Help ID what part is called (picture)
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #16
    HP power supply 240w
    • PeterOz
      • Mar 2021
      • 4181
      #17
      can i ask how are you going to fit the drives in the case
      • marioxb
        • Jan 2023
        • 11
        #18
        So the motherboard has two SATA ports. It came with a hard drive (of course) and a DVD drive. There is one empty bay next to the disc drive. I’ve installed a new HDD in that slot, using the cables from the (broken) DVD drive. Now I want to replace that DVD drive with a BD burner, and also add in a 3rd HDD. (All 3.5"). Not entirely sure where the third HDD would go. I suppose I could get an external enclosure for that one. But I’d like at least one more sata port.
        • PeterOz
          • Mar 2021
          • 4181
          #19
          do you have anything plugged into the pcie ports - black ones
            #20
            @marioxb - still need help?
            • marioxb
              • Jan 2023
              • 11
              #21
              Sorry I haven’t had a chance to look inside my PC again, I’ll look in the morning. Thank you!
              • marioxb
                • Jan 2023
                • 11
                #22
                No. But are they PCIE? They seem too long. [ATTACH type=“full”]11345[/ATTACH]
                • PeterOz
                  • Mar 2021
                  • 4181
                  #23
                  Something like this should work Server Busy
                  @Bruce @phillpower2
                    #24
                    the long blacks are PCIe x 16.
                    the short blacks are PCIe x 1.
                    the whites are PCI.
                    the Amazon link from Peter would be a good way to go.
                    not sure of the bottlenecking if 4 SATA devices are connected on that one PCIe x 1 bus lane.
                    would be better than USB2 external connections, and probably better than USB3 speeds.
                    • marioxb
                      • Jan 2023
                      • 11
                      #25
                      Alright guys. I appreciate all the help. I think I can take it from here. Thanks!
                        #26
                        no worries.
                        I’ll close this then, and you can always PM a staff member to have it re-opened if necessary.
