Bluetooth not working, nor wifi. And nothing I've tried works... help!
  • kUTUSOV
    • Mar 2020
    • 17
    Bluetooth stopped working overnight and I’ve gone through 2 pages of google tutorials and videos but nothing works. It can’t add or connect to previously connected devices. Wifi is also not picking up anything network.
    I’m running an HP Pavilion Power 580-104np desktop (win10 64) and HP support asked me to run a few things I had tried before:
    Run the Bluetooth troubleshooter - didn’t work.
    Uninstall the Bluetooth adapter in Device Manager - didn’t work
    Run system test with HP Hardware diagnostics (UEFI) - it didn’t detect any error but failed to detect network card. Apparently that should have showed up on the results but it didn’t. It’s not a failed test, it’s an omission from the result summary.
    Thing is, I can run those tests individually and they pass. Network adapter does show on Device Manager with no errors. Ethernet and two wireless printers are working fine…
    Previously and after this issue, I had occasions when the PC wouldn’t boot up, it turned on and immediately restarted without even reaching BIOS. A couple of times it froze and went to a blue screen, always with different error massages. I suspected a faulty PSU and replaced it. This problem did happen again a couple of times but that’s it. I did get a very poor generic 300w PSU because that was the only one available at the store but I later ordered a Corsair VS450 that I haven’t installed yet.
    Can anyone help me go over this problem?
    Welcome to PCHF kUTUSOV,
    You are hopefully using the Ethernet on the computer and will able to do the following for us;
    • kUTUSOV
      • Mar 2020
      • 17
      Hi, thanks for replying! Yes, I am connected to the internet via ethernet.
      Here’s Speccy link (hope I got this right): http://speccy.piriform.com/results/s...304FQLCxFusxyp
        That`s it thanks (y)
        If not checked yourself already, Speccy shows that both your BT and Wlan are running but what is not running is the Wi-Fi Direct Services Connection Manager Service.
        The AV protection can sometimes cause problems with internet connectivity, have a couple of suggestions so easiest first, are you ok with temporarily uninstalling Bitdefender and using Windows Defender and Firewall instead, let us know and we will provide the steps for you.
        • kUTUSOV
          • Mar 2020
          • 17
          Yes, I am fine with unistalling Bitdefender.
            Noticed that you have post on other forums (including HP) so need to post the obligatory info below so we each know where we stand;
            We are always happy to help when we can but we cannot safely do so if you are already receiving assistance on any other forum, doing so may lead to confusion as to whose and what guidance you are following which can be both dangerous and costly, decide on which forum you wish to continue and as a courtesy let the other/s know that assistance is no longer required.
            Thank you for your understanding.
            If you continue on PCHF see the below;
            It is best that we address one item at a time, based on the fact that you can connect to two wireless printers without issue it suggests that the wireless card is working in some way so we should look at that first and the Bluetooth device second.
            Couple of things for you to do;
            Power Profile
            Active power scheme: [COLOR=rgb(184, 49, 47)]High performance
            Change the Windows Power Plan to Balanced, High Performance is a form of overclocking that is known to cause stability and overheating issues and the setting should only be used for gaming type notebooks that have a discrete GPU that needs the extra power.
            RE Bitdefender: if the AV product that you have is a paid for version you should make sure that you have a copy of the product key kept somewhere safe just in case you ever wish to reinstall it.
            [COLOR=rgb(184, 49, 47)]Please create a new system restore point first.
            [COLOR=rgb(0, 0, 0)] Bitdefender removal tools[COLOR=rgb(184, 49, 47)] here
            Restart and test, if no change do the below for us if you will,
            Download then run the Windows All in One Repair tool from here, disregard the malware guidance but follow the other steps to the letter and in particular ensuring that you first create a new restore point and perform a proper Windows clean boot before running the repair, details for the clean boot here.[/COLOR][/COLOR][/COLOR][/COLOR]
            • kUTUSOV
              • Mar 2020
              • 17
              Hi, Yes, I went first to HP but that wasn’t much help, thread is now closed. On the other forum I got no replies and it was then that I searched for alternative help. I will follow steps just from here from now on.
              Power plan is now on Balanced.
              EDIT: Sorry, pressed post by mistake. Still following the steps, will update in a while
                Thanks, you would be surprised at how many people think that it is acceptable to start threads on multiple forums and either chop and change the guidance they follow or simply abandon all of the threads without bothering to reply to any of them, had one person that had post on several forums throw a tantrum when a fellow admin asked them to have a little courtesy and thank the forums that had tried to help them.
