher.exe" -silent -launchcontext=boot
LGHUB : "C:\Program Files\LGHUB\system_tray\lghub_system_tray.exe" --minimized
MicrosoftEdgeAutoLaunch_ED187E6E6357BE14E05D5B47ACC16E36 : "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --no-startup-window --win-session-start
OneDrive : "C:\Program Files\Microsoft OneDrive\OneDrive.exe" /background
Overwolf : C:\Program Files (x86)\Overwolf\OverwolfLauncher.exe -overwolfsilent
Plex Media Server : "C:\Program Files\Plex\Plex Media Server\Plex Media Server.exe"
RiotClient : C:\Riot Games\Riot Client\RiotClientServices.exe --launch-background-mode
SoundSwitch : C:\Program Files\SoundSwitch\SoundSwitch.exe
Steam : "C:\Program Files (x86)\Steam\steam.exe" -silent
Microsoft Store Apps:
Version: 2.1810.18004.0
Publisher: CN=Microsoft Corporation, O=Microsoft Corporation, L=Redmond, S=Washington, C=US
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.0_2.1810.18004.0_x64__8wekyb3d8bbwe
Version: 14.0.32530.0
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00_14.0.32530.0_x64__8wekyb3d8bbwe
Version: 2.2.29512.0
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Framework.2.2_2.2.29512.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Framework.2.2_2.2.29512.0_x86__8wekyb3d8bbwe
Version: 2.2.28604.0
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Runtime.2.2_2.2.28604.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Runtime.2.2_2.2.28604.0_x86__8wekyb3d8bbwe
Version: 2.4.18324.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Wallet_2.4.18324.0_x64__8wekyb3d8bbwe
Version: 2000.802.31.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.2_2000.802.31.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.2_2000.802.31.0_x86__8wekyb3d8bbwe
Version: 8.2310.30001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.8_8.2310.30001.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.8_8.2310.30001.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00.UWPDesktop_14.0.32530.0_x64__8wekyb3d8bbwe
Version: 1.54.4001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.XboxGameOverlay_1.54.4001.0_x64__8wekyb3d8bbwe
Version: 2.42007.9001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.4_2.42007.9001.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.4_2.42007.9001.0_x64__8wekyb3d8bbwe
Version: 1.7.27413.0
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Framework.1.7_1.7.27413.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Framework.1.7_1.7.27413.0_x64__8wekyb3d8bbwe
Version: 1.7.27422.0
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Runtime.1.7_1.7.27422.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.NET.Native.Runtime.1.7_1.7.27422.0_x64__8wekyb3d8bbwe
Version: 1.21.13002.0
Install Location: C:\Program Files\WindowsApps\Microsoft.XboxSpeechToTextOverlay_1.21.13002.0_x64__8wekyb3d8bbwe
Version: 2.32002.13001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.3_2.32002.13001.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.3_2.32002.13001.0_x64__8wekyb3d8bbwe
Version: 10.0.23012.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Services.Store.Engagement_10.0.23012.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.Services.Store.Engagement_10.0.23012.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.0_2.1810.18004.0_x86__8wekyb3d8bbwe
Version: 1.24.10001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Xbox.TCUI_1.24.10001.0_x64__8wekyb3d8bbwe
Version: 4.2308.1005.0
Install Location: C:\Program Files\WindowsApps\Microsoft.549981C3F5F10_4.2308.1005.0_x64__8wekyb3d8bbwe
Version: 3000.934.1904.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.3_3000.934.1904.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.3_3000.934.1904.0_x64__8wekyb3d8bbwe
