Monitor isn't recognized but works and there's no PnP Monitor driver
  • virtuo
    • Jun 2020
    • 4
    Soo hello guys, I’ve a problem where my monitor is working fine and all but the pc can’t recognize it nor is there even a plug and play monitor driver(or the non-pnp variant)
    This windows hasn’t recognized my monitor for a long time but it always had the plug and play monitor driver, until,suddenly happened a while ago when I restarted my pc and I didn’t know why but i found that the starting screen is very low res so was the bios which had changed(like the options in it and how it looks changed slightly) and the pc no longer had plug and play monitor it rather said in resolution, “Display device on: DVI”.
    This is very frustrating cause my pc can’t recognize my monitor’s resolutions or aspect ratio and it disabled multiple options in nvidia control panel and continues to annoy me.
    I tried all types of fixes like updating bios, updating graphics card, tried to update and manually download my monitor’s driver(they’re for vista x64 x32) but couldn’t install them not even over pnp monitor cause it said they were latest, deleted plug and play monitor drivers which did nothing cause pc said they were unplugged, I tried changing bios settings and restoring them to default, I did sfc /scannow, I installed latest pc drivers earlier, I deleted old graphics cards drivers, tried to stop secure boot but since my bios changed, it was no longer there and I couldn’t do legacy boot or anything cause there were no options, manually installing plug and play monitors again but I couldn’t
    all in all, I wish I really could fix this, I wish if my pc can recognize the monitor itself but at least I want plug and play monitor to be identified
    my monitor is Dell 1907FP
    PC is HP Compaq 8200 Elite small form factor
    My graphics card is GT 1030 2gb ddr5
    My bios is HP bios 00.02.33(latest)
    windows 7 sp 1 x64
    if you need anything else please dont hesitate to ask! any help is welcome, I really wish to fix this!
    Here are my specs
    [HEADING=1]System Information[/HEADING]
    Time of this report: 6/14/2020, 17:29:46
    Machine name: YOUSSEF
    Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr_escrow.190220-1800)
    Language: English (Regional Setting: English)
    System Manufacturer: Hewlett-Packard
    System Model: HP Compaq 8200 Elite SFF PC
    BIOS: Default System BIOS
    Processor: Intel(R) Core™ i5-2400 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
    Memory: 10240MB RAM
    Available OS Memory: 10198MB RAM
    Page File: 7226MB used, 28969MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7601.17514 64bit Unicode
    [HEADING=1]DxDiag Notes[/HEADING]
    Code:
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
    [HEADING=1]DirectX Debug Levels[/HEADING]
    Direct3D: 0/4 (retail)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    [HEADING=1]Display Devices[/HEADING]
    Code:
          Card name: NVIDIA GeForce GT 1030
       Manufacturer: NVIDIA
          Chip type: GeForce GT 1030
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_1D01&SUBSYS_37671458&REV_A1
     Display Memory: 2706 MB
    Dedicated Memory: 1959 MB
    Shared Memory: 746 MB
    Current Mode: 1280 x 1024 (32 bit) (70Hz)
    Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,n vwgf2um,nvwgf2um
    Driver File Version: 26.21.0014.4614 (English)
    Driver Version: 26.21.14.4614
    DDI Version: 11
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 5/19/2020 00:18:40, 22226656 bytes
    WHQL Logo’d: Yes
    WHQL Date Stamp:
    Device Identifier: {D7B71E3E-5E41-11CF-EE65-69171BC2D735}
    Vendor ID: 0x10DE
    Device ID: 0x1D01
    SubSys ID: 0x37671458
    Revision ID: 0x00A1
    Driver Strong Name: oem86.inf:NVIDIA_Devices.NTamd64.6.1:Section138:26 .21.14.4614ci\ven_10de&dev_1d01
    Rank Of Driver: 00E62001
    Video Accel:
    Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    D3D9 Overlay: Supported
    DXVA-HD: Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    [HEADING=1]Sound Devices[/HEADING]
    Code:
            Description: Speakers (Realtek High Definition Audio)
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_103C1495& REV_1001
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: RTKVHD64.sys
    Driver Version: 6.00.0001.6730 (English)
    WHQL Logo’d: Yes
    Date and Size: 9/13/2012 17:05:30, 4145936 bytes
    Other Files:
    Driver Provider: Realtek Semiconductor Corp.