                Power Plan and edit info acknowledged (y)
                • kUTUSOV
                  • Mar 2020
                  • 17
                  So did everything you suggested.
                  Power plan to balanced
                  Unistalled Bit Defender through tools
                  Restarted and no change.
                  Ran Windows All in One Repair tool after clean boot and in safe mode.
                  Still no changes, bluetooth doesn’t work
                    #10
                    Did you perhaps misread my reply #6?
                    Is there no change with the wireless connection?
                    • kUTUSOV
                      • Mar 2020
                      • 17
                      #11
                      Oh, sorry, read it but kept the exact opposite message
                      Yes, no change. PC sees no wifi networks.
                        #12
                        Thought so but had to ask (y)
                        Got two more things to try, one you can do sat at your desk but the other could be a bit more problematic as it involves disconnecting and moving the computer, first things first though;
                        Flush DNS
                        Report IE Proxy Settings
                        Reset IE Proxy Settings
                        Report FF Proxy Settings
                        Reset FF Proxy Settings
                        List content of Hosts
                        List IP Configuration
                        List Winsock Entries
                        List Installed Programs
                        List Devices (Only Problems)
                        Click on Go.
                        Post the resulting log in your next reply for us.
                        • kUTUSOV
                          • Mar 2020
                          • 17
                          #13
                          Ran by Utilizador (administrator) on 21-03-2020 at 16:04:46
                          Running from “D:\Users\Utilizador\Desktop”
                          Model: HP Pavilion Power Desktop 580-1xx Manufacturer: HP
                          Boot Mode: Normal
                          Windows IP Configuration
                          Proxy is not enabled.
                          No Proxy Server is set.
                          “Reset IE Proxy Settings”: IE Proxy Settings were reset.
                          “Reset FF Proxy Settings”: Firefox Proxy settings were reset.
                          127.0.0.1 localhost
                          Realtek Gaming GbE Family Controller = Ethernet (Connected)
                          Realtek RTL8821CE 802.11ac PCIe Adapter = WiFi (Media disconnected)
                          Bluetooth Device (Personal Area Network) = Bluetooth Network Connection (Media disconnected)
                          [HEADING=1]----------------------------------[/HEADING]
                          [HEADING=1]IPv4 Configuration[/HEADING]
                          pushd interface ipv4
                          reset
                          popd
                          [HEADING=1]End of IPv4 configuration[/HEADING]
                          Host Name . . . . . . . . . . . . : DESKTOP-9R2F3RB
                          DNS Suffix Search List. . . . . . : home
                          Ethernet adapter Ethernet:
                          Connection-specific DNS Suffix . : home
                          Description . . . . . . . . . . . : Realtek Gaming GbE Family Controller
                          Physical Address. . . . . . . . . : C8-D3-FF-41-86-B5
                          Link-local IPv6 Address . . . . . : fe80::947d:f86:fb5:a918%17(Preferred)
                          IPv4 Address. . . . . . . . . . . : 192.168.1.8(Preferred)
                          Lease Obtained. . . . . . . . . . : 21 March 2020 14:20:41
                          Lease Expires . . . . . . . . . . : 21 March 2020 16:50:40
                          DHCPv6 IAID . . . . . . . . . . . : 583586815
                          DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-2E-80-B3-C8-D3-FF-41-86-B5
                          Wireless LAN adapter WiFi:
                          Description . . . . . . . . . . . : Realtek RTL8821CE 802.11ac PCIe Adapter
                          Physical Address. . . . . . . . . : 5C-EA-1D-5D-EC-9D
                          Wireless LAN adapter Local Area Connection* 9:
                          Physical Address. . . . . . . . . : 5E-EA-1D-5D-EC-9D
                          Wireless LAN adapter Local Area Connection* 10:
                          Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
                          Physical Address. . . . . . . . . : DE-EA-1D-5D-EC-9D
                          Ethernet adapter Bluetooth Network Connection:
                          Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
                          Physical Address. . . . . . . . . : 5C-EA-1D-5D-EC-9E
                          Server: router.home
                          Address: 192.168.1.1
                          Addresses: 2a00:1450:4003:802::200e
                          216.58.201.142
                          Pinging google.com [216.58.201.142] with 32 bytes of data:
                          Reply from 216.58.201.142: bytes=32 time=29ms TTL=55
                          Reply from 216.58.201.142: bytes=32 time=23ms TTL=55
                          Ping statistics for 216.58.201.142:
                          Minimum = 23ms, Maximum = 29ms, Average = 26ms
                          Server: router.home
                          Addresses: 2001:4998:44:41d::3
                          2001:4998:58:1836::11