Version: 10.2103.28.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsSoundRecorder_10.2103.28.0_x64__8wekyb3d8bbwe
Version: 10.2008.3001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.ScreenSketch_10.2008.3001.0_x64__8wekyb3d8bbwe
Version: 48.104.4001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.XboxApp_48.104.4001.0_x64__8wekyb3d8bbwe
Version: 2000.21051.1282.0
Install Location: C:\Program Files\WindowsApps\Microsoft.MixedReality.Portal_2000.21051.1282.0_x64__8wekyb3d8bbwe
Version: 1.0.9.0
Publisher: CN=84674BE6-A801-4225-AB65-33A21CCABF33
Install Location: C:\Program Files\WindowsApps\55809savaged.BlackNotepad_1.0.9.0_neutral__p2aarvyam9pfc
Version: 10.2312.1.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Getstarted_10.2312.1.0_x64__8wekyb3d8bbwe
Version: 4000.1082.2259.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.4_4000.1082.2259.0_x64__8wekyb3d8bbwe
Version: 14.0.33321.0
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00_14.0.33321.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00.UWPDesktop_14.0.33321.0_x64__8wekyb3d8bbwe
Version: 14.0.33519.0
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00.UWPDesktop_14.0.33519.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00_14.0.33519.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00_14.0.33519.0_x64__8wekyb3d8bbwe
Version: 10.22091.10061.0
Install Location: C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.22091.10061.0_x64__8wekyb3d8bbwe
Version: 4000.1136.2333.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.4_4000.1136.2333.0_x64__8wekyb3d8bbwe
Version: 1.1.451.0
Install Location: C:\Program Files\WindowsApps\Microsoft.VP9VideoExtensions_1.1.451.0_x64__8wekyb3d8bbwe
Version: 19.23.19.0
Install Location: C:\Program Files\WindowsApps\microsoft.microsoftskydrive_19.23.19.0_x64__8wekyb3d8bbwe
Version: 10.2202.100.0
Install Location: C:\Program Files\WindowsApps\Microsoft.People_10.2202.100.0_x64__8wekyb3d8bbwe
Version: 1.1.861.0
Install Location: C:\Program Files\WindowsApps\Microsoft.HEIFImageExtension_1.1.861.0_x64__8wekyb3d8bbwe
Version: 5001.119.156.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.119.156.0_x64__8wekyb3d8bbwe
Version: 8.1.966.0
Publisher: CN=D6816951-877F-493B-B4EE-41AB9419C326
Install Location: C:\Program Files\WindowsApps\NVIDIACorp.NVIDIAControlPanel_8.1.966.0_x64__56jybvy8sckqj
Version: 11.2403.4.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsMaps_11.2403.4.0_x64__8wekyb3d8bbwe
Version: 4000.1227.1637.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.4_4000.1227.1637.0_x64__8wekyb3d8bbwe
Version: 14.0.33728.0
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00.UWPDesktop_14.0.33728.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.140.00.UWPDesktop_14.0.33728.0_x64__8wekyb3d8bbwe
Version: 1.1.1295.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WebMediaExtensions_1.1.1295.0_x64__8wekyb3d8bbwe
Version: 12.0.40653.0
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.120.00.UWPDesktop_12.0.40653.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.120.00.UWPDesktop_12.0.40653.0_x64__8wekyb3d8bbwe
Version: 9.29.1974.0
Install Location: C:\Program Files\WindowsApps\Microsoft.DirectXRuntime_9.29.1974.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.DirectXRuntime_9.29.1974.0_x86__8wekyb3d8bbwe
Version: 11.0.61135.0
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.110.00.UWPDesktop_11.0.61135.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.VCLibs.110.00.UWPDesktop_11.0.61135.0_x64__8wekyb3d8bbwe
