Help diagnosing pc. Beeps 5 times, system fan won't spin, others do. MB lights up
  • loosand12
    • Dec 2021
    • 6
    Hi everyone and thanks for your help.
    I have been working on this for over a day now…
    I opened my tower case to inspect my GA-Z170-HD3 MB for a m.2 slot to upgrade my ssd.
    I found the slot, then decided to clean out some dust while I was there… this is where the problems started.
    I used (now regrettably) the end of a plastic vacuum to suck up some of the dust that I cleaned out of the pc case. (I definately did not notice any static electricity come off)
    I took off the cpu fan, the top 2 general fans, wiped the dust then put them back on and turned on my pc.
    At first it was fine, then youtube started to stall.. then alot.. i restarted my pc, it became progressively slower, so I restarted it again.
    it took forever to boot, then got stuck in a cycle where the fans would start (both general fans and cpu fan) but the pc would not turn
    on, it would turn off then try again to turn on 1 second later.
    After doing some research I thought it could be the power supply, so I did the paperclip test, it passed - it powered both general fans.
    I tried the whole pc again.. This time everything turns on except the cpu fan. - The motherboard lights up orange and steady,
    Everything seems to run except the system fan. the computer does not beep once on startup (like it normally does),
    it goes for about 1 minute then beeps 5 times, shuts down and tries again, repeat and repeat.
    It therefore seems to me that the issue is either the psu, cpu fan, cpu or motherboard.
    I am trying to think of ways I can narrow the search for the damaged piece down better before buying and testing each piece listed above.
    In order of suspicion, I Guess it would be cpu fan 1, cpu 2, power supply 3, motherboard 4.
    Because the motherboard lights up, and the cpu fan does not go at all. Does the cpu need the cpu fan to be spinning for the cpu to operate?
    I had the vacuum closest to the cpu fan, though they may not matter.
    I have a good pc with good parts and want to salvage as much as possible. It wasn’t cheap!
    Gigabyte GA-Z170-HD3 MB
    Intel core I7 6700K
    Corsair 550w TX550M 80 Plus gold PSU
    Deepcool Maelstrom 120t blue led intel amd cpu cooler
    Samsung ssd 250gb
    4 X DDR4 8gb hyperfury memory sticks
    Any suggestions appreciated. thank you.
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    Hi loosand12
    When you removed the CPU fan did you just unclip/unscrew the fan from the heatsink or did you remove the heatsink also.
    Double check you connected the cpu fan to the correct connector on the motherboard.
    Clear the cmos - see attached
    TOUCh metal to discharge static
    Cheers
    PeterOz
    • loosand12
      • Dec 2021
      • 6
      Originally posted by PeterOz
      Hi loosand12
      Cheers
      PeterOz
      i just unclipped unscrewed it, I did not remove the heatsink. About an hour ago, I tried the pc again, this time the psu began clicking constantly which led me to believe the issue is the psu. I borrowed a friends psu and the pc worked, (although the borrowed psu was quite weak - the cpu fan did not come on, but probably did not need to as the pc was quite cool then). So I am now looking ay buying a new psu, hoping the was the only issue. Lucky for me, the pc gave different responses as I left it for a while then turned it back on - first just turning off and on, then beeping 5 times, then the psu clicking, which has helped me narrow it down (hopefully) to the psu as the only damaged item. I will let you know how I go, many thanks for your help Peter.
      • PeterOz
        • Mar 2021
        • 4181
        Some cpu fans will stay off until it get hot - monitor it .
        I would up the PSU from 550W and now tou can get them with a 10 year warranty.
        Please do. You are welcome
        Cheers
        PeterOz
        • georgeks
          • May 2017
          • 335
          GIGABYTE provides a list for the BIOS beep codes.
          See it here https://www.gigabyte.com/Support/FAQ/816
            @loosand12 - do you still need help?
              Closing thread