                          2001:4998:c:1023::4
                          2001:4998:44:41d::4
                          2001:4998:c:1023::5
                          2001:4998:58:1836::10
                          72.30.35.10
                          98.138.219.232
                          98.138.219.231
                          72.30.35.9
                          98.137.246.7
                          98.137.246.8
                          Pinging yahoo.com [98.138.219.231] with 32 bytes of data:
                          Reply from 98.138.219.231: bytes=32 time=165ms TTL=45
                          Reply from 98.138.219.231: bytes=32 time=161ms TTL=45
                          Ping statistics for 98.138.219.231:
                          Minimum = 161ms, Maximum = 165ms, Average = 163ms
                          [HEADING=1]Ping statistics for 127.0.0.1:
                          Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
                          [HEADING=1]Interface List
                          17…c8 d3 ff 41 86 b5 …Realtek Gaming GbE Family Controller
                          9…5c ea 1d 5d ec 9d …Realtek RTL8821CE 802.11ac PCIe Adapter
                          8…5e ea 1d 5d ec 9d …Microsoft Wi-Fi Direct Virtual Adapter
                          13…de ea 1d 5d ec 9d …Microsoft Wi-Fi Direct Virtual Adapter #2
                          6…5c ea 1d 5d ec 9e …Bluetooth Device (Personal Area Network)
                          1…Software Loopback Interface 1[/HEADING]
                          [HEADING=1]IPv4 Route Table[/HEADING]
                          [HEADING=1]Active Routes:
                          0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.8 26
                          192.168.1.0 255.255.255.0 On-link 192.168.1.8 281
                          192.168.1.8 255.255.255.255 On-link 192.168.1.8 281
                          192.168.1.255 255.255.255.255 On-link 192.168.1.8 281
                          224.0.0.0 240.0.0.0 On-link 192.168.1.8 281
                          255.255.255.255 255.255.255.255 On-link 192.168.1.8 281[/HEADING]
                          Persistent Routes:
                          None
                          [HEADING=1]IPv6 Route Table[/HEADING]
                          1 331 ::1/128 On-link
                          17 281 fe80::/64 On-link
                          17 281 fe80::947d:f86:fb5:a918/128
                          On-link
                          1 331 ff00::/8 On-link
                          17 281 ff00::/8 On-link[/HEADING]
                          Persistent Routes:
                          None
                          Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
                          Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                          Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                          Catalog5 04 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog5 05 C:\WINDOWS\SysWOW64\winrnr.dll [23552] (Microsoft Corporation)
                          Catalog5 06 C:\WINDOWS\SysWOW64\NLAapi.dll [70144] (Microsoft Corporation)
                          Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
                          Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 15 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 16 C:\WINDOWS\SysWOW64\mswsock.dll [324920] (Microsoft Corporation)
                          Catalog9 17 C:\WINDOWS\SysWOW64\vsocklib.dll [File not found] ()
                          Catalog9 18 C:\WINDOWS\SysWOW64\vsocklib.dll [File not found] ()
                          x64-Catalog5 01 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
                          x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86528] (Microsoft Corporation)
                          x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [86528] (Microsoft Corporation)
                          x64-Catalog5 04 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog5 05 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
                          x64-Catalog5 06 C:\Windows\System32\NLAapi.dll [93184] (Microsoft Corporation)
                          x64-Catalog5 07 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
                          x64-Catalog9 01 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 02 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 03 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 04 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 05 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 06 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 07 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 08 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 09 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 10 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 11 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 12 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 13 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 14 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 15 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 16 C:\Windows\System32\mswsock.dll [407544] (Microsoft Corporation)
                          x64-Catalog9 17 C:\Windows\System32\vsocklib.dll [File Not found] ()
                          x64-Catalog9 18 C:\Windows\System32\vsocklib.dll [File Not found] ()
                          Error: (03/21/2020 03:45:59 PM) (Source: ESENT) (User: )
                          Description: svchost (23980,R,98) TILEREPOSITORYS-1-5-18: Error -1023 (0xfffffc01) occurred while opening logfile C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log.
