Problem introducing a second monitor
  • Stefan_Vanderty
    • Jan 2023
    • 2
    Hello!
    Does anyone know if my monitors go into power-saving mode if I insert a second monitor?
    I can only operate both for a few seconds and then enter this power-saving mode, the unit remains open but the monitors no longer light up.
    I also changed the battery from the motherboard, cleaned the ram memory, and restored the power plan to default, but without effect.
    Thanks!
    • 8980
    Try this.
    And quote:
    [ol]
    [li]Click the Power icon on the right side of the desktop taskbar.[/li][li]Click the blue “More Power Options” link at the bottom of the pop-up window.[/li][li]Click and enable the “High Performance” radio button in the Additional Plans section in the lower half of the Power Options window.[/li][/ol]
    More items…
    • Stefan_Vanderty
      • Jan 2023
      • 2
      Hello! I tried this method and it still didn’t work, and also I tried all the methods from the link you sent.
        • 8980
        OK
        Let’s get more help.
        @PeterOz @Bruce
        • Rustys
          • 7862
          What Operating system?
          Version?
          Release?
          Desktop Environment?
          Complete system specs including make and model
          • PeterOz
            PCHF Technical Response Team
            • Mar 2021
            • 4190
            If this is a laptop as well as make and model could you post the serial number.
              PCHF Moderator
              • 10699
              let’s get all the specs…
              get Speccy from here; Speccy - Download Builds
              now you can paste (Ctrl+V) that link into a post.
              One component Speccy doesn’t cover is the Power Supply Unit, so please also include the make/model of the PSU.
              • Rustys
                • 7862
                abandoned thread