    HW Accel Level: Basic
    Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX™ 2.0 Listen/Src: No, No
    I3DL2™ Listen/Src: No, No
    Sensaura™ ZoomFX™: No
    [HEADING=1]Sound Capture Devices[/HEADING]
    Code:
            Description: Microphone (Realtek High Definition Audio)
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x1
    Format Flags: 0xFFFFF
    [HEADING=1]DirectInput Devices[/HEADING]
    Code:
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Code:
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Code:
      Device Name: USB KEYBOARD
         Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x258A, 0x0001
    FF Driver: n/a
    Code:
         Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Poll w/ Interrupt: No
    [HEADING=1]USB Devices[/HEADING]
    • USB Root Hub
      | Vendor/Product ID: 0x8086, 0x1C2D
      | Matching Device ID: usb\root_hub20
      | Service: usbhub
      | Driver: usbhub.sys, 11/20/2010 02:44:32, 343040 bytes
      | Driver: usbd.sys, 7/14/2009 03:06:23, 7936 bytes
      ±+ Generic USB Hub
      | | Vendor/Product ID: 0x8087, 0x0024
      | | Matching Device ID: usb\class_09
      | | Service: usbhub
    [HEADING=1]Gameport Devices[/HEADING]
    [HEADING=1]PS/2 Devices[/HEADING]
    • HID Keyboard Device
      | Matching Device ID: hid_device_system_keyboard
      | Service: kbdhid
      | Driver: kbdhid.sys, 11/20/2010 02:33:26, 33280 bytes
      | Driver: kbdclass.sys, 7/14/2009 04:48:04, 50768 bytes
    • Terminal Server Keyboard Driver
      | Matching Device ID: root\rdp_kbd
      | Upper Filters: kbdclass
      | Service: TermDD
      | Driver: i8042prt.sys, 7/14/2009 02:19:57, 105472 bytes
    • HID-compliant mouse
      | Vendor/Product ID: 0x093A, 0x2521
      | Matching Device ID: hid_device_system_mouse
      | Service: mouhid
      | Driver: mouhid.sys, 7/14/2009 03:00:20, 31232 bytes
      | Driver: mouclass.sys, 7/14/2009 04:48:27, 49216 bytes
    • Terminal Server Mouse Driver
      | Matching Device ID: root\rdp_mou
      | Upper Filters: mouclass
      | Service: TermDD
      | Driver: termdd.sys, 11/20/2010 05:33:58, 63360 bytes
      | Driver: sermouse.sys, 7/14/2009 03:00:20, 26624 bytes
    [HEADING=1]Disk & DVD/CD-ROM Drives[/HEADING]
    Code:
      Drive: C:
    Free Space: 0.1 GB
    Total Space: 49.9 GB
    File System: NTFS
    Model: WDC WD2500AAKX-603CA0 ATA Device
    Code:
      Drive: D:
    Free Space: 37.3 GB
    Total Space: 188.5 GB
    File System: NTFS
    Code:
      Drive: E:
    Free Space: 200.5 GB
    Total Space: 476.7 GB
    File System: NTFS
    Model: ST500DL001 HD503HI ATA Device
    [HEADING=1]System Devices[/HEADING]
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 7 - 1C1C
    Device ID: PCI\VEN_8086&DEV_1C1C&SUBSYS_1495103C&REV_B4\3&115 83659&0&E6
    Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 05:33:50, 184704 bytes
    Code:
     Name: High Definition Audio Controller
    Device ID: PCI\VEN_10DE&DEV_0FB8&SUBSYS_37671458&REV_A1\4&6E7 A141&0&01E0
    Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 02:43:44, 122368 bytes
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18
    Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_1495103C&REV_B4\3&115 83659&0&E4
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
    Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_1495103C&REV_B4\3&115 83659&0&E0
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
    Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_1495103C&REV_04\3&115 83659&0&D0
    Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17514 (English), 11/20/2010 02:43:56, 52224 bytes
    Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17514 (English), 11/20/2010 02:44:02, 325120 bytes
    Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17514 (English), 11/20/2010 02:44:32, 343040 bytes
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family 2 port Serial ATA Storage Controller - 1C08
    Device ID: PCI\VEN_8086&DEV_1C08&SUBSYS_1495103C&REV_04\3&115 83659&0&FD
    Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 04:45:45, 12352 bytes
    Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 04:45:46, 48720 bytes
    Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 04:52:21, 24128 bytes
    Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 05:32:48, 155520 bytes
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
    Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_1495103C&REV_04\3&115 83659&0&E8