                          Error: (03/21/2020 03:14:04 PM) (Source: ESENT) (User: )
                          Description: svchost (24436,R,98) TILEREPOSITORYS-1-5-18: Error -1023 (0xfffffc01) occurred while opening logfile C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log.
                          Error: (03/21/2020 03:08:02 PM) (Source: ESENT) (User: )
                          Description: svchost (14264,R,98) TILEREPOSITORYS-1-5-18: Error -1023 (0xfffffc01) occurred while opening logfile C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log.
                          Error: (03/21/2020 03:00:31 PM) (Source: ESENT) (User: )
                          Description: svchost (18788,R,98) TILEREPOSITORYS-1-5-18: Error -1023 (0xfffffc01) occurred while opening logfile C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log.
                          Error: (03/21/2020 02:53:26 PM) (Source: ESENT) (User: )
                          Description: svchost (18212,R,98) TILEREPOSITORYS-1-5-18: Error -1023 (0xfffffc01) occurred while opening logfile C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log.
                          Error: (03/21/2020 02:32:45 PM) (Source: ESENT) (User: )
                          Description: svchost (4492,R,98) TILEREPOSITORYS-1-5-18: Error -1023 (0xfffffc01) occurred while opening logfile C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log.
                          Error: (03/21/2020 02:28:23 PM) (Source: Microsoft-Windows-PerfNet) (User: DESKTOP-9R2F3RB)
                          Description: Unable to open the Server service performance object. The first four bytes (DWORD) of the Data section contains the status code.
                          Error: (03/21/2020 02:20:43 PM) (Source: Microsoft-Windows-CAPI2) (User: )
                          Description: The Cryptographic Services service failed to initialise the Catalogue Database. The ESENT error was: -1023.
                          Error: (03/21/2020 02:20:43 PM) (Source: ESENT) (User: )
                          Description: Catalog Database (4796,R,98) Catalog Database: Error -1023 (0xfffffc01) occurred while opening logfile C:\WINDOWS\system32\CatRoot2\edb.log.
                          Error: (03/21/2020 02:15:10 PM) (Source: Microsoft-Windows-WMI) (User: NT AUTHORITY)
                          Description: Event provider wsp_sr attempted to register query “select * from WSP_ReplicationGroupStorageModificationEvent” whose target class “WSP_ReplicationGroupStorageModificationEvent” in //./root/Microsoft/Windows/Storage/Providers_v2 namespace does not exist. The query will be ignored.
                          Error: (03/21/2020 03:50:40 PM) (Source: Service Control Manager) (User: )
                          Description: The Browser service failed to start due to the following error:
                          %%1053 = The service did not respond to the start or control request in a timely fashion.
                          Description: A timeout was reached (30000 milliseconds) while waiting for the Browser service to connect.
                          [HEADING=1]Microsoft Office Sessions:[/HEADING]
                          Error: (03/21/2020 03:45:59 PM) (Source: ESENT)(User: )
                          Description: svchost23980,R,98TILEREPOSITORYS-1-5-18: C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log-1023 (0xfffffc01)
                          Error: (03/21/2020 03:14:04 PM) (Source: ESENT)(User: )
                          Description: svchost24436,R,98TILEREPOSITORYS-1-5-18: C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log-1023 (0xfffffc01)
                          Error: (03/21/2020 03:08:02 PM) (Source: ESENT)(User: )
                          Description: svchost14264,R,98TILEREPOSITORYS-1-5-18: C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log-1023 (0xfffffc01)
                          Error: (03/21/2020 03:00:31 PM) (Source: ESENT)(User: )
                          Description: svchost18788,R,98TILEREPOSITORYS-1-5-18: C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log-1023 (0xfffffc01)
                          Error: (03/21/2020 02:53:26 PM) (Source: ESENT)(User: )
                          Description: svchost18212,R,98TILEREPOSITORYS-1-5-18: C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log-1023 (0xfffffc01)
                          Error: (03/21/2020 02:32:45 PM) (Source: ESENT)(User: )
                          Description: svchost4492,R,98TILEREPOSITORYS-1-5-18: C:\WINDOWS\system32\config\systemprofile\AppData\L ocal\TileDataLayer\Database\EDB.log-1023 (0xfffffc01)
                          Error: (03/21/2020 02:28:23 PM) (Source: Microsoft-Windows-PerfNet)(User: DESKTOP-9R2F3RB)
                          Description: 3221225506
                          Error: (03/21/2020 02:20:43 PM) (Source: Microsoft-Windows-CAPI2)(User: )
                          Description: -1023
                          Error: (03/21/2020 02:20:43 PM) (Source: ESENT)(User: )
                          Description: Catalog Database4796,R,98Catalog Database: C:\WINDOWS\system32\CatRoot2\edb.log-1023 (0xfffffc01)
                          Error: (03/21/2020 02:15:10 PM) (Source: Microsoft-Windows-WMI)(User: NT AUTHORITY)
                          Description: wsp_srselect * from WSP_ReplicationGroupStorageModificationEventWSP_Re plicationGroupStorageModificationEvent//./root/Microsoft/Windows/Storage/Providers_v2
                          [HEADING=1]CodeIntegrity Errors:[/HEADING]
                          Date: 2020-03-17 20:19:45.682
                          Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume5\Windows\Installer\MSI4A1F. tmp because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
                          Date: 2020-01-13 18:41:41.000
                          Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\System32\svchost. exe) attempted to load \Device\HarddiskVolume5\Program Files\AVAST Software\Avast\aswAMSI.dll that did not meet the Windows signing level requirements.
