Originally posted by Bruce
Problem with settings
Hard to say without further testing.
Reset the BIOS back to factory defaults, and remove the potentially incompatible 2GB memory sticks, and disconnect D:\ and that may shed more light on the issue.
Apart from a potentially faulty GPU or mobo, it could also be the PSU - getting another for testing would be great.Comment
Don`t know what you mean by this, please explain both what you mean and what you did.Originally posted by Timevery time I updated the bios to different versions.
The card should have been in the board so that we could see if it was detected at all, there is a very good reason why us knowing this is important.Originally posted by TimWhen I started speecy the card was not installed
When you put the add on GPU back in we need you to get us the revision number of the MB for us, you mentioned updating the BIOS and so it is possible that you have been installing the wrong BIOS because there are different revisions of the same MB, there is a known PCI-E fault on one of them so we need the exact board that you have, some info here for how to find the number for us.Comment
Being that the OP has frequently revisited the forum but chose not to acknowledge my reply this thread will be closed.Comment
