my hard drive led constantly blinks and no boot normally
  • farshad271
    • Apr 2020
    • 2
    when i turn on computer hard drive led constantly blinks every second and boot completed after about 15 minutes.
    but if i press Restart button on the computer case, normally boot in about 45 second and no blinking after restart (every thing is ok after hard restart).
    Please help me
    [li]OS: win 10 enterprise v.1809/build.17763 LTSC[/li][li]CPU: Intel i5-7500[/li][li]MB: Gigabyte h270 gaming 3[/li][li]RAM: Kingmax 8GB DDR4 2400Mhz[/li][li]VGA: Gigabyte GTX 1050 Ti 4GB DDR5[/li][li]HDD: TOSHIBA 1TB - DT01ACA1[/li][li]Power: Green 480W/Real[/li][li]CD/Rom: None.[/li][li]Bios Mode: UEFI[/li][/ul]
    how old is the HDD?
    what are the SMART values. there are plenty of programs that can tell you those, Defraggler by Piriform being one example.
    my money is either on a failing drive or a corrupted OS.
    you could try a fresh install of Windows 10 as a first step.
    but personally, I’d also take the oppurtunity to do that on a new drive and upgrade to a SSD, that why you’d be killing a couple of birds with the same stone with the added benefit of breathing some new life, performance wise, into an old’ish machine.
      also, any reason why you are still on version 1809?
      • farshad271
        • Apr 2020
        • 2
        HDD old = less than 2 years.
        HDD info:
        [ATTACH type=“full”]6122[/ATTACH]
        My System is old ?! no!
        my system config is in my first topic, please see top of this page!!!
        with hddlife and hddtune scan and everythings was ok.
        i format all hdd and new partitioning and clear install new windows (for 2 times)
        I installed win10 enterprise and also enterprise LTSC, but the result was the same.
        please help me :cry:
          let’s get your complete specs.
          get Speccy from here; Speccy - Download Builds
          now you can paste(Ctrl+V) that link into a post.
          • system
            PCHF Owner
            • 7695
            • CachyOS
            • Intel Arc A770 (16 GB)
            How did you come to get Windows 10 Enterprise?