                          Date: 2020-01-13 18:40:55.528
                          Date: 2019-11-08 10:00:34.215
                          Date: 2019-11-08 09:59:49.218
                          Date: 2019-11-06 07:41:27.156
                          Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume5\Windows\System32\FlightSet tings.dll because the set of per-page image hashes could not be found on the system.
                          Date: 2019-11-06 07:41:27.150
                          Date: 2019-11-06 07:41:26.879
                          Date: 2019-11-06 07:41:26.873
                          Date: 2019-11-06 07:41:26.864
                          Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume5\Windows\System32\dsreg.dll because the set of per-page image hashes could not be found on the system.
                          µTorrent (HKCU...\uTorrent) (Version: 3.5.5.45608 - BitTorrent Inc.)
                          Adobe Acrobat Reader DC (HKLM-x32...{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 20.006.20042 - Adobe Systems Incorporated)
                          Adobe AIR (HKLM-x32...\Adobe AIR) (Version: 32.0.0.125 - Adobe)
                          Bonjour (HKLM...{6E3610B2-430D-4EB0-81E3-2B57E8B9DE8D}) (Version: 3.0.0.10 - Apple Inc.)
                          Broadcom Bluetooth Drivers (HKLM...{0A1B4690-E176-4533-8058-939480AEE1D0}) (Version: 12.0.1.921 - Broadcom Corporation)
                          Cisco EAP-FAST Module (HKLM-x32...{64BF0187-F3D2-498B-99EA-163AF9AE6EC9}) (Version: 2.2.14 - Cisco Systems, Inc.)
                          Cisco LEAP Module (HKLM-x32...{AF312B06-5C5C-468E-89B3-BE6DE2645722}) (Version: 1.0.19 - Cisco Systems, Inc.)
                          Cisco PEAP Module (HKLM-x32...{0A4EF0E6-A912-4CDE-A7F3-6E56E7C13A2F}) (Version: 1.1.6 - Cisco Systems, Inc.)
                          Dropbox (HKLM-x32...\Dropbox) (Version: 93.4.273 - Dropbox, Inc.)
                          Dropbox Update Helper (HKLM-x32...{099218A5-A723-43DC-8DB5-6173656A1E94}) (Version: 1.3.295.1 - Dropbox, Inc.) Hidden
                          EaseUS Todo Backup Free 12.0 (HKLM-x32...\EaseUS Todo Backup_is1) (Version: 12.0 - CHENGDU YIWO Tech Development Co., Ltd)
                          Energy Star (HKLM...{5CB22648-35F8-41BC-9C35-1E41FE6E12A5}) (Version: 1.1.1 - HP Inc.)
                          Epson Customer Research Participation (HKLM...{B26449A6-6007-4460-B4FE-C4776115BCEA}) (Version: 1.83.0000 - Seiko Epson Corporation)
                          EPSON ET-2600 Series Printer Uninstall (HKLM...\EPSON ET-2600 Series) (Version: - Seiko Epson Corporation)
                          Epson ET-2600 User’s Guide (HKLM-x32...\UsersGuideEpson ET-2600 User’s Guide_is1) (Version: 1.0 - Epson America, Inc.)