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family 4 port Serial ATA Storage Controller - 1C00
    Device ID: PCI\VEN_8086&DEV_1C00&SUBSYS_1495103C&REV_04\3&115 83659&0&FA
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
    Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_1495103C&REV_04\3&115 83659&0&FB
    Driver: n/a
    Code:
     Name: Intel(R) 82579LM Gigabit Network Connection
    Device ID: PCI\VEN_8086&DEV_1502&SUBSYS_1495103C&REV_04\3&115 83659&0&C8
    Driver: C:\Windows\system32\DRIVERS\e1c62x64.sys, 11.15.0016.0000 (English), 1/11/2012 13:30:58, 360624 bytes
    Driver: C:\Windows\system32\e1c62x64.din, 12/23/2009 20:12:56, 3114 bytes
    Driver: C:\Windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 5/26/2009 10:05:46, 36472 bytes
    Driver: C:\Windows\system32\NicInstC.dll, 9.10.0074.0000 (English), 11/7/2011 02:28:54, 98496 bytes
    Driver: C:\Windows\system32\e1cmsg.dll, 10.00.0099.0000 (English), 11/3/2011 01:54:02, 68264 bytes
    Code:
     Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_1495103C&REV_A4\3&115 83659&0&F0
    Code:
    Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_1495103C&REV_04\3&115 83659&0&D8
    Code:
     Name: 2nd generation Intel® Core™ processor family DRAM Controller - 0100
    Device ID: PCI\VEN_8086&DEV_0100&SUBSYS_1495103C&REV_09\3&115 83659&0&00
    Driver: n/a
    Code:
     Name: Intel(R) Q67 Express Chipset Family LPC Interface Controller - 1C4E
    Device ID: PCI\VEN_8086&DEV_1C4E&SUBSYS_1495103C&REV_04\3&115 83659&0&F8
    Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 04:48:27, 15424 bytes
    Code:
     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 8 - 1C1E
    Device ID: PCI\VEN_8086&DEV_1C1E&SUBSYS_1495103C&REV_B4\3&115 83659&0&E7
    Code:
     Name: NVIDIA GeForce GT 1030
    Device ID: PCI\VEN_10DE&DEV_1D01&SUBSYS_37671458&REV_A1\4&6E7 A141&0&00E0
    Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 26.21.0014.4614 (English), 5/19/2020 00:21:34, 725232 bytes
    Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/16/2020 05:57:45, 1663204 bytes
    Driver: C:\Windows\System32\DriverStore\FileRepository\nv_ dispi.inf_amd64_neutral_11f32d4d2b40e8c9\DisplayDr iverRAS.dll, 1.10.0000.0000 (English), 5/19/2020 00:21:34, 2569968 bytes
    Driver: C:\Windows\System32\DriverStore\FileRepository\nv_ dispi.inf_amd64_neutral_11f32d4d2b40e8c9\NvContain erSetup.exe, 1.00.0010.0000 (English), 5/19/2020 00:22:06, 4755368 bytes
    Driver: C:\Windows\System32\DriverStore\FileRepository\nv_ dispi.inf_amd64_neutral_11f32d4d2b40e8c9\NvCplSetu pInt.exe, 1.00.0010.0000 (English), 5/19/2020 00:22:08, 32946512 bytes
    Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 5/19/2020 00:22:20, 21912 bytes
    Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:18, 184048 bytes
    Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:24, 124144 bytes
    Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 5/19/2020 00:22:22, 22424 bytes
    Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:20, 220400 bytes
    Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:24, 146672 bytes
    Driver: C:\Program Files\NVIDIA Corporation\license.txt, 5/16/2020 05:57:45, 27216 bytes
    Driver: C:\Program Files\NVIDIA Corporation\nvgsync\detoured.dll, 2.01.0000.0224 (English), 5/19/2020 00:22:22, 22424 bytes
    Driver: C:\Program Files\NVIDIA Corporation\nvgsync\nvgsyncdetours.dll, 5/19/2020 00:22:30, 164760 bytes
    Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 5/19/2020 00:21:42, 849832 bytes
    Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0014.4614 (English), 5/19/2020 00:22:20, 444824 bytes
    Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 5/16/2020 05:57:45, 106838 bytes
    Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0014.4614 (English), 5/19/2020 00:22:32, 561392 bytes
    Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0014.4614 (English), 5/19/2020 00:22:48, 1005976 bytes
    Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 26.21.0014.4614 (English), 5/19/2020 00:22:42, 23060376 bytes
    Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0014.4614 (English), 5/19/2020 00:22:30, 2071792 bytes
    Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0014.4614 (English), 5/19/2020 00:22:38, 1482136 bytes
    Driver: C:\Windows\system32\NvIFROpenGL.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:38, 626584 bytes