Version: 11.2405.2.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsCalculator_11.2405.2.0_x64__8wekyb3d8bbwe
Version: 5001.159.55.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.159.55.0_x64__8wekyb3d8bbwe
Version: 1.1.1711.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WebpImageExtension_1.1.1711.0_x64__8wekyb3d8bbwe
Version: 1.23.1911.0
Install Location: C:\Program Files\WindowsApps\Microsoft.DesktopAppInstaller_1.23.1911.0_x64__8wekyb3d8bbwe
Version: 5001.178.1908.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.178.1908.0_x64__8wekyb3d8bbwe
Version: 12.115.1001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.XboxIdentityProvider_12.115.1001.0_x64__8wekyb3d8bbwe
Version: 2024.11070.11002.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2024.11070.11002.0_x64__8wekyb3d8bbwe
Version: 6.1.2.0
Install Location: C:\Program Files\WindowsApps\Microsoft.MicrosoftStickyNotes_6.1.2.0_x64__8wekyb3d8bbwe
Version: 16001.14326.22008.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Office.OneNote_16001.14326.22008.0_x64__8wekyb3d8bbwe
Version: 1.2407.21972.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsFeedbackHub_1.2407.21972.0_x64__8wekyb3d8bbwe
Version: 5001.214.1843.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.214.1843.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.214.1843.0_x86__8wekyb3d8bbwe
Version: 22407.1401.0.0
Install Location: C:\Program Files\WindowsApps\Microsoft.StorePurchaseApp_22407.1401.0.0_x64__8wekyb3d8bbwe
Version: 7.2407.16012.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Microsoft3DViewer_7.2407.16012.0_x64__8wekyb3d8bbwe
Version: 6.2408.2027.0
Install Location: C:\Program Files\WindowsApps\Microsoft.MSPaint_6.2408.2027.0_x64__8wekyb3d8bbwe
Version: 19041.62.215.0
Install Location: C:\Program Files\WindowsApps\Microsoft.LanguageExperiencePacken-GB_19041.62.215.0_neutral__8wekyb3d8bbwe
Version: 11.2406.59.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAlarms_11.2406.59.0_x64__8wekyb3d8bbwe
Version: 4000.1309.2056.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.4_4000.1309.2056.0_x86__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.4_4000.1309.2056.0_x64__8wekyb3d8bbwe
Version: 10.2407.22431.0
Install Location: C:\Program Files\WindowsApps\Microsoft.GetHelp_10.2407.22431.0_x64__8wekyb3d8bbwe
Version: 7.2409.9001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.7_7.2409.9001.0_x64__8wekyb3d8bbwe
Install Location: C:\Program Files\WindowsApps\Microsoft.UI.Xaml.2.7_7.2409.9001.0_x86__8wekyb3d8bbwe
Version: 0.1800.625.0
Install Location: C:\Program Files\WindowsApps\Microsoft.Windows.DevHome_0.1800.625.0_x64__8wekyb3d8bbwe
Version: 24.93.16001.0
Install Location: C:\Program Files\WindowsApps\Microsoft.GamingServices_24.93.16001.0_x64__8wekyb3d8bbwe
Version: 22408.1401.5.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsStore_22408.1401.5.0_x64__8wekyb3d8bbwe
Version: 1.51.331.0
Publisher: CN=83564403-0B26-46B8-9D84-040F43691D31
Install Location: C:\Program Files\WindowsApps\RealtekSemiconductorCorp.RealtekAudioControl_1.51.331.0_x64__dt26b99r8h8gj
Version: 1.24082.137.0
Install Location: C:\Program Files\WindowsApps\Microsoft.YourPhone_1.24082.137.0_x64__8wekyb3d8bbwe
Version: 7.224.9242.0
Install Location: C:\Program Files\WindowsApps\Microsoft.XboxGamingOverlay_7.224.9242.0_x64__8wekyb3d8bbwe
Version: 2.1.2192.0
Install Location: C:\Program Files\WindowsApps\Microsoft.HEVCVideoExtensions_2.1.2192.0_x64__8wekyb3d8bbwe
Version: 1.100.5635.0
Publisher: CN=EB51A5DA-0E72-4863-82E4-EA21C1F8DFE3
Install Location: C:\Program Files\WindowsApps\AppUp.IntelGraphicsExperience_1.100.5635.0_x64__8j3eq9eme6ctt
Version: 4.20.9120.0