                          Epson Event Manager (HKLM-x32...{AB8BE3EA-01D3-44B7-8E77-A9601CBDEBDE}) (Version: 3.10.0085 - Seiko Epson Corporation)
                          Epson Printer Connection Checker (HKLM-x32...{FFA5C174-DB3F-4AFE-B59D-C0FB1744CD76}) (Version: 3.1.0.0 - Seiko Epson Corporation)
                          Epson Scan 2 (HKLM-x32...\Epson Scan 2) (Version: - Seiko Epson Corporation)
                          EPSON Scan OCR Component (HKLM-x32...{563B99D8-8895-4E3E-AE8D-15BE8C05F1C1}) (Version: 3.00.04 - SEIKO EPSON Corp.)
                          Epson Software Updater (HKLM-x32...{FD036A57-F81D-4865-AAF0-811558EA76AE}) (Version: 4.5.1 - Seiko Epson Corporation)
                          EpsonNet Print (HKLM...{96ED1D58-440C-4345-8FEE-C4781366C67F}) (Version: 3.1.4.0 - SEIKO EPSON Corporation)
                          Google Chrome (HKLM...{50ADB1A8-7D22-3FA4-9F99-AD149455FE09}) (Version: 80.0.3987.149 - Google LLC)
                          Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.35.451 - Google LLC) Hidden
                          HiSuite (HKLM-x32...\Hi Suite) (Version: 10.0.1.100 - )
                          HP Audio Switch (HKLM-x32...{BC852AA8-58F6-4F07-ACB1-7377E52CA4F3}) (Version: 1.0.150.0 - HP Inc.)
                          HP Connection Optimizer (HKLM-x32...{6468C4A5-E47E-405F-B675-A70A70983EA6}) (Version: 2.0.16.0 - HP Inc.)
                          HP Documentation (HKLM...\HP_Documentation) (Version: 1.0.0.1 - HP Inc.)
                          HP ePrint SW (HKLM-x32...{cdb5f70f-5107-4613-bf69-15de903b5b5d}) (Version: 5.5.22560 - HP Inc.)
                          HP JumpStart Bridge (HKLM-x32...{3FC961DB-BD36-4D8D-B276-0C456A2BB638}) (Version: 1.4.0.441 - HP Inc.)
                          HP JumpStart Launch (HKLM-x32...{F213102E-FD30-4E22-AF73-4C682D65FFEE}) (Version: 1.4.441.0 - HP Inc.)
                          HP LaserJet M14-M17 Basic Device Software (HKLM...{DBD3A5B4-0A41-4C1B-A3EE-DA05AA5D5D70}) (Version: 46.2.2636.18185 - HP Inc.)
                          HP LaserJet M14-M17 Help (HKLM-x32...{860F83D4-E1ED-425C-9A5F-C07867AE1EC5}) (Version: 0.00.0005 - HP)
                          HP Support Assistant (HKLM-x32...{1E14ACF0-1480-4467-A73D-67C4FD35A5F4}) (Version: 8.8.24.33 - HP Inc.)
                          HP Support Solutions Framework (HKLM-x32...{ED0D1C52-9ED3-49F5-955C-6E9EAB0BD46E}) (Version: 12.14.49.15 - HP Inc.)
                          HP System Event Utility (HKLM-x32...{57058272-92B0-4EFA-8FDD-ED3E5D689D37}) (Version: 1.4.32 - HP Inc.)
                          HP Wireless Button Driver (HKLM-x32...{30B2D1D8-0A07-4B71-9553-0710C5D31E35}) (Version: 1.1.2.1 - Hewlett-Packard Company)
                          Icecream Ebook Reader version 5.19 (HKLM-x32...{B8C30F0F-1F23-49E1-A3ED-44DE17660EE2}_is1) (Version: 5.19 - Icecream Apps)
                          Intel(R) Computing Improvement Program (HKLM...{A9133872-C9FE-45CC-8F01-D1947B0F09EA}) (Version: 2.4.04755 - Intel Corporation)
                          Intel(R) Management Engine Components (HKLM...{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.7.0.1043 - Intel Corporation)
                          Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 17.8.0.1065 - Intel Corporation)
                          Intel(R) Trusted Connect Service Client x86 (HKLM-x32...{C9552825-7BF2-4344-BA91-D3CD46F4C441}) (Version: 1.47.715.0 - Intel Corporation) Hidden
                          Intel(R) Trusted Connect Services Client (HKLM-x32...{2b32b7d0-4f9f-47c8-adb7-807e6cb2fb75}) (Version: 1.47.715.0 - Intel Corporation) Hidden
                          Intel® Optane™ Pinning Explorer Extensions (HKLM...{4487026C-A32C-4FF5-858E-8DB890814949}) (Version: 17.8.0.1065 - Intel Corporation)
                          JDownloader 2 (HKLM-x32...\jdownloader2) (Version: 2.0 - AppWork GmbH)
                          Logitech Options (HKLM...\LogiOptions) (Version: 8.10.154 - Logitech)
                          MediaMonkey 4.1 (HKLM-x32...\MediaMonkey_is1) (Version: 4.1 - Ventis Media Inc.)