    Driver: C:\Windows\system32\OpenCL.dll, , 0 bytes
    Driver: C:\Windows\system32\nv-vk64.json, 5/16/2020 05:57:45, 671 bytes
    Driver: C:\Windows\system32\nvapi64.dll, 26.21.0014.4614 (English), 5/19/2020 00:18:34, 4770272 bytes
    Driver: C:\Windows\system32\nvcbl64.dll, 26.21.0014.4614 (English), 5/19/2020 00:21:50, 632544 bytes
    Driver: C:\Windows\system32\nvcompiler64.dll, 26.21.0014.4614 (English), 5/19/2020 00:21:58, 40556264 bytes
    Driver: C:\Windows\system32\nvcuda.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:12, 17601424 bytes
    Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0014.4614 (English), 5/19/2020 00:22:18, 5448432 bytes
    Driver: C:\Windows\system32\nvd3dumx.dll, 26.21.0014.4614 (English), 5/19/2020 00:18:40, 22226656 bytes
    Driver: C:\Windows\system32\nvfatbinaryLoader.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:28, 1350568 bytes
    Driver: C:\Windows\system32\nvinfo.pb, 5/16/2020 05:57:45, 53678 bytes
    Driver: C:\Windows\system32\nvinitx.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:40, 182168 bytes
    Driver: C:\Windows\system32\nvofapi64.dll, 5/19/2020 00:22:50, 428440 bytes
    Driver: C:\Windows\system32\nvoglshim64.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:52, 164264 bytes
    Driver: C:\Windows\system32\nvoglv64.dll, 26.21.0014.4614 (English), 5/19/2020 00:23:00, 40450472 bytes
    Driver: C:\Windows\system32\nvopencl64.dll, 26.21.0014.4614 (English), 5/19/2020 00:23:14, 31023856 bytes
    Driver: C:\Windows\system32\nvoptix.dll, 7.01.0000.0000 (English), 5/19/2020 00:23:22, 132262800 bytes
    Driver: C:\Windows\system32\nvptxJitCompiler.dll, 26.21.0014.4614 (English), 5/19/2020 00:23:46, 11944864 bytes
    Driver: C:\Windows\system32\nvrtum64.dll, 26.21.0014.4614 (English), 5/19/2020 00:23:48, 30669544 bytes
    Driver: C:\Windows\system32\nvumdshimx.dll, 26.21.0014.4614 (English), 5/19/2020 00:24:00, 501664 bytes
    Driver: C:\Windows\system32\nvwgf2umx.dll, 26.21.0014.4614 (English), 5/19/2020 00:18:52, 41111584 bytes
    Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.01.0130.0000 (English), 12/20/2019 20:26:58, 1073464 bytes
    Driver: C:\Windows\system32\vulkan-1.dll, 1.01.0130.0000 (English), 12/20/2019 20:26:58, 1073464 bytes
    Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.01.0130.0000 (English), 12/20/2019 20:27:02, 1722680 bytes
    Driver: C:\Windows\system32\vulkaninfo.exe, 1.01.0130.0000 (English), 12/20/2019 20:27:02, 1722680 bytes
    Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0014.4614 (English), 5/19/2020 00:22:28, 1565080 bytes
    Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0014.4614 (English), 5/19/2020 00:22:36, 1141672 bytes
    Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:38, 516848 bytes
    Driver: C:\Windows\SysWow64\OpenCL.dll, , 0 bytes
    Driver: C:\Windows\SysWow64\nv-vk32.json, 5/16/2020 05:57:45, 671 bytes
    Driver: C:\Windows\SysWow64\nvapi.dll, 26.21.0014.4614 (English), 5/19/2020 00:18:32, 4216256 bytes
    Driver: C:\Windows\SysWow64\nvcompiler32.dll, 26.21.0014.4614 (English), 5/19/2020 00:21:52, 35418016 bytes
    Driver: C:\Windows\SysWow64\nvcuda.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:08, 15160208 bytes
    Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0014.4614 (English), 5/19/2020 00:22:16, 4862888 bytes
    Driver: C:\Windows\SysWow64\nvd3dum.dll, 26.21.0014.4614 (English), 5/19/2020 00:18:36, 18527624 bytes
    Driver: C:\Windows\SysWow64\nvfatbinaryLoader.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:26, 1048488 bytes
    Driver: C:\Windows\SysWow64\nvinit.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:40, 158104 bytes
    Driver: C:\Windows\SysWow64\nvofapi.dll, 5/19/2020 00:22:50, 378776 bytes
    Driver: C:\Windows\SysWow64\nvoglshim32.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:52, 144280 bytes
    Driver: C:\Windows\SysWow64\nvoglv32.dll, 26.21.0014.4614 (English), 5/19/2020 00:22:54, 29696240 bytes
    Driver: C:\Windows\SysWow64\nvopencl32.dll, 26.21.0014.4614 (English), 5/19/2020 00:23:08, 26343664 bytes
    Driver: C:\Windows\SysWow64\nvptxJitCompiler.dll, 26.21.0014.4614 (English), 5/19/2020 00:23:44, 10286480 bytes
    Driver: C:\Windows\SysWow64\nvumdshim.dll, 26.21.0014.4614 (English), 5/19/2020 00:23:58, 419232 bytes
    Driver: C:\Windows\SysWow64\nvwgf2um.dll, 26.21.0014.4614 (English), 5/19/2020 00:18:44, 35464864 bytes
    Driver: C:\Windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.01.0130.0000 (English), 12/20/2019 20:26:58, 932152 bytes
