I have a Dell XPS 8940 desktop. I have two physical hard drives, a Western Digital NVMe SSD pc SN530 512 GB, M.2 2280, and a Crucial MX500 1TB 3D NAND SATA 2.5 Inch Internal SSD.
Originally I had Windows installed on the smaller but faster NVMe drive, and I had my Windows user profile folder mapped to the slower but more spacious SATA drive.
I recently unsuccessfully tried to set up dual boot with Ubuntu. Ubuntu doesn’t work with Dell’s Intel Rapid Storage Technology, and it pointed me to this tutorial on how to disable it:
Unfortunately, it didn’t work, Windows wouldn’t boot and I think I may have made things worse with the DOS diskpart command. I’ve included screenshots of my BIOS and current Disk Management profile. I;'m not concerned about Linux right now, but I want to get my PC back the way it was.
I ended up having to reinstall Windows 11, but the problem is that for some reason, it reinstalled it on my larger but slower SATA drive. I’m not sure why it did this but I’d like to get it back on my NVMe drive.
In BIOS it shows that drive in the boot sequence but can’t or won’t boot to it. Looking at that drive in File Explorer it still has Windows folders there, so it wasn’t wiped. Is there a way I can try to ‘force’ it to try to boot to that drive instead? I have Acronis True Image 2020. Maybe I should try to image my new current working boot drive and ghost it to that original drive?
Thanks for any guidance you can offer.