                          Microsoft Office 365 - en-us (HKLM...\O365HomePremRetail - en-us) (Version: 16.0.12624.20276 - Microsoft Corporation)
                          Microsoft Office 365 - pt-pt (HKLM...\O365HomePremRetail - pt-pt) (Version: 16.0.12624.20276 - Microsoft Corporation)
                          Microsoft Office 365 ProPlus - en-us (HKLM...\O365ProPlusRetail - en-us) (Version: 16.0.12624.20276 - Microsoft Corporation)
                          Microsoft Office 365 ProPlus - pt-pt (HKLM...\O365ProPlusRetail - pt-pt) (Version: 16.0.12624.20276 - Microsoft Corporation)
                          Microsoft OneDrive (HKCU...\OneDriveSetup.exe) (Version: 20.028.0206.0009 - Microsoft Corporation)
                          Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50918.0 - Microsoft Corporation)
                          Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}) (Version: 8.0.61000 - Microsoft Corporation)
                          Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
                          Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
                          Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32...{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
                          Microsoft Visual C++ 2017 Redistributable (x64) - 14.16.27012 (HKLM-x32...{427ada59-85e7-4bc8-b8d5-ebf59db60423}) (Version: 14.16.27012.6 - Microsoft Corporation)
                          Mozilla Firefox 72.0.2 (x64 en-US) (HKLM...\Mozilla Firefox 72.0.2 (x64 en-US)) (Version: 72.0.2 - Mozilla)
                          Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 69.0.2 - Mozilla)
                          Mozilla Thunderbird 68.6.0 (x86 en-GB) (HKLM-x32...\Mozilla Thunderbird 68.6.0 (x86 en-GB)) (Version: 68.6.0 - Mozilla)
                          MusicBee 3.3.7367 (HKLM-x32...\MusicBee) (Version: 3.3.7367 - Steven Mayall)
                          NVAPI Monitor plugin for NvContainer (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.NvapiMonitor) (Version: 1.19 - NVIDIA Corporation) Hidden
                          NVIDIA GeForce Experience 3.20.2.34 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.20.2.34 - NVIDIA Corporation)
                          NVIDIA Graphics Driver 442.59 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 442.59 - NVIDIA Corporation)
                          NVIDIA HD Audio Driver 1.3.38.21 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.21 - NVIDIA Corporation)
                          NVIDIA O software do sistema PhysX 9.19.0218 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.PhysX) (Version: 9.19.0218 - NVIDIA Corporation)
                          Office 16 Click-to-Run Extensibility Component (HKLM...{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.12624.20276 - Microsoft Corporation) Hidden
                          Office 16 Click-to-Run Licensing Component (HKLM...{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.12624.20276 - Microsoft Corporation) Hidden
                          Office 16 Click-to-Run Localization Component (HKLM...{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.12624.20276 - Microsoft Corporation) Hidden
                          Office 16 Click-to-Run Localization Component (HKLM...{90160000-008C-0816-1000-0000000FF1CE}) (Version: 16.0.12624.20276 - Microsoft Corporation) Hidden
                          Opera Stable 67.0.3575.79 (HKCU...\Opera 67.0.3575.79) (Version: 67.0.3575.79 - Opera Software)
                          Product Improvement Study for HP LaserJet M14-M17 (HKLM...{44899623-FEB7-4FE2-BC7C-3D22C2F4D84C}) (Version: 46.2.2636.18185 - HP Inc.)