    Driver: C:\Windows\SysWow64\vulkan-1.dll, 1.01.0130.0000 (English), 12/20/2019 20:26:58, 932152 bytes
    Driver: C:\Windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.01.0130.0000 (English), 12/20/2019 20:27:00, 1321784 bytes
    Driver: C:\Windows\SysWow64\vulkaninfo.exe, 1.01.0130.0000 (English), 12/20/2019 20:27:00, 1321784 bytes
    Driver: C:\Windows\System32\DriverStore\FileRepository\nv_ dispi.inf_amd64_neutral_11f32d4d2b40e8c9\NvTelemet ry64.dll, 14.03.0054.0000 (English), 5/19/2020 00:23:58, 4548488 bytes
    Driver: C:\Windows\system32\nvdispco6444614.dll, 2.00.0058.0000 (English), 5/19/2020 00:22:22, 1722096 bytes
    Driver: C:\Windows\system32\nvdispgenco6444614.dll, 2.00.0028.0002 (English), 5/19/2020 00:22:22, 1484184 bytes
    [HEADING=1]DirectShow Filters[/HEADING]
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.02.4436.0000
    Xiph.Org Theora Decoder,0x00600000,1,1,dsfTheoraDecoder.dll,
    Xiph.Org Vorbis Decoder,0x00600000,1,1,dsfVorbisDecoder.dll,
    ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.02.4436.0000
    ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.02.4436.0000
    ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.02.4436.0000
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.2438 2
    LAV Splitter,0x00400001,1,1,LAVSplitter.ax,0.50.0001.0 000
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.1751 4
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.24382
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.24382
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7 601.17514
    Xiph.Org Ogg Muxer,0x00200000,1,0,dsfOggMux.dll,
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200. 16426
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17514
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601. 17514
    Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.1751 4
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.2 4382
    CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.24382
    Xiph.Org FLAC Decoder,0x00600000,1,1,dsfFLACDecoder.dll,
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.24382
    VSDC Video Decoder,0x0080a000,1,1,mslvddsfilter4.ax,4.00.0001 .0161
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.1751 4
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.1751 4
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17 514
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.24382
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.24382
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.24382
    Haali Media Splitter,0x00800001,0,1,splitter.x64.ax,1.11.0287. 0023
    Haali Media Splitter (AR),0x00400000,1,1,splitter.x64.ax,1.11.0287.0023
    Xiph.Org Theora Encoder,0x00200000,1,1,dsfTheoraEncoder.dll,
    Xiph.Org Vorbis Encoder,0x00200000,1,1,dsfVorbisEncoder.dll,
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17 514
    Xvid MPEG-4 Video Decoder,0x00800002,1,1,xvid.ax,
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.24382
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.24382
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17514
    Xiph.Org Native FLAC Decoder,0x00600000,0,1,dsfNativeFLACSource.dll,
    Line 21 Decoder,0x00600000,1,1,
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.24382
    Xiph.Org Speex Encoder,0x00200000,1,1,dsfSpeexEncoder.dll,
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.24382
    Xiph.Org Speex Decoder,0x00600000,1,1,dsfSpeexDecoder.dll,
    Xiph.Org FLAC Encoder,0x00200000,1,1,dsfFLACEncoder.dll,
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
    Sony Wave Hammer Surround,0x00200000,1,1,mchammer_x64.dll,1.01.0000 .2475
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.1751 4
    File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
    Yuv2Rgb,0x00600001,1,1,YUV2RGB64.ax,7.04.0000.0000
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
    Bandisoft MPEG-1 Video Decoder,0xff800001,1,1,bdfilters64.dll,1.00.0005.0 016
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
    Haali Simple Media Splitter,0x00200000,0,1,splitter.x64.ax,1.11.0287. 0023
    DirectVobSub,0x00200000,2,1,VSFilter.dll,1.06.0002 .4485
    DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.06.0002.448 5
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.24382
    Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.1751 4
    Overlay Mixer2,0x00200000,1,1,
