Red cpu debug light on and my display for the monitor is black and says no connection
  • uniseslayer
    • Jan 2024
    • 3
    Hi I just built my pc and I set up and once I turned it on everything worked well but I have a cpu debug light on and my monitor says no connection I tried updating bios using the flash button and I reseatted the ram and cpu but it didn’t work please help
    SPECS:
    I7- 12700k
    Msi z690 edge WiFi ddr4
    Asus 4070 OC Dual
  • uniseslayer
    • Jan 2024
    • 3
    Here are the pics
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      Could you also include the power supply specs E.g Cooler Master 850W Gold V2 NOT E.g 850w
      What ram are you using - and speed
      Did you remove the plastic cover on the ram chip
      Did you use thermal paste?
      have you tried without the GPU
      • uniseslayer
        • Jan 2024
        • 3
        Yes I tried without the gpu I have the Corsair vengeance ddr4 3600 MHz for my cooler I got the LS720 se by deep cool and my power supply is the corsair rme 80+ 750 W gold
        • PeterOz
          • Mar 2021
          • 4181
          And these two? - Not trying to be funny. This happened just recently.
          Your ram is not compatible with your CPU. However, it should not be the cause.
          Can you try with just 1 stick of ram.
          https://ark.intel.com/content/www/us...-5-00-ghz.html
          • PeterOz
            • Mar 2021
            • 4181
            Put 1 stick of ram into Slot A2
            Have you connected the cpu power to the cpu1 connection.
            Is your cooler connected to the CPU Fan1 or the cpu Pump1
            • PeterOz
              • Mar 2021
              • 4181
              Looking at Pic 0111 It looks like the cpu power is not connected.
              I cannot be 100% sure because it goes blurry when enlarged.
                @uniseslayer - any update?
                  Closing - no activity.