                          REALTEK Bluetooth Driver (HKLM-x32...{9D3D8C60-A5EF-4123-B2B9-172095903AB}) (Version: 1.0.0.106 - REALTEK Semiconductor Corp.)
                          Realtek Card Reader (HKLM-x32...{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 10.0.15063.31235 - Realtek Semiconductor Corp.)
                          Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.23.1003.2017 - Realtek)
                          Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8237 - Realtek Semiconductor Corp.)
                          Realtek PCI-E Wireless LAN Driver (HKLM-x32...\InstallShield
                          {70714FB7-4084-4202-A599-2D5935DECB67}) (Version: Drv_3.00.0015 - REALTEK Semiconductor Corp.)
                          REALTEK Wireless LAN Driver (HKLM-x32...{A5107464-AA9B-4177-8129-5FF2F42DD322}) (Version: 1.0.0.104 - REALTEK Semiconductor Corp.)
                          Skype versão 8.53 (HKLM-x32...\Skype_is1) (Version: 8.53 - Skype Technologies S.A.)
                          Software de Dispositivos Chipset Intel® (HKLM-x32...{44ded3eb-1686-46a6-9770-fd79096c29f7}) (Version: 10.1.1.45 - Intel(R) Corporation) Hidden
                          Speccy (HKLM...\Speccy) (Version: 1.32 - Piriform)
                          Teams Machine-Wide Installer (HKLM-x32...{731F6BAA-A986-45A4-8936-7C3AAAAA760B}) (Version: 1.2.0.24753 - Microsoft Corporation)
                          Topping USB Audio Device Driver v4.14.0 (HKLM-x32...\Software_Topping_Topping_UsbAudio_Driver_Se tup) (Version: 4.14.0 - Topping)
                          Tweaking.com - Windows Repair (HKLM-x32...\Tweaking.com - Windows Repair) (Version: 4.7.2 - Tweaking.com)
                          Update for Windows 10 for x64-based Systems (KB4023057) (HKLM...{32DC821E-4A7D-4878-BEE8-337FA153D7F2}) (Version: 2.63.0.0 - Microsoft Corporation) Hidden
                          Update for Windows 10 for x64-based Systems (KB4480730) (HKLM...{3BAE4496-6F6C-4330-A8AA-B93D3D346FA5}) (Version: 2.53.0.0 - Microsoft Corporation)
                          UpdateAssistant (HKLM...{C4BE7550-ECE1-417D-A787-01266DC1F5A6}) (Version: 1.22.0.0 - Microsoft Corporation) Hidden
                          VLC media player (HKLM...\VLC media player) (Version: 3.0.8 - VideoLAN)
                          WhatsApp (HKCU...\WhatsApp) (Version: 0.4.1299 - WhatsApp)
                          WinRAR 5.71 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.71.0 - win.rar GmbH)
                          Percentage of memory in use: 56%
                          Total physical RAM: 8083.61 MB
                          Available physical RAM: 3509.7 MB
                          Total Virtual: 16787.61 MB
                          Available Virtual: 9558.4 MB
                          1 Drive c: (WINDOWS) (Fixed) (Total:222.34 GB) (Free:136.55 GB) NTFS
                          2 Drive d: (Internal Storage HD) (Fixed) (Total:931.5 GB) (Free:630.97 GB) NTFS
                          3 Drive e: (RECOVERY) (Fixed) (Total:14.9 GB) (Free:1.74 GB) NTFS
                          4 Drive f: (Seagate Expansion Drive) (Fixed) (Total:3725.9 GB) (Free:2271.47 GB) NTFS
                          User accounts for \DESKTOP-9R2F3RB
                          Administrador Convidado DefaultAccount
                          morai Utilizador WDAGUtilityAccount
                          **** End of log ****
                            #14
                            Couple of questions, one I should have asked earlier.
                            Have you checked that Flight Mode is not enabled.
                            Have you tried different browsers.
                            While working with PCHF have you been disconnecting the Ethernet cable when checking the wireless connection and is the wireless listed in the Network & Internet area of the Action Centre.
                            • kUTUSOV
                              • Mar 2020
                              • 17
                              #15
                              Flight mode is off and I use Chrome, Firefox and Opera for different things, non work without ethernet.
                              I’m not sure what you mean on the last question… On the Network & Internet section status is “connected to the internet” with ethernet; not connected if I unplug it. There is a wifi tab and going into it it’s turned on. If I click on “Show available networks” I get “No Wifi networks found”.