    Haali Matroska Muxer,0x00200000,1,0,splitter.x64.ax,1.11.0287.002 3
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17 514
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601 .17514
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
    ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.02.4436.0000
    LAV Splitter Source,0x00400001,0,1,LAVSplitter.ax,0.50.0001.000 0
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.1 7514
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.1751 4
    Xiph.Org Ogg Demuxer,0x00600000,1,1,dsfOggDemux2.dll,
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.760 1.17514
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
    Overlay Mixer,0x00200000,0,0,
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.2 4382
    NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.1 7514
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.24382
    Dump,0x00200000,1,0,DvFileWriter.prm,13.05.0000.03 47
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.24382
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.24382
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.24382
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.24382
    ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.02.4436.0000
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0 000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601 .17514
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
    Bandisoft MPEG-1 Audio Decoder,0xff800001,1,1,bdfilters64.dll,1.00.0005.0 016
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.24382
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.24382
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.24382
    Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.175 14
    Video Out,0x00200000,0,1,mslvvdsfilter4.ax,
    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
    LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.50.0001.0000
    WebM Muxer Filter,0x00200000,2,1,webmmux.dll,0.09.0012.0000
    WebM VP8 Decoder Filter,0x00600000,1,1,vp8decoder.dll,0.09.0012.000 0
    WebM VP8 Encoder Filter,0x00200000,1,1,vp8encoder.dll,0.09.0012.000 0
    WebM Splitter Filter,0x00600000,1,1,webmsplit.dll,0.09.0012.0000
    LAV Video Decoder,0x00800003,1,1,LAVVideo.ax,0.50.0001.0000
    Haali Video Sink,0x00200000,1,0,splitter.x64.ax,1.11.0287.0023
    AC3File,0x00600000,0,1,ac3file64.ax,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.24382
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17514
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.24382
    Sony ExpressFX Chorus,0x00200000,1,1,sfxpfx2_x64.dll,1.01.0000.24 75
    Sony ExpressFX Delay,0x00200000,1,1,sfxpfx2_x64.dll,1.01.0000.247 5
    Sony ExpressFX Distortion,0x00200000,1,1,sfxpfx1_x64.dll,1.01.000 0.2475
    Sony ExpressFX Equalization,0x00200000,1,1,sfxpfx2_x64.dll,1.01.0 000.2475
    Sony ExpressFX Flange/Wah-Wah,0x00200000,1,1,sfxpfx1_x64.dll,1.01.0000.2475
    Sony ExpressFX Amplitude Modulation,0x00200000,1,1,sfxpfx2_x64.dll,1.01.000 0.2475
    Sony ExpressFX Reverb,0x00200000,1,1,sfxpfx1_x64.dll,1.01.0000.24 75
    Sony ExpressFX Stutter,0x00200000,1,1,sfxpfx1_x64.dll,1.01.0000.2 475
    Sony ExpressFX Dynamics,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000. 2475
    Sony ExpressFX Graphic EQ,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000.2475
    Sony ExpressFX Noise Gate,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000.2475
    Sony ExpressFX Time Stretch,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000.2 475
    Sony ExpressFX Audio Restoration,0x00200000,1,1,xpvinyl_x64.dll,1.01.00 00.2475
    Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2_x64.dll,1.01.0000 .2475
    Sony Track Compressor,0x00200000,1,1,sftrkfx1_x64.dll,1.01.00 00.2475
    Sony Dither,0x00200000,1,1,sftrkfx1_x64.dll,1.01.0000.2 475
    Sony Chorus,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2 475
    Sony Distortion,0x00200000,1,1,sfppack3_x64.dll,1.01.00 00.2475
    Sony Gapper/Snipper,0x00200000,1,1,sfppack3_x64.dll,1.01.0000. 2475
    Sony Simple Delay,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.24 75
    Sony Reverb,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2 475
    Sony Multi-Tap Delay,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.24 75
    Sony Track Noise Gate,0x00200000,1,1,sftrkfx1_x64.dll,1.01.0000.247 5
    Sony Graphic EQ,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2475