Install Location: C:\Program Files\WindowsApps\Microsoft.MicrosoftSolitaireCollection_4.20.9120.0_x64__8wekyb3d8bbwe
Version: 3.1.11720.0
Publisher: CN=33F0F141-36F3-4EC2-A77D-51B53D0BA0E4
Install Location: C:\Program Files\WindowsApps\Clipchamp.Clipchamp_3.1.11720.0_neutral__yxz26nhyzhsrt
Version: 16005.14326.22054.0
Install Location: C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_16005.14326.22054.0_x64__8wekyb3d8bbwe
Version: 18.2409.1102.0
Install Location: C:\Program Files\WindowsApps\Microsoft.MicrosoftOfficeHub_18.2409.1102.0_x64__8wekyb3d8bbwe
Version: 4.53.62621.0
Install Location: C:\Program Files\WindowsApps\Microsoft.BingWeather_4.53.62621.0_x64__8wekyb3d8bbwe
Version: 11.2408.4.0
Install Location: C:\Program Files\WindowsApps\Microsoft.ZuneMusic_11.2408.4.0_x64__8wekyb3d8bbwe
Version: 2024.2408.1.0
Install Location: C:\Program Files\WindowsApps\Microsoft.WindowsCamera_2024.2408.1.0_x64__8wekyb3d8bbwe
Version: 2.2438.5.0
Publisher: CN=24803D75-212C-471A-BC57-9EF86AB91435
Install Location: C:\Program Files\WindowsApps\5319275A.WhatsAppDesktop_2.2438.5.0_x64__cv1g1gvanyjgm
Version: 5.27.4.0
Publisher: CN=CACCD12F-7BFA-4346-AD14-30B4E275348F
Install Location: C:\Program Files\WindowsApps\33C30B79.HyperXNGenuity_5.27.4.0_x64__0a78dr3hq0pvt
Version: 1.247.364.0
Publisher: CN=453637B3-4E12-4CDF-B0D3-2A3C863BF6EF
Install Location: C:\Program Files\WindowsApps\SpotifyAB.SpotifyMusic_1.247.364.0_x64__zpdnekdrzrea0
Version: 2410.1001.41.0
Install Location: C:\Program Files\WindowsApps\Microsoft.GamingApp_2410.1001.41.0_x64__8wekyb3d8bbwe
This is my laundry list, it's a good starting point for troubleshooting and should get you an idea what's going on, none of these should impact a warranty claim:
1. Try running the following programs, also try to keep at least 25-30% of your disks as free space.
Run Disk Cleanup (check all the boxes) this will delete things such as your recycling bin, so make sure you don't have any files you want to keep.
Run Defragment and Optimize Drives, run this on your drives.
These will free up some space, but you may need to relocate/delete files to reach the suggested free space.
2. Disable any overclocking or changes to power/performance settings
Undo any overclocking you may have done (if any)
Settings > System > Power and sleep > Additional power settings
Make sure your power plan is set to balanced, high performance/ultimate performance is only beneficial on gaming laptops where it needs that extra boost.
3. Check for Operating System Corruption
Right click on the Windows logo in the bottom left and select Windows Powershell (Admin)
Run these three commands separately:
sfc /scannow
Dism /Online /Cleanup-Image /CheckHealth
Dism /Online /Cleanup-Image /ScanHealth
Dism /Online /Cleanup-Image /RestoreHealth
These will take a while to run, do not close out of Powershell while they are running, if one fails then move onto the next and then loop back around.
Note: It doesn't hurt to make a system backup before you make all these changes, save any important files of folders. While these changes shouldn't cause any issues, better to be safe than sorry.
4. Unplug unnecessary devices.
If you have a gamepad, extra monitor, external hard drive/flash drive, or anything that is not essential to using the computer plugged in, unplug it.
Once you have completed all of these tasks, restart it (using the restart option in the power menu) and re-test.
Reactions: veeg
To avoid us having to ask for an update every couple of days we will close this thread until the OP has the time available to work towards resolving the issue, PM a member of staff when you are ready and the thread can be reopened.
