Problem with i7 10700k! It gets too hot!
  • Steve
    • Jul 2021
    • 13
    Hello guys, heres my System:
    Win 10 Home
    i7 10700k not OC
    Motherboard: MPG Z490 Gaming Plus (Newest Bios Version)
    32 GB RAM Corsair Vengeance
    650 W Corsair PSU
    2 SSDs ( 250GB, 1 TB), 1 HDD (750 GB)
    RTX 2070 Super Asus Dual EVO Advanced
    CPU Cooler: BeQuiet Dark Rock 4 Pro
    Case: Bequiet Pure Base 600 (with the 2 Stock Fans)
    I just reinstalled Windows 10, updated all Drivers (Windows Updates, Chipset Drivers etc.)
    and my i7 10700k idles at 55 Celsius Degrees most of the time. it weirdly jumps from 52-60 all the time in IDLE, and CPU Frequence (Clock) is 4700 MHZ all the Time.
    I have the Windows Energy Options on Balanced.
    I applied a fairly big dot on the CPU (Grizzly Thermal Paste) and applied the CPU Cooler.
    I dont know what I can do anymore, its just too hot.
    My room temperature is 25 Celsius Degrees.
    Thanks for the help!
  • Steve
    • Jul 2021
    • 13
    Yeah i just bought it yesterday. I applied a dot as big as a pea as sugessted on various youtube videos.
    Yeah the fans spin!
    • jmarket
      PCHF Owner
      • 7695
      • CachyOS
      • Intel Arc A770 (16 GB)
      It’s quite possible the CPU cooler is a dud. Take a look at the CPU cooler. Do you see any thermal paste coming out where the heatsink contacts the lid of the CPU?
      The CPU is not de-lidded is it?
      • Steve
        • Jul 2021
        • 13
        no no thermal paste, the cpu is not delidded.
        could it be the high cpu base clock of 4700 mhz?
        • jmarket
          PCHF Owner
          • 7695
          • CachyOS
          If you’re overclocking, a fan CPU won’t cut it. You need a liquid cooler because of the intense heat created by overclocking.
          • Steve
            • Jul 2021
            • 13
            Nope Im not overclocking
              Any updates?
              • Steve
                • Jul 2021
                • 13
                I just added 2 additonal system fans, one on the top of the case above the cpu cooler and one more at the front of the case.
                Temps are still 30-55 in idle (always fluctuating) dont know why.
                When downloading a game and while writing this its even 55-60.
                And my CPU fan runs at 875 RPM most of the time at 67 Percent, is that normal or too less RPM?
                  Sorry i missed your post.. Do you still need assistance?
                  • Steve
                    • Jul 2021
                    • 13
                    #10
                    Yeah still get high temps in idle 40-55 and in cyberpunk 60-75
                      #11
                      Any updates?
                      • Steve
                        • Jul 2021
                        • 13
                        #12
                        Run a benchmark test 84 was the highest peak. I changed the CPU cooler tough. Could the heat come from a faulty motherboard?
                          #13
                          Or the heat damaged the mobo..
                          jmarket
                          • Steve
                            • Jul 2021
                            • 13
                            #14
                            But could a faulty motherboard cause heat problems? Because then I would change my z490 gaming plus with a z490 tomahawk to see if it’s still there. Would I have to reinstall windows 10 for that?
                              #15
                              I don’t so but you have to install the chipset drivers for the tomahawk.