    Sony Track EQ,0x00200000,1,1,sftrkfx1_x64.dll,1.01.0000.2475
    Sony Smooth/Enhance,0x00200000,1,1,sfppack3_x64.dll,1.01.0000. 2475
    Sony Resonant Filter,0x00200000,1,1,sfresfilter_x64.dll,1.01.000 0.2475
    Sony Parametric EQ,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2475
    Sony Time Stretch,0x00200000,1,1,sfppack1_x64.dll,1.01.0000. 2475
    Sony Noise Gate,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.247 5
    Sony Paragraphic EQ,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2475
    Sony Vibrato,0x00200000,1,1,sfppack3_x64.dll,1.01.0000. 2475
    Sony Pan,0x00200000,1,1,sffrgpnv_x64.dll,1.01.0000.2475
    Sony Pitch Shift,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.24 75
    Sony Volume,0x00200000,1,1,sffrgpnv_x64.dll,1.01.0000.2 475
    Sony Flange/Wah-wah,0x00200000,1,1,sfppack3_x64.dll,1.01.0000.2475
    Sony Graphic Dynamics,0x00200000,1,1,sfppack2_x64.dll,1.01.0000 .2475
    Sony Amplitude Modulation,0x00200000,1,1,sfppack3_x64.dll,1.01.00 00.2475
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.1751 4
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
    ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.02.4436.0000
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.243 82
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.24382
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.24382
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.24382
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.24382
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.24382
    MP2,0x00200000,1,1,quartz.dll,6.06.7601.24382
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.24382
    Audio Capture Sources:
    Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17 514
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17 514
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17 514
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.24382
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.24382
    WDM Streaming Capture Devices:
    Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    WO Mic Device,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    VAD Wave,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
    AlterCam Camera (WDM),0x00200000,0,2,ksproxy.ax,6.01.7601.17514
    WDM Streaming Rendering Devices:
    Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    ,0x00000000,0,0,
    ,0x00000000,0,0,
    ,0x00000000,0,0,
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
    Video Capture Sources:
    Fake Webcam Source V7.4,0x00800000,0,1,VCamSrc64.ax,7.04.0000.0000
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17514
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17514
    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17514
    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17514
    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17514
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.24382
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.24382
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.24382
    DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.24382
    [HEADING=1]EVR Power Information[/HEADING]
    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
    Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
    Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
    PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
    Hello virtuo,
    Can i first of all mention that drivers for monitors are a thing of the past and you do not need to install them separately and haven’t had to since Windows XP. and CRT monitors, if you are having resolution problems the issue is with the GPU drivers
    The list of HP drivers here does not list any for the GPU that you have, have you fitted the GT 1030 yourself.
    • Rustys
      • 7862
      What is the make and model of the power supply?
      That system usually came with a 240 Watt power supply.
      The GT 1030 card requires a 300 watt minimal power supply to run.
        Thread closed due to lack of any feedback from the OP.
        • Rustys
          • 7862
          Thread has been unlocked @virtuo
          Duplicate thread removed
          • virtuo
            • Jun 2020
            • 4
            Okay thanks a lot for unlocking it, anyways as I was saying, yes I fitted the GT 1030 myself after making sure my power supply, HP-D3201E0(Which I googled but I couldn’t find about a lot), it had maximum supply of 320 watt.
            Anyways wanted to note that the problem with the monitor not being recognized by the pc at all had started before getting the GT 1030 when I had AMD Radeon HD 5450, except there were plug and play monitor drivers which the pc recognized but the problem it gave me wrong resolutions(my monitor’s maximum is 1280 x 1024 with 70 hertz, this gives me 1920 x 1080 with hertz 100+) that don’t work with the monitor, I don’t remember when was the first time my windows worked on plug and play drivers and couldn’t regonize my DELL monitor but it was a very long time ago(more than 1-2 years), until I got my GT 1030 which worked normally with plug and play except after about a week or two, the plug and play drivers suddenly out of nowhere(I don’t remember installing or changing any drivers or doing anything) disappeared and my pc no longer could recognize there was ANY monitors but it knew there was a monitor plugged into DVI-D(the plug and play drivers were acting as if the monitor was unplugged).
            My drivers for the graphics card are fully updated and for the monitor, they can’t be installed cause they’re pretty old and only for vista and XP. I don’t remember installing monitor’s drivers in the past(more than 2-3 years ago) but I surely remember my pc always recognizing it.
              I wouldn`t trust that PSU to be able to produce anywhere near 320W tbh as the numbers on the PSU label do not add up, 256W if you are lucky but most likely nearer 200W.
              Download and run DriverView which you can get from here
              Save the results to text and attach to your next reply for us if you will.
              • virtuo
                • Jun 2020
                • 4
                I’m not really sure tbh, it’s written on the label “MAXIMUM POWER SHALL NOT EXCEED 320W” and some chinese lines later on with 320W in between.
                But anyways here’s my speccy: http://speccy.piriform.com/results/B...w6iuNSDY8Ohup6
                and in driverview, I selected all and chose to export(I think that’s what you wanted), I attached it.
                  No need for us to look at the list of drivers as we can see that you have multiple issues going on with the amount of free storage space on the C: partition being the most critical.
                  Rather than us have to check I prefer to be direct and ask if the version of Windows 7 on this computer is legitimate, the lack of Windows updates suggest that it may not be.
                  Troubleshooting computer problems is a waste of time when it is known that Windows is out of date as any one of a number of the missing hot fixes could be the solution to any problem that you may be having.
                  Partition 0
                  Partition ID: Disk #0, Partition #0
                  [COLOR=rgb(184, 49, 47)]Disk Letter: C:
                  File System: NTFS
                  Volume Serial Number: E4BDB8DA
                  Used Space: 48 GB (98%)
                  [COLOR=rgb(184, 49, 47)]Free Space: 636 MB (2%)
                  Partition 1
                  [COLOR=rgb(184, 49, 47)]Disk Letter: D:
                  File System: NTFS
                  Volume Serial Number: 04A4CD36
                  Used Space: 169 GB (91%)
                  [COLOR=rgb(184, 49, 47)]Free Space: 14.8 GB (9%)
                  For Windows to be able to run efficiently and to be able to update you need to have between 20 and 25% of the partition or drive available as free storage space at all times, if you don`t you risk Windows becoming corrupt or not being able to update which puts you at risk of malware attack.
                  [COLOR=rgb(184, 49, 47)]Please note that storage devices can physically fail if the amount of free storage space is allowed to drop below the required 10 or 20/25% minimum.
                  Uninstall as many unused programs, games, videos and music files as you can and get yourself another means of backing up to, post back when you have between 20 and 25% free storage on the C: drive/partition and we can go from there.[/COLOR][/COLOR][/COLOR][/COLOR][/COLOR]
                  • virtuo
                    • Jun 2020
                    • 4
                    #10
                    I seriously don’t think that’s the problem at all because nothing as it WAS working and it SUDDENLY stopped working(my c had even had much less storage) and I haven’t touched or did anything nearby updates thus they’re quite obviously not related. I’ve always used most of my c free storage and I never did windows update because they always hindered my pc in a way or another and I downloaded them when required. But since you’re the expert here, I will trust what you’re saying and give it a shot and I will post here when I’ve free 20 to 25% so give me like till tomorrow.
                      #11
                      First and foremost it is your computer and so entirely up to you if you follow our advice or not but just so you know until you answer the question that was asked and provide a new Speccy report showing Windows fully up to date as per the PCHF Terms and rules we cannot provide any further assistance in any event;
                      1. Support for, discussion of, or promotion of sites offering cracks, warez, torrents, *********** or any other illegal material or any software created to download any of the above. [COLOR=rgb(184, 49, 47)]This includes nulled, copied or any other illegal software or operating systems.
                        [/COLOR]
                      [COLOR=rgb(184, 49, 47)][/color]
                        #12
                        Thread closed as per the PCHF Terms and rules explanation above.
